Challenger RG900 to RG1300B Rogator Liquid System Parts Catalog 562723D1
Brand: Challenger
Type of Machine: Applicators
Model: Challenger RG900, RG900B, RG1100, RG1100B, RG1300, RG1300B Rogator Liquid System (2013-2017)
Serial Number: DXXX1001 - HXXX9999
Part Number: 562723D1
Number of Pages: 7300 Pages
Product Containment
Rg900b Rg1100b Rg1300b
Ball Valve, Union, Poly, 1.00npt
Boom Stop Bracket Assembly, Left Hand
Boom Stop Brace Assemby, Left Hand, 900
Boom Stop Bracket Assembly, Right Hand
Boom Stop Brace Assemby, Right Hand, 1100 1300
Bracket Assembly, Input Output Boom Stop, Right Hand, 900
Bracket Assembly, Input Output Boom Stop, Right Hand,1100 1300
Catwalk Installation, Rear, Right Hand, 900
Catwalk Installation, Rear, Right Hand, 1100 1300
900
Cross Assembly, 1.50 Hose Barb X 1.50 Hose Barb X 1.50 X .75
Tank Assembly, 20 Gallon, Without Agitator
Tank Assembly, 40 Gallon, Without Agitator
Tank Assembly, 900 Gallon, Ss
Lid Assembly, 10 Inch
Tank Assembly, 1100 Gallon, Ss
Kz Valve And Fitting Assembly, 1.50, 90d X T, Sparger
Ball Valve, Flange, Electric
Valve Body Assembly, Flanged, 1.00, 2w
1.00, 90d X Hose Barb
Tank Assembly, 1100 Gallon, 4x3, Ss
Tank Assembly, 1300 Gallon, 4.00 X 3.00, Ss
Tank Assembly, 1300 Gallon, Ss
Tank Vent Assembly
Tank And Saddle Assembly, 900 Gallon, 3x2
Rinse Tank Installation, Top, 900 Gallon
Rinse Tank Assembly, Top, 900 Gallon
Rinse Tank, 100 Gallon, Top, Poly
Rinse Tank Strap Assembly
Saddle Assembly, Boom Tree, 900 Gallon
Tiedown Installation, System
Tank And Saddle Assembly, 1100 Gallon, 4x3
Tank And Saddle Assembly, 1300 Gallon, 4x3
Tank And Saddle Assembly, Boom Tree, 1100 Gallon
Tank And Saddle Assembly, Boom Tree, 1300 Gallon
Tank Support Assembly, Plastic, Right Hand
Injection Tank Stand Installation, Liquid, Rogator, Left Hand
Injection Tank Stand Installation, Liquid, Rogator, Right Hand
Support Assembly, Tank, Chemical Injection, Left Hand
Rinse Tank Installation, Top, 1100 Gallon
Rinse Tank Installation, Top, 1300 Gallon
Rinse Tank, 130 Gallon, Top, Poly
Rinse Tank Assembly, Top, 1100 1300 Gallon
Sight Gauge Installation, 900 Gallon
Sight Gauge Assembly, Front, 900 Gallon
Sight Gauge Assembly, Rear, 900 Gallon
Sight Gauge Installation, 900 Gallon, International
Sight Gauge Assembly, Front, 900 Gallon, International
Sight Gauge Assembly, Rear, 900 Gallon, International
Sight Gauge Installation, 1100 Gallon
Sight Gauge Assembly, Front, 1100 Gallon
Sight Gauge Assembly, Rear, 1100 Gallon
Sight Gauge Installation, 1100 Gallon, International
Sight Gauge Assembly, Front, 1100 Gallon, International
Sight Gauge Assembly, Rear, 1100 Gallon, International
Sight Gauge Installation, 1300 Gallon
Sight Gauge Assembly, Front, 1300 Gallon
Sight Gauge Assembly, Rear, 1300 Gallon
Sight Gauge Installation, 1300 Gallon, International
Sight Gauge Assembly, Front, 1300 Gallon, International
Sight Gauge Assembly, Rear, 1300 Gallon, International
Support Assembly, Spreader, Combo
Product Pump Mounting Assembly, 9306
Product Pump Mounting Assembly, 3.00 X 2.00
Reload Installation, 2.00, Liquid System
Ball Valve, 2.00 Inch, Poly Full Flow
Reload Installation, 3.00, Liquid System
Ball Valve, 3.00 Inch, Poly, Full Flow
Valve Assembly, 3.00 Inch Electrical, Eh4, 3 Section
Valve, 3.00 Inch, Butterfly With 10 Position Lever
Primary Product Distribution
Actuator Valve, 2.00, Spring Return
Actuator, 000-60-M-9
Air Plumbing, Front Reload
Ball Valve, 1.00 Inch Full Port Flange, Electric
Ball Valve, 2.00 Inch, Full Port Flange, Electrical
Ball Valve, Ss, .50 , 610l
Boom Cleanout Installation, Air Main Shut-Off, 2.00, 90 100
Butterfly Valve And Bracket Assembly, Main, 2.00
Butterfly Valve, 2.00, Spring Return, Pneumatic
Boom Cleanout Installation, Air Main Shut-Off, 3.00, 90 100
Boom Cleanout Installation, Air Main Shut-Off, 3.00, 120
Boom Cleanout Installation, 2.00 Electric Main Shut-Off,90 100
Boom Cleanout Installation, 2.00 Electric Main Shut-Off, 120
Boom Manifold Assembly, With Ball Valve, Standard
Ball Valve, 1.00 Inch Full Port Flange X Npt, Electrical
Boom Manifold Assembly, With Ball Valve, High Volume
Ball Valve, 1.50 Inch, Sideload
Ball Valve, 1.50 Inch Poly, Full Flow
Boom Plumbing Installation, High Volume, Center
Quick Stop Valve, 1.00npt X 0.75npt
Boom Plumbing Installation, High Volume, Left Hand, 80
Boom Plumbing Installation, High Volume, Right Hand, 80
Boom Manifold Assembly, 3.00 Hose Barb X 1.50 Flange
Butterfly Valve, 3.00, Spring Return, Pneumatic
Butterfly Valve And Bracket Assembly, Main Shut-Off, 3.00, 120
Cap Installation, 1.50 Inch Valve, 120 X 7
Centrifugal Pump, 2.00 X 1.50, 9306chm5
Hydraulic Motor, Hm5 With Bypass
Centrifugal Pump, 3.00 X 2.00, 9307
Center Installation, Plumbing, Without Strain, 9 100
Center Installation, Plumbing, Without Strain, 120
Center Plumbing Installation, 5 Section, 90 100 Foot
120 Foot Boom
Chemical Eductor Assembly, Ss
Chemical Eductor, Clean Load Ii, Poly
Clean Load Lid Kit, 12 Inch
Chemical Eductor Option, Ss, Agco
Valve, 2.00 Inch, Flange, T Handle, Pp
Chemical Eductor Assembly, Poly
Chemical Eductor Option, Poly, Cleanload
Control Box Assembly, Pressure Manifold Plumbing
3 Way Valve, Bottom Load, 2.00 Standard Port Flange
Elbow And Flange Assembly, 90 Degree, 3.00, Ss
Electric Ball Valve, 2.00 Inch Full Port Flange
Electrical Valve, Reg, 2 Inch Flange X 1 Inch Fnpt
Flowmeter Assembly, Rfm60p, 2.00 Inch Full Port Flange
Flowmeter, 2.00 Inch, Sp Flange, Rfm60, 12 Volt
Flowmeter Installation, 2.00 Inch, Without Low Rate
Flowmeter, 2.00 Inch, 140 Pulse Per Gallon, 12 Volt
Flowmeter Assembly, 2.00 Inch, Without Low Rate
Flowmeter Installation, 2.00 Inch, With Low Rate
Flowmeter Installation, 3.00 Inch, Without Low Rate
Flowmeter Assembly, 3.00 Inch, Without Low Rate
Flowmeter Assembly, 2.00 Inch, With Low Rate
Low Rate Assembly Kit, 2.00 Full Port Flange
Valve Assembly, Regulating, Pressure
Flowmeter Installation, 3.00 Inch, 41 Pulse Per Gallon
Flowmeter Assembly, 3.00 Inch, 41 Pulse Per Gallon
3x2 Plumbing
2017
Loose Option
Flowmeter Assembly-Raven, 3.00 Flange
4x3 Plumbing
Flange Assembly Mounting, 3.00 Full Port X 3.00 Full Port
Fitting Assembly, 4 Hole Compression Flange X Flange, 3.00
Hose Hanger Bracket Assembly, 3.00, Large
Hose Hanger Bracket Assembly, 4.00, Large
Hose Bracket And Clamp Assembly, 2.00
Hose Bracket And Clamp Assembly, 3.00
Injection Assembly, 2 Inch Check Valve, 2 X 2 Inch Hose Barb
Injection Pump, Raven, Integrated Node
Injection Pump Plumbing Installation, Left Hand
3 Way Valve, 0.75, Sideload
Ball Valve, 0.75 Poly, Bottom Load
Injection Pump Plumbing Installation, Right Hand, 1 Tank
Strainer Body Assembly, .75 Inch
Injection Pump Plumbing Installation, Right Hand, 2 Tank
Injection Plumbing And Tank Installation, Right Hand, Rogator
Kz Valve And Fitting Assembly, 2.00, 90d X T, Sparger
Low Rate Installation Kit, Rogator Liquid System
Manifold Assembly, 2.00 Hose Barb X 1.50 Flange
80, 90, And 100 Foot Boom
Manifold Assembly, 3x2, 1.50 Plumbing, 90 100
Manifold Assembly, 4x3, 1.50 Plumbing, 90 100
Manifold Installation, High Volume, Ball Valve
Standard Boom Plumbing
Manifold Installation, Standard, Ball Valve
Manifold Installation, 2.00 Hose Barb X 1.50 Flange
Manifold Installation, 3.00 Hose Barb X 1.50 Flange
Manifold Installation, 4 X 3, 1.50 Plumbing, 90 100
2015
Mounting Bracket Assembly, Sensor
Mounting Bracket Assembly, Right Hand
Mounting Bracket Assembly, Left Hand
Mounting Bracket Assembly, Kz Valve, Tip, Right Hand
Mounting Bracket Assembly, Y Manifold, Boom Plumbing
Pressure Plumbing Assembly, 3.00 Inch With Chemical Injection
Mixer, 4x3
2016-2017
Pump Installation, Loop 1, Raven
Pump Installation, Loop 2, Raven
Plug And Cap Option, Without Chemical Eductor
Plumbing System Installation, 1.00, 80 X 5, Triple
Y Manifold Assembly, 1.00 Full Port Flange, Electrical
Product Pump Installation, 3 X 2 Plumbing
Ball Valve, 2.00 Sp Flange X 2.00 Male Quick Coupler
Product Pump Installation, 4 X 3 Plumbing
Plumbing Assembly, 3.00 Suction, 2x1.5 Pump
Pump Sub Assembly, 3.00 Suction, 2 X 1.5
Pump Sub Assembly, 4.00 Suction, 3x2
Pressure Distribution Plumbing Assembly, 2.00
Y Strainer, 2.00 Inch, Full Port Flange, With 30 Mesh
Pressure Distribution Plumbing Assembly, 3.00
Strainer Assembly, 3.00 Inch Full Port Flange
Strainer, 3.00 Line, 316 Ss
Flange
Pressure Plumbing Assembly, 2.00, With Chemical Injection
Reload Installation, 3.00 Side, 4x3
Reload Installation, Front, Liquid System, 4x3, 3.00
Reload Installation, Front, Liquid System, 4x3, 4.00
Reload Valve Sub Assembly, 4.00, Front, Air
Valve, 4.00 Inch, Butterfly With 10 Position Lever
Reload Installation, 4.00 Side, 4x3
Strainer Installation, 1.50, 90 100x5
Y Strainer, 2.00 Inch, Standard Port, Flange With 30 Mesh
Strainer Installation, 1.50, 120x7
Suction Installation, 3.00 Inch, With Front Reload
Suction Installation, 3.00 Inch, With Front Reload, Air
Suction Installation, 3.00 Inch, Without Front Reload
Suction Installation, 4.00 Inch, With Front Reload
Suction Installation, 4.00 Inch, With Front Reload, Air
Suction Installation, 4.00 Inch, Without Front Reload
System Installation, 3.00 Inch, Without Boom Cleanout
System Installation, 2.00 Inch,Without Boom Clean Out,90 120
System Installation, 2.00 Inch, Without Boom Cleanout, 120
System Installation, Without Boom Cleanout
2014
L Bracket Assembly, 1.50 Stauff, Standard U
Suction Plumbing Assembly
Sump Valve Option, 3.00 Inch, Manual
Sump Valve Option, 3.00 Inch, Electric
Sump Valve Option, 4.00 Inch, Manual
Sump Valve Option, 4.00 Inch, Electric
Tube Installation, Without Low Rate Kit
Valve Assembly, 3.00, Front Reload
Valve Bracket Assembly, 3.00 Inch Butterfly
Valve Assembly, 4.00 Inch, Front Reload
Valve Assembly, 3.00, Front Reload, Air
Valve Assembly, 4.00 Inch, Front Reload, Air
Y Fitting, Valve Assembly, With 45, 3.00 Inch, Butterfly
Y Fitting, Valve Assembly, With 45, 4.00 Inch, Butterfly
Secondary Product Distribution
Identification Chart
2013
Pipe Assembly, 90d With 1.00 Hose Barb, 4 X 10, Ss, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 4 X 10, Ss, Right Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 10x10, Ss, Right Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 10x10, Ss, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 12x10, Ss, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 12x10, Ss, Right Hand
Tee Pipe Assembly, With Two 1.00 Hose Barb, 16 X 10, Ss
X Pipe Assembly, With Three 1.00 Hose Barb, 11x10, Ss
L Bracket Assembly, Standard U, Bolt
L Bracket Assembly, Reversed P Clamp, Standard U
L Bracket Assembly, With P Clip, Standard U, Bolt
L Bracket Assembly, With 2 1.00 Inch P Clips, Standard U, Bolt
L Bracket Assembly, 2 X 1.50, Stauff, Standard U-Bolt
L Bracket Assembly, Poly Stauff, Long U Bolt
Pipe Assembly, 90d With 1.00 Hose Barb, 2 X 15, Ss
Pipe Assembly, 90d With 1.00 Hose Barb, 8 X 15, Ss, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 8 X 15, Ss, Right Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 7 X 15, Ss, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 7 X 15, Ss, Right Hand
With Two 1.00 Hose Barb, 11 X 15, Ss
X Pipe Assembly, With Three 1.00 Hose Barb, 11 X 10, Ss
L Bracket Assembly, With Reversed P Clamp
Pipe Assembly, 90d With 1.00 Hose Barb, 2 X 20, Ss
Pipe Assembly, 90d With 1.00 Hose Barb, 5 X 20, Ss, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 5 X 20, Ss, Right Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 6 X 20, Ss
Tee Pipe Assembly, With Two 1.00 Hose Barb, 8 X 20, Ss
X Pipe Assembly, With Three 1.00 Hose Barb, 6 X 20, Ss
Pipe Assembly, L 20, 7x10, Poly, Aspirator, Left Hand
Aspirator Assembly, 1.00 Pipe, Poly, Plug
Service Kit, Aspirator, 1.00
Service Kit, Aspirator Plug End
Pipe Assembly, L 20, 7x10, Poly, Aspirator, Right Hand
X Pipe Assembly, 20, 11x10, Poly, Aspirator
Bracket Assembly, Straight, Long, 1.00, Standard U
Bracket Assembly, Straight, Long, P Clip, Long U
L Bracket Assembly, Long, Ips, X Long Offset
L Bracket Assembly, Long, Stauff, Long U Bolt
Pipe Assembly, L 16, 6x10, Poly, Aspirator, End Row
Pipe Assembly, L 20, 5x10, Poly, Aspirator, Right Hand
Tee Pipe Assembly, 20, 11x10, Poly, Aspirator
Tee Pipe Assembly, 20 16, 11 X 10, Poly, Aspirator
Bracket Assembly, Straight, Short, 1.25 P-Clip, Reverved
Bracket Assembly, Straight, Long, 1.25 P-Clip
Bracket Assembly, Straight, Long, 1.00, P-Clip
L Bracket Assembly, Long, Stauff, 1.25p Ins
L Bracket Assembly, Long, Stauff, 1.25p Center
L Bracket Assembly, Long, Stauff, Reversed U
L Bracket Assembly, Long Offset, Ips
Z Bracket Assembly, Short, 1.00 Ips
Z Bracket Assembly, Short, 1.00 Ips 1.25 P-Clip
Z Bracket Assembly, Long, 2ips P-Clip
Z Bracket Assembly, Poly, Stauff
Z Bracket Assembly, Poly, Stauff, Reversed U
Pipe Assembly, L 20, 5x10, Poly, Aspirator, Left Hand
Z Bracket Assembly, Poly, Stauff, Lower P-Clip
Pipe Assembly, L 20, 5x10, Ss, Aspirator, Left Hand
Pipe Adapter, Tee, 1.00 Flange
Pipe Assembly, L 20, 7x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 20, 7x10, Ss, Aspirator, Right Hand
Tee Pipe Assembly, 20, 8x10, Ss, Aspirator
Tee Pipe Assembly, 20, 11x10, Ss, Aspirator
Tee Pipe Assembly, 20 16, 11 X 10, Ss, Aspirator
X Pipe Assembly, 20, 11x10, Ss, Aspirator
Bracket Assembly, Straight, Short, 1.00 P-Clip
Bracket Assembly, Straight, Short, 1.00 P-Clip, Reversed U
Bracket Assembly, Straight, Short, 1.25 P-Clip, Reversed U
L Bracket Assembly, Long, Stauff, Xlong Offset
Z Bracket Assembly, Short, 1.25 P-Clip
Z Bracket Assembly, Long, 2x1.25 P-Clip
Pipe Assembly, L 16, 6x10, Ss, Aspirator, End Row
Pipe Assembly, L 20, 5x10, Ss, Aspirator, Right Hand
Bracket Assembly, Straight, Short, P-Clip
L Bracket Assembly, Short Offset, Ips
Pipe Assembly, 90d With 1.00 Hose Barb, 7x10, Ss, Aspirator,Lh
Pipe Assembly, 90d With 1.00 Hose Barb, 7x10, Ss, Aspirator,Rh
Tee Pipe Assembly, 1.50 X 1.25 Hose Barb, 11x10, Ss, Aspirator
X Pipe Assembly, Two 1.00 Hose Barb, 11x10, Ss, Aspirator
L Z Bracket Assembly, Long, 1.50 Stauff, Ips, Poly P-Clamp
Z Bracket Assembly, Long, Lower, Ips P-Clip
Z Bracket Assembly, Poly, Stauff, Upr 1 P-Clip
Pipe Assembly, 90d 1.25 Hose Barb, 5x10, Ss, Aspirator, Lh
Pipe Assembly, L 20, 5x15, Poly, Aspirator, Right Hand
Pipe Assembly, L 20, 5x15, Poly, Aspirator, Left Hand
X Pipe Assembly, 20, 7x15, Poly, Aspirator
Bracket Assembly, Straight, 2x, Long, 1.25p-Clip
Pipe Assembly, L 16, 5x15, Poly, Aspirator, End Row
Pipe Assembly, V 20, 3x15, Poly, Aspirator, Right Hand
Tee Pipe Assembly, 20, 5x15, Poly, Aspirator
Tee Pipe Assembly, 20, 8x15, Poly, Aspirator
Tee Pipe Assembly, 20 16, 6x15, Poly, Aspirator
Pipe Assembly, V 20, 3x15, Poly, Aspirator, Left Hand
Pipe Assembly, L 20, 5x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 20, 5x15, Ss, Aspirator, Right Hand
X Pipe Assembly, 20, 7x15, Ss, Aspirator
Pipe Assembly, L 16, 5x15, Ss, Aspirator, End Row
Pipe Assembly, L 20, 3x15, Ss, Aspirator, Right Hand
Tee Pipe Assembly, 20, 5x15, Ss, Aspirator
Tee Pipe Assembly, 20, 8x15, Ss, Aspirator
Tee Pipe Assembly, 20 16, 6x15, Ss, Aspirator
Bracket Assembly, Straight, Long, 1.25 Up P
Pipe Assembly, L 20, 3x15, Ss, Aspirator, Left Hand
Pipe Assembly, 90d With 1.0 Hose Barb, 5x15, Ss, Aspirator, Lh
L Pipe Assembly, 16, 12x10, Ss, With Aspirator, End Row
Tee Pipe Assembly, 1.25 X 1.00 Hose Barb, 6x15,Ss,Asperator,Rh
X Pipe Assembly, Two 1.00 Hose Barb, 7x15, Ss, Aspirator
Bracket Assembly, Straight, Long, Long U-Bolt
L Bracket Assembly, Poly Stauff, 1.25 P Clip
Z Bracket Assembly, Long 1.50 Stauff,1.00 Poly, Long U-Bolt
Tee Pipe Assembly, 1.25 X 1.00 Hose Barb, 6x15,Ss,Asperator,Lh
Pipe Assembly, L 20, 3x20, Poly, Aspirator, Left Hand
Pipe Assembly, L 20, 3x20, Poly, Aspirator, Right Hand
X Pipe Assembly, 20, 6x20, Poly, Aspirator
Pipe Assembly, L 16, 4x20, Poly, Aspirator, End Row
Pipe Assembly, V 20, 2x20, Poly, Aspirator, Right Hand
Tee Pipe Assembly, 20, 4x20, Poly, Aspirator
Tee Pipe Assembly, 20, 6x20, Poly, Aspirator
Tee Pipe Assembly, 20 16, 5x20, Poly, Aspirator
Bracket Assembly, Straight, Long, 1.25 Dn P
Bracket Assembly, Straight, Long, P-Clip, 1.00 U
Pipe Assembly, V 20, 2x20, Poly, Aspirator, Left Hand
Pipe Assembly, L 16, 3x20, Poly, Aspirator, Right Hand
Tee Pipe Assembly, 24 16, 6x20, Poly, Aspirator
Pipe Assembly, L 20, 3x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 20, 3x20, Ss, Aspirator, Right Hand
X Pipe Assembly, 20, 6x20, Ss, Aspirator
Bracket Assembly, Straight, Extra Long, P-Clip
Pipe Assembly, L 16, 4x20, Ss, Aspirator, End Row
Pipe Assembly, V 20, 2x20, Ss, Aspirator, Right Hand
Pipe Adapter, Straight, 1.00 Flange
Tee Pipe Assembly, 20, 4x20, Ss, Aspirator
Tee Pipe Assembly, 20, 6x20, Ss, Aspirator
Tee Pipe Assembly, 20 16, 5x20, Ss, Aspirator
Pipe Assembly, V 20, 2x20, Ss, Aspirator, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 3x20, Ss, Aspirator,Lh
Pipe Assembly, 90d With 1.00 Hose Barb, 3x20, Ss, Aspirator,Rh
Tee Pipe Assembly, 1.50 X 1.00 Hose Barb, 5x20,Ss,Asperator,Rh
X Pipe Assembly, Two 1.00 Hose Barb, 6x20, Ss, Aspirator
Tee Pipe Assembly, 1.50 X 1.00 Hose Barb, 5x20,Ss,Asperator,Lh
Pipe Assembly, L 16, 3x50cm, Poly, Aspirator, End Row
Tee Pipe Assembly, 16, 6x50cm, Poly, Aspirator, Left Hand
Bracket Assembly, Straight, Short, Ips Clip, P Clip
Bracket Assembly, Straight, Short, 1.00 Ips Clip
Z Bracket Assembly, Ips Clip
Pipe Assembly, L 16, 3x50cm, Poly, Aspirator, Left Hand
Pipe Assembly, L 16, 6x50cm, Poly, Aspirator
Pipe Assembly, With Two 1.00 Hose Barb X 2225, Poly
X Pipe Assembly, 20 16, 6x50cm, Poly, Aspirator
Bracket Assembly, Straight, Long, 2ips Clip
L Bracket Assembly, Stauff, Long U Bolt
Z Bracket Assembly, Short, Ips Clip
Pipe Assembly, L 16, 3x50cm, Poly, Aspirator, Right Hand
Tee Pipe Assembly, 16, 6x50cm, Poly, Aspirator, Right Hand
X Pipe Assembly, 1.50 X 1.00 Inch, 6x50 Cm, Poly, Aspirator
L Bracket Assembly, Poly Stauff, P Clip, 1.00
Pipe Assembly, L 16, 12x10, Poly, Aspirator, End Row
Tee Pipe Assembly, 24 16, 11x10, Poly, Aspirator
L Bracket Assembly, Long, Stauff, Center Clamp
L Bracket Assembly, Long, Stauff, 1.50 P-Clamp
L Bracket Assembly, Long, Stauff, Ins Clip
Z Bracket Assembly, Long, Ips 2 P-Clip
Pipe Assembly, 2 Tee, 20 16, 12x10, Ss, Aspirator
Tee Pipe Assembly, 24 20, 11x10, Ss, Aspirator
Bracket Assembly, Straight, Short, 1.50 P-Clip
Z Bracket Assembly, Long, 1.25 1.50 P-Clip
Pipe Assembly, 90d 1.25 Hose Barb, 5x10, Ss, Aspirator, Rh
Z Bracket Assembly, Long, 1.50 P-Clip
Z Bracket Assembly, Long, Ips 1.50 P-Clip
Pipe Assembly, 90d, 20 06, 7x15, Ss, Aspirator
Tee Pipe Assembly, 24 20, 7x15, Ss, Aspirator
Pipe Assembly, L 16, 8x15, Poly, Aspirator, End Row
Tee Pipe Assembly, 24 16, 7x15, Poly, Aspirator
Pipe Assembly, L 16, 6x20, Poly, Aspirator, End Row
Bracket Assembly, Straight, Long, 1.50 P-Clip
Pipe Assembly, L 16, 3x20, Poly, Aspirator, Left Hand
Pipe Assembly, 90d, 20 06, 6x20, Ss, Aspirator
Tee Pipe Assembly, 24 20, 6x20, Ss, Aspirator
Pipe Assembly, L 16, 6x50cm, Poly, Aspirator, End Row
Tee Pipe Assembly, 20, 6x50cm, Poly, Aspirator, Right Hand
Bracket Assembly, Straight, Short, Ips, 1.25 P Clip
Tee Pipe Assembly, 20, 6x50cm, Poly, Aspirator, Left Hand
L Bracket Assembly, Poly Stauff 1.25 P Clip
Bracket Assembly, Straight, Long, Reversed 1.00u
L Bracket Assembly, Long, Stauff, Reversed 1.00u
Pipe Assembly, L 16, 5x10, Poly, Aspirator, Right Hand
Pipe Assembly, L 20, 8x10, Poly, Aspirator, Right Hand
Tee Pipe Assembly, 16, 8x10, Poly, Aspirator
Tee Pipe Assembly, 20 16, 8x10, Poly, Aspirator, Right
Bracket Assembly, Straight, Short, 1.00 1.25 P-Clip
Bracket Assembly, Straight, Extra Long, 2xp-Clip
Bracket Assembly, Straight, Extra Long, 1.00 P-Clip
L Bracket Assembly, Long, Stauff, P-Clamp, 1.00 U
L Bracket Assembly, Extra Long, Stauff, 2xp, 1.00u
Pipe Assembly, L 20, 8x10, Poly, Aspirator, Left Hand
Pipe Assembly, 2 Tee, 20 16, 19x10, Poly, Aspirator
X Pipe Assembly, 32 20, 11x10, Poly, Aspirator
Bracket Assembly, Straight, Short, Ips, 1.25 P-Clip
L Bracket Assembly, Z, Stauff, 1.25 P Clamp
L Bracket Assembly, Reversed, 1.00pp Stauff
Z Bracket Assembly, Long, 2xips
Z Bracket Assembly, Long, 1.00 Ips
Pipe Assembly, L 16, 5x10, Poly, Aspirator, Left Hand
Tee Pipe Assembly, 20 16, 8x10, Poly, Aspirator, Left
Pipe Assembly, L 16, 12x10, Ss, Aspirator, End Row
Bracket Assembly, Straight, Extra Long, 1.00, 1.00 U
Tee Pipe Assembly, 20, 8x10, Ss, Aspirator, Left Hand
Bracket Assembly, Straight, Extra Long, 1.00 1.25 P-Clip
Bracket Assembly, Straight, Extra Long, 1.25 P-Clip
L Bracket Assembly, Long, Stauff, 1.00 1.25p
L Bracket Assembly, Long Offset, Ips, 1.00u
Z Bracket Assembly, Short, 1.00 1.25 P-Clip
Pipe Assembly, 2 Tee, 16 20, 19x10, Ss, Aspirator
X Pipe Assembly, 16 20, 11x10, Ss, Aspirator
Z Bracket Assembly, Long, Upr Ips
Tee Pipe Assembly, 20, 8x10, Ss, Aspirator, Right Hand
Pipe Assembly, 2 Tee, 1.25 Hose Barb, 16x10, Ss, Aspirator, Lh
Pipe Assembly, 2 Tee, 1.25 Hose Barb, 16x10, Ss, Aspirator, Rh
X Pipe Assembly, Three 1.00 Hose Barb, 11x10, Ss, Aspirator
Bracket Assembly, Straight, Short, Ips, 1.00 P-Clip
L Bracket Assembly, Long, Stauff, Lower P-Clamp
L Bracket Assembly, Long, Stauff, 2xp-Clamp
L Bracket Assembly, Long, Stauff, 2xp Clamp, Extension
L Bracket Assembly, Long, Ips, 1.00 U Bolt
Z Bracket Assembly, Short, 1.00 P-Clip
Z Bracket Assembly, Long, 1.00 Ips 1.00 P-Clip
Pipe Assembly, L 16, 5x15, Poly, Aspirator, Left Hand
Pipe Assembly, L 16, 5x15, Poly, Aspirator, Right Hand
X Pipe Assembly, 32 16, 7x15, Poly, Aspirator
Bracket Assembly, Straight, Short, 1.00 P-Clip, Long U
Pipe Assembly, L 16, 3x15, Poly, Aspirator, Right Hand
Pipe Assembly, L 16, 4x15, Poly, Aspirator, Right Hand
Pipe Assembly, 2 Tee, 20 16, 13x15, Poly, Aspirator
Tee Pipe Assembly, 20, 5 X 15 Inch, Poly, Aspirator,Right Hand
Tee Pipe Assembly, 16, 6x15, Poly, Aspirator
Bracket Assembly, Straight, Extra Long, 2x1.00 Clip
L Bracket Assembly, Long, Stauff, 2x1.00 Clamp
Z Bracket Assembly, Poly, Stauff, 1.00 P-Clip
Pipe Assembly, L 16, 3x15, Poly, Aspirator, Left Hand
Pipe Assembly, L 16, 4x15, Poly, Aspirator, Left Hand
Tee Pipe Assembly, 20, 5 X 15 Inch, Poly, Aspirator, Left Hand
X Pipe Assembly, 24 20, 8x15, Ss, Aspirator
Pipe Assembly, L 20, 4x15, Ss, Aspirator, Right Hand
Pipe Assembly, 2 Tee, 20 16, 13x15, Ss, Aspirator
Tee Pipe Assembly, 20, 5x15, Ss, Aspirator, Right Hand
Tee Pipe Assembly, 20, 6x15, Ss, Aspirator
Pipe Assembly, L 20, 4x15, Ss, Aspirator, Left Hand
Tee Pipe Assembly, 20, 5x15, Ss, Aspirator, Left Hand
Pipe Assembly, 2 Tee, 1.25 Hose Barb, 11x15, Ss, Aspirator, Lh
Pipe Assembly, 2 Tee, 1.25 Hose Barb, 11x15, Ss, Aspirator, Rh
Pipe Assembly, 90d With 1.0 Hose Barb, 5x15, Ss, Aspirator, Rh
Pipe Assembly, 90d 1.00 Hose Barb, 8x15, Ss, Aspirator,End Row
X Pipe Assembly, 1.50 X 1.00 Inch, 7x15, Ss, Aspirator
Pipe Assembly, L 20, 7x20, Poly, Aspirator
Pipe Assembly, With Two 1.00 Hose Barb, 102.00, Poly
Tee Pipe Assembly, 20 16, 8x20, Poly, Aspirator, Left
Tee Pipe Assembly, 20 16, 8x20, Poly, Aspirator, Right
X Pipe Assembly, 1.50 X 1.00 Inch, 6x20, Poly, Aspirator
X Pipe Assembly, 32 16, 6x20, Poly, Aspirator
Pipe Assembly, L 16, 6x20, Ss, Aspirator, End Row
Pipe Assembly, L 20, 7x20, Ss, Aspirator
Tee Pipe Assembly, 20, 3x20, Ss, Aspirator
Tee Pipe Assembly, 20, 5x20, Ss, Aspirator, Left Hand
L Bracket Assembly, Ips
Pipe Assembly, L 16, 3x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 3x20, Ss, Aspirator, Right Hand
X Pipe Assembly, 16, 6x20, Ss, Aspirator
L Z Bracket Assembly, Stauff, 1.00 P Clamp
Tee Pipe Assembly, 20, 5x20, Ss, Aspirator, Right Hand
Pipe Assembly, 90d 1.00 Hose Barb, 3x20, Ss, Aspirator, Lh
Pipe Assembly, 90d 1.00 Hose Barb, 3x20, Ss, Aspirator, Rh
Pipe Assembly, 90d 1.00 Hose Barb, 6x20, Ss, Aspirator,End Row
X Pipe Assembly, 1.50 X 1.00 Inch, 6x20, Ss, Aspirator
Bracket Assembly, Straight, Short, Ips Clip, 1.00 U
Bracket Assembly, Straight, Short, Ips, 1.00p, 1.00 U
L Bracket Assembly, Poly Stauff, 1.00 U
Pipe Assembly, L 16, 2x50cm, Poly, Aspirator, Right Hand
Pipe Assembly, L 16, 7x50cm, Poly, Aspirator, Right Hand
Tee Pipe Assembly, 16, 4x50cm, Poly, Aspirator
Tee Pipe Assembly, 20 16, 4x50cm, Poly, Aspirator
Bracket Assembly, Straight, Long, Reversed P Clamp
Bracket Assembly, Straight, Long, 2x P-Clip
L Bracket Assembly, With Two 1.00 P Clamp, Standard
L Bracket Assembly, Stauff, P-Clamp, 1.00 U
Tee Pipe Assembly, 16, 7x50cm, Poly, Aspirator
X Pipe Assembly, 32 16, 6x50cm, Poly, Aspirator
Pipe Assembly, L 16, 2x50cm, Poly, Aspirator, Left Hand
Pipe Assembly, L 16, 7x50cm, Poly, Aspirator, Left Hand
Pipe Assembly, 2 Tee, 20, 8x50cm, Poly, Aspirator
X Pipe Assembly, 1.00 X 1.50 Inch, 6x50 Cm, Poly, Aspirator
Bracket Assembly, Straight, Long, 1.00 Inch Poly
Brand: Challenger
Product Containment
900
Tank Vent Assembly
120 Foot Boom
3x2 Plumbing
2017
Loose Option
4x3 Plumbing
2015
Mixer, 4x3
2016-2017
Flange
2014
2013
