Challenger RG700 RG700B Rogator Liquid System Parts Catalog 567544D1
Brand: Challenger
Type of Machine: Applicators
Model: Challenger RG700, RG700B Rogator Liquid System (2014-2019)
Serial Number: EXXX1001 - KXXX9999
Part Number: 567544D1
Number of Pages: 2781 Pages
Product Containment
Rg700 Rg700b
Tank And Saddle Installation, 700 Gallon, Poly
Tank Assembly, 700 Gallon, With Inserts
Sight Gauge Option, Gallon
Sight Gauge Option, Liter
Sight Gauge Installation
Rinse Tank Installation, 65 Gallon
Ball Valve, 0.50 Npt, Union, Poly
Tank Screen Installation, Product, 700 Gallon
Tiedown Installation, Liquid System
Primary Product Distribution
2014-2015
2016-2019
System Installation, Plumbing, 5 Section, Electric
Y Manifold Assembly, 1.00 Full Port Flange, Electrical
Actuator, 000-60-M-9
System Installation, Plumbing, 7 Section, Electric
Ball Valve, 1.00 Inch Full Port Flange, Electric
Valve Body Assembly, Flanged, 1.00, 2w
Mounting Plate Assembly, Y Manifold, Boom Plumbing
Valve Assembly, Regulating, Pressure
Flowmeter, 2.00 Inch, Sp Flange, Rfm60, 12 Volt
Valve, 2.00 Full Port, With Flange
Butterfly Valve, 1.50, 90d
Manifold Assembly, Strainer And Rinse Valve, 1.50
Ball Valve, 1.00 Inch Full Port Flange X Npt, Electrical
Ball Valve, Union, Poly, 1.00npt
3 Way Valve, Bottom Load, 2.00 Standard Port Flange
Ball Valve, 1.50 Npt, Union, Poly
Stubby Valve, 2.00 Full Port, Mnpt X Fnpt
Sump Valve Assembly
Ball Valve, 2.00 Inch, Full Port Flange
Centrifugal Pump, 1.50 X 1.25, 9303chm1
Hydraulic, Motor Hm1 With Bypass
Reload Installation, Side, 2.00, Standard
Reload Valve Assembly, 2.00
Reload Installation, Side, 3.00, Standard
Reload Valve Assembly, 3.00
Stubby Valve, 3 Flange X 3 Male Quick Coupler
Reload Plumbing Assembly, Side, Standard
Chemical Eductor Installation, 7 Gallon, Poly
Chemical Eductor Parallelogram Assembly
Plumbing Assembly, Venturi, Chemical Eductor
Pressure Plumbing Assembly, Chemical Eductor
Hose Installation, Chemical Eductor
Chemical Eductor Assembly, 7 Gallon
Chemical Eductor, Cleanload, 7 Gallon
Tank Ball Valve
Chemical Eductor Option
Boom Manifold Assembly, With Ball Valve, Standard
Strainer Body Assembly, 1.00 Inch
No Eductor Option
Boom Manifold Assembly, With Ball Valve, 7 Section
Tank Fitting, 2.00 Flange X 2.00 Inch Full Port
Reload Station Cover Assembly
Manifold
Secondary Product Distribution
Identification Chart
Bracket Assembly, Straight, Short, 1.00 Ips Clip
L Bracket Assembly, Poly Stauff
X Pipe Assembly, With Three 1.00 Hose Barb, 11 X 10, Poly
Bracket Assembly, Straight, Short, Ips Clip, 1.00 U
Bracket Assembly, Straight, Long, P Clip, 1.00 U
Bracket Assembly, Straight, Long, 2ips, P Clip
Bracket Assembly, Straight, Long, 3 Clips
L Bracket Assembly, Poly Stauff, Reversed P Clamp
L Bracket Assembly, P Clip
L Bracket Assembly, Poly Stauff, 1.00 U
L Bracket Assembly And Long Straight, Poly Pipe Clip
L Bracket Assembly, So, Stauff, Reversed P Clamp
Pipe Assembly, 90d With 1.00 Hose Barb, 5x10, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 9x10, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 12x10, Poly
Poly
X Pipe Assembly, 90d With 1.00 Hose Barb, 11x10, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 11x10, Right Hand
L Bracket Assembly, Poly, P Clip
Tee Pipe Assembly, With Two 1.00 Hose Barb, 4x10, Poly
X Pipe Assembly, With Three 1.00 Hose Barb, 7 X 15, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 6x15, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 7x15, P, Right Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 7x15, P, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 3x15, Right Hand
Tee Pipe Assembly, With Two 1.00 Hose Barb, 8 X 15, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 5 X 15, Right Hand
Tee Pipe Assembly, With Two 1.00 Hose Barb, 5 X 15, Left Hand
Tee Pipe Assembly, With Two 1.00 Hose Barb, 4 X 15, Poly
X Pipe Assembly, With Three 1.00 Hose Barb, 6 X 20, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 5 X 20, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 6x20, Poly, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 3 X 20, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 2 X 20, Poly
L Bracket Assembly, With 2 1.00 Inch P Clips, Standard U, Bolt
Pipe Assembly, 90d With 1.00 Hose Barb, 6x20, Poly, Right Hand
2016-2017
Tee Pipe Assembly, With Two 1.00 Hose Barb, 3 X 20, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 5 X 20, Poly
Bracket Assembly, Straight, Large, P Clip, 1.00 U
L Bracket Assembly, With Two 1.00 P Clamp, Standard
Pipe Assembly, 90d With 1.00 Hose Barb, 5x50cm, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 3x50cm, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 2 X 50cm, Poly
X Pipe Assembly, With Three 1.00 Hose Barb, 6 X 50cm, Poly
Pipe Assembly, With .75 Hose Barb, 11 X 10, Poly
L Bracket Assembly, Long Straight, Poly Pipe Cilp
L Bracket Assembly, Long Straight, Poly Pipe Clip
Pipe Assembly, 90d With 1.00 Hose Barb, 15x10, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 6 X 10, Poly
Pipe Assembly, With .75 Hose Barb, 7 X 15, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 10x15, Poly
Pipe Assembly, With .75 Hose Barb, 6 X 20, Poly
Bracket Assembly, Straight, Long, 2ips Clip
L Bracket Assembly, Poly, Reverse P Clip
Pipe Assembly, 90d With 1.00 Hose Barb, 8x20, Poly
Pipe Assembly, With 1.00 Hose Barb, 6 X 50cm, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 8x50cm, Poly
Bracket Assembly, Straight, Long, 2ips Clip, 1.00 U
Pipe Assembly, 90d With 1.00 Hose Barb, 8x10, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 9 X 10, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 5x15, Poly
Pipe Assembly-Tee With 2 1.00 Hose Barb, 6x15, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 6 X 20, Poly
Pipe Assembly, 90d, With 1.00 Hose Barb, 6x50cm, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 2x50cm, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 6x50cm, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 15 X 10, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 6x50cm, Right Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 6x50cm, Left Hand
Pipe Assembly, 90d With 1.00 Hose Barb, 10 X 15, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 6 X 15, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 3 X 50cm, Poly
Triple Nozzle Assembly Option, 50cm X 80
Triple Nozzle Assembly Option, 50cm X 90
3 Way Rotary Nozzle Installation, 15x80
3 Way Rotary Nozzle Installation, 15x90
Rotary Nozzle Body, 3 Way, 1.00 Inch
Spray Bar Assembly, Rear
Nozzle Valve
Fence Row Nozzle Assembly 60 80 Boom
Endrow Pipe Assembly, 5 X 20, Poly
Electrical Valve, Reg, 2 Inch Flange X 1 Inch Fnpt
1Booms
Boom Installation, 80 Foot, Right Hand
Boom Installation, 80 Foot, Left Hand
Boom Assembly, 80 Foot
Hydraulic Tip Fold Cylinder Assembly
80, 90, 100 Foot
Boom Installation, 90 Foot, Right Hand
Boom Installation, 90 Foot, Left Hand
Boom Assembly, 90 Foot
Boom Rest Block Assembly
Boom Hinge Option, 60 80 90
Hinge Assembly, 60 80 90, Right Hand
Hinge Assembly, 60 80 90, Left Hand
Boom Tilt Cylinder Assembly, With Accumulator, Left Hand
Boom Hinge Option, With Height Control, 80 90
Breakaway Cam Assembly, 60 80
Boom Option, 60 80
Boom Option, 6090
Boom Breakaway Cam Assembly
Flag Pin
Boom Tilt Rack Installation, 60 90
Boom Tilt Rack Assembly
Boom Lift Installation, Parallel Link
Boom H Frame Installation
Boom H Frame Assembly, Rear
Hydraulic Boom Swing Cylinder Assembly
Hydraulic Cylinder, 2.75 X 11 X 1.38
1Foam Marker
Foam Marker Plumbing Installation, Boom, 80 Foot
Foam Marker Plumbing Installation, Boom, 90 Foot
Foam Marker Installation, Tank And Pumps
Foam Marker Assembly, Tank And Pumps
Foam Marker Airline Installation
Foam Marker Mixing Chamber, Richway
1Hydraulic System
Hose Installation, Boom Tilt, 6080 90
Boom Tilt Cylinder Installation
Boom Tilt Cylinder Assembly, With Accumulator, Right Hand
Hydraulic Hoist Cylinder Assembly
Hydraulic And Electric Installation, Norac, 60 80 90
Tilt Cylinder Installation, Autoboom
Hose Installation, Hydraulic, H Frame
Hydraulic Block Installation, 7 Bank Boom, Without Autoboom
Hydraulic Block Assembly, 7 Bank Boom Valve, Without Autoboom
Hydraulic Block Installation, Norac, Small Boom
Electrical Installation, System, Norac
Sensor Assembly, Roll, Norac
Valve Block, Shut Off, Accumulator, Cylinder
Cap Installation, Standard, Without Boom
Hydraulic Block Installation, 7 Bank Boom, With Autoboom
Hydraulic Block Assembly, 7 Bank Boom Valve, With Autoboom
Valve Block Assembly, Autoboom, Raven
Cap Installation, Raven, Without Boom
Hose Installation, Hydraulic, H Frame Only
Hydraulic And Electric Installation, Norac Ready
Hydraulic Installation, Norac Without Boom
Hydraulic Installation, Boom Hoist
Boom Tip
Hydraulic Block Assembly, Norac, Passive
Hydraulic Block, Norac, Passive
1Electrical System
Kit, Repair
2015
Worklight Installation
Worklight
Electrical Installation, System, Raven
Electrical System Installation, Topcon
Electrical Installation, System, Accuboom
Electrical Installation, System, Autoboom
Electrical Installation, System, 5 Section
Electrical Installation, System, 7 Section
Switch Installation, End Row
End Row Switch Installation, Cab
Plug Installation, No End Row
No Work Light Installation, System
Worklight Installation, Halogen, Liquid System
Electrical Installation, System, Autoboom, No Boom
Electrical Installation, System, Falcon Vt
Taillight Assembly, Led, Speaker, Molded, Ss
Worklight, Hid
I O Module Valve, Norac
Taillight Assembly
1Controller System
Control Installation, System
Sensor Installation, Autoboom, 90 Foot
Sensor Installation, Autoboom, Center
Ultrasonic Sensor, Digital
Sensor Installation, Autoboom, Inner Boom
Ultrasonic Sensor
Sensor Installation, Autoboom, 80 Foot
Sensor Installation, Norac, Inner Boom
Sensor Mounting Assembly, Low Profile, Short Flange
Norac
Sensor Installation, Norac, 80 Foot
Sensor Installation, Norac, Boom, 80 Foot
Boom Sensor Arm Assembly
Sensor Installation, Norac, 90 Foot
Sensor Installation, Norac, Center
Sensor Assembly, Center, Norac
1Decals
2016-2018
1Attachments
Rinse Tank Assembly, 8 Gallon
Sign Installation, Slow Moving Vehicle
Sign Installation, Speed Indicator Sign, 30 Mph
Sign Installation, Speed Indicator Sign, 50 Kph
License Bracket Installation Option, Liquid System
License Bracket Installation, Liquid System
Limiter Installation, Standard
Limiter Installation, Crop Shields
Electrical Box Assembly
1Accessories
Field Accessories, Chemical Eductor, Poly
Field Accessories, Foam Marker Power Unit And Plumbing
Field Accessories, Nozzle, Fence Row, 60 80 90
Brand: Challenger
Product Containment
Rg700 Rg700b
2014-2015
2016-2019
Sump Valve Assembly
Tank Ball Valve
No Eductor Option
Manifold
Poly
2016-2017
Nozzle Valve
1Booms
80, 90, 100 Foot
Boom Option, 60 80
Boom Option, 6090
Flag Pin
1Foam Marker
1Hydraulic System
Boom Tip
1Electrical System
Kit, Repair
2015
Worklight
Worklight, Hid
Taillight Assembly
1Controller System
Ultrasonic Sensor
Norac
1Decals
2016-2018
1Attachments
1Accessories
