Challenger Rogator 635D 645D 655D Parts Catalog AG645681
Brand: Challenge Rogator
Type of Machine: Applicators
Model: Challenge 635D, 645D, 655D Rogator 2016
Serial Number: ..GW001001 - ..GW001126
Part Number: AG645681
Publication Date: 2017
Number of Pages: 2429 Pages
Publication Information
Engine Fuel And Exhaust System
Engine Gp-4.9l Sisu,Rg635,St4
Engine Inst-4.9 7.4l Sisu,X28
Hose Instl-Heater,Cab,4.9l
Bracket Instl-Engine,4.9l St4
Ccv Instl-4.9l Stage4
Coupler Instl-Flex,Sae3 175_14
Dipstick Instl-4.9l St4
Engine Asm-4.9l Sisu,Rg635,4
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Intake Manifold
Turbocharger
Oil Sump And Pump
Oil Cooler And Filter
Closed Crankcase Ventilation
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electr. Engine Management
Starter Motor
Air Compressor
Aircondit. Compressor
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine Gp-7.4l Sisu,Rg645,St4
Bracket Instl-Engine,7.4l Sisu
Hose Instl-Heater,Cab,7.4l 3b
Ccv Instl-7.4l Stage 3b
Dipstick Instl-7.4l Sisu,4
Engine Asm-7.4l Sisu,Rg645,4
Engine Gp-7.4l Sisu,Rg655,St4
Engine Asm-7.4l Sisu,Rg655, St4
Gear Housing
Flywheel Housing
Valve Mechanism
Inlet- And Exhaust Manifold
Piping Of Turbo
Oil Sump
Coolant Pump
Fuel Pump
Eem4 Parts
Compressor
Scr Parts
Fuel Group-6x5c
Filter Instl-Pre,Fuel
Tank Instl-Fuel
Tank Asm-Fuel
Door Asm-Toolbox
Door-Toolbox
Fuel Line Instl-Rg6x5,My16
Filter Instl-Fuel W Sep,74awi,
Cooler Group-4.9l,Stage 4
Tank Instl-Exp And Coolant,Rg6x5
Cooler Instl-Combi,Rg6x5,St4
Cooler Asm-Combi,Rg6x5,St4
Cooler-Combi,Hydac,Rg6x5,St4
Tube Instl-Coolant,Rg635,St4
Tube Instl-Cac,Rg635,St4
Grill Instl-Cooler,Rg6x5
Grill Asm-Cooler,Rg6x5
Hose Instl-Cooler,Rg6x5
Cooler Group-Rg645 655,Stage4
Tube Instl-Coolant,Rg645 655,4
Tube Instl-Cac,Rg645 655,4
Exhaust Group-4.9l,Stage 4
Sensor Instl-Ambiant,Rg6x5
Tube Instl-Exh,Turbo Aio,49awf
Eat Instl-All In One,Rg635,St4
Tube Instl-Exhaust,Rg635,St4
Sensor Instl-Aio,49awf,St4
Insulation Instl-Rg6x5,Stage 4
Exhaust Group-7.4l,Stage 4
Sensor Instl-Aio,Stage 4
Tube Instl-Exhaust,Stage 4
Tube Instl-Exh,Turbo Aio,74awf
Eat Instl-All In One,Rg6x5,St4
Sensor Instl-Turbo 74 Aio,St4
Def System Gp-6x5c,Stage4
Tank Instl-Def
Tank Asm-Def
Dosing Module Instl-Def,Stage4
Pump Instl-Dosage,T4f,Rg,Gen2
Hose Instl-Def,Rg,Stage4
Hose Instl-Coolant Def,Rg,St4
Air Intake Group-4.9l,Stage4
Filter Instl-Air,7.4l,Stage4
Filter Asm-Air,7.4l,Stage4
Filter-Air,7.4l
Tube Instl-Filter,7.4l,Top
Tube Instl-Filter,4.9l,Turbo
Hose Instl-Filter,Air,4.9l T4f
Air Intake Group-7.4l,Stage 4
Tube Instl-Filter,7.4l,Turbo
Hose Instl-Filter,Air,7.4l 4
Axle Gp-60cc Motor,Rg6x5,My16
Axle Instl,Bracket,6x5
Cover Instl-Wheelarm,Rg6x5
Wheelarm Instl-60cc,Rg6x5
Gearbox Asm-Hydr Mtr,Lt
Gearbox-Wheel,Gft13
Motor-Hyd,60cc
Plate Instl-Sprt,Hoses,Hydr
Sensor Instl-Axle,Std,Rg6x5,My
Sensor-Angle,0 90
Suspension Instl-Std,Rg6x5
Suspension Asm-Wheel,Lf Rr
Corner Module Lf Rr,My16
Service Kit-Bearing
Pin Bearing Asm-Beam
Service Kit-Pin,Steering
Suspension Asm-Wheel,Rf Lr
Corner Module Rf Lr,My16
Cilinder Instl-Steer,Rg6x5
Cilinder Asm-Steer,Front
Valve Asm-Steer,Cil,Front
Cylinder-Hyd,D80 36 236 535mm
Cilinder Asm-Steer,Rear
Valve Asm-Steer,Cil,Rear
Tube Instl-Hyd.Drive,60cc
Cylinder Instl-Spnsn,Rg6x5
Cylinder Asm-Spnsn.Front
Cylinder-Hyd,D90 75 410 695mm
Cylinder Asm-Spnsn,Rear
Sensor-Angle,0 90
Axle Gp-85cc Motor,Rg6x5,My16
Wheelarm Instl-85cc,Rg6x5
Gearbox Asm-Hydr Mtr,Whl,Hvy
Gearbox-Wheel,Gft17
Motor-Hyd,85cc
Tube Instl-Hyd,Drive,85cc
Track Width Instl,1.80 Rg6x5c
Plug Instl-Hyd,Blind,Tubing Sa
Track Instl, 1.80 Rg6x5b
Cover-Axle,Fixed,Rg600b
Block Hyd Inst,Chas,Excl Sa,20
Block Asm-Hyd,Chas,Excl Sa,My16
Block-Hyd,Chas,Excl Sa,My16
Tube Instl-Hyd,Chasblk,Ecxl Sa
Track Width Instl,1.83 Rg6x5c
Track Instl, 1.83 Rg6xb
Track Width Instl,2.00 Rg6x5c
Track Instl, 2.00 Rg6xb
Track Width Instl-2.00m,480
Track Instl-2.00m,480
Track Instl-2.00,520
Track Width Instl,2.03 Rg6x5c
Track Instl, 2.03 Rg6xb
Track Width Instl,2.25 Rg6x5c
Track Instl, 2.25 Rg6xb
Track Width Instl-2.25,480
Track Instl-2.25m,480
Track Width Instl-2.25,520
Track Instl-2.25m,520
Axle Instl-Hydr Adj,Rg6x5,My16
Axle Instl-Hydr Adj,6x5
Cylinder-Hyd,D63 36 460 670mm
Kit-Hydraulic,Adjustment
Tube Instl-Hyd,Chasblk, Incl S
Hose Instl-Sliding,Axle
Block Hyd Inst,Chas,Incl Sa,20
Block-Hyd,Chas,Incl,Sa,2014
Block-Asm,Hyd,Chas,Sl Axle,201
Block-Hyd,Chas,Sl Axle,2014
Frame And Suspension
Chassis Instl-Rg6x5,My16
Plate Bottom-Instl,Rg600b
Bottom Plate-Instl,Bracket
Support Instl-Wheelcover
Plate Instl-Cover,Engine
Box Instl-Battery,Rg6x5
Support Instl-Front,Tank
Cap Instl-Tube,Chassis
Support Instl-Cab,Rear
Instl-Orbitrol,Ospef,315cc
Orbitrol Asm-Ospef,315cc
Emergency Steer,6x5
Instl-Harness,Esteer,6x5
Pressure Valve,Emer Control
Instl-Esteer,Relay,6x5
Instl-Harness,Esteer,6x5b
Instl-Brake Valve,Pedal,Rg,My1
Pedale-Brake,Vision,Rg
Air System
Air System Group-Std,Rg6x5
Instl-Harness,Airdryer,6x5
Hose Instl-Air,Comp Dryer
Tube Instl-Air,Comp Dryer,Rg6x
Component Instl-Air Sys,Std
Component Asm-Air Sys,Standard
Tank Instl-Air,30l,Rg6x5
Tank Asm-Air,30l
Tank Instl-Air,Regen,Rg6x5
Tank Asm-Air, Regeneration
Dryer Instl-Air,Sgl Cstr,Rg6x5
Dryer Asm-Air,Sgl Canister
Dryer-Air,Sgl Canister,12v
Instl Reeler-Hose,Air
Pistol Blow Asm
Tire Pressure Gauge Asm,X28
Instl Air-Tool Kit,Chassis
Drive Sys Group-145cc Pump
Drive Sys Instl-145cc Pump
Pump Asm-Hyd,Ls,63cc
Pump-Hyd,63cc,Ls,Workhyd Rgx28
Pump Asm-Hyd,Ls,45cc
Pump-Hyd,45cc,Sprayhyd Rgx28
Pump Asm-Hyd,145cc,Hd,A4vg
Pump-Hyd,145cc-Hd,A4vg
Hose Instl-Hd Pump,175cc
Hose Instl-Hd Pump,G Conn
Hose Instl-Suct,Pump 145cc
Drive Sys Group-175cc Pump
Hose Suct Instl,Pump 180cc
Drive Sys Instl-175cc Pump
Pump Asm-Hyd,175cc,Hd,A4vg
Pump-Hyd,175cc-Hd,A4vg
Mli Hydraulic Gp-6x5, My16
Tube Gp-Hyd,Sliding Axle,Chas
Adapter Instl-Hyd,Bulkh,Sl Axl
Tube Instl-Hyd,Sliding Axle
Tube Instl-Hyd,Chas Funct Rear
Tube Asm-Hyd,Chas Funct Rear
Tube Instl-Hyd,Hitch
Adapter Instl-Hyd, Bulkhead,Ch
Manifold Instl-Suct Return,Oil
Manifold Asm-Suct Return,Oil
Hose Instl,80cc Axle.Rr.Rh
Manifold Instl-Dr Sys Chas,Rr
Manifold Asm-Chassis Funct,Rr
Manifold Asm-Switching Chas,Rr
Block-Hyd,Spnsn,Rr Axle,Rg6x5
Manifold Asm-Drive Sys,Rear
Valve Inst-Charge,Rg,My16
Valve-Asm,Charge,Rg,My16
Valve-Charge,Rg,My16
Manifold Instl-Dr Sys Chas,Fr
Manifold Asm-Drive Sys Chas,Fr
Manifold Asm-Funct,Fr,2013
Manifold Asm-Drive Sys,Fr,My15
Tube Instl-Hyd,Steering Brake,
Tube Asm-Hyd,Steering Brake,My
Tube Instl-Suction,Hyd,Rg6x5
Hose Instl-Chassis,Rg6x5,My16
Hose Instl,Hitchcylinder,Rg
Hose Instl,Pump Ls-System,Rg
Hose Instl-Steering System
Hose Instl-Drive,Rg6x5
Hose Instl-Drive,Lf
Hose Instl-Drive,Rf
Hose Instl-Drive,Lr
Hose Instl-Drive,Rr
Tube Instl-Hyd,P Boomblock
Hose Instl-Suspension,Front
Hose Instl-Suspension,Rear
Hose Instl-P T,Block,Boom
Hose Instl-Orbitrol,Rg6x5
Hose Inst-Pedal,Brake
Hose Instl-Manifold,Fr
Hose Instl-Brake,Rg6x5
Hose Instl-Fandrive
Hose Instl-Oilcooler
Hose Instl-Spraypump
Valve-Sequence
Tube Instl-Hyd,Drive Sys,Rg6x5
Tube Instl-Hyd,P Ls Brake Strg
Cylinder-Hyd,Dz80 45-465-665
Cylinder,Balance Damper
Cylinder-Hyd,Dz70 36-240-485
Cylinder-Hydr,D40 80 375,My15
Cylinder-Asm,Hyd,D30 50 450mm
Elec-Group,Chassis,6x5
Instl-Battery,6x5
Instl-Harness,Chassis,6x5
Instl-Elec,Comp,Chas,6x5
Instl-Cable,Battery,6x5
Camera Gp-Backup Nozzle,6x5d
Camera Gp-Drawbar,6x5d
Roadlight Gp-Eu Traffic,6x5d
Light Unit-Rear,Lh,Rg6x5
Light Unit-Rear,Rh,Rg6x5
Roadlight Gp-Uk Traffic,6x5d
Elec Gp-Centerframe,Pommier
Instl Elec-Components,Cf
Instl-Harness,Cf
Instl-Lights,Nozzle,2
Instl-Lights,Nozzle,4
Instl-Wl,Oper Stat,Std,Hal
Instl-Wl,Boomrest,Hal,6x5
Work Light Instl,Rear Cntrfr
Light-Work,Led,Cab,Boomrest
Light-Work,Led,Nozzle,2
Light-Work,Led,Nozzle,4
Beacon Gp-Boom System,My15 16
Cab Gp-6x5d
Plate Instl-Cover,Cab,Bottom
V Cab
Front
Cab Mounting
Vision Cab
Adjusting
Mount
Suspension Seat
Steering Column Assembly
Armrest Rg600 Global
Mli Instl-Radio,Dresden230bt
Instl-Display,2nd,Nt01
Antenna Gp-Novatel,Meter
Antenna Gp-Novatel,Centimeter
Instl-Rtk,Radio,Satel
Instl-Ntrip,Antenna
A C Group-Rg6x5
Filter Instl-A C,Rg6x5
Hose Instl-A C,Rg6x5
Receiver-Dehydrator
Hvac Group
Hvac
Apperance Group-6x5c
Instl Hood-Engine,Rg600b
Cover-Asm,Dipstick,Rg600b
Cover Instl-Middle,Bumper
Cover-Bumper,Middle,Section
Cover Instl-Lh,Rh,Bumper
Cover-Bumper,Rh
Cover-Bumper,Lh
Cover-Instl,Wheelhouse,Rg600
Cover-Instl,Wheelhouse,Back
Cover-Instl,Wheelhouse,Front
Cover Instl-Cooler,X28,T4
Storagebox Instl-Cab
Storage Box-Group
Stairs With Storage Box Instl
Box Compl Asm-Chemicals
Rail Asm-Box
Kit-Profile-Aluminium,995mm
Box Asm-Chemicals
Ladder Asm
Box-Storage,Chemicals
Cover Upr,Storage Box Instl
Fender Instl-2.55m,Rg6x5,My16
Fender-Instl,2.55m,Rr,Rh
Fender-Instl,2.55m,Rr,Lh
Support Instl-Fenders,Front
Fenders-Instl. 2.55m,Fr,Lh,My1
Fenders-Instl. 2.55m,Fr,Rh,My1
Fender Instl-3.00m,Rg6x5,My16
Fender-Instl,3.00m,Rr,Lh
Fender-Instl,3.00m,Rr,Rh
Fender-Instl. 3.00m,Fr,Lh,My16
Fender-Instl. 3.00m,Fr,Rh,My16
Decals-Trade Dress Chal 6x5
Decal Instl-Tank, Rg 6x5
Decal Asm-Tank Striping,Rg,Lh
Decal Asm-Tank Striping,Rg,Rh
Decal Instl-Roof,Rg635d
Decal Instl-Roof,Rg645d
Decal Instl-Roof,Rg655d
Decals-Safety,Rg600d,My16
Wheel Instl-320 105r46,166d,35
Rimandtire-320 105r46,Lh
Rimandtire-320 105r46,Rh
Wheel Instl-380 90r54,178a8,35
Rimandtire-380 90r54,Rh
Rimandtire-380 90r46,Lh
Wheel,Instl-380 90r46,173d
Rimandtire-380 90r46,Rh
Wheel Instl-480 80r50,2.40mtr
Rimandtire-480 80r50,Lh
Rimandtire-480 80r50,Rh
Wheel Instl-480 80r50,166d,354
Wheel Instl-520 85r46,173a8,38
Rimandtire-520 85r46,Rh
Rimandtire-520 85r46,Lh
Wheel,Instl-620 70r42,160d
Rimandtire-620 70r42,Rh
Rimandtire-620 70r42,Lh
Wheel Instl-620 75r34,170a8
Rimandtire-620 75r34,Lh
Rimandtire-620 75r34,Rh
Wheel Instl-710 75r34,178a8
Rimandtire-710 75r34,Lh
Rimandtire-710 75r34,Rh
Cover-Wheelnut Instl,Rg600
Product Containment
Tank Instl-3800l,Rg6x5x
Seal Asm,Section Clamp,Lip
Agitation-Instl,Tank,Rg6x5b
Rinse Instl-Tank
Rinse Asm-Tank
Bulkhead Instl-Tank
Bulkhead Asm-Tank
Tank Instl-5000l,Rg6x5x
Tank Instl-6000l,Rg6x5x
Lock Up Instl-6000l Tank,Rg6x5
Support Instl-Reinf,Tank
Indicator Instl-Level,Rg6x5
Tank Inst-Fresh 6x5
Level-Indicator Tank-Inst 6x5
Primary Product Distribution
Pump Instl-Spray
Pump Instl-Spray Sys,Rpm
Pump-Cntfgl,3.00x2.00,9306c,Rpm
Panel-Control,Spraypack,X28
Instl-Harn,Spraypack
Pump Instl-Spray Sys,Ss,Rpm
Pump-Cntfgl,3.00x2.00,9306c,Ss,Rpm
Valve Instl-5-Way,Manual,Rg6x5
Valve-5-Way,2in
Kit-Seal,2in Polmac 5-Way Vlv
Valve Instl-5-Way,Electric,Rg6
Valve Asm-5-Way,2in,12v-80w
Valve Instl-5-Way,Elec,Ss Ball
Valve Asm-5-Way,Ss,2in,12v-80w
Plumbing Instl-2 In. ,Suct,Rg6x5
Valve Asm-Electric,2 In. Fp,Uf,12v
Plumbing Instl-3 In. ,Suct,Rg6x5
Plumbing Instl-Press,3 In. ,Rg6x5
Valve-Elec,Reg,2.0flgx1.5barb
Strainer-Y,2.00fp Flg,W 80mesh
Flowmeter Asm-Std Flow,Rg6x5
Flowmeter-1.5 In. ,10-350 L Min
Plumbing Instl-Reload,2 In. ,Rg6x5
Vlv-Sh,2.00fp Flg X M Qdc,Pp
Adapter Asm-Camlock,45deg,2in
Plumbing Instl-Reload,3 In. ,Rg6x5
Adapter Asm-Camlock,45deg,3in
Valve-3 In. Flg Stby,Short
Strainer Instl-Suc,3 In. 12mesh
Strainer-Manifold,3in,12mesh
Tube Instl-Reload,3in,Rg6x5
Adapter Instl-Self Priming
Filling Instl-Quick,Gp
Adapter-Camlock,3 In. Fe-2 In. Ma
Valve Instl-Tranfer,X28
Cap Instl-Transfer
Eductor Instl-Chem,Rg6x5
Nozzle-Asm Rinse,Bottle
Handgun Opt-Chem Eductor,Rg6x5
Autofill Instl-Ecomatic.My16
Valve Asm-Elec,2 In. Fp,3-Way,12v
Flowmeter-1.00 In. Uf,3-20l Min
Hose Suction Instl,2 In. ,Rg6x5,My
Hose Suction Asm,2 In. ,Rg6x5,My16
Filter-Open Water,Suct Hose,2 In.
Hose Suction Instl,3 In. ,Rg6x5,My
Hose Suction Asm,3 In. ,Rg6x5,My16
Filter-Open Water,Suct Hose,3 In.
1secondary Product Distribution
Plumbing Instl 12 24m,Rg6x5
Tube Middle Section Instl,Rg6x
Hose Instl Plumbing,Centraleframe
Guide Instl-Hose,Bm Fold
Support Instl-Boom,12 24m
Asm-Supports,12 24m
Asm-Support,12 24m
Boomstop Instl,Rg6x5
Plumbing Instl 18 24m,Rg6x5
Strip Instl-Slide,Bmrest
Plumbing Instl 18 27m,Rg6x5
Plumbing Instl 27 15m,Rg6x5
Plumbing Instl 18 28m,Rg6x5
Plumbing Instl 28 15m,Rg6x5
Plumbing Instl 18 30m,Rg6x5
Plumbing Instl 30 15m,Rg6x5
Plumbing Instl 18 32m,Rg6x5
Plumbing Instl 18 33m,Rg6x5
Plumbing Instl 18 36m,Rg6x5
Nozzle Instl-5way,Rtry,48x500
Nozzle-Body,5-Way,Airstop
Nozzle Instl-Multi2,Rtry,48x50
Body-Nozzle,Multiselect2,25mm
Clamp-Nozzle Body,Altek,25mm
Nozzle Instl-5way,Rtry,54x500
Nozzle Instl-Multi2,Rtry,54x50
Nozzle Instl-5way,Rtry,56x500
Nozzle Instl-Multi2,Rtry,56x50
Nozzle Instl-5way,Rtry,60x500
Nozzle Instl-Multi2,Rtry,60x50
E-Nozzle,5-Way,30 18m
Instl-Arag,Common
Instl-Arag,Cables,30 18m
Instl-Arag,Nozzle,Single,60
Seletron-Single,5way
Instl-Plug,Airtank
E-Nozzle,5-Way,30 15m
Instl-Arag,Cables,36 18m
Nozzle Instl-5way,Rtry,64x500
Nozzle Instl-Multi2,Rtry,64x50
Nozzle Instl-5way,Rtry,66x500
Nozzle Instl-Multi2,Rtry,66x50
E-Nozzle,5-Way,33 18m
Instl-Arag,Cables,33 18m
Nozzle Instl-5way,Rtry,72x500
Nozzle Instl-Multi2,Rtry,72x50
E-Nozzle,5-Way,36 18m
Instl-Arag,Nozzle,Single,72
Valve Section-Instl,6x1
Instl-Elec,Section 6 1
Hose Instl-Valve,Sectie
Valve Section-Asm
Intake Manifold
Turbocharger
Oil Sump And Pump
Fuel Filters
Starter Motor
Air Compressor
Gear Housing
Flywheel Housing
Valve Mechanism
Piping Of Turbo
Oil Sump
Coolant Pump
Fuel Pump
Eem4 Parts
Compressor
Scr Parts
Fuel Group-6x5c
Tank Instl-Fuel
Tank Asm-Fuel
Door Asm-Toolbox
Door-Toolbox
Tank Instl-Def
Tank Asm-Def
Filter-Air,7.4l
Gearbox-Wheel,Gft13
Motor-Hyd,60cc
Sensor-Angle,0 90
Service Kit-Bearing
Sensor-Angle,0 90
Gearbox-Wheel,Gft17
Motor-Hyd,85cc
Emergency Steer,6x5
Air System
Tank Asm-Air,30l
Pistol Blow Asm
Hose Instl-Drive,Lf
Hose Instl-Drive,Rf
Hose Instl-Drive,Lr
Hose Instl-Drive,Rr
Hose Instl-Fandrive
Valve-Sequence
Instl-Battery,6x5
Instl-Harness,Cf
Cab Gp-6x5d
V Cab
Front
Cab Mounting
Vision Cab
Adjusting
Mount
Suspension Seat
Instl-Ntrip,Antenna
A C Group-Rg6x5
Receiver-Dehydrator
Hvac Group
Hvac
Cover-Bumper,Rh
Cover-Bumper,Lh
Storage Box-Group
Rail Asm-Box
Box Asm-Chemicals
Ladder Asm
Product Containment
Rinse Instl-Tank
Rinse Asm-Tank
Bulkhead Instl-Tank
Bulkhead Asm-Tank
Tank Inst-Fresh 6x5
Pump Instl-Spray
Valve-5-Way,2in
Cap Instl-Transfer
Asm-Supports,12 24m
Asm-Support,12 24m
Instl-Arag,Common
Instl-Plug,Airtank
Valve Section-Asm
