Challenger Rotary Combine 660B Parts Catalog 79032833
Brand: Challenger
Type of Machine: Rotary Combine
Model: Challenger 660B Rotary Combine
Part Number: 79032833
Number of Pages: 672 Pages
Engine And Mounting
Front Gear Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve
Intake And Exhaust Manifold
Turbocharger
Oil Sump And Pump
Oil Cooler And Filter
Centrifugal Oil Cleaner
Coolant Pump System
Coolant Pump
Fuel Injection System
Fuel Lines And Filters
Engine Electrical
Alternator Mounting
Starter Motor
Drive Belt System
Engine Overhaul Kit
Air Intake And Exhaust
Coolant & Air Tubes
Radiator And Shroud
Cooling System And Rotary Screen
Slinger
Rotary Screen, Panel And Screen
Rotary Screen Latch
Fuel Lines
Fuel Filter Kit
Fuel Tanks
Drive System
Propel Pump Drive
Drive
Left Hand
Right Hand Drive
Fixed Speed Header Drive
Grain Bin
Drive And Idler
Beater
Non-Ce
Straw Chopper
Primary Drive
Secondary Drive
Fan Drive
Clean Grain Elevator
Drive And Clutch Bin Unloader
Right Hand
Belt And Chain Drives
Rear Support
Ce
Adjustable Rear Axle
Class 8 Steering Axle
Rear Wheel Assist Axle
Rear Wheel Assist
Wheel Motor Unit
Valve Flow Control
Frame And Suspension
Inlet And Stone Trap
Processor Base
Rotor Exhaust
Fan And Auger Housing
Mainframe
Control, Steering Column
Steering Column Components
Control, Gearshift
S41
Axle Risers
Pressure Lube And Hydro Motor
Input Shaft And Gears
Intermediate And Main Shaft
Service Brakes Control
Brake Master Cylinder
Control, Park Brake And Hydro Propel Cable
Service And Parking
Lines And Fittings
Header
Hydraulic Cylinder
Shuttle Valve
Hydraulic Hoses
Hydraulic
System Pump
Right Side, Upper
Accumulator Assembly
Control Valve And Fittings
Steering Lines
Steering Valve
Left Side Frame
Lines And Fittings, Unloader Swing
Header Lift Hydraulics
Single Point
Mount And Multi-Coupler
Reel Fore And Aft
Rotary Screen Motor
Cylinder, Header Lift
Priority Valve
Reservoir And Filter
Reservoir Group
Lines
Front
Left And Rear
Right Side Frame
Tandem Pumps
Component 1 Of 4
Component 2 Of 4
Component 3 Of 4
Component 4 Of 4
Motor-Hydro Propel And Rotor
Feeder Electrical
Front Frame
Rear Frame
Left Hand Frame
Engine Wiring
Steering Pressure
Controls And Switches
Cab Electrical
Upper Cab Components
Radio And Antenna
Powerfold Grain Bin
Beacon Lights
Field Kit, High Intensity Lighting
Rekord
Yield Monitor System
Frame And Mounting
Windows And Doors
Windows And Doors, Interior And Exterior Handles
Interior
Right And Left
Headliner
Left And Lower
Noise Reduction
4 Inch
145 Inch Tread
Mirrors And Extremity Lights, Remote Adjust
Windshield Wiper Assembly
Roof And Lights
Seat Console
Seat, Operator And Instructor
Standard
Deluxe
Pressure Unit And Ducting
Pressurizer Unit
Compressor And Lines
Heater Lines
Handrails
Ladder And Railings
Folding Ladder
Front And Right Side
Right, Middle
Right, Rear
Mud Shields, Left
Left Side And Front
Rear Right Hand
Right Side And Rear
Rear
Drive Wheel
Feeding System
Jack Kit
Feeder Floor
Pivot Shaft
Variable Speed Header Drive
Latch
Conveyor Drum
Feed Reverser
Feed Reverser Motor, Clutch Housing And Shaft Assembly
Torque Motor
Lateral Tilt
Anchors
Threshing System
Beater Drum And Shaft
Mounting
Concave
Edible Bean Kit
Concave Adjust Control
Separator Grates
Rotor And Rasp
Control Linkage
2 Speeds
Cleaning System
Separator Fan
Separator Pan
Pitman
Shoe Shaker Group
Upper Frame And Sieves
Lower Pan
Electric Adjustable Sieves
Grain Bin And Elevator System
Lower
Bin Loader
Loader Head
Auger
Return Elevator
Upper
Tailing Elevator Drive
Unloader Swing
Bin Unloader Auger, Swivel
Spill Saver
Top Cover
Step And Covers
Front And Rear
Sides And Corners
Discharge System
No Discharge
Redekop Straw Chopper
Housing And Drives
Guards
Drive Shields
Hood And Supports
Housing
Precision Farming Systems
Topdock Cab Mount
Topdock, Autoguide, W External Antenna
Autoguide
Steering Valve And Plumbing
Rear Axle
Brand: Challenger
Engine And Mounting
Front Gear Housing
Camshaft And Valve
Turbocharger
Oil Sump And Pump
Coolant Pump System
Coolant Pump
Engine Electrical
Alternator Mounting
Starter Motor
Drive Belt System
Engine Overhaul Kit
Coolant & Air Tubes
Radiator And Shroud
Slinger
Rotary Screen Latch
Fuel Lines
Fuel Filter Kit
Fuel Tanks
Drive System
Propel Pump Drive
Drive
Left Hand
Right Hand Drive
Grain Bin
Drive And Idler
Beater
Non-Ce
Straw Chopper
Primary Drive
Secondary Drive
Fan Drive
Right Hand
Rear Support
Ce
Rear Wheel Assist
Wheel Motor Unit
Valve Flow Control
Processor Base
Rotor Exhaust
Mainframe
Control, Gearshift
S41
Axle Risers
Service And Parking
Lines And Fittings
Header
Hydraulic Cylinder
Shuttle Valve
Hydraulic Hoses
Hydraulic
System Pump
Right Side, Upper
Steering Lines
Steering Valve
Left Side Frame
Single Point
Reel Fore And Aft
Rotary Screen Motor
Priority Valve
Reservoir Group
Lines
Front
Left And Rear
Right Side Frame
Tandem Pumps
Component 1 Of 4
Component 2 Of 4
Component 3 Of 4
Component 4 Of 4
Feeder Electrical
Front Frame
Rear Frame
Left Hand Frame
Engine Wiring
Steering Pressure
Cab Electrical
Radio And Antenna
Powerfold Grain Bin
Beacon Lights
Rekord
Frame And Mounting
Windows And Doors
Interior
Right And Left
Headliner
Left And Lower
Noise Reduction
4 Inch
145 Inch Tread
Roof And Lights
Seat Console
Standard
Deluxe
Pressurizer Unit
Heater Lines
Handrails
Ladder And Railings
Folding Ladder
Right, Middle
Right, Rear
Mud Shields, Left
Left Side And Front
Rear Right Hand
Right Side And Rear
Rear
Drive Wheel
Feeding System
Jack Kit
Feeder Floor
Pivot Shaft
Latch
Conveyor Drum
Feed Reverser
Torque Motor
Lateral Tilt
Anchors
Threshing System
Mounting
Concave
Edible Bean Kit
Separator Grates
Rotor And Rasp
Control Linkage
2 Speeds
Cleaning System
Separator Fan
Separator Pan
Pitman
Shoe Shaker Group
Lower Pan
Lower
Bin Loader
Loader Head
Auger
Return Elevator
Upper
Unloader Swing
Spill Saver
Top Cover
Step And Covers
Front And Rear
Sides And Corners
Discharge System
No Discharge
Housing And Drives
Guards
Drive Shields
Hood And Supports
Housing
Topdock Cab Mount
Autoguide
Rear Axle
