Challenger Rogator 618S Chassis Parts Catalog AG629131
Brand: Challenge Rogator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenger 618S Rogator Chassis
Serial Number: 618458308 - 618XXXX10
Part Number: AG629131
Number of Pages: 898 Pages
Publication Information
Base Chassis
Standard Chassis
Cylinder Asm-Suspension,Rh
Cylinder Asm-Suspension,Lh
Bumper Aeon Instl,Rg618
Axle Group
Axle Instl-Front,Adjustable
Axle Asm-Front,Adjustable
Cylinder Asm-Adj Axle
Cylinder-Hyd,D25 50 225 520mm
Cylinder Asm-Steering
Cylinder-Hyd,D25 50 266 480mm
Cylinder Asm-Hyd Track Rod
Motor Asm-Hyd,Lh Front
Motor Asm-Hyd,Rh Front
Cylinder-Hyd,D25 50 450 754mm
Axle Instl-Rear,Adjustable
Axle Asm-Rear,Adjustable
Motor Asm-Hyd,Rh Rear
Motor Asm-Hyd,Lh Rear
Hyd Component Instl-Adj Axle
Manifold Asm-Adj Fr Axle
Manifold Asm-Adj Rear Axle
Manifold Asm-Flow Divider
Manifold-Flow Divider,Bxp20595
Hyd Instl-Hose Clamps,Adj Axle
Plumbing Instl-Adj Axle
Harness Instl-Adj Axle
Axle Instl-Front,1.80m
Axle Asm-Front,1.80m
Track Rod Asm-1.80m Axle
Axle Instl-Rear,1.80m
Axle Asm-Rear,1.80m
Power Train Group
Engine Instl-Sisu,Rg618s
Engine Asm-Sisu
Heating Instl-Cab
Drive System Instl
Pump Asm-Hyd,Drive System,Pri
Pump Asm-Hyd,Drive System,Sec
Pump Asm-Hyd,Gear
Fan Instl-Cooling,Rg618s
Cooler Instl-Rg618s
Cooler Asm-Rg618s
Tank Instl-Deaeration
Hose Instl-Cooling Package
Exhaust Instl-Rg618s
Filter Instl-Air Intake
Filter Instl-A C,Rg618s
Filter Asm-A C
Appearance Group
Nose Instl,Rg618s
Bumper Instl-Lh Rh
Hood Instl-Engine,Lh
Hood Asm-Engine,Lh
Hood Instl-Engine,Rh
Hood Asm-Engine,Rh
Center Console Inst
Center Console Asm
Ladder Instl-Entrance
Cylinder Asm-Air,Ladder
Plate Instl-Cover,Rg618
Toolbox Instl-Rg618
Ladder Instl-Oskaro
Flap Instl-Mud,Rg618-Ii
Cab Group
Cab Instl-Rg618
Mirror Instl-Europe,Rg618
Bracket Asm-Mir,Lh,Incl Bcn Lt
Bracket Asm-Mirror,Rh
Mirror Instl-Uk,Rg618
Bracket Asm-Mir,Rh,Incl Bcn Lt
Bracket Asm-Mirror,Lh
Glass Asm-Cab
Window Asm-Glass,Rh
Roof Asm-Cab,Outer
Door Instl-Cab,Rg618
Door Asm-Cab
Door Asm-Glass
Handle Instl-Cab
Wiper Asm
Worklight Instl-Cab,Rear
Hose Instl-Dry Air,Cab,Rg
Cable Blkhd Asm-Hydrst Cab Air
Air Horn Asm
Valve Asm-Solenoid,12volt
Floormat Cover Asm
Trim Asm-Interior
Barrier Instl-Heat
Floormat Instl-Rg
Inner Roof Asm
Electric Asm-Inner Roof
Decal Instl-Light Panel,Cab
Audio Asm
Radio Instl-Blaupunkt
Steering Column Asm Instl
Orbitrol Instl-80 160cc
Orbitrol Asm-80 160cc
Pedal Instl-Throttle
Pedal Asm-Throttle
Pedal Instl-Brake
Pedal Asm-Brake
Plate Instl-Cov,Foot Throttle
Switch Instl-Dimmer,4ws
Buzzer Instl-Warning
Controls Asm-Rogator
Bracket Instl-Mtg,Eip,Rg
Bracket Asm-Mtg,Eip
Eip Instl-Rg,J1939
Panel Instl-Cover,Rh Console
Console Asm-Rh
Panel Instl-Ignition
Panel Asm-Ignition
Panel Instl-Control,Cab
Panel Asm-Control,Chassis
Panel Asm-Info
Bracket Instl-Cont Mtg,Seat
Console Instl-Rg,W O Grip
Console Asm-Rg,W O Grip
Console Asm-Control
Handle Instl-Hydrostat,Rg618
Joystick Asm-10 Sect,Rg618
Seat Instl-Scis Actn,Air Compr
Seat Asm-Modified
Seat Asm-Sciss Actn,Air Compr
Hvac Asm
Hvac Unit
Cab Asm-Electrical
Panel Instl-Cover,Falcon
Relay Instl-Parking Brake
Relay Asm-Prkg Brake Ladder
Relay Instl-Power
Relay Asm-Power
Stud Instl-Power
Amplifier Instl-Radar
Amplifier Asm-Radar
Connector Instl-Intcon Radar
Kit-Extra Key
Tire And Wheel Group
Tire Instl-750 65 R26
Rim And Tire Asm-750 65 R26,Rh
Rim And Tire Asm-750 65 R26,Lh
Tire Instl-620 75 R34
Rim And Tire Asm-620 75 R34,Rh
Rim And Tire Asm-620 75 R34,Lh
Tire Instl-540 75 R38
Rim And Tire Asm-540 75 R38,Rh
Rim And Tire Asm-540 75 R38,Lh
Tire Instl-380 90 R46
Rim And Tire Asm-380 90 R46,Rh
Rim And Tire Asm-380 90 R46,Lh
Tire Instl-320 90 R50
Rim And Tire Asm-320 90 R50,Rh
Rim And Tire Asm-320 90 R50,Lh
Tire Instl-320 90 R50,Tuv
Tire Instl-300 95 R46
Rim And Tire Asm-300 95 R46,Rh
Rim And Tire Asm-300 95 R46,Lh
Tire Instl-300 95 R46,Tuv
Hydraulic Tank Group
Tank Instl-Hyd,180l
Tank Asm-Hyd,180l
Fuel Group
Tank Instl-Fuel,260l
Tank Asm-Fuel,260l
Fuel Line Instl
Air System Group
Air Component Instl-Chassis
Air System Instl-Chassis
Valve Asm-Air,Ladder Entr
Hydraulic Group
Hyd Instl-Hose Clamps Flanges
Hyd Component Instl-Chassis
Valve Asm-Flow Cont,Spray Pump
Valve-Flow Control,3way
Manifold Asm-Press Relief
Manifold-Pressure Relief
Manifold Asm-Ng4
Manifold-Range Selec,3sect
Manifold Asm-Suspension
Manifold-Suspension
Manifold Asm-Ng6
Valve Asm-4wheelsteering
Manifold Asm-Drive System
Manifold Asm-Leakage
Manifold Asm-Return
Valve Asm-Reducer,3 8in
Accumulator Asm-Brake
Manifold Asm-Front Axle
Manifold Asm-Rear Axle
Plumbing Instl-Chassis
Plumbing Instl-Tank Pump
Plumbing Instl-Drive System
Plumbing Instl-Whl Motor,Front
Plumbing Instl-Whl Motor,Rear
Plumbing Instl-Parking Brake
Plumbing Instl-Leak Oil
Plumbing Instl-Accumulator
Plumbing Instl-Brake
Plumbing Instl-Ng6 Manifold
Plumbing Instl-4ws
Plumbing Instl-Spnsn,Fr Axle
Cylinder-Hyd,D50 60 120 365mm
Electrical Group
Elec Component Instl-Chassis
Box Asm-Switch,Rg618
Box Asm-Switch,Suspension
Battery Instl-Rg618
Battery Cable Instl-Rg618
Harness Instl-Chassis
Harness Instl-Engine
Harness Instl-4wheelsteering
Harness Instl-Suspension
Harness Instl-Ladder
Harness Instl-Worklight,Nose
Sensor Instl-Spnsn Cylinder
Harness Instl-Rotating Lamp
Harness Instl-Worklight,Cab
Harness Instl-Accessory Plug
Harness Inst-Cab,Rg618
Bracket Asm-Fuse Block
Flasher Instl-Eur
Decal Group
Decal Instl-Holland
Decal Instl-Germany
Decal Instl-United Kingdom
Decal Instl-Czech Republic
Decal-Inst,Cabroof,618s
Decal-Inst,Nose,618s
Options Group
Deflector Instl-Crop
Rape Seed Kit Instl-Rg
Valve Instl-Traction Control
Valve Asm-Traction Control
Plumbing Instl-Traction Cont
Elec Component Instl-Trac Cont
Door Instl-Sl,Cab
Towing Hook Instl-Spray Pack
Harness Instl-Ltg,Towing Hook
Air Spring Instl,Rg618
Recommended Dealer Stock
