Challenger Rogator RG900 RG1100 RG1300 Chassis Parts Catalog 552450D1
Brand: Challenge Rogator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenge RG900, RG1100, RG1300 Rogator Chassis (2012-2014)
Serial Number: ..CXXX1001 - ..EXXX9999
Part Number: 552450D1
Number of Pages: 2270 Pages
Rg900 Rg1100 Rg1300
Rg900
Engine, 8.4l, 280hp, T4i, Epa Compliant, 900
Cylinder Block Assembly
Gear Housing Assembly
Flywheel And Housing Assembly
Crankshaft Assembly
Valve Mechanism Assembly, Epa Compliant
Cylinder Head Assembly
Inlet And Exhaust Assembly
Turbocharger Piping Assembly
Oil Sump Assembly
Oil Cooler Assembly
1100 1300
Coolant Pump Assembly
Fuel Pump Assembly
Eem4 Parts Assembly
Alternator Assembly
Starter Motor Assembly
Drive Device Assembly
Scr Parts Assembly
Engine Overhaul Parts
Ccv And Intake Group
Air Conditioner Compressor
Pressure Relief Valve, With O-Ring
Rg1100
Engine, 8.4l, 311hp, T4i Epa Compliant, 1100
Fuel Filter Assembly, Epa Compliant
Compressor Assembly
Rg1300
Engine, 8.4l, 339hp, T4i, Epa Compliant 1300
Engine Installation, 280hp, Non Epa Compliant, 900
Engine, 8.4l, 280hp, Less Regulated Countries, 900
Valve Mechanism Assembly, Non Epa Compliant
Fuel Filter Assembly, Non Epa Compliant
Engine Installation, 311hp, Non Epa Compliant, 1100
Engine, 8.4l, 311hp, Less Regulated Countries, 1100
Engine Installation, 339hp, Non Epa Compliant, 1300
Engine, 8.4l, 339hp, Less Regulated Countries, 1300
Exhaust Installation, Less Regulated Countries, Rogator
Air Intake Installation
Air Cleaner, Psd10
900 1100 1300
Cooling Package
Air Conditioner Condensor And Fuel Cooler Core
Spring Assembly, Pump Support
Fuel Tank Installation, Locking Cap
Fuel Tank Assembly, Left Hand, Lock
Fuel Tank Assembly, Right Hand, Lock
Fuel Line Installation, Standard
Fuel Line Installation, 2nd, Fuel And Water Seperator
Fuel Filter, Complete
2 Wheel Steering Axle, 609gb
Frame And Suspension
Air Bag Assembly, Left, Front
Air Bag Mounting Bracket
Air Bag Assembly, Right, Front
Air Bag Assembly, Rear
Eye Bolt Assembly
Anti-Roll Bar Assembly
Crossmember Assembly
Steering Control Group
Steering Column Assembly
Wheel Leg Installation, Front, 609gb
4 Wheel Steering
Hydraulic Component Installation, 4 Wheel Steering
Valve Assembly, 4 Wheel Steering
Hydraulic Valve, 4 Wheel Steering
Valve Assembly, D03, 4 Wheel Steering
Manifold, With Counter Balance, 4 Wheel Steering
Hydraulic Steering Cylinder Assembly, Rear
Steel Fork
Electrical Installation, 4 Wheel Steering, Rogator
4 Wheel Steering Assembly, 609gb
Standard Steering Orbitrol
Standard Steering Orbitrol Installation
Hydraulic Steering Orbitrol Assembly, Standard
Standard Steering Hose Kit, 900 1100 1300
Standard Steering Pump, 607gb, Bosch Rexroth, 900 1100
Steering Pump, 2.75cid
Dr Control Valve, A10vo45
Priority Valve Assembly, Eaton
Cold Start Steering Pump, 607gb, Bosch Rexroth, 900 1100
Steering Pump, 2.75cid With Dump, Bosch Rexroth, 900 1100
Steering Pump Group, Standard, Bosch Rexroth, 1300
Hydraulic Pump, Steering, 63cc, Standard
Steering Pump Group, Cold Start, Bosch Rexroth, 1300
Hydraulic Steering Pump, 63cc, Cold Start, Bosch Rexroth, 1300
Steering Pump Group, Standard, Sauer Danfoss, 900 1100
900 1100
Steering Pump Group, Cold Start, Sauer Danfoss, 900 1100
Steering Pump Group, Standard, Sauer Danfoss, 1300
Steering Pump, 60cc, Standard, Sauer Danfoss, 1300, Right Hand
Steering Pump Group, Cold Start, Sauer Danfoss, 1300
Steering Pump, 60cc, Cold Start, Sauer Danfoss, Right Hand
1300
Hydraulic Block, Pressure Washer Control
Assisted Steering Unit
Hydraulic
Steering Electrical Assembly, Pved Kit
Split Flange Kit, Code 61-32
Hydraulic Steering Cylinder Installation
Steering Cylinder Assembly, Front
Front
Hydraulic Cylinder, 3.00 X 1.000 X 1.38
Air System
Air System Group
Air Tank Installation
Air Reservoir Assembly, Standard, 42 Liter
Control Valve Assembly, Front
Control Valve Assembly, Rear
High Volume Air Dryer Group
Air Governor
Air Dryer, Single Canister
Tank Assembly, Wet Cooling
Hi Volume Air Dryer Option
No High Volume Air Dryer Group
Cab Airline Fitting Installation, 1274c
Air Horn Arrangement
Air Horn, Europe
Brake Option, Europe
O-Ring Kit, Rogator
Hydraulic Oil Tank Installation, 900 1100 1300
Hydraulic Tank Assembly
Hydraulic Installation, Dry System
Hydraulic Cylinder Assembly, Ladder
Hydraulic Cylinder, 2.00 X 6.50 X .75
2012
Hydraulic Installation, Drive Wheel, 900 1100
Superseded By 561444d1
Hydraulic Motor, 80cc, H1, With Ss 900 1100
Speed Sensor Assembly
Split Flange Mounting Kit, -16, Code 62
Drive Hose Kit, 900 1100
Hydraulic Installation, Drive Pumps, 900 1100
With Internal Braking Function
Hydraulic Pump, Front Hydro, 529995d1, 900 1100
Hydro Pump Drive Kit, 900 1100
Hydraulic Valve, Park Brake, With Tow Override, 900 1100 1300
Hydraulic Ladder Control Valve, 900 1100 1300
Hydraulic Installation, Drive Wheel, 1300
Superseded By 561445d1
Hydraulic Motor, 107cc, A6ve, With Ss 1300
Flange Kit, -16 Code 62
Drive Hose Kit, 1300
Hydraulic Installation, Drive Pumps, 1300
Tandem Pump, Drive, 125cc, Right Hand, 1300
Hydraulic Pump, Front, 1300
Hydraulic Pump, Rear, 568273d1, 1300
Auxiliary Hose Kit, 900 1100
Auxiliary Hose Kit, 1300
Gearbox, 609, 26.6 1, 80cc
Gearbox, 609, 22.1 1, 107cc, 1300
Speed Sensor Assembly, 1300
Hydraulic Installation, Track Adjust, Air 900 1100 1300
Track Adjust Block Assembly, Front
Hydraulic Track Adjust Valve
Hydraulic Track Adjust Cylinder Assembly, 3.25
Hydraulic Cylinder, 3.25 X 16 X 1.25
Hydraulic Track Adjust Cylinder Assembly, 3.75, Auto Tie Rod
Track Adjust Block Assembly, Rear
Hydraulic Cylinder, 3.25 X 16.00 X 1.25
Hydraulic Return Manifold Assembly, 900 1100 1300
Hydraulic Manifold, Return Oil
Hydraulic Brake Caliper
Hydraulic Track Adjust Cylinder Assembly, 3.25, Auto Tie Rod
Hydraulic Cylinder, 3.25 X 16 X 1.25, Auto
Hydraulic Cylinder, 3.75 X 16 X 1.375, Auto
Manual Track Adjust Assembly
Bulkhead
Hydraulic Installation, Dry System, 13xx
Hydraulic Installation, Auto Track Adjust
Track Adjust Hose Kit
Hydraulic Cylinder, 3.75 X 16.00 X 1.375, Auto
Hydraulic Cylinder, 3.25 X 16.00 X 1.25, Auto
Sensor Assembly, Hall Effect, Linear Position
Hydraulic Cylinder, 3.0 X 10.0 X 1.38, 4ws
Hydraulic Tank Heater, 1000 Watt, 120 Volt
Smartrac
Hydraulic Valve Assembly, Smartrax
Hydraulic Valve, Smartrax
Cold Start Option, 120 Volt
Europe Only
Hydraulic Installation, Brake Valve
Valve Assembly, Brake Pedal
Brake Valve, Modulating, 2000 Psi
Brake Release Assembly
Hydraulic Installation, Brake Accumulator
Brake Accumulator Assembly
Common
Hydraulic Cap Plug Installation
Kit, Repair
International
North American
Field Accessories, Radio, Domestic, Sirius
Satellite Radio
Radio Kit Installation, Sirius
Electric Group, Domestic, 900 1100, 2012
Clamping Installation
Harness Installation, Cable, Chassis, Domestic, Air Ride
Battery Installation, Rogator
Electric Group, Domestic, 1300, 2012
2014
Cab Harness Installation, Rogator, Instuctor Seat, 2014
Power Distribution Module, 42 Fuse
Housing Assembly, Power Port
Radio Accessory Kit
Outer Roof Arrangement
Inner Roof Arrangement
Cab Glass
Interior Trim Arrangement
2016-2017
Antenna Base Assembly
Cigar Lighter Assembly
Door Assembly
Wiper Group
Wiper Motor, 1 Inch Shaft, Left Hand, 85
Windshield Washer Kit
Radio Kit Installation, Xm
Seat Installation, Leather, Deluxe
Seat Assembly, Leather, Semi Active
Semi Active Suspension
Semi Active Seat Suspension Kit
Seat Top Kit, Sst
Recliner Assembly Kit
Seat Pan Back Kit, With Lumbar
Lumbar Kit, Sst
Slide Adjustment
Swivel
Slide Latch Assembly Kit
Slide Puck Assembly Kit
Seat Installation, Basic
Seat Assembly, Basic, Air
Basic
Passive Seat Suspension Kit
Deluxe
Seat Assembly, Deluxe, Semi Active
Seat Back Kit, Upper
2017
Seat Install, Basic
Seat Install, Deluxe
Cloth
Leather
Knobs Assembly Kit
Mount Assembly
Cab Floormat Installation
Cover Assembly, Right Hand
Cab Installation
Glass Hammer Assembly
Air Conditioning High Pressure Switch Assembly
Receiver Dehydrator
Heating, Ventilation And Air Conditioning Installation
Heating, Ventilation And Air Conditioning Group
Auto Control
Motor Blower Assembly, Pressure
Gaskets Kit
Hood Installation
Grille Assembly
Hood Transition Assembly
Bracket Group
Bezel Group, Rogator
Deflector Cover Installation
Deflector And Cover Support Assembly, Left Front
Deflector And Cover Support Assembly, Right Front
Deflector And Cover Support Assembly, Right Rear
Deflector And Cover Support Assembly, Left Rear
Mirror Installation, Heated And Adjustable
Poly Box And Tool Box Installation
Poly Box And Tank Group, Left Hand
Poly Box And Tank Assembly, Left Hand
Tool Box Assembly, Right Hand
Door Assembly, Tool Box, Right Hand
Door Assembly, Box And Tank, Poly, Left Hand
Entrance Installation, Front, Rogator
Battery Box Assembly
Battery Box Top Cover Assembly
Ladder Installation, Front, Rogator
Entrance Ladder Assembly, Front
Platform Installation, Front, Rogator
Handrail Installation, Front, Rogator
Left Hand
Mirror Installation, Standard
Chassis Installation, Narrow Transport
System Installation, Narrow Transport
Boom Stop Bracket Assembly, Left Hand
Boomrest Installation, Domestic
Boomrest Installation, Non Domestic
Boomrest
2 Wheel Steering
Fender Option, Row Crop
Fender Option, Row, 4 Wheel Steering
Non Def Group
1decals
Decal Installation, Chassis, International 2012-2013
Cab Filter
Decal Installation, Rogator Chassis, International, 2014
Decal Installation, Rg900, Challenger
Decal Installation, Rg1100, Challenger
Decal Installation, Rg1300, Challenger
Decal Installation, Rg900, Less Regulated Countries
Decal Installation, Rg1100, Less Regulated Country
Decal Installation, Rg1300, Less Regulated Countries
Emblem Assembly
Emblem Assembly, Challenger
1wheels
Wheel Hardware Installation
Brake Rotor Installation
Wheel Center Installation, 609gb
Wheel Disk Assembly, Center, 609gb
168, R1
156, R1
Tire And Wheel Assembly, 380 90r46, Goodyear
Tire And Wheel Assembly, 650 65r42, R1w, Goodyear
Titan Tire Option
Tire And Wheel Assembly, 320 90r50, Titan
Tire And Wheel Assembly, 650 65r42, R1w, Titan
Tire And Wheel Assembly, 480 80r42, Titan
Tire And Wheel Assembly, 620 70r38, Michelin
Tire And Wheel Assembly, 380 90r46.Michelin
Tire And Wheel Assembly, 380 90r46, Michelin
1controller System
Radar Group
Raven Control Installation, Viper Pro
Weather Station
Control Installation, Topcon, X30, Rogator
Topdock Assembly, Ag150, Aed
Control Installation, C3000
1precision Farming Systems
Topdock Installation-Agi-4, Aed
Gps Kit, Phoenix 300
Gps Kit, Phoenix 300, Gs
Receiver Installation, Groups, Phoenix 300
Antenna Installation, Phoenix 300, Gps
Phoenix 200 Installation
Gps Kit, Phoenix 200
Telemetry, 2011
Telemetry Assembly
Telemetry Hardware Kit
Telemetry Ready Assembly
Lightbar Option, Rgl 600, Viper Pro
Lightbar Kit, Rgl 600, Viper Pro
Cable Installation, Rgl 600, Viper Pro
Lightbar Installation, Rgl 600, Rg
Gps Ready Installation, Rogator
Dome Housing Bracket Installation
Gps Receiver
Receiver Installation, Phoenix P300 Hp Xp
2015
2014-2015
1attachments
Pressure Washer Option
Pressure Washer Reel Assembly
No Pressure Washer Option
Pressure Washer Plumbing Installation
1accessories
Extra Key Kit
Engine Mount Field Kit
Field Service Kits
Field Accessories, Brake Release
Field Accessories, Raven, Rogator
Field Accessories, Smartrax, Raven
Field Accessories, C3000, Crenlo, Cab
Rg900 Rg1100 Rg1300
Rg900
Crankshaft Assembly
Oil Sump Assembly
Oil Cooler Assembly
1100 1300
Fuel Pump Assembly
Eem4 Parts Assembly
Alternator Assembly
Scr Parts Assembly
Rg1100
Compressor Assembly
Rg1300
Air Cleaner, Psd10
900 1100 1300
Cooling Package
Eye Bolt Assembly
4 Wheel Steering
Steel Fork
900 1100
1300
Hydraulic
Front
Air System
Air System Group
Air Governor
Air Horn, Europe
O-Ring Kit, Rogator
2012
Bulkhead
Smartrac
Europe Only
Common
Kit, Repair
International
North American
Satellite Radio
2014
Radio Accessory Kit
Cab Glass
2016-2017
Door Assembly
Wiper Group
Seat Top Kit, Sst
Lumbar Kit, Sst
Slide Adjustment
Swivel
Basic
Deluxe
2017
Seat Install, Basic
Cloth
Leather
Knobs Assembly Kit
Mount Assembly
Cab Installation
Receiver Dehydrator
Auto Control
Gaskets Kit
Hood Installation
Grille Assembly
Bracket Group
Left Hand
Boomrest
2 Wheel Steering
Non Def Group
1decals
Cab Filter
Emblem Assembly
1wheels
168, R1
156, R1
Titan Tire Option
1controller System
Radar Group
Weather Station
Telemetry, 2011
Telemetry Assembly
Gps Receiver
2015
2014-2015
1attachments
1accessories
Extra Key Kit
Field Service Kits
