Challenger Rogator RG900B RG1100B RG1300B Chassis Parts Catalog 571470D1
Brand: Challenge Rogator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenge RG900B, RG1100B, RG1300B Rogator Chassis (2015-2017)
Serial Number: ..FXXX1001 - ..HXXX9999
Part Number: 571470D1
Number of Pages: 2078 Pages
Rg900 Rg900b Rg1100 Rg1100b Rg1300 Rg1300b
2015
Fan Assembly
7.4 Liter
Air Conditioner Compressor
Pressure Relief Valve, With O-Ring
Engine Assemblies
Less Regulated Countries, 2015
8.4 Liter
Electrical Caps Installation, Less Regulated Countries
2016-2017
Rg900b 2015
Def Tank Group, Non-Locking, 7.4 Liter
Def Tank Group
Rg1100b 1300b 2015
Def Tank Group, Non-Locking, 8.4 Liter
2016-2020
7.4 Liter 2015
Tier 4, Final Compliant
8.4 Liter 2015
Air Cleaner, Psd10
Installation-Air Intake
Alternator Assembly
Sight Gauge
Cooling Package
7.4 Liter 2016-2017
8.4 Liter 2016-2017
Latch Strap, Bottom
Fuel Tank Installation, Locking Cap
Fuel Tank Assembly, Right Hand, Lock
Fuel Tank Assembly, Left Hand, Lock
Fuel Filter, Complete
Fuel Line Installation, Standard
Fuel Line Installation, 2nd, Fuel And Water Seperator
900
Scr
Electronic Engine Management
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Timing Gears And Housing
Intake Manifold
Exhaust Manifold
High Pressure Turbocharger
Low Pressure Turbocharger And Icac
Up To Engine Serial Number A74702
Starting From Engine Serial Number A74703
Oil Pump And Sump
Oil Cooler And Filter
Coolant Piping
Coolant Pump And Thermostat
Fuel Injection System
Up To Engine Serial Number A77999
Starting From Engine Serial Number B50000 Jld291001
Fan Drive
Air Compressor
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine Installation, Agco Power, 7.4 Liter
Valve Rocker Cover
Fuel Filters
Engine Installation, Agco Power, 8.4 Liter
Hydraulic Lash Adjustment
M12 Turbo Mounting Stud Bolts
Engine Type Awf
2 Wheel Steering Axle, 609gb
Harness Installation, Autoguide Only
4 Wheel Steering Axle
Hydraulic Component Installation, 4 Wheel Steering
Hydraulic Steering Cylinder Assembly, Rear
Valve Assembly, 4 Wheel Steering
Hydraulic Valve, 4 Wheel Steering
Valve Assembly, D03, 4 Wheel Steering
Manifold, With Counter Balance, 4 Wheel Steering
Electrical Installation, 4 Wheel Steering, Rogator
Nylon Fork
Wheel Leg Installation, Front, 609gb
Frame And Suspension
Boomrest Installation, Domestic
Boomrest Installation, Non Domestic
Boomrest
Standard Chassis, Rogator
Air Bag Assembly, Left, Front
Air Bag Mounting Bracket
Air Bag Assembly, Right, Front
Frame Assembly, Rogator
Eye Bolt Assembly
Air Bag Assembly, Rear
Anti-Roll Bar Assembly
Crossmember Assembly
Shock Installation
Steering Control Group
Steering Column Assembly
Standard Steering Pump, 607gb, Bosch Rexroth, 900 1100
Spring Assembly, Pump Support
Priority Valve Assembly, Eaton
Steering Pump, 2.75cid
Cold Start Steering Pump, 607gb, Bosch Rexroth, 900 1100
Steering Pump, 2.75cid With Dump, Bosch Rexroth, 900 1100
Steering Pump Group, Standard, Bosch Rexroth, 1300
Hydraulic Pump, Steering, 63cc, Standard
Steering Pump Group, Cold Start, Bosch Rexroth, 1300
Hydraulic Steering Pump, 63cc, Cold Start, Bosch Rexroth, 1300
Standard Steering Orbitrol
Standard Steering Orbitrol Installation
Hydraulic Steering Orbitrol Assembly, Standard
Standard Steering Hose Kit, 900 1100 1300
Hydraulic Steering Cylinder Installation
Steering Cylinder Assembly, Front
Steering Pump Group, Standard, Sauer Danfoss, 900 1100
900 1100
Steering Pump Group, Cold Start, Sauer Danfoss, 900 1100
Steering Pump Group, Standard, Sauer Danfoss, 1300
Steering Pump, 60cc, Standard, Sauer Danfoss, 1300, Right Hand
Steering Pump Group, Cold Start, Sauer Danfoss, 1300
Steering Pump, 60cc, Cold Start, Sauer Danfoss, Right Hand
Steering Pump Control Kit
Solenoid Valve Kit
1300
Hydraulic Pump, Variable Displacement, 35cc, Right Hand
Steering Hose Kit, Assisted
Hydraulic Steering Installation, Rogator
Steering Assembly, Hydraulic
Hydraulic
Steering Electrical Assembly, Pved Kit
Air System
Air Dryer, Single Canister
Air Governor
Air System Group
Air Tank Installation
Air Reservoir Assembly, Standard, 42 Liter
Control Valve Assembly, Rear
Control Valve Assembly, Front
Air Horn Arrangement
High Volume Air Dryer Group
Tank Assembly, Wet Cooling
2015-2019
No High Volume Air Dryer Option
O-Ring Kit, Rogator
Auxiliary Hose Kit, 1300
Auxiliary Hose Kit, 900 1100
Brake Valve, Modulating, 2000 Psi
Brake Release Assembly
Case Drain Filter Group Replacement Kit
Drive Hose Kit, 900 1100
Drive Hose Kit, 1300
Flange Kit, -16 Code 62
Hydraulic Block, Pressure Washer Control
Hydraulic Cylinder Assembly, Ladder
Hydraulic Cylinder, 2.00 X 6.50 X .75
Hydraulic Installation, Track Adjust, Air 900 1100 1300
Track Adjust Block Assembly, Front
Hydraulic Track Adjust Valve
Track Adjust Block Assembly, Rear
Hydraulic Track Adjust Cylinder Assembly, 3.75, Auto Tie Rod
Sensor Assembly, Hall Effect, Linear Position
Hydraulic Track Adjust Cylinder Assembly, 3.25
Track Adjust Hose Kit
Hydraulic Cylinder, 3.75 X 16 X 1.375, Auto
Hydraulic Return Manifold Assembly, 900 1100 1300
Hydraulic Manifold, Return Oil
Hydraulic Brake Caliper
Hydraulic Oil Tank Installation, 900 1100 1300
Hydraulic Tank Assembly
Hydraulic Tank Heater, 1000 Watt, 120 Volt
Hydraulic Tank Heater, 1000 Watt, Europe Only
Manual Track Adjust Assembly
Bulkhead
Hydraulic Installation, Auto Track Adjust
Hydraulic Track Adjust Cylinder Assembly, 3.25, Auto Tie Rod
Hydraulic Valve Assembly, Smartrax
Hydraulic Valve, Smartrax
Hydraulic Installation, Brake Valve
Valve Assembly, Brake Pedal
Hydraulic Installation, Drive Pumps, 900 1100
With Internal Braking Function
Hydraulic Pump, Front Hydro, 529995d1, 900 1100
Hydraulic Ladder Control Valve, 900 1100 1300
Hydro Pump Drive Kit, 900 1100
Hydraulic Valve, Park Brake, With Tow Override, 900 1100 1300
Hydraulic Motor, 80cc, H1, With Ss 900 1100
Speed Sensor Assembly
Split Flange Mounting Kit, -16, Code 62
Hydraulic Motor, 107cc, A6ve, With Ss 1300
Speed Sensor Assembly, 1300
Hydraulic Installation, Drive Pumps, 1300
Tandem Pump, Drive, 125cc, Right Hand, 1300
Hydraulic Pump, Front, 1300
Hydraulic Pump, Rear, 568273d1, 1300
Hydraulic Cap Plug Installation
Hydraulic Installation, Brake Accumulator
Kit, Repair
Battery Box Assembly
Battery Box Top Cover Assembly
900 1100 1300
Master Switch Assembly
Cab Electrical Kit, Mini Fuse
Cab Harness Installation
Power Distribution Module, 42 Fuse
Electric Mounting Group
Electric Horn Installation
Electrical Installation, Ag Ready
Fuse Installation
Radio Installation, Cd, Xm ,Blue Tooth, Usb
Back Up Alarm
Powerstrip Assembly
High Beam Installation
Light, Hid, L1
Light, Hid, R1
Light, Halogen, L2
Light, Halogen, Short Range
Light, Halogen, R2
Light, Halogen, Left 1
Light, Halogen, Long Range
Light, Halogen, Right 1
Worklight Installation
Light, Hid, R3
Light, Hid, L3
Light, Halogen, R3
Light, Halogen, L3
Lighting Group, Double Hid
Light Assembly, Left, Double Hid
Light Assembly, Right, Double Hid
Installation, Not Autoguide 150 Ready, Rogator
Worklight, Dual Beam
Rotating Beacon Lamp
Worklight, Hid
Starter
Steel Fork
System Connector Installation, Combo
Worklight, Hid, Pendent Mount
Worklight, Dual Beam, Pendent Mount
Boom Rest Light Installation, No Worklight
Armrest Installation, Rogator, 5 Section, With A5 Controller
Armrest Installation, Rogator, 7 Section, With A5 Controller
Console Group, Rogator, 7 Section, With A5
Hydro Handle Assembly
Console Assembly, Control, Top, Rogator
Arm Pad
Pc Board Assembly, 7 Section
Console Group, Rogator, 5 Section, With A5
Pc Board Assembly, 5 Section
Cab Mounting, Air Ride
Metric
Non-Metric
Extra Key Kit
Seat Installation, Leather, Deluxe
Seat Assembly, Leather, Semi Active
Slide Adjustment
Swivel
Slide Latch Assembly Kit
Slide Puck Assembly Kit
Seat Top Kit, Sst
Recliner Assembly Kit
Seat Pan Back Kit, With Lumbar
Lumbar Kit, Sst
Semi Active Suspension
Semi Active Seat Suspension Kit
Air Tank Kit
Air Tank Adapter Assembly
Air Spring Kit
Semi Active Seat Suspension Kit, Left Hand Air Tank
Cab Installation
Seat Install, Basic
Seat Assembly, Basic, Air
Passive Seat Suspension Kit
Passive
Seat Install, Deluxe
Seat Assembly, Deluxe, Semi Active
2016
Suspension Kit
2017
Heat Barrier Installation
Hydro Cable Bulkhead Installation
Dash Installation, Center Console
Controls Arrangement, Front
Cab Floor Mats And Covers
Radio Installation
Radio Accessory Kit
Antenna Base Assembly
Interior Trim Arrangement
Cigar Lighter Assembly
Outer Roof Arrangement
Inner Roof Arrangement
Wiper Group
Wiper Motor, 1 Inch Shaft, Left Hand, 85
Windshield Washer Kit
Cab Floormat Installation
Cover Assembly, Right Hand
2014-2015
Door Assembly
Cab Final, Painted, Rogator
Cab Glass
Cloth
Trainer Seat, Leather
A2000 Passive Suspension Service Kit
Trainer Seat, Cloth
Air Conditioning High Pressure Switch Assembly
Gaskets Kit
Heating, Ventilation And Air Conditioning Group
Auto Control
Motor Blower Assembly, Pressure
Receiver Dehydrator
Boom Stop Bracket Assembly, Left Hand
Boom Stop Bracket Assembly, Right Hand
Chassis Installation, Narrow Transport
Left Hand
Crop Deflector Assembly, Right Hand
Crop Deflecotr Assembly, Left Hand
Deflector Cover Installation
Deflector And Cover Support Assembly, Left Front
Deflector And Cover Support Assembly, Right Front
Deflector And Cover Support Assembly, Left Rear
Deflector And Cover Support Assembly, Right Rear
Door Assembly, Box And Tank, Poly, Left Hand
Door Assembly, Tool Box, Right Hand
Entrance Ladder Assembly, Front
2 Wheel Steering
4 Wheel Steering
Grille Assembly
Handrail Installation, Front, Rogator
Hood Installation
Hood Assembly
Panel Assembly, Left Hand
Panel Assembly, Right Hand
Hood Support Group
Ladder Installation, Front, Rogator
Mirror Installation, Heated And Adjustable
Mirror Installation, Standard
Platform Installation, Front, Rogator
Poly Box And Tool Box Installation
Poly Box And Tank Group, Left Hand
Poly Box And Tank Assembly, Left Hand
Tool Box Group, Right Hand
Tool Box Assembly, Right Hand
System Installation, Narrow Transport
Decal Installation, Rg900b
Decal Installation, Rg1100b
Decal Installation, Rg1300b
Decal Installation, International
Decal Installation, Chassis, International
International
Emblem Mount Assembly
Fuse
Brake Rotor Installation
Wheel Hardware Installation
Tire And Wheel Assembly, 650 65r42, R1w, Goodyear
Tire And Wheel Assembly, 650 65r42, R1w, Titan
Tire And Wheel Assembly, 380 90r46, Goodyear
Tire And Wheel Assembly, Vf380 90r46, Goodyear
Tire And Wheel Assembly, Vf380 90r46, Michelin
Tire And Wheel Assembly, Vf380 90r46, Firestone
Tire And Wheel Assembly,Vf380 90r46,Telleborg
Controller System
Control Installation, C3000
Weather Station
Agcontrol
Radar Group
With Internal Gps
With Internal Gs Gps
Without Internal Gps
Slingshot Installation, Verizon
Slingshot Installation, Ready, Raven
Telemetry Assembly
Telemetry Ready Assembly
Precision Farming Systems
Antenna Installation, Phoenix 300, Gps
Mounting Bracket
Cable Installation, Rgl 600, Viper Pro
Control Installation, Raven, Viper
Dome Housing Bracket Installation
Gateway Assembly
Gps Kit, Phoenix 300
Gps Kit, Phoenix 300, Gs
Gps Kit, Internal Viper 4, Raven
Gps Ready Installation, Rogator
Lightbar Kit, Rgl 600, Viper Pro
Lightbar Installation, Rgl 600, Rg
Phoenix 200 Installation
Receiver Installation, Groups, Phoenix 300
Receiver Installation, Phoenix P300 Hp Xp
Gps Receiver
Slingshot Installation, 2.0, Verizon
Topdock Installation-Agi-4, Aed
Waas Installation, Left Hand, Ag
Ball Valve, 0.75 Npt, Union, Poly
Brake Option, Europe
Cold Start Package, Europe Only
Cold Start Option, 120 Volt
Pressure Washer Plumbing Installation
Pressure Washer Pump And Motor
Pressure Washer Motor
Pressure Washer Option
Pressure Washer Assembly
Pressure Washer Reel Assembly
1accessories
Antenna
Field Accessories, Ag150 Ready, Topcon
Field Accessories, Beacon, Amber, Roof Mount
Field Accessories, Brake Release
Bonnet
Field Accessories, C3000, Crenlo, Cab
Fender
Field Accessories, Fuel Water Separator
Field Accessories, Gateway Ready
Field Accessories, Gateway Assembly
Field Accessories, Gps Ready, Topcon
Field Accessories, Gps, Topcon
Field Accessories, Halogen, Auxilary 1, Auxilary 2
Field Accessories, Hid, Auxilary 1, Auxilary 2
Field Accessories, Power Mirror Installation
Field Accessories, Pressure Washer
Field Accessories, Raven, Rogator
Field Accessories, Smartrax
Radio Installation, Blue Tooth, Usb
Radio, Deluxe
Radio, Deluxe Xm
Field Accessories, High Frequency Shocks
Field Accessories, Worklight Kit, Halogen
Field Service Kits
