Challenger Rogator 635B 645B 655B Parts Catalog AG639423
Brand: Challenge Rogator
Type of Machine: Applicators
Model: Challenge 635B, 645B, 655B Rogator 2012-2
Serial Number: ..CW001038 - ..CW001077
Part Number: AG639423
Publication Date: 2016
Number of Pages: 2080 Pages
Publication Information
Engine Gp-4.9l Sisu,Rg635,W Ai
Engine Inst-4.9 7.4l Sisu,X28
Coupler Instl-Flex,Sae3 140cc
Engine Asm-4.9l Sisu,Rg635
Bracket Instl-Engine,4.9l Sisu
Hose Instl-Heater,Cab,4.9l
Dipstick Instl-4.9l Sisu,2
Compressor Instl-4.9l 4v Sisu
Cylinderblock
Gear Housing
Flywheel Housing
Valve Machanism
Inlet- And Exhaust Manifold
Piping Of Turbo
Oil Sump
Coolant Pump
Fuel Pump
Eem3 Parts
Starter Motor
Engine Overhaul Parts
Oil Filter
Balancer Weight
Engine Gp-7.4l Sisu,Rg645,W A,
Bracket Instl-Engine,7.4l Sisu
Hose Instl-Heater,Cab,7.4l 3b
Dipstick Instl-7.4l Sisu,3b,2
Engine Asm-7.4l Sisu,Rg645,3b
Ccv Instl-7.4l Stage 3b
Valve Mechanism
Cilinder Head
Crankcase Ventilation
Eem4 Parts
Compressor
Scr Parts
Engine Gp-7.4l Sisu,Rg655,W A,
Coupler Instl-Flex,Sae3 180cc
Engine Asm-7.4l Sisu,Rg655,3b
Fuel Group-Rg6x5
Tank Instl-Fuel,65gl,Rg6x5
Tank Asm-Fuel,65gl,Rg6x5
Cap Instl-Fuel,Lockable
Fuel Line Instl-Rg6x5
Filter Instl-Pre,Fuel
Biodiesel Group,Rg6x5,Stage 3a
Fuel Group-Rg6x5,Stage 3b
Filter Instl-Fuel W Sep,74awi,
Cooler Group-Rg635
Fan Instl-Dia 715mm,Rg6x5
Fan Asm-Dia 715mm,Rg6x5
Tank Instl-Exp And Coolant,Rg6x5
Cooler Instl-Combi,Haugg,Rg6x5
Cooler Asm-Combi,Haugg,Rg6x5
Hose Instl-Cooler,Rg6x5
Tube Instl-Coolant,Rg635
Tube Instl-Cac,Rg635
Grill Instl-Cooler,Rg6x5
Grill Asm-Cooler,Rg6x5
Cooler Group-Rg645 655,Stage3b
Tube Instl-Coolant,Rg645 655
Tube Instl-Cac,Rg645 655
Cooler Instl-Fuel,Rg6x5
Exhaust Gp-4.9l
Tube Instl-Exhaust,Middle,7.4l
Muffler Instl-Exhaust,Rg6x5
Tube Instl-Exhaust,Engine,4.9l
Exhaust Group-7.4l,Stage 3b
Sensor Instl-Doc Scr,Stage 3b
Tube Instl-Exhaust,Stage 3b
Tube Instl-Exh,Turbo Doc,74awi
Eat Instl-Doc Scr,Rg6x5
Eat Asm-Doc Scr,Rg6x5
Sensor Instl-Ambiant,Rg6x5
Insulation Instl-Rg6x5,Stage 3
Sensor Instl-Turbo 74 Doc,3b
Air Intake Group-4.9l
Filter Instl-Air,7.4l
Filter Asm-Air,7.4l
Filter-Air,7.4l
Tube Instl-Filter,Air,7.4l
Bracket-Support,Air Intake,X28
Tube Instl-Filter,Air,4.9l
Hose Instl-Filter,Air,4.9l
Air Intake Group-7.4l,Stage 3b
Hose Instl-Filter,Air,7.4l 3b
Tube Instl-Filter,Air,7.4l 3b
Def System Group-Rg6x5,3b
Dosing Module Instl-Def,Tg
Pump Instl-Dosage,Def,Tg
Hose Instl-Def,Rg
Hose Instl-Coolant Def,Rg
Tank Instl-Def,42l
Tank Asm-Def,42l,Compl
Tank Asm-Def,42l,Elkamet
Light-Flash,Rg600
Axle Gp-55cc Motor,6x5
Suspension Instl-Axle,Std,6x5
Wheel Suspension Lf Rr
Corner Module Lf Rr
Service Kit-Bearing
Pin Bearing Asm-Beam
Service Kit-Pin,Steering
Wheel Suspension Rf
Corner Module Rf
Ring Asm-Mtg,Sensor,Ag
Wheel Suspension Lr
Corner Module Lr
Cover Plate Instl-6x5
Axle Instl,Bracket,6x5
Leg Instl-Wheel,Light
Gearbox Asm-Hyd Mtr,Whl,Lt
Motor-Hyd,55cc
Gearbox-Wheel,Gft13
Steering Cilinder Instl-6x5
Cilinder Asm-Steer,Front
Cylinder-Hyd,D80 36 236 535mm
Cylinder Instl-Spnsn,Rg6x5
Cylinder Asm-Spnsn,Front
Cylinder-Hyd,D90 75 410 695mm
Cylinder Asm-Spnsn,Rear
Hose-Instl,55cc Axle Gp,Rg6x5
Hose-Instl,55cc Axle,Rear Righ
Hose-Instl,55cc Axle,Rear Left
Hose-Instl,55cc Axle,Front Lef
Hose-Instl,55cc Axle,Front Rig
Axle Instl-Hydr Adj,6x5
Block Instl-Hyd,Chas,Incl Sa
Block Asm-Hyd,Chas,Incl Sa
Tube Instl-Hyd,Chasblk, Incl S
Tube Inslt-Hyd,Chasblk,Ecxl Sa
Cylinder-Hyd,D63 36 460 670mm
Kit-Hydraulic,Adjustment
Hose Instl-Sliding,Axle
Instl-Switch,Trackadjust,6x5
Track Width Instl,1.80 Rg6x5b
Block Instl-Hyd,Chas,Excl Sa
Block Asm-Hyd,Chas,Excl Sa
Plug Instl-Hyd,Blind,Tubing Sa
Track Instl, 1.80 Rg6x5b
Cover-Axle,Fixed,Rg600b
Leg Instl-Wheel,Heavy
Gearbox Asm-Hyd Mtr,Whl,Hvy
Gearbox-Wheel,Gft17
Motor-Hyd,80cc
Track Width Instl,1.83 Rg6x5b
Track Instl, 1.83 Rg6xb
Track Width Instl,2.00 Rg6x5b
Track Instl, 2.00 Rg6xb
Track Width Instl,2.03 Rg6x5b
Track Instl, 2.03 Rg6xb
Track Width Instl,2.25 Rg6x5b
Track Instl, 2.25 Rg6xb
Frame And Suspension
Chassis Instl-Rg6x5
Stairs Instl-Main
Plate Bottom-Instl,Rg600b
Bottom Plate-Instl,Bracket
Support Instl-Chassis,Cab,Tank
Support Instl-Wheelcover
Accessory Instl-Platf,Chassis
Cover Asm-Plate,Platform
Box Instl-Battery,Rg6x5
Plate Instl-Cover,Engine
Cilinder Asm-Steer,Rear
Overcenter-Device,Steer,Rear
Orbitrol Instl-Lagc320,Rg6x5
Orbitrol Asm-Lagc320,Rg6x5
Valve Instl-Brake,Rg6x5b
Valve Asm-Brake,Safim
Valve Asm-Brake,Safim,Rg6x5
Valve Asm-Brake,Safim,Adapters
Instl-Pedal,Brake,X28
Adjustment-Pedal,Brake,X28
Air System
Air System Group-Std,Rg6x5
Instl-Harness,Airdryer,6x5
Hose Instl-Air,Comp Dryer
Tube Instl-Air,Comp Dryer,Rg6x
Component Instl-Air Sys,Std
Component Asm-Air Sys,Standard
Tank Instl-Air,30l,Rg6x5
Tank Asm-Air,30l
Tank Instl-Air,Regen,Rg6x5
Tank Asm-Air, Regeneration
Dryer Instl-Air,Sgl Cstr,Rg6x5
Dryer Asm-Air,Sgl Canister
Dryer-Air,Sgl Canister,12v
Valve-Air,Spray Boom,X28
Valve-Air,15mm,5 2
Tube Instl-Hyd,Steering Brake
Tube Asm-Hyd,Steering Brake
Instl-Tube-Hyd,Prt2,Pb_Brake
Asm-Tube-Hyd,Prt2,Pb_Brake
Mli Dr System Instl-140cc Pump
Drive System Instl-140cc Pump
Pump Asm-Hyd,Ls,63cc
Pump-Hyd,63cc,Ls,Workhyd Rgx28
Pump Asm-Hyd,Hd,140cc
Pump-Hyd,140cc,Hd,Drivepump Rg
Pump Asm-Hyd,Ls,45cc
Pump-Hyd,45cc,Sprayhyd Rgx28
Hose Instl,Hd-Pump,140cc,Rg6x5
Hose Instl,Drive Syst,Acc
Mli Dr System Instl-180cc Pump
Drive System Instl-180cc Pump
Pump Asm-Hyd,Hd,180cc
Pump-Hyd,180cc,Hd,Drivepump Rg
Hose Instl,Hd-Pump,180cc,Rg6x5
Axle Gp-80cc Motor,6x5
Hose-Instl,80cc Axle Gp,Rg6x5
Hose-Instl,80ccaxle, Front Rig
Hose-Instl,80ccaxle, Rear Righ
Hose-Instl,80ccaxle, Rear Left
Hose-Instl,80ccaxle, Front Lef
Hydraulic Group-Rg6x5
Manifold Instl-Dr Sys Chas,Fr
Manifold Asm-Drive Sys Chas,Fr
Manifold Asm-Drive Sys,Front
Manifold Asm-Chassis Funct,Fr
Valve Bal Dbl Act Asm,3 8bsp
Manifold Instl-Dr Sys Chas,Rr
Manifold Asm-Drive Sys Chas,Rr
Manifold Asm-Drive Sys,Rear
Manifold Asm-Switching Chas,Rr
Manifold Instl-Suct Return,Oil
Manifold Asm-Suct Return,Oil
Tube Instl-Hyd,Drive Sys, Rg6x
Tube Gp-Hyd,Sliding Axle,Chas
Adapter Instl-Hyd,Bulkh,Sl Axl
Tube Instl-Hyd,Sliding Axle
Tube Instl-Hyd,P Ls Brake Strg
Tube Instl-Hyd,Chas Funct Fr
Tube Instl-Hyd,Chas Funct Rear
Tube Asm-Hyd,Chas Funct Rear
Tube Instl-Hyd,Hitch
Accumulator Instl-Drive System
Accumulator Asm-Drive System
Adapter Instl-Hyd, Bulkhead,Ch
Hose Instl,Chassis,Rg6x5
Hose Instl,Orbitrol,Rg6x5
Hose Instl,Balance Valve
Hose Instl,Pump Ls-System,Rg
Hose Instl Fandrive
Hose Instl Oilcooler
Hose Instl Steering System
Hose Instl Manifold
Hose Instl Suspension,Front
Hose Instl Brake
Hose Instl Suspension Rear
Tank Instl-Hyd,Rg6x5b
Tank Asm-Hyd,Rg6x5,My12
Cap-Hyd Tank,Breather,Argo
Valveblock Uc4,Norac Instl
Valveblock-Asm,Uc4,Cc Ls,Norac
Hydraulic Block Instl,Pommier
Block Hyd Ctr Asm,My2012,Rg6x5
Central Block Hyd,Rg6x5
Block Hyd Asm,3fold Pommier
Block Hyd,3 Fold, Pommier,Lh
Hose Instl,Boom Blocks,Standar
Hose Instl,Balance Lockcyl,Rg
Hose Instl,Press Retour,Rg
Hose Instl,Hitchcylinder,Rg
Hose Instl,Folding Booms
Hose Instl,Second Folding Boom
Hose Instl,Tiltcylinder
Hose Instl,Boom Block,Norac
Hydr.Grp,Folded Boom,No Norac
Cylinder-Hyd,D36 70 265 460mm
Cylinder-Hyd,D90 45 465 665mm
Hydr.Grp,2prt,Folded Boom
Hydraulic Block Instl,Chafer
Block Hyd Asm,3 Fold Chafer
Block Hyd,2 Fold,Chafer.Lh
Hydr.Grp,3prt,Folded Boom
Hydr Block Instl,Chafer 3fold
Block Hyd Asm,4 Fold,Chafer
Block Hyd,3 Fold, Chafer,Lh
Hose Instl,3prt,Folding,Chafer
Cylinder-Hyd,D40 80 375 735mm
Cylinder-Hyd,D80 45 465 665mm
Service Parts Hydraulic Seals
Elec-Group,Chassis,6x5b
Instl-Battery,6x5
Instl-Harn,Roof,6x5
Instl-Cable,Battery,6x5
Instl-Elec,Harness,Chas,635b
Instl-Comp,Elec,Chas,635b
Elec-Group,Chassis,645 655b
Instl-Elec,Harness,Chas,645 65
Instl-Comp,Elec,Chas,645 655b
Road Lights-Eu Traffic,6x5b
Light Instl-Eu,Rg6x5b
Light Instl-Common,Rg6x5b
Light Unit-Rear,Lh,Rg6x5
Light Unit-Rear,Rh,Rg6x5
Road Lights-Uk Traffic,6x5b
Light Instl-Uk,Rg6x5b
Instl-Wl,Side,Hal,6x5
Electrical Group-Chafer,Single
Connector-Plug,6p,Plug,Dt
Electrical Group-Chafer,Twin H
Instl-Elec,Section,6 1
Instl-Elec,Section,7 1
Instl-Elec,Section,8 1
Instl-Elec,Section,9 1
Instl-Elec,Section,10 1
Instl-Elec,Section,6 2
Instl-Elec,Section,7 2
Instl-Elec,Section,8 2
Instl-Elec,Section,9 2
Instl-Elec,Section,10 2
Beacon-Gp,Roof,Center,6x5
Beacon Gp-Boom,Sys,My2012,Rg
Instl-Harness,Endrow,6x5
Instl-Switch,Endrows,6x5
Instl Harness-Cntr Frame,6x5b
Instl-Cab,6x5b
Instl-Bracket,Topdock,Rg600
Cover Instl,Cab,Rg6x5
Door-Asm,Cabinet,Cab,Lh
Door-Asm,Cabinet,Cab,Rh
Cover-Asm,Cabinet,Cab,Rh
Rail Instl-Cab,Hand Foot
Rail Asm-Cab,Left,Foot
Asm-Cab,6x5b
Visor Gp -Cab ((Front) )
Instl-Pedal,Throttle,6x5
Instl-Roof,Cab,6x5
Keys-Included,Cab,6x5
Switch Instl-Rkr,On-Off-On,As
Instl-Duct,Cab,6x5b
Instl-Elec,Cab,6x5b,Base
Instl-Trim,Cab,6x5b
Gauge,Cabin-Pressure
Instl-Antenna,Radio,Rg6x5
Antenna-Radio,Blaupunkt,Deutsc
Asm Cab-6x5b,Base
Speaker Gp-Radio
Cab Asm-6x5,Crenlo
Glass-Windshield,Rg6x5
Door Gp
Door Latch As.
Handle As.-Interior
Mount Asm
Mount Asm-Latch
Instl-Roof,6x5,Cab,Base
Roof As.-Inner
Instl-Wiper,6x5,Cab,Base
Instl-Floormat,Cab,6x5
Instl-Duct,Cab,6x5b,Base
Lamp Gp-Porch
Dome
Liner Gp-Operator Compartment
Console Gp
Control Gp-Mtg And Steering
Cylinderblock
Gear Housing
Flywheel Housing
Valve Machanism
Piping Of Turbo
Oil Sump
Coolant Pump
Fuel Pump
Eem3 Parts
Starter Motor
Oil Filter
Balancer Weight
Valve Mechanism
Cilinder Head
Eem4 Parts
Compressor
Scr Parts
Fuel Group-Rg6x5
Cooler Group-Rg635
Exhaust Gp-4.9l
Filter Asm-Air,7.4l
Filter-Air,7.4l
Hose Instl-Def,Rg
Tank Instl-Def,42l
Light-Flash,Rg600
Corner Module Lf Rr
Service Kit-Bearing
Wheel Suspension Rf
Corner Module Rf
Wheel Suspension Lr
Corner Module Lr
Motor-Hyd,55cc
Gearbox-Wheel,Gft13
Gearbox-Wheel,Gft17
Motor-Hyd,80cc
Chassis Instl-Rg6x5
Stairs Instl-Main
Air System
Tank Asm-Air,30l
Valve-Air,15mm,5 2
Hose Instl Fandrive
Hose Instl Manifold
Hose Instl Brake
Instl-Battery,6x5
Instl-Harn,Roof,6x5
Instl-Cab,6x5b
Asm-Cab,6x5b
Instl-Roof,Cab,6x5
Instl-Duct,Cab,6x5b
Instl-Trim,Cab,6x5b
Asm Cab-6x5b,Base
Speaker Gp-Radio
Cab Asm-6x5,Crenlo
Door Gp
Door Latch As.
Handle As.-Interior
Mount Asm
Mount Asm-Latch
Roof As.-Inner
Lamp Gp-Porch
Dome
Console Gp
