702,019
Challenger Rogator 333 344 Parts Catalog AG647462
Brand: Challenge Rogator
Type of Machine: Applicators
Model: Challenge 333, 344 Rogator 2017
Serial Number: ..HV001001 - ..HV001...
Part Number: AG647462
Number of Pages: 553 Pages
Fixed
Steering
From 1.50 M Until 1.80 M
From 1.90 M Until 2.25 M
Frame And Suspension
Short
Fender Support Assembly
Boom Support
Lock Tank Front
Support Platform
Bottom Plate
Drawbar And Hitch
Trailer Coupler
Drawbar Hitch
Cylinder
Fixed Position
Bearing Kingpin
Kit Linear King Pin
From 1.50 M Until 1.80m
From 1.80 M Until 2.25 M
Pto
Cover
Support
Drive Bearing Support
Installation
Brake Booster
Air
Hydraulic
Spindle Cable Brake
Air System
Tank
85 Cc
Tube Assembly Ls
Tube Assembly Open Center
Tubes And Hoses
Manual Operating
Fittings
Return
Pommier Norac
Flow Ng 6
Manifold
Boom Center
Boom Block
Pommier
Until 30 M
Balance Cylinder
Tilting
Cylinder 24 Meter
Aftermarket
Chassis Short
Wire Harness
Sensor
Alarm
Harness
Stand Alone
Novatel
Tail Light Rear Assembly
Beacon Amber
Worklights Control Center And Injector
2 Fold
Rear View Camera
Center Frame
Monitor
X 25
Platform
Right Hand
Left Hand
Right Hand Installation
2.55 Meter
3.00 Meter
Rg3xx
Rg333
Rg344
Product Containment
3300 L & 4400 L
Lid
Bulk Head
Rinse Assembly, With Pressure Washer
Water Tank Front
Hose Assembly
Level Indicator Assembly
Mixing Chamber Installation
Nozzle Assembly
Primary Product Distribution
3.00 X 2.00 9306c
3.00 X 2.00 9306s Stainless Steel
Control Panel Spraypack
Spraypack Assembly
5 Way Manual
5 Way Electric
2 Inch
2 Inch Electric
2 Inch Electric Stainless Steel
2 Inch Full Port Electric 12v
3 Inch
Press 3 Inch
Full Port Flange W 80 Mesh
Standard Flow
Reload
2 Inch Stubby
2 Inch 45 Degree
Reload 3.00 Assembly
54
Standard Port Ball Valves
Self Priming
No Self Priming
Manifold 12 Mesh
Quick Attach Installation
No Extern Fast Fill
Transfer
Rinse Bottle
Handgun Option
Ecomatic
Secondary Product Distribution
24 12 M
27 15 M
28 15 M
30 15 M
Hose Installation
Middle
High Flow
Recirculation
Boomstop Assembly
Aluminium
Options
Booms
Until 28 M
Reinforcement
Stabiliser Bar
Installation Sensor
Cover Inside
Hose
Hc 3
Bracket
Norac
Components
Hc 5
Boom Position Indicator
From 24 M
24 M
24 12 M Tr 4 R Lh
24 12 M Tr 4 R Rh
27 15 M Tr 4 R Lh
27 15 M Tr 4 R Rh
28 15 M Tr 4 R
28 15 M Tr 4 R Lh
28 15 M Tr 4 R Rh
30 15 M Tr 4 R Lh
30 15 M Tr 4 R Rh
Cover Boom Tip
Country Specs
Customer Documentation
Manual
Zeca 15 Mm
Tank Reeler
Reeler
Cleaning
Eu
Theft Protection
Sign Installation, Slow Moving Vehicle
Nozzle
Wheel Chock Installation
Service Kit
Basic
Advanced
