Challenger Rogator RG1300C Chassis & Systems Parts Catalog 652362
Brand: Challenge Rogator
Type of Machine: Applicators
Type of Manual: (Chassis & Systems) Parts Catalog
Model: Challenge RG1300C Chassis & Systems (2018-2021)
Serial Number: .JXXX1001 - ..MXXX9999
Part Number: 652362
Number of Pages: 6604 Pages
Belts & Filters Guide
Engine V835277817 84 Awf-Hla
8.4 Liter
Hydraulic Lash Adjustment
Electronic Engine Management
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Valve Rocker Cover
Intake Manifold
M12 Turbo Mounting Stud Bolts
Oil Pump And Sump
Oil Cooler And Filter
Coolant Piping
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Fan Drive
Air Compressor
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine V835277885 84 Awf-Hla
Up To Engine Serial Number D79603
Starting From Engine Serial Number D79604 Jld291001
Engine Acw6677560 84 Awf-Hla
Engine Installation
Engine Installation, Agco Power, 8.4 Liter
Air Cleaner, Psd10
Installation-Air Intake
Alternator Assembly
Cooling Package
Air Conditioner
Def Tank Group, Non-Locking, 8.4 Liter
Def Tank Group
Non Def Group
Electrical Caps Installation, Less Regulated Countries
Fan And Alternator
Exhaust Group, 8.4 Liter, Tier 4 Final
Tier 4, Final Compliant
Fuel Tank Installation, Locking Cap
Fuel Line Installation, Standard
Fuel Line Installation, 2nd, Fuel And Water Seperator
Fuel Filter, Complete
2 Wheel Steering Axle
Rear Axle Installation
Hydraulic Installation
Electrical Installation, 4 Wheel Steering
Wheel Angle Sensor Installation
Drive Hose Kit, 2 Wheel Steering
4 Wheel Steering
Front
Hydraulic Track Adjust Valve
Rear
Hydraulic Track Adjust Group, Standard
Hydraulic Track Adjust Cylinder
Manual Track Adjust Assembly
Bulkhead
Steering Column Assembly
Steering Control
Hydraulic
Steering Pump Group, Standard
Priority Valve Assembly
Cold Start
Air System
Air System Group
Air Tank Installation
Control Valve Assembly, Front
Control Valve Assembly, Rear
Air Dryer, Single Canister
Air Governor
2015-2019
2021
No High Volume Air Dryer Option
Air Box Assembly, Boom Cleanout
Small Tree
Mounting Bracket Assembly, Air Box, Boom Cleanout, Small Tree
Large Tree
Mounting Bracket Assembly, Air Box, Boom Cleanout, Large Tree
Valve Assembly, Regulating, Pressure
Pneumatic Assembly
O-Ring Kit, Rogator
1300
Hydraulic Accumulator Installation
Hydraulic Tank Installation
Hydraulic Tank Assembly
Hydraulic Tank Heater, 1000 Watt, 120 Volt
Brake Installation
Manifold Assembly, Hydraulic Return
Hydraulic Return Manifold Assembly
Park And Ladder Valve Assembly
Brake Pedal Valve Assembly
900 1100 1300
Hydraulic Installation, Drive Wheel, 1300
Hydraulic Ladder Cylinder Assembly
Hydraulic Installation, Routing Accessories
C Series
Puller For Brake Circlip
Boom Breakaway Cylinder Assembly
Boom Hoist Cylinder Assembly
Large Tree, Auto
Boom Tip Fold Cylinder Assembly
120 Foot
Cylinder Installation, Boom Tip Fold
Large Boom
Hydraulic Block Installation, No Autoboom, Small Boom
Hydraulic Block Assembly, Boom, No Autoboom, Small Boom
Valve Block, 7 Bank, Without Autoboom, Small Boom
Hydraulic Block Installation, With Autoboom, 120
Hydraulic Block Assembly, Boom, 120, With Autoboom
Hydraulic Block Installation, With Autoboom, Small Boom
Hydraulic Block Assembly, Boom, With Autoboom, Small Boom
Valve Block, 7 Bank, With Autoboom, Small Boom
Hydraulic Block Installation, 120
Hydraulic Block Assembly, 120
Valve Block, 7 Bank, Without Autoboom, Large Boom
Hydraulic Block Installation, Without Autoboom, 120
Hydraulic Block Assembly, Without Autoboom, 120
Hydraulic Block Installation, Norac Small Boom
Hydraulic Block Installation, Norac Large Boom
Hydraulic Block Installation, Small Boom
Hydraulic Block Assembly, Small Boom
Hydraulic Block Assembly, Norac, Passive
Norac, Passive
Hydraulic Cap And Plug Installation
Hydraulic Motor, Hm5 Without Bypass
3x2 Plumbing
Hose Installation-Hydraulic, Boom Block, Rg
Hydraulic Hose Installation, 3x2
Liquid System
Hydraulic Pump, 45cc Ep Control
4x3 Plumbing
Hydraulic Hose Installation, 4x3
Hydraulic Damper Cylinder Installation, Norac, Small Boom
Hydraulic Damper Cylinder Installation, Norac, Large Boom
132 Foot Boom
Hydraulic Hose Installation, 120 Foot
80 90 100 Foot
Small Boom
Large Tree, 90 100
Large Tree, 120
90 100, Left Hand
90 100, Right Hand
Small Tree, 90 100
Passive
120 Foot, Left Hand
120 Foot, Right Hand
Boom Fold Hydraulics Installation
Solenoid Valve
Fan Circuit Hydraulics Installation
Low Pressure Hydraulic Filter Assembly
Hydraulic Servo Valve Assembly, Fan Speed
Fan Motor Group Hydraulics Installation
Cartridge Valve, Rotary Flow Control
Fertilizer Group Hydraulics Installation
Flow Control Valve, 15gpm
Hydraulic Motor, Parker Tf 100
Hydraulic Cylinder, 1.50 X 6.00 X 1.00
2016
2017
2018
Hydraulic Bracket Installation
Power Head, Raven, 15 Section
Pump Bolts, Bosch Rexroth
Pump Bolts, Sauer Danfoss
Pump Support
Pump Support Assembly
Reservoir Group Hydraulics Installation
Second Metering System Hydraulics Installation
Ball Valve, 1.25 Inch Npt
Ball Valve, 2.00 Inch Npt
Gearcase Breather Tube Assembly
Cooler Assembly, Hydac Eld4.5
Hydraulic Motor Assembly
Hydraulic Servo, 9gpm
Hydraulic Servo, 40gpm
Hydraulic Valve, Electrical Pwm
Hydraulic Tank Heater Installation
Hydraulic Pump Installation, Nl Single
Hydraulic Pump Assembly, Nl Single
Hydraulic Valve, Load Sense Blocking
Nl4500
New Leader Dry System
Multapplier
Hydraulic Pump Installation, New Leader, Multapplier
Hydraulic Pump Assembly, Nl Ma
Nl4500ma
L4258
Hydraulic Valve Block Assembly
40 Gpm
Hydraulic Tank And Cooler Assembly
New Leader G4 Edge
Return Filter
With Relief
Fitting Kit, Suction, Hydraulic
Pump Assembly With Connector
Hydraulic Tank Group
Tank Cooler Assembly
30 Gpm
11 Foot
Valve Assembly, Sfp 9gpm
Nl4330
New Leader 4330 Multapplier
L4330
New Leader 4330
Hydraulic Hose Installation, Airmax Precision
Hydraulic Component Installation
Hydraulic Boom Valve Assembly
Single Bin
Twin Bin
Multapplier Ready
Multapplier Complete
Single Bin, 12 Foot
Spreader Control Valve
New Leader
Multi Product, 12 Foot
Cylinder Control Valve
G5
Dual 14.1 Cid
4 Position
Back Up Alarm
Battery
Cab Electrical Kit, Mini Fuse
Cab Harness Installation
Clamping Installation
Electric Horn Installation
Harness Installation, Cable, Chassis, Domestic, Air Ride
Harness Installation, Wheel Leg, Sauer
Boomrest
Light Assembly, Right, Double Hid
Light Bezel, Right
Light Assembly, Left, Double Hid
Light Bezel, Left
Halogen
Right Hand
Left Hand
Lighting Group, Standard Lights
Lighting Group, Double Hid
Lighting Group, Led
Powerstrip Assembly
Radio Installation, Cd, Xm ,Blue Tooth, Usb
Radio Accessory Kit
System Connector Installation, Combo
Boom Rest Light Installation
Boom Sensor Arm Assembly
Breakaway Amber Flashing Warning Light Installation
100 Feet
120 Feet
Raven
90x10
90x15
90x20
90x50
100x10
100x15
100x20
100x50
120x10
120x15
120x20
120x50
Electric Installation, Norac, Passive
Box
2019
No Boom
Norac 120
Electric Installation, System
Electric Clamping Installation
Uc7
Reload
Front Reload
Harness, Flow Sensor
Nozzle Control Module Installation
Plug, -I O, Load, Simulator, 1500 Ohm
Rotating Beacon Lamp Assembly
System Installation, Single Injection, Rogator
Marker
Eame
1 Inch Mounting
Ultrasonic Sensor
Worklight Installation, #3, Dual Beam
#3
Tail Light
Kit, Repair
Taillight Assembly, Led, Speaker, Molded, Ss
Sensor Installation, Lockout
Electric Installation, Reverse Camera
Electrical Installation, Raven, Granular, Air Max 180
No Worklight #3
License Plate Light
Rotating Beacon Installation
No Worklight
Beacon Assembly
Bin Level Sensor Assembly
Reverse Camera Installation
Electric
Taillight Installation, New Leader, Rogator
Electric Roll Tarp Installation
No Roll Tarp Installation, New Leader
Module Group, Body Control
11-12 Foot
Harness Installation, Master Module, New Leader
Module
Mount Assembly
Slave Module Group, 11-12 Foot
Duel Spinner Speed
Hydraulic Tank
Beacon Installation
Air Max Precision, R1
Air Max Precision, R2
Electric Box Assembly, Input Output
Plate
Taillight And Amber Flashing Warning Light Installation
Worklight Installation, Halogen
Led
Conveyor
Platform
Antenna
Antenna Base Assembly
Rogator
Arm Rest
Virtual Terminal Installation
Terminal Support
Camera Cables
Armrest Adjust Mechanism, Right Hand
Audio Group
Plug Installation
Cab Door Assembly
Cab Floormat Installation
Cab Floor Mats And Covers
Cab Glass
Cab Mounting, Air Ride
Metric
Standard Isolator Cab Mounting
Controls Arrangement, Front
Dash Panel Assembly
Dome Housing Bracket Installation
Glass Hammer Assembly
Heat Barrier Installation
Inner Roof Arrangement
Outer Roof Assembly
Interior Trim Arrangement
Interior Trim
Mirror Installation, Standard
Mirror Installation, Heated And Adjustable
Convex Mirror Installation
Mirror Mounting Group
Air
A2000 Passive Suspension Service Kit
Passive Seat Suspension Kit
Knobs Assembly Kit
Seat Group, Deluxe
Semi Active Suspension
Trainer Seat, Cloth
Trainer Seat, Leather
Semi Active Seat Suspension Kit, Left Hand Air Tank
Wiper Group
Wiper Motor, 1 Inch Shaft, Left Hand, 85
Hvac Group
Auto Control
Air Conditioning High Pressure Switch Assembly
Anti-Roll Bar Assembly
Crossmember Assembly
Chassis Installation, Narrow Transport
Deflector Cover Installation
Deflector And Cover Support Assembly, Left Front
Deflector And Cover Support Assembly, Right Front
Deflector And Cover Support Assembly, Left Rear
Deflector And Cover Support Assembly, Right Rear
Entrance Installation, Front, Rogator
Handrail Installation, Front
Platform Installation, Front
2 Wheel Steering
Grill Assembly
Hood Installation
Hood Group
Hood Support Group
Hood Support Bracket Group
Tool Box Group, Right Hand
Tool Box Assembly, Right Hand
Tool Box Hand Rinse Tank
Ppe Box Tank Assembly, Left Hand
Cab Decal Installation, Inside
Chassis Decal Installation
Rg900c Rg1100c Rg1300c
Decal Installation, Chassis, North America
Decal Installation, Chassis, International
Engine Decal Installation
Emblem Assembly, Challenger
Option, Decal-Global
Decal Installation, Air
Speed Indicator Symbol Installation, 35 Mph
Speed Indicator Symbol Installation, 55 Kph
Slow Moving Vehicle Sign Installation
Lubrication Decal And Chain Conveyor Assembly
Decal Installation, Speed Indicator Symbol, 35 Mph
Decal Group, Decor
Decal Group, Decor, L4258
Decal Group, Endgate, L4258
Decal, Speed Indication Sign, New Leader, 55kph
Safety
Body
Red Black
Nl4330 Multapplier
Decal Group, Safety Multapplier
Back
Right Side
Patent
Wheel Hardware Installation
Goodyear, Firestone, Michelin, Telleborg
Tire And Wheel Assembly, 380 90r46, Goodyear
Tire And Wheel Assembly, 320 90r50, Titan
Tire And Wheel Assembly, 480 80r42, Titan
Tire And Wheel Assembly, 620 70r38, Michelin
Tire And Wheel Assembly, 650 65r42, R1w, Goodyear
1controller System
Boom Level Sensor Assembly , Norac
Norac
Roll Sensor Installation, Norac, Small Boom
Roll Sensor Installation, Norac, Large Boom
Small
Sensor Installation, Center Section, 80 90 100
Ultrasonic Sensor, Digital
Ultrasonic Sensor, Autoboom, Lh And Rh Mounting, 1.50 Inch
Sensor Installation, Center Section, 120
Sensor Installation, Norac, Boom, 90 100 Foot
Sensor Installation, Norac, Boom, 120 Foot
Sensor Assembly, Center, Norac, Small Boom
Sensor Assembly, Center, Norac, Large Boom
Application Rate Sensor, Raven
Encoder, Dickey-John 360, With 12 Inch Cable
Multapplier Multibin
Multibin
Autoboom
304ss
Spinner Assembly
1precision Farming Systems
Vd03
Antenna Installation, Phoenix 300, Gps
Cable Installation, Rgl 600, Agcontrol
Cable Installation, Rgl 600, Raven
Camera Kit, Agcam
Camera Installation
Camera Installation, 9 Inch Monitor
Single
Nt01
Camera Ready System
9 Inch Display
Without Gps, Viper 4, Raven, Ag
Controller Installation, Raven V4
Controller-Vd0x W Gyro 3g, Modem
Controller-Vd0x W Gyro Cdma, Modem
Gateway Assembly
Gateway, Mid Spec, Lte
Gateway, Mid Spec, Gsm
Gps Ready Installation
Lightbar Installation, Rgl 600, Rg
Agcontrol
Quad Camera Display Monitor
Smart 6
Smart 7
Camera (Agcam)
Lightbar
Radar Installation
Slingshot Installation, 2.0, Verizon
Slingshot Installation, Ready, Raven
Slingshot Installation, Verizon
Slingshot Installation, No Gps, Cab
Receiver
Weather Station
Control Installation, Raven, Viper 4
1product Containment
Tank And Saddle Assembly, 1300 Gallon, 3x2
Saddle Assembly, Boom Tree, 1300 Gallon, Ss
Boom Stop Bracket Assembly, Left Hand
Boom Stop Bracket Assembly, 1100 1300 Gallon, Right Hand
Boom Stop Bracket Assembly, Right Hand
Tank Assembly, 1300 Gallon, Ss, 3 X 2 Inch
Ball Valve, Flange, Electric
Valve Body Assembly, Flanged, 1.00, 2w
Rinse Tank Installation, Top, 1300 Gallon
Rinse Tank Assembly, Top, 1100 1300 Gallon
Cross Assembly, 1.50 Hose Barb X 1.50 Hose Barb X 1.50 X .75
Tiedown Installation, System
Plumbing Installation-Rinse, 130 Gallon, 3x2
Ball Valve, 2.00 Sp Flange X 2.00 Male Quick Coupler
Ball Valve, 2.00 Inch, Poly
Boom Stop Brace Assemby, Right Hand, 1100 1300
Tank And Saddle Assembly, 1300 Gallon, 4x3
Tank Assembly, 1300 Gallon, Ss, 4 X 3 Inch
Ball Valve, 2-Way, Mx
M220, 2 Way
Plumbing Installation-Rinse, 130 Gallon, 4x3
Pump Support Assembly, 3x2
Pump Support Assembly, 4x3
Tank Assembly, 40 Gallon, Injection System, Left Hand
Ball Valve, Union, Poly, 1.00npt
Tank Assembly, 40 Gallon, Injection System, Right Hand
Tank Support Assembly, Injection
Sight Gauge Installation, 1300 Gallon
Sight Gauge Assembly, Front, 1300 Gallon
Sight Gauge Assembly, Rear, 1300 Gallon
Sight Gauge Installation, 1300 Gallon, International
Sight Gauge Assembly, Front, 1300 Gallon, International
Sight Gauge Assembly, Rear, 1300 Gallon, International
Hoist Installation, Liquid System, 90 100
Combo Support, Front, 80 90 100
Hoist Installation, Liquid System, 120
Combo Support, Front, 120
Catwalk Installation, Rear, Right Hand, 1100 1300
Rg Air Max 180 Filters
Cable Spool Kit, Short
Cartridge Group, 15 Inch
Catch Pan Installation
Seal Group
Handrail Installation, Rear
Hopper Assembly
Hopper Screen
Motor Kit, Srt2
Tarp Motor Group, Srt
Roll Tarp
Roll Tarp Hardware Group, Srt2
Sleeper Installation, Air Max 180, 1264c
Stationary Tube Plug Group
Tarp Assembly, Air Max 180
Tarp Stop Assembly, Short Clevis Pin, Quick Release
Tarp Stop Assembly Hardware Group
Tarp Stop Assembly, Offset, Qr
Tiedown Installation, Air Max 180, 1264c
Rg L4258g4 Filters
Bracket Kit, 3 Pin Clevis, Quick Release
Tarp Stop Assembly, Tall Clevis Pin, Quick Release
Belly Pan
Conveyor And Shield Assembly, 409ss, 11 Foot
Chain Shield Group, 11 Foot, 409ss, #4 Belt Over Chain
Wiper, Front, 304ss
Chain Assembly, #4 Box 11 Foot
Front Conveyor Guard Group
Chain Oiler Assembly
Tank
Drive Assembly, 30 Inch, Left Hand, With Sensor Mount
Drive Idler Group
Inverted Vee Kit, 11 And 12 Foot, 409ss
12 Foot V, Ss
409ss
Edge
Gear Case
Divider Assembly
Ratchet Assembly, 1.00 Inch, Ss
Roll Tube Assembly, 132 Inch Box
Rate Sensor Mount Installation, Dickey John
Pivot Mount Hardware Kit, Sst
Shaft Assembly, 30 Inch Drive
Slow Moving Vehicle Sign Installation, New Leader
Tarp Kit, Srt2, New Leader, 4258, 120 X 132
Tarp Installation, L4258g4
Tiedown Installation, Liquid System
Glass
Rg L4330g4 Filters
Chain Shield Group, 11 Foot, 304ss, #4 Belt Over Chain
# 4, Right Hand
Conveyor And Shield Assembly, 304ss, 11 Foot,#4
Conveyor And Shield Assembly,#4, 409ss, 11 Foot
120 Links
Short
Endgate Assembly, 409ss
Endgate Assembly, 304ss
Endgate Hardware Kit
Gear Case, 6.1
Inverted Vee Kit, 11 And 12 Foot, 304ss
Tarp Kit, Srt2, New Leader, 120 X 132
Stainless Steel
Air Max Precision, R1 R2
Bin Divider Installation
Bumper Installation
Mount
Window Installation
No Micro Bin Installation Group
Rear Manifold Installation
Manifold Assembly
Front And Rear
Screen Installation
Unloading Chute Installation
V-Hood Installation
V-Hood Installation, Dual Bin
Nl5000 G5
30
12 Foot
Endgate Assembly, 409ss, 120 Inch Sf
Window Installation, Hopper
#4 Belt Over Chain Assembly
Smv Emblem And Mounting
Extension
Multapplier Shell, 5 Foot 120 Inch, Standard Flare
Hillside Divider
30
Endgate Assembly, 409ss, 120 + 6 Sf
Endgate Group, 409ss, 120sf
Endgate Group, 409ss, 120 + 6 Sf
Endgate Group, 304ss, 120sf
Endgate Assembly, 304ss, 120 + 6 Sf
1primary Product Distribution
Support Assembly, Spreader, Combo
Actuator, 000-60-M-9
Valve Assembly, Rear, Sight Gauge
Ball Valve, 1.00 Inch Full Port Flange, Electric
Ball Valve, 0.75 Npt, Union, Poly
Flange
Ball Valve, 2.00 Inch, Full Port Flange, Electrical
Valve, 2.00 Full Port, With Flange
Electric Ball Valve, 2.00 Inch Full Port Flange
Ball Valve, 3.00 Inch, Poly, Full Flow
Ball Valve, Prostop-E
Butterfly Valve Rework, 4.00
Valve, 4.00 Inch, Butterfly With 10 Position Lever
3 Way Valve, Bottom Load, 2.00 Standard Port Flange
Centrifugal Pump, 2.00 X 1.50, 9306chm5
Centrifugal Pump, 3.00 X 2.00, 9307
Chemical Eductor Installation, 7 Gallon, Poly
Chemical Eductor, Cleanload, 7 Gallon
Tank Ball Valve
Control Box Assembly, Pressure Manifold Plumbing
Injection System
Elbow And Flange Assembly, 90 Degree, 3.00, Ss
Fitting Assembly, 4 Hole Compression Flange X Flange, 3.00
Flowmeter Assembly-Raven, 2.00 Flange
Loose Option
Flowmeter Assembly-Raven, 3.00 Flange
Hose Installation, Injection System, #1
Hose Installation, Injection System, #2
#2
Strainer Body Assembly, .75 Inch
High Volume
Injection Pump, Raven, Integrated Node
Injection Assembly, 2 Inch Check Valve, 2 X 2 Inch Hose Barb
Injection Tank Stand Installation
Low Rate Assembly Kit, 2.00 Full Port Flange
Manifold Assembly, 3 Inch Flange
Manifold Assembly, 2 Inch Flange
Mounting Ring Assembly, Cleanload
Mixer Assembly, Chemical Injection, 4 X 3,Raven
Manifold Assembly, Front Reload, 4.00 Inch
Valve Assembly, 4.00 Inch, Electric, 3 Section, Key, Safi
Pressure Plumbing Assembly, 2.00, Without Chemical Injection
Y Strainer, 2.00 Inch, Full Port Flange, With 30 Mesh
Y Strainer, 2.00 Inch, Full Port Flange, With 50 Mesh
Hose Bracket And Clamp Assembly, 2.00
Pressure Plumbing Assembly, 3 Inch, Without Chemical Injection
Hose Bracket And Clamp Assembly, 3.00
Plumbing Assembly, Inlet, Injection Pump
With 40 Gallon Tank
Pressure Injection Pump Plumbing Assembly
Z Bracket Assembly, Stauff, .75 Double
2020
Strainer Assembly, 3.00 Inch Full Port Flange
Strainer, 3.00 Line, 316 Ss
Pressure Plumbing Assembly, 2.00, With Chemical Injection
Pressure Plumbing Assembly, 3.00 Inch With Chemical Injection
Mixer, 4x3
Pressure Distribution Plumbing Assembly, 2.00
Product Pump Installation, 3 X 2 Plumbing
Pump Sub Assembly, 3.00 Suction, 2 X 1.5
Valve Assembly, Front, Pump Vent
Product Pump Assembly, 4 X 3
Product Pump Installation, 4 X 3 Plumbing
Reload Valve Sub Assembly, 4.00, Front, Air
Reload Installation, Front, Liquid System, 4x3, 4.00
Reload Installation, Front, Liquid System, 4x3, 3.00
Reload Installation, 3.00 Side, 3x2
Reload Installation, 3.00 Side, 4x3
Reload Installation, 4.00 Side, 4x3
50 Mesh
Sump Valve Option, 3.00 Inch, Electric
Sump Valve Option, 3.00 Inch, Manual
Valve, 3.00 Inch, Butterfly With 10 Position Lever
Sump Valve Option, 4.00 Inch, Electric
Sump Valve Option, 4.00 Inch, Manual
Stubby Valve, 3 Flange X 3 Male Quick Coupler
Suction Installation, 3.00 Inch, With Front Reload, Air
Valve Assembly, 3.00, Front Reload, Air
Y Fitting, Valve Assembly, With 45, 3.00 Inch, Butterfly
Hose Hanger Bracket Assembly, 3.00, Large
Suction Installation, 3.00 Inch, Without Front Reload
Suction Installation, 4.00 Inch, With Front Reload, Air
Valve Assembly, 4.00 Inch, Front Reload, Air
Hose Hanger Bracket Assembly, 4.00, Large
Suction Installation, 4.00 Inch, Without Front Reload
Valve Assembly, 3.00 Inch Electrical, Eh4, 3 Section
Valve Bracket Assembly, 3.00 Inch Butterfly, Small
1.5
Valve Bracket Assembly, 3.00 Inch Butterfly, Large
Valve Installation, Product Recovery-Clean Out Sump 3x2
Valve Installation, Product Recovery-Clean Out Sump 4x3
Gearbox, Worm, Hydraulic Drive, Left Hand
Gearbox, Worm, Hydraulic Drive, Right Hand
Fan Assembly
Fertilizer Metering
Manifold
Metering Roller
#4
L4258g4 L4500g4
Disc Assembly, Left Hand, 24 Inch
Disc Assembly, Right Hand, 24 Inch
5.10 Cir
3.19 Cir
Blower Installation
Blower Assembly
Motor
Single Bin Twin Bin
Conveyor Cover
Divided Funnel Box Installation
Panel Installation
Transition Chute Cover
Transition Chute
Assembly
1secondary Product Distribution
Identification Chart
Plumbing Installation, Ss, 90 X 10, On
Pipe Assembly, 1.50 Inch, Boom Feed
Pipe Assembly, L 12, 17x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 31x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 31x10, Ss, Aspirator, Right Hand
Product Recovery
Pipe Assembly, 25.4 Poly, With 2 Hose Barb, .2835mm Er
Pipe Assembly, 25.4 Poly, With 2 Hose Barb .4105mm
L Bracket Assembly, Short Offset, Ips
L Bracket Assembly, Long, Stauff, 1.00p
L Bracket Assembly, Long, Stauff, 1.00p, Inverted
L Bracket Assembly, Long, Stauff, Xlong Offset
L Bracket Assembly, Xxxlong, Stauff, Long U Bolt
Z Bracket Assembly, Short, 1.00 Ips
Z Bracket Assembly, Short, 1.00 P-Clip
Z Bracket Assembly, Long, 1.00 Ips 1.50 P-Clip
Z Bracket Assembly, Long, Double 1.00 P-Clip
Z Bracket Assembly, Long, Double 1.00 P-Clip, Long U-Bolt
Z Bracket Assembly, 1.50 Stauff,1.00 Poly, Left Hand
Z Bracket Assembly, 1.50 Stauff,1.00 Poly, Right Hand
Z Bracket Assembly, Poly, Stauff, Reversed U
Z Bracket Assembly, Long, 1.00 Stauff
Z Bracket Assembly, Long, 1.50 Stauff
Bracket Assembly, Straight, 1.50, Stauff, Right Hand
Bracket Assembly, Straight, 1.50, Stauff, Left Hand
Bracket Assembly, Straight, Long, 1.00, P-Clip
Plumbing Installation, Ss, 90 X 15, On
Pipe Assembly, L 12, 11x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 12, 11x15, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 7x15, Ss, Aspirator, End Row
Pipe Assembly, L 16, 21x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 21x15, Ss, Aspirator, Right Hand
L Bracket Assembly, Long, Stauff, Reversed U
Plumbing Installation, Ss, 90 X 20, Off
Pipe Assembly, L 12, 9x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 12, 9x20, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 15x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 15x20, Ss, Aspirator, Right Hand
Poly Plumbing Installation, 90 X 20, Off
Pipe Assembly, L 12, 9x20, Poly, Left Hand
Pipe Assembly, L 12, 9x20, Poly, Right Hand
Pipe Assembly, L 16, 6x20, Poly, Aspirator
Pipe Assembly, L 16, 15x20, Pp, Aspirator, Left Hand
Pipe Assembly, L 16, 15x20, Pp, Aspirator, Right Hand
Plumbing Installation Ss, 90x50, Off
Pipe Assembly, L 12, 9x50, Ss, Aspirator, Left Hand
Pipe Assembly, L 12, 9x50, Ss, Aspirator, Right Hand
Pipe Assembly, 2x90d 1.00 Inch, 15x50, Ss, Left Hand
Pipe Assembly, 2x90d 1.00 Inch, 15x50, Ss, Right Hand
Pipe Assembly, 25.4 Poly, With 2 Hose Barb, .2530mm Er
Plumbing Installation, Ss, 100 X 10, On
4359 Mm
Pipe Assembly, L 12, 23x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 12, 23x10, Ss, Aspirator, Right Hand
Plumbing Installation, Ss, 100 X 15, On
Plumbing Installation, Ss, 100 X 20, Off
Pipe Assembly, 2x90d .75hb ,12x20, Ss, Aspirator, Left Hand
Pipe Assembly, 2x90d .75hb ,12x20, Ss, Aspirator, Right Hand
Poly Plumbing Installation, 100 X 20, Off
Pipe Assembly, L 12, 12x20, Poly, Aspirator, Left Hand
Pipe Assembly, L 12, 12x20, Poly, Aspirator, Right Hand
Plumbing Installation, Ss, 100 X 50, Off
Plumbing Installation, Ss, 120 X 10, On
2530 Mm
6096 Mm
Pipe Assembly, L 16, 16x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 16x10, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 17x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 17x10, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 33x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 33x10, Ss, Aspirator, Right Hand
Pipe Assembly, 1.50 Inch, Boom Feed, 45d, Left Hand
Pipe Assembly, 1.50 Inch, Boom Feed, 45d, Right Hand
L Bracket Assembly, 1.00 Stauff
L Bracket Assembly, Long, Ips, 1.00 U Bolt
L Bracket Assembly, Extra Long, Stauff, P-Clip, 1.00u
L Bracket Assembly, Xxlong, Stauff, Long U Bolt
Z Bracket Assembly, Long, 1.00 Stauff, Ss U-Bolt
Z Bracket Assembly, Long, Upper, Ips, Long U-Bolt
Bracket Assembly, Straight, Long, Ips, P Clip, Right Hand
Bracket Assembly, Straight, Long, Ips, P Clip, Left Hand
Bracket Assembly, Straight, Long, P-Clip, 1.00 U
Bracket Assembly, Straight, 1.50, Stauff, Standard
Bracket Assembly, Straight, 1.50, Stauff, Long U Bolt
Bracket Assembly, Straight, Extra Long, 1.00 P-Clip
Plumbing Installation, Ss, 120 X 15, On
Pipe Assembly, L 16, 11x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 11x15, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 22x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 22x15, Ss, Aspirator, Right Hand
Z Bracket Assembly, Poly, Stauff, 1.00 P-Clip
Mounting Bracket Assembly, Y Manifold, 45d
Plumbing Installation, Ss 120 X 20, Off
Pipe Assembly, L 16, 6x20, Ss, Aspirator, End Row
Pipe Assembly, L 16, 8x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 8x20, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 9x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 9x20, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 16x20, Ss, Aspirator, Left Hand
Poly Plumbing Installation, 120 X 20, Off
Pipe Assembly, L 16, 8x20, Poly, Left Hand
Pipe Assembly, L 16, 16x20, Poly, Left Hand
Pipe Assembly, L 16, 16x20, Poly, Right Hand
Pipe Assembly, L 16, 9x20, Poly, Left Hand
L Bracket Assembly, Ips
Z Bracket Assembly, Long, 2xips
Plumbing Installation, Ss, 120 X 50, Off
Pipe Assembly, L 16, 6x50, Ss, Aspirator, End Row
Pipe Assembly, L 16, 8x50, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 8x50, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 17x50, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 17x50, Ss, Aspirator, Right Hand
Left Outer
Left Center
Left Inner
Boom Tree
Right Inner
Right Outer
Right Center
Pipe Assembly, L 12, 17x10, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 8x20, Poly, Right Hand
Pipe Assembly, L 16, 16x20, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 9x20, Poly, Right Hand
Endrow Nozzle And Solenoid Installation, 90 100 Foot
Endrow Nozzle And Solenoid Assembly, Left Hand
Solenoid Valve, Nozzle Body, Arag, 150 Psi
Nozzle Valve
Endrow Nozzle And Solenoid Assembly, Right Hand
120 Foot Boom
Hose Installation, Manifold, 1.00 Inch
Rotary Nozzle Body, 5 Way, 1.00 Inch, Left Hand
Service Kit, Aspirator, 1.00
2booms
Axle Assembly, Autoboom Cushion, Left Hand
Hub
Axle Assembly, Autoboom Cushion, Right Hand
Boom Assembly, 90 Foot, Left Hand
Adjustable
Boom Retainer Assembly, Non 120
Linkage Assembly, Cylinder, Hydraulic, Inner Mid
Boom Assembly, 90 Foot, Right Hand
Boom Assembly, 100 Foot, Left Hand
Boom Assembly, 100 Foot, Right Hand
Boom Assembly, 120 Foot, Left Hand
Bracket Installation, Mounting, Adjustable, Spring, Upper
Bumper Installation-Fold Back, 120, Lh
Retainer Assembly, 120 Foot Boom, Liquid System
Tip Assembly-Fold Back, Boom, 120 Foot, Left Hand
Boom Rest Installation, Fold Back, 120 Foot, Left Hand
Boom Assembly, 120 Foot, Right Hand
Bumper Installation-Fold Back, 120, Rh
Tip Assembly-Fold Back, Boom, 120 Foot, Right Hand
Boom Rest Installation, Fold Back, 120 Foot, Right Hand
Aluminium
Boom Breakaway Cam Assembly
Boomrest Installation, Domestic
Boomrest Installation, Non Domestic
Boom Tip Guard Assembly, 120 Ft
Boom Tree Installation, Center, 5.00 Slide
Boom Tree Assembly, Center, 5.00 Slide
Heavy Duty, Large
Boom Tree Assembly, Sub, 5.00 Slide
Boom Tree Installation, Center, 90 100 Foot
Boom Tree Assembly, Center, 90 100 Foot
90 100 Foot
Boom Tree Assembly, Center, 2.50 Slide
Bumper Installation, Tree Limit, 120 Foot
90 Foot
100 Foot
Heavy Duty Wear Pad Plate Assembly
Mounting Arm Assembly, Wheel, 90 100 Foot
Spring Installation, Boom Level, Small Boom
Spring Installation, Boom Level, Large Boom
Passive, 90 100
Wear Pad Assembly, Passive, 120
Wheel Installation, Autoboom, 90 100 Foot
Wheel And Axle Assembly, Cushioned, Autoboom, Left Hand
Wheel And Axle Assembly, Cushioned, Autoboom, Right Hand
Wheel Installation, Autoboom, 120
Wheel Mounting Arm Assembly, 120 Foot
Boom Assembly, 30 Inch Spacing
Boom Fold Assembly
Boom Lock Installation
Boom Suspension
Boom Pivot Installation
Boom Rack Installation
Boom Suspension Installation
Boom Suspension Cylinder Assembly
Manual
Boom 70 Ft
Outlet Tube Installation, Boom Center
2foam Marker
Boom Plumbing Installation, Foam Marker, 90 Foot, Rogator
Foam Marker Mixing Chamber, Richway
Boom Plumbing Installation, Foam Marker, 100 Foot, Rogator
Boom Plumbing Installation, Foam Marker, 120 Foot, Rogator
Foam Marker
Foam Marker Installation, Tank And Pumps
Foam Marker Assembly, Tank And Pumps
Foam Marker Tank Assembly, Air Max 180
Solenoid Valve Rework
Regulator Assembly Foam Marker
Solenoid Valve, 25npt, 12 Volt
Foam Marker Regulator Assembly
Foamer Unit Installation
Unit
Installation
2pressure Washer And Rinse System
Option
Pressure Washer Reel Assembly
Pressure Washer Assembly
Pressure Washer Plumbing Installation
No Pressure Washer Option
Pressure Washer, Air Max 180
Air Max 180
Foam Marker Presure Washer
2attachments
Raven Mount
Without Chemical Eductor
Discharge Installation, Rear
License Bracket Installation, Liquid System
Center, Small, 100 Foot
Center, Large, 100 Foot
Center, Large, 120 Foot
License Plate Bracket Installation
Door Stop Extension Installation
Cab Kit, 98 Air Max, New Cab
Multapplier, 5 Foot
Foot Mount Group
Multapplier Wiper
Feedgate, Front
Main
Endgate
Sign Installation, Slow Moving Vehicle
2accessories
Cap Installation, Combo, Liquid System
Without Product Recovery Or Cleanout
Eye Bolt Assembly
Real Time Kinematic
Field Accessories, Brake Release
Camera Adapter, Motec
Camera Monitor
Ecology Drain
Fender
Field Accessories, Fuel Water Separator
Field Accessories, Halogen, Cab Lights, Rear
Field Accessories, High Frequency Shocks
Field Accessories, Led, Cab Lights, Rear
Field Accessories, Modem Satellite
Field Accessories, Power Mirror Installation
Power Strip
Pressure Washer
Radio, Deluxe Xm
Radio, Deluxe
Radio Installation, Blue Tooth, Usb
Satellite Antenna Installation
Field Accessories, Smartrax, Raven
Hydraulic Valve Assembly, Smartrax
Viper 4
Charge Air Cooler
Field Kit, Steer Fitting Rework
Kit-Rework, Oil Fill Access
Scr
Field Accessories, 3.00 Sump Valve, Electric
Field Accessories, 4.00 Sump Valve, Electric
Catwalk Installation, Rear, Right Hand, 900
Field Accessories, Control Box, Nozzle Prostop
Field Accessories, Eductor, Poly, Cleanload
Field Accessories, Endrow, 90 100 Foot
Field Accessories, Endrow, 120 Foot
Field Accessories, Foam Marker Power Unit And Plumbing
Field Accessories, Injection Mixer, 2.00 Inch
Field Accessories, Injection Mixer, 3.00 Inch
Field Accessories, Injection Plumbing, 2 Pumps, 2 Tanks
Iso System
Field Kit, Boom Valve Relocation
Cylinder, Norac Passive
Field Kit, Main System Harness
Package Parts, Prostop-E
Dry System
Field Accessories
Calibration Kit
Chute Calibration Kit
Cartridge Clamp Hardware Group
Nl 4258g4 Edge, 409ss
Pattern Test Kit, New Leader
Srt Roll Tarp Hardware Kit
Chain Guides
Divider Group
Field Service Kits
Camera Kit
Adjusting
Density Scale
Parts Bag
Pressure Washer Tank Assembly
Premium Work Light Package
