Challenger Rogator RG900C Chassis Parts Catalog 652172
Brand: Challenge Rogator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenge RG900C Rogator Chassis (2018-2021)
Serial Number: .JXXX1001 - ..MXXX9999
Part Number: 652172
Number of Pages: 956 Pages
Belts & Filters Guide
Engine V835077815 74 Awf Cwi2
7.4 Liter
Electronic Engine Management
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Valve Rocker Cover
Intake Manifold
Oil Pump And Sump
Oil Cooler And Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Fan Drive
Air Compressor
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine V835077623 74 Awf Cwi2
Engine Installation
Engine Installation, Agco Power, 7.4 Liter
Air Cleaner, Psd10
Installation-Air Intake
Alternator Assembly
Cooling Package
Air Conditioner
Fan And Alternator
Fuel Tank Installation, Locking Cap
Fuel Line Installation, Standard
Fuel Line Installation, 2nd, Fuel And Water Seperator
Fuel Filter, Complete
Def Tank Group, Non-Locking, 7.4 Liter
Def Tank Group
Non Def Group
Electrical Caps Installation, Less Regulated Countries
Tier 4, Final Compliant
2 Wheel Steering Axle
Rear Axle Installation
Hydraulic Installation
Electrical Installation, 4 Wheel Steering
Wheel Angle Sensor Installation
Drive Hose Kit, 2 Wheel Steering
4 Wheel Steering
Front
Hydraulic Track Adjust Valve
Rear
Hydraulic Track Adjust Group, Standard
Hydraulic Track Adjust Cylinder
Manual Track Adjust Assembly
Bulkhead
Steering Column Assembly
Steering Control
Hydraulic
Steering Pump Group, Standard
Priority Valve Assembly
Cold Start
Air System
Air System Group
Air Tank Installation
Control Valve Assembly, Rear
Control Valve Assembly, Front
Air Dryer, Single Canister
Air Governor
2015-2019
2021
No High Volume Air Dryer Option
O-Ring Kit, Rogator
Hydraulic Cap Plug Installation
Hydraulic Accumulator Installation
Hydraulic Tank Installation
Hydraulic Tank Heater, 1000 Watt, 120 Volt
Brake Installation
Manifold Assembly, Hydraulic Return
Hydraulic Return Manifold Assembly
Park And Ladder Valve Assembly
Brake Pedal Valve Assembly
900 1100 1300
900 1100
Puller For Brake Circlip
Hydraulic Ladder Cylinder Assembly
Hydraulic Installation, Routing Accessories
C Series
Back Up Alarm
Battery
Cab Harness Installation
Cab Electrical Kit, Mini Fuse
Clamping Installation
Electric Horn Installation
Harness Installation, Cable, Chassis, Domestic, Air Ride
Harness Installation, Wheel Leg, Sauer
Boomrest
Boom Rest Light Installation
Lighting Group, Double Hid
Light Assembly, Left, Double Hid
Light Assembly, Right, Double Hid
Lighting Group, Led
Left Hand
Right Hand
Lighting Group, Standard Lights
Halogen
Radio Installation, Cd, Xm ,Blue Tooth, Usb
Powerstrip Assembly
Radio Accessory Kit
System Connector Installation, Combo
Antenna
Antenna Base Assembly
Rogator
Arm Rest
Virtual Terminal Installation
Terminal Support
Camera Cables
Armrest Adjust Mechanism, Right Hand
Audio Group
Beacon Assembly
Plug Installation
Cab Door Assembly
Cab Floormat Installation
Cab Floor Mats And Covers
Cab Glass
Cab Mounting, Air Ride
Metric
Standard Isolator Cab Mounting
Controls Arrangement, Front
Dash Panel Assembly
Dome Housing Bracket Installation
Glass Hammer Assembly
Heat Barrier Installation
Inner Roof Arrangement
Outer Roof Assembly
Interior Trim Arrangement
Interior Trim
Mirror Installation, Standard
Mirror Installation, Heated And Adjustable
Convex Mirror Installation
Mirror Mounting Group
Air
A2000 Passive Suspension Service Kit
Passive Seat Suspension Kit
Passive
Knobs Assembly Kit
Seat Group, Deluxe
Semi Active Suspension
Trainer Seat, Cloth
Trainer Seat, Leather
Semi Active Seat Suspension Kit, Left Hand Air Tank
Wiper Group
Wiper Motor, 1 Inch Shaft, Left Hand, 85
Hvac Group
Auto Control
Air Conditioning High Pressure Switch Assembly
2019
Anti-Roll Bar Assembly
Crossmember Assembly
Eye Bolt Assembly
Boom Stop Bracket Assembly, Left Hand
Boomrest Installation, Domestic
Boomrest Installation, Non Domestic
Chassis Installation, Narrow Transport
Deflector Cover Installation
Deflector And Cover Support Assembly, Left Front
Deflector And Cover Support Assembly, Right Front
Deflector And Cover Support Assembly, Left Rear
Deflector And Cover Support Assembly, Right Rear
Entrance Installation, Front, Rogator
Handrail Installation, Front
Platform Installation, Front
2 Wheel Steering
Grill Assembly
Hood Installation
Hood Group
Hood Support Group
Hood Support Bracket Group
Tool Box Group, Right Hand
Tool Box Assembly, Right Hand
Tool Box Hand Rinse Tank
Ppe Box Tank Assembly, Left Hand
Cab Decal Installation, Inside
Chassis Decal Installation
Electric
Rg900c Rg1100c Rg1300c
Decal Installation, Chassis, North America
Decal Installation, Chassis, International
Engine Decal Installation
Emblem Assembly, Challenger
Wheel Hardware Installation
Goodyear, Firestone, Michelin, Telleborg
Tire And Wheel Assembly, 380 90r46, Goodyear
Tire And Wheel Assembly, 320 90r50, Titan
Tire And Wheel Assembly, 480 80r42, Titan
Tire And Wheel Assembly, 620 70r38, Michelin
Tire And Wheel Assembly, 650 65r42, R1w, Goodyear
Precision Farming Systems
Antenna Installation, Phoenix 300, Gps
Vd03
Cable Installation, Rgl 600, Agcontrol
Cable Installation, Rgl 600, Raven
Camera Kit, Agcam
Camera Installation
Camera Installation, 9 Inch Monitor
Single
Nt01
Camera Ready System
9 Inch Display
Without Gps, Viper 4, Raven, Ag
Controller Installation, Raven V4
Controller-Vd0x W Gyro 3g, Modem
Controller-Vd0x W Gyro Cdma, Modem
Raven
Gps Ready Installation
Gateway Assembly
Gateway, Mid Spec, Lte
Gateway, Mid Spec, Gsm
2018
Lightbar Installation, Rgl 600, Rg
Agcontrol
Quad Camera Display Monitor
Smart 6
Smart 7
Camera (Agcam)
Lightbar
Radar Installation
Slingshot Installation, 2.0, Verizon
Slingshot Installation, Ready, Raven
Slingshot Installation, Verizon
Slingshot Installation, No Gps, Cab
Receiver
Weather Station
Control Installation, Raven, Viper 4
Option
Pressure Washer Reel Assembly
Pressure Washer Assembly
Pressure Washer Plumbing Installation
No Pressure Washer Option
Real Time Kinematic
Field Accessories, Brake Release
Camera Adapter, Motec
Camera Monitor
Ecology Drain
Field Accessories, Fuel Water Separator
Field Accessories, Halogen, Cab Lights, Rear
Field Accessories, Led, Cab Lights, Rear
Field Accessories, High Frequency Shocks
Led
Field Accessories, Modem Satellite
Field Accessories, Power Mirror Installation
Power Strip
Pressure Washer
Radio, Deluxe Xm
Radio, Deluxe
Radio Installation, Blue Tooth, Usb
Satellite Antenna Installation
Field Accessories, Smartrax, Raven
Hydraulic Valve Assembly, Smartrax
Viper 4
Charge Air Cooler
Field Kit, Steer Fitting Rework
Field Service Kits
Kit-Rework, Oil Fill Access
Scr
Part Number: 652172
7.4 Liter
Valve Rocker Cover
Intake Manifold
Oil Pump And Sump
Fuel Filters
Fan Drive
Air Compressor
Engine Installation
Air Cleaner, Psd10
Alternator Assembly
Cooling Package
Air Conditioner
Fan And Alternator
Def Tank Group
Non Def Group
4 Wheel Steering
Front
Rear
Bulkhead
Steering Control
Hydraulic
Cold Start
Air System
Air System Group
Air Governor
2015-2019
2021
O-Ring Kit, Rogator
Brake Installation
900 1100 1300
900 1100
C Series
Back Up Alarm
Battery
Boomrest
Lighting Group, Led
Left Hand
Right Hand
Halogen
Powerstrip Assembly
Radio Accessory Kit
Antenna
Rogator
Arm Rest
Terminal Support
Camera Cables
Audio Group
Beacon Assembly
Plug Installation
Cab Door Assembly
Cab Glass
Metric
Dash Panel Assembly
Outer Roof Assembly
Interior Trim
Air
Passive
Knobs Assembly Kit
Seat Group, Deluxe
Trainer Seat, Cloth
Wiper Group
Hvac Group
Auto Control
2019
Eye Bolt Assembly
2 Wheel Steering
Grill Assembly
Hood Installation
Hood Group
Hood Support Group
Electric
Vd03
Camera Kit, Agcam
Camera Installation
Single
Nt01
Camera Ready System
9 Inch Display
Raven
Gateway Assembly
2018
Agcontrol
Smart 6
Smart 7
Camera (Agcam)
Lightbar
Radar Installation
Receiver
Weather Station
Option
Real Time Kinematic
Camera Monitor
Ecology Drain
Led
Power Strip
Pressure Washer
Radio, Deluxe Xm
Radio, Deluxe
Viper 4
Charge Air Cooler
Field Service Kits
Scr
