Challenger Rotary Combine 670B Parts Catalog 79035352
Brand: Challenger
Type of Machine: Rotary Combine
Model: Challenger 670B Rotary Combine (EEA)
Part Number: 79035352
Number of Pages: 598 Pages
Engine And Mounting
Front Gear Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve
Intake And Exhaust Manifold
Turbocharger
Oil Sump And Pump
Oil Cooler And Filter
Centrifugal Oil Cleaner
Coolant Pump System
Coolant Pump
Fuel Injection System
Fuel Lines And Filters
Engine Electrical
Alternator Mounting
Air Intake And Exhaust
Coolant And Air Tubes
Pto And Pump Mounting
Radiator And Shrouds
Cooling System And Rotary Screen
Radiator - Slinger
Rotary Screen, Panel And Screen
Rotary Screen Latch
Fuel Lines
Fuel Filter - Option
Fuel Tanks
Drive System
Drive Group - Rotor Pump
Drive Group - Propel Pump
Pivot Drive Idler - Left Hand
Feed House Jackshaft - Right Hand Drive
Countershaft And Drives - Fixed Speed Header Drive
Main Countershaft - Processor
Main Countershaft Drive - Drive And Idler
Drive And Idler - Beater
Primary Jackshaft Drive - Non-Ce
Secondary Drive - Straw Chopper
Straw Spreader - Secondary Drive
Secondary Drive - Rekord Chopper
Variable Speed - Fan Drive
Pitman - Drive
Drive - Clean Grain Elevator
Drive Belt System - Left Hand
Drive Belt System - Right Hand
Belt And Chain Drives
Tow Hook - Rear Support
Adjustable Rear Axle
Class 8 Steering Axle - Ce
Spindle Housing - Class 8 Steering Axle
Rear Wheel Assist Axle - Non-Ce
Axle Assembly - Rear Wheel Assist
Rear Wheel Assist - Wheel Motor Unit
Rear Wheel Assist - Valve Flow Control
Axle And Wheels - Class 8 Steering Axle
Axle Assembly - Class 8 Steering Axle
Wheel Motor Unit - Class 8 Steering Axle
Selector And Flow Divider - Rear Wheel Assist
Frame And Suspension
Inlet And Stone Trap
Housing - Inlet And Stone Trap
Processor Base
Rotor Exhaust
Fan And Auger Housing
Mainframe
Control, Steering Column
Steering Column Components
Control, Gearshift
Front Axle And Final Drive - Non-Ce
Final Drive - S42
080_4 Inch - Axle Risers
Transmission Assembly
Service Brakes Control
Brake Master Cylinder
Control, Park Brake And Hydro Propel Cable
Drum Brakes - Service And Parking
Drum Brakes - Lines And Fittings
Lines And Fittings - Variable Speed Header Drive
Lateral Tilt - Hydraulic Cylinder
Lateral Tilt - Lines And Fittings
Lateral Tilt - Shuttle Valve
Chaff Spreader - Hydraulic Hoses
Hydraulic Lines And Fittings - Engine
System Pump
Hydraulic Lines And Fittings - Right Side, Upper
Hydrostatic - Suction Plumbing
Valve Group, Main Control - Hydraulic Hoses
Accumulator Assembly
Control Valve Assembly
Control Valve And Fittings
Steering Lines
Hydraulic Hoses - Steering Valve
Steering Lines - Left Side Frame
Steering - Hydraulic Lines - Class 8 Steering Axle
Steering Cylinder - Adjustable Rear Axle
Steering Cylinder - Rear Wheel Assist Axle
Lines And Fittings, Unloader Swing
Hydraulic Hoses - Single Point
Mount And Multi-Coupler
Reel Fore And Aft
Rotary Screen Motor
Drive Disconnect - Tandem Pumps
Cylinder, Header Lift
Priority Valve
Reservoir And Filter
Reservoir Group
Hydraulic Lines And Fittings - Reservoir Group
Rotor Pump And Motor - Lines
Propel Pump And Motor - Lines
Grease Lines - Feeder - Front
Grease Lines - Left Side Frame
Grease Lines - Left And Rear
Grease Lines - Right Side Frame
Propel Pump - Component 1 Of 4
Propel Pump - Component 2 Of 4
Propel Pump - Component 3 Of 4
Propel Pump - Component 4 Of 4
Motor-Hydro Propel And Rotor
Hydraulic Pump - Tandem
Rotor Pump - Component 4 Of 4
Rotor Pump - Component 2 Of 4
Rotor Pump - Component 3 Of 4
Rotor Pump - Component 1 Of 4
Rear Wheel Assist - Rear Wheel Assist
Telemetry Module
Feeder Electrical
Wiring - Front Frame
Wiring - Rear Frame
Wiring - Left Hand Frame
Engine Wiring
Battery Wiring - Non-Ce
Console - Controls And Switches
Cab Electrical
Upper Cab Components
Radio And Antenna
Monitoring Systems, Main Harness - Rear Frame
Grain Bin Harness And Lighting - Non-Ce
Rear Deck And Taillights - Non-Ce
Beacon Lights
Service Connectors, Harness Repair
Straw Chopper Electrical - Rekord
Yield Monitor System
Frame And Mounting
Windows And Doors
Windows And Doors, Interior And Exterior Handles
Door Handle - Interior
Valance And Shields - Non-Ce
Shields - Right And Left
Interior Trim - Left And Lower
Interior Trim - Right Hand
Noise Reduction
Platform And Powerfold Ladder, Left Hand - Non-Ce
Deck Extension, For Duals - 180 Inch Tread
Deck Extension - 4 Inch
Mirrors And Extremity Lights, Remote Adjust
Windshield Wiper Assembly
Roof And Lights
Seat Console
Seat, Operator And Instructor
Seat Assembly - Standard
Seat Assembly - Deluxe
Pressure Unit And Ducting
Pressurizer Unit
Air Conditioner - Compressor And Lines
Heater Lines
Engine Cover Group - Non-Ce
Rear - Handrails
Rear - Ladder And Railings
Side - Folding Ladder
Panels - Left Hand
Panel - Left And Lower
Panel - Left And Rear
Panels - Right Hand
Panel - Front And Right Side
Panel - Right, Middle
Panel - Right, Rear
Mud Shields, Left - Non-Ce
Mud Shields, Right - Non-Ce
Engine Deck - Non-Ce
Rear - Folding Ladder
Safety Decals - Left Side And Front
Safety Decals - Rear Right Hand
Logo - Left Side And Front
Cab - Non-Ce
Drive Wheel
Feeding System
Housing And Shields - Non-Ce
Jack Kit
Feeder Floor
Pivot Shaft
Jackshaft And Idler - Variable Speed Header Drive
Countershaft And Drives-Fixed Speed - Variable Speed Header Drive
Header - Latch
Feeder Housing - Conveyor Drum
Feed Reverser
Feed Reverser Motor, Clutch Housing And Shaft Assembly
Lateral Tilt
Lateral Tilt - Anchors
Threshing System
Beater Drum And Shaft
Concaves - Mounting
Blanks - Concave
Edible Bean Kit
Separator Grates
Support And Braces - Concave
Rotor And Rasp
Rotor Drive And Motor - Control Linkage
Rotor Drive - 2 Speed
Rotor Motor
Cleaning System
Separator Fan
Separator Pan
Shaft - Pitman
Shoe Shaker Group
Cleaning Shoe - Upper Frame And Sieves
Cleaning Shoe - Lower Pan
Electric Adjustable Sieves
Grain Bin And Elevator System
Clean Grain Elevator - Lower
Grain Elevator - Bin Loader
Sheet Metal - Loader Head
Grain Bin - Auger
Return Elevator
Return Elevator - Lower
Return Elevator - Upper
Tailing Elevator Drive
Drive Unloader - Auger
Bin Unloader Auger, Swivel - Upper
Unloader Swing
Auger - Bin Unloader Auger, Swivel
Spill Saver
Unloader Tube - Spout
Top Cover
Drive And Clutch Bin Unloader
Grain Bin - Step And Covers
Step And Covers
Extension, 300 Bushel, Manual Fold - Non-Ce
Extension, Front, Manual Fold - Non-Ce
Extension, Side, Manual Fold - Non-Ce
Extension, 350 Bushel, Manual Fold - Non-Ce
Extension, 350 Bushel, Manual Fold - Sides
Extension, 300 Bushel, Power Fold - Front And Rear
Extension, 350 Bushel, Power Fold - Sides And Corners
Extension, 300 Bushel, Power Fold - Rear
Extension, 300 Bushel, Power Fold - Sides And Corners
Unloader Cover - Non-Ce
Discharge System
No Discharge
Straw Chopper And Shielding - Non-Ce
Housing - Redekop Straw Chopper
Straw Chopper Rotor - Non-Ce
Straw Spreader - Housing And Drives
Straw Spreader - Guards
Straw Spreader - Drive Shields
Hood And Supports - Rekord Chopper
Straw Chopper Shield - Rekord
Housing - Rekord Chopper
Tailboard - Non-Ce
Rekord Chopper - Converger
Chaff Spreader - Housing
Precision Farming Systems
Antenna Kit And Remote Gnss
Console And Topdock Kit
System 150 Installation Kit
Electrical - Autoguide
Steering Valve And Plumbing
Position Sensor - Rear Axle
Position Sensor - Class 8 Steering Axle
Brand: Challenger
Engine And Mounting
Front Gear Housing
Camshaft And Valve
Turbocharger
Oil Sump And Pump
Coolant Pump System
Coolant Pump
Engine Electrical
Alternator Mounting
Radiator - Slinger
Rotary Screen Latch
Fuel Lines
Fuel Tanks
Drive System
Pitman - Drive
Processor Base
Rotor Exhaust
Mainframe
Control, Gearshift
Final Drive - S42
System Pump
Steering Lines
Reel Fore And Aft
Rotary Screen Motor
Priority Valve
Reservoir Group
Telemetry Module
Feeder Electrical
Wiring - Rear Frame
Engine Wiring
Cab Electrical
Radio And Antenna
Beacon Lights
Frame And Mounting
Windows And Doors
Noise Reduction
Roof And Lights
Seat Console
Pressurizer Unit
Heater Lines
Rear - Handrails
Panels - Left Hand
Panels - Right Hand
Panel - Right, Rear
Cab - Non-Ce
Drive Wheel
Feeding System
Jack Kit
Feeder Floor
Pivot Shaft
Header - Latch
Feed Reverser
Lateral Tilt
Threshing System
Concaves - Mounting
Blanks - Concave
Edible Bean Kit
Separator Grates
Rotor And Rasp
Rotor Motor
Cleaning System
Separator Fan
Separator Pan
Shaft - Pitman
Shoe Shaker Group
Grain Bin - Auger
Return Elevator
Unloader Swing
Spill Saver
Top Cover
Step And Covers
Discharge System
No Discharge
Tailboard - Non-Ce
