Challenger RG1100C Rogator Liquid System Parts Catalog 652176
Brand: Challenger
Type of Machine: Applicators
Model: Challenger RG1100C Rogator Liquid System (2018-2021)
Serial Number: ..JXXX1001-..MXXX9999
Part Number: 652176
Number of Pages: 3500 Pages
Product Containment
Liquid System
Tank And Saddle Assembly, 1100 Gallon, 3x2
Tank Assembly, 1100 Gallon, Ss, 3 X 2 Inch
Ball Valve, Flange, Electric
Valve Body Assembly, Flanged, 1.00, 2w
Saddle Assembly, Boom Tree, 1100 Gallon, Ss
Boom Stop Bracket Assembly, Left Hand
Boom Stop Bracket Assembly, 1100 1300 Gallon, Right Hand
Boom Stop Bracket Assembly, Right Hand
Rinse Tank Installation, Top, 1100 Gallon
Rinse Tank Assembly, Top, 1100 1300 Gallon
Cross Assembly, 1.50 Hose Barb X 1.50 Hose Barb X 1.50 X .75
Tiedown Installation, System
Boom Stop Brace Assemby, Right Hand, 1100 1300
Plumbing Installation-Rinse, 130 Gallon, 3x2
Ball Valve, 2.00 Sp Flange X 2.00 Male Quick Coupler
Ball Valve, 2.00 Inch, Poly
Tank And Saddle Assembly, 1100 Gallon, 4x3
Tank Assembly, 1100 Gallon, Ss, 4 X 3 Inch
M220, 2 Way
Ball Valve, 2-Way, Mx
Plumbing Installation-Rinse, 130 Gallon, 4x3
Sight Gauge Installation, 1100 Gallon
Sight Gauge Assembly, Front, 1100 Gallon
Sight Gauge Assembly, Rear, 1100 Gallon
Sight Gauge Installation, 1100 Gallon, International
Sight Gauge Assembly, Front, 1100 Gallon, International
Sight Gauge Assembly, Rear, 1100 Gallon, International
Hoist Installation, Liquid System, 90 100
Combo Support, Front, 80 90 100
Hoist Installation, Liquid System, 120
Combo Support, Front, 120
Support Assembly, Spreader, Combo
Catwalk Installation, Rear, Right Hand, 1100 1300
Pump Support Assembly, 3x2
Pump Support Assembly, 4x3
Tank Assembly, 40 Gallon, Injection System, Left Hand
Ball Valve, Union, Poly, 1.00npt
Tank Assembly, 40 Gallon, Injection System, Right Hand
Tank Support Assembly, Injection
Primary Product Distribution
Actuator, 000-60-M-9
Large Tree
Valve Assembly, Rear, Sight Gauge
Ball Valve, 1.00 Inch Full Port Flange, Electric
Ball Valve, 0.75 Npt, Union, Poly
Small Tree
Flange
Ball Valve, 2.00 Inch, Full Port Flange, Electrical
Valve, 2.00 Full Port, With Flange
Electric Ball Valve, 2.00 Inch Full Port Flange
Ball Valve, 3.00 Inch, Poly, Full Flow
Ball Valve, Prostop-E
3 Way Valve, Bottom Load, 2.00 Standard Port Flange
900
Centrifugal Pump, 2.00 X 1.50, 9306chm5
Hydraulic Motor, Hm5 Without Bypass
Centrifugal Pump, 3.00 X 2.00, 9307
Chemical Eductor Installation, 7 Gallon, Poly
Chemical Eductor, Cleanload, 7 Gallon
Tank Ball Valve
Control Box Assembly, Pressure Manifold Plumbing
Injection System
Elbow And Flange Assembly, 90 Degree, 3.00, Ss
Fitting Assembly, 4 Hole Compression Flange X Flange, 3.00
3x2 Plumbing
4x3 Plumbing
Loose Option
Flowmeter Assembly-Raven, 3.00 Flange
Hose Installation, Injection System, #1
Hose Installation, Injection System, #2
#2
Strainer Body Assembly, .75 Inch
High Volume
Injection Pump, Raven, Integrated Node
Injection Assembly, 2 Inch Check Valve, 2 X 2 Inch Hose Barb
Injection Tank Stand Installation
Low Rate Assembly Kit, 2.00 Full Port Flange
Valve Assembly, Regulating, Pressure
Manifold Assembly, 2 Inch Flange
Manifold Assembly, 3 Inch Flange
Mounting Ring Assembly, Cleanload
Mixer Assembly, Chemical Injection, 4 X 3,Raven
Manifold Assembly, Front Reload, 4.00 Inch
Valve Assembly, 4.00 Inch, Electric, 3 Section, Key, Safi
Pressure Plumbing Assembly, 2.00, Without Chemical Injection
Y Strainer, 2.00 Inch, Full Port Flange, With 30 Mesh
Y Strainer, 2.00 Inch, Full Port Flange, With 50 Mesh
Hose Bracket And Clamp Assembly, 2.00
Pressure Plumbing Assembly, 3 Inch, Without Chemical Injection
Hose Bracket And Clamp Assembly, 3.00
Plumbing Assembly, Inlet, Injection Pump
With 40 Gallon Tank
2019
Pressure Injection Pump Plumbing Assembly
Z Bracket Assembly, Stauff, .75 Double
2020
Strainer Assembly, 3.00 Inch Full Port Flange
Strainer, 3.00 Line, 316 Ss
Pressure Plumbing Assembly, 2.00, With Chemical Injection
Pressure Plumbing Assembly, 3.00 Inch With Chemical Injection
Mixer, 4x3
Pressure Distribution Plumbing Assembly, 2.00
Product Pump Installation, 3 X 2 Plumbing
Pump Sub Assembly, 3.00 Suction, 2 X 1.5
Valve Assembly, Front, Pump Vent
Product Pump Installation, 4 X 3 Plumbing
Product Pump Assembly, 4 X 3
Reload Valve Sub Assembly, 4.00, Front, Air
Valve, 4.00 Inch, Butterfly With 10 Position Lever
Reload Installation, Front, Liquid System, 4x3, 4.00
Reload Installation, Front, Liquid System, 4x3, 3.00
Reload Installation, 3.00 Side, 3x2
Reload Installation, 3.00 Side, 4x3
Reload Installation, 4.00 Side, 4x3
50 Mesh
Sump Valve Option, 3.00 Inch, Electric
Sump Valve Option, 3.00 Inch, Manual
Valve, 3.00 Inch, Butterfly With 10 Position Lever
Sump Valve Option, 4.00 Inch, Electric
Sump Valve Option, 4.00 Inch, Manual
Stubby Valve, 3 Flange X 3 Male Quick Coupler
Suction Installation, 3.00 Inch, With Front Reload, Air
Valve Assembly, 3.00, Front Reload, Air
Y Fitting, Valve Assembly, With 45, 3.00 Inch, Butterfly
Hose Hanger Bracket Assembly, 3.00, Large
Front Reload
Suction Installation, 3.00 Inch, Without Front Reload
Suction Installation, 4.00 Inch, With Front Reload, Air
Valve Assembly, 4.00 Inch, Front Reload, Air
Hose Hanger Bracket Assembly, 4.00, Large
Suction Installation, 4.00 Inch, Without Front Reload
Valve Assembly, 3.00 Inch Electrical, Eh4, 3 Section
Valve Bracket Assembly, 3.00 Inch Butterfly, Small
1.5
Valve Bracket Assembly, 3.00 Inch Butterfly, Large
Valve Installation, Product Recovery-Clean Out Sump 3x2
Valve Installation, Product Recovery-Clean Out Sump 4x3
Secondary Product Distribution
Identification Chart
Plumbing Installation, Ss, 90 X 10, On
Pipe Assembly, 1.50 Inch, Boom Feed
Pipe Assembly, L 12, 17x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 31x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 31x10, Ss, Aspirator, Right Hand
Product Recovery
Pipe Assembly, 25.4 Poly, With 2 Hose Barb, .2835mm Er
Pipe Assembly, 25.4 Poly, With 2 Hose Barb .4105mm
L Bracket Assembly, Short Offset, Ips
L Bracket Assembly, Long, Stauff, Xlong Offset
L Bracket Assembly, Xxxlong, Stauff, Long U Bolt
L Bracket Assembly, Long, Stauff, 1.00p
L Bracket Assembly, Long, Stauff, 1.00p, Inverted
Z Bracket Assembly, Short, 1.00 P-Clip
Z Bracket Assembly, Short, 1.00 Ips
Z Bracket Assembly, Long, 1.00 Ips 1.50 P-Clip
Z Bracket Assembly, Long, Double 1.00 P-Clip
Z Bracket Assembly, Long, Double 1.00 P-Clip, Long U-Bolt
Z Bracket Assembly, 1.50 Stauff,1.00 Poly, Left Hand
Z Bracket Assembly, 1.50 Stauff,1.00 Poly, Right Hand
Z Bracket Assembly, Poly, Stauff, Reversed U
Z Bracket Assembly, Long, 1.00 Stauff
Z Bracket Assembly, Long, 1.50 Stauff
Bracket Assembly, Straight, 1.50, Stauff, Right Hand
Bracket Assembly, Straight, 1.50, Stauff, Left Hand
Bracket Assembly, Straight, Long, 1.00, P-Clip
Plumbing Installation, Ss, 90 X 15, On
Pipe Assembly, L 12, 11x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 12, 11x15, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 7x15, Ss, Aspirator, End Row
Pipe Assembly, L 16, 21x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 21x15, Ss, Aspirator, Right Hand
L Bracket Assembly, Long, Stauff, Reversed U
Plumbing Installation, Ss, 90 X 20, Off
Pipe Assembly, L 12, 9x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 12, 9x20, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 15x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 15x20, Ss, Aspirator, Right Hand
Poly Plumbing Installation, 90 X 20, Off
Pipe Assembly, L 12, 9x20, Poly, Left Hand
Pipe Assembly, L 12, 9x20, Poly, Right Hand
Pipe Assembly, L 16, 6x20, Poly, Aspirator
Pipe Assembly, L 16, 15x20, Pp, Aspirator, Left Hand
Pipe Assembly, L 16, 15x20, Pp, Aspirator, Right Hand
Plumbing Installation Ss, 90x50, Off
Pipe Assembly, L 12, 9x50, Ss, Aspirator, Left Hand
Pipe Assembly, L 12, 9x50, Ss, Aspirator, Right Hand
Pipe Assembly, 2x90d 1.00 Inch, 15x50, Ss, Left Hand
Pipe Assembly, 2x90d 1.00 Inch, 15x50, Ss, Right Hand
Pipe Assembly, 25.4 Poly, With 2 Hose Barb, .2530mm Er
Plumbing Installation, Ss, 100 X 10, On
4359 Mm
Pipe Assembly, L 12, 23x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 12, 23x10, Ss, Aspirator, Right Hand
Plumbing Installation, Ss, 100 X 15, On
Left Hand
Right Hand
Plumbing Installation, Ss, 100 X 20, Off
Pipe Assembly, 2x90d .75hb ,12x20, Ss, Aspirator, Left Hand
Pipe Assembly, 2x90d .75hb ,12x20, Ss, Aspirator, Right Hand
Poly Plumbing Installation, 100 X 20, Off
Pipe Assembly, L 12, 12x20, Poly, Aspirator, Left Hand
Pipe Assembly, L 12, 12x20, Poly, Aspirator, Right Hand
Plumbing Installation, Ss, 100 X 50, Off
Plumbing Installation, Ss, 120 X 10, On
2530 Mm
6096 Mm
Pipe Assembly, L 16, 16x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 16x10, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 17x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 17x10, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 33x10, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 33x10, Ss, Aspirator, Right Hand
Pipe Assembly, 1.50 Inch, Boom Feed, 45d, Left Hand
Pipe Assembly, 1.50 Inch, Boom Feed, 45d, Right Hand
L Bracket Assembly, Extra Long, Stauff, P-Clip, 1.00u
L Bracket Assembly, Long, Ips, 1.00 U Bolt
L Bracket Assembly, Xxlong, Stauff, Long U Bolt
L Bracket Assembly, 1.00 Stauff
Z Bracket Assembly, Long, 1.00 Stauff, Ss U-Bolt
Z Bracket Assembly, Long, Upper, Ips, Long U-Bolt
Bracket Assembly, Straight, Long, Ips, P Clip, Right Hand
Bracket Assembly, Straight, Long, Ips, P Clip, Left Hand
Bracket Assembly, Straight, Long, P-Clip, 1.00 U
Bracket Assembly, Straight, 1.50, Stauff, Standard
Bracket Assembly, Straight, 1.50, Stauff, Long U Bolt
Bracket Assembly, Straight, Extra Long, 1.00 P-Clip
Plumbing Installation, Ss, 120 X 15, On
Pipe Assembly, L 16, 11x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 11x15, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 22x15, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 22x15, Ss, Aspirator, Right Hand
Z Bracket Assembly, Poly, Stauff, 1.00 P-Clip
Mounting Bracket Assembly, Y Manifold, 45d
Plumbing Installation, Ss 120 X 20, Off
Pipe Assembly, L 16, 6x20, Ss, Aspirator, End Row
Pipe Assembly, L 16, 8x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 8x20, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 9x20, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 9x20, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 16x20, Ss, Aspirator, Left Hand
Poly Plumbing Installation, 120 X 20, Off
Pipe Assembly, L 16, 8x20, Poly, Left Hand
Pipe Assembly, L 16, 16x20, Poly, Left Hand
Pipe Assembly, L 16, 16x20, Poly, Right Hand
Pipe Assembly, L 16, 9x20, Poly, Left Hand
L Bracket Assembly, Ips
Z Bracket Assembly, Long, 2xips
Plumbing Installation, Ss, 120 X 50, Off
Pipe Assembly, L 16, 6x50, Ss, Aspirator, End Row
Pipe Assembly, L 16, 8x50, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 8x50, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 17x50, Ss, Aspirator, Left Hand
Pipe Assembly, L 16, 17x50, Ss, Aspirator, Right Hand
Left Outer
Left Center
Left Inner
Boom Tree
Right Inner
Right Center
Right Outer
Pipe Assembly, L 12, 17x10, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 8x20, Poly, Right Hand
Pipe Assembly, L 16, 16x20, Ss, Aspirator, Right Hand
Pipe Assembly, L 16, 9x20, Poly, Right Hand
Endrow Nozzle And Solenoid Assembly, Left Hand
Solenoid Valve, Nozzle Body, Arag, 150 Psi
Nozzle Valve
Endrow Nozzle And Solenoid Assembly, Right Hand
Endrow Nozzle And Solenoid Installation, 90 100 Foot
120 Foot Boom
Hose Installation, Manifold, 1.00 Inch
Rotary Nozzle Body, 5 Way, 1.00 Inch, Left Hand
Service Kit, Aspirator, 1.00
Booms
Axle Assembly, Autoboom Cushion, Left Hand
Hub
Axle Assembly, Autoboom Cushion, Right Hand
Boom Assembly, 90 Foot, Left Hand
Boom Retainer Assembly, Non 120
Adjustable
Linkage Assembly, Cylinder, Hydraulic, Inner Mid
Boom Assembly, 90 Foot, Right Hand
Boom Assembly, 100 Foot, Left Hand
Boom Assembly, 100 Foot, Right Hand
Boom Assembly, 120 Foot, Left Hand
Bumper Installation-Fold Back, 120, Lh
Bracket Installation, Mounting, Adjustable, Spring, Upper
Retainer Assembly, 120 Foot Boom, Liquid System
Tip Assembly-Fold Back, Boom, 120 Foot, Left Hand
120 Foot
Boom Rest Installation, Fold Back, 120 Foot, Left Hand
Boom Assembly, 120 Foot, Right Hand
Bumper Installation-Fold Back, 120, Rh
Tip Assembly-Fold Back, Boom, 120 Foot, Right Hand
Boom Rest Installation, Fold Back, 120 Foot, Right Hand
Aluminium
Boom Breakaway Cam Assembly
Boomrest Installation, Domestic
Boomrest Installation, Non Domestic
2018
Bumper Installation, Tree Limit, 120 Foot
Boom Tree Installation, Center, 5.00 Slide
Boom Tree Assembly, Center, 5.00 Slide
Heavy Duty, Large
Large Tree, Auto
Boom Tree Assembly, Sub, 5.00 Slide
Boom Hoist Cylinder Assembly
Large Boom
Boom Tree Assembly, Center, 2.50 Slide
Boom Tree Installation, Center, 90 100 Foot
Boom Tree Assembly, Center, 90 100 Foot
90 100 Foot
Boom Breakaway Cylinder Assembly
Boom Tip Guard Assembly, 120 Ft
90 Foot
100 Foot
Heavy Duty Wear Pad Plate Assembly
Mounting Arm Assembly, Wheel, 90 100 Foot
Spring Installation, Boom Level, Small Boom
Spring Installation, Boom Level, Large Boom
Passive, 90 100
Wear Pad Assembly, Passive, 120
Wheel Installation, Autoboom, 90 100 Foot
Wheel And Axle Assembly, Cushioned, Autoboom, Left Hand
Wheel And Axle Assembly, Cushioned, Autoboom, Right Hand
Wheel Installation, Autoboom, 120
Wheel Mounting Arm Assembly, 120 Foot
1Foam Marker
Boom Plumbing Installation, Foam Marker, 90 Foot, Rogator
Foam Marker Mixing Chamber, Richway
Boom Plumbing Installation, Foam Marker, 100 Foot, Rogator
Boom Plumbing Installation, Foam Marker, 120 Foot, Rogator
Foam Marker
Foam Marker Installation, Tank And Pumps
Foam Marker Assembly, Tank And Pumps
1Hydraulic System
Boom Tip Fold Cylinder Assembly
Cap Installation, Combo, Liquid System
Without Product Recovery Or Cleanout
Cylinder Installation, Boom Tip Fold
Hydraulic Block Installation, No Autoboom, Small Boom
Hydraulic Block Assembly, Boom, No Autoboom, Small Boom
Valve Block, 7 Bank, Without Autoboom, Small Boom
Hydraulic Block Installation, With Autoboom, 120
Hydraulic Block Assembly, Boom, 120, With Autoboom
Hydraulic Block Installation, With Autoboom, Small Boom
Hydraulic Block Assembly, Boom, With Autoboom, Small Boom
Valve Block, 7 Bank, With Autoboom, Small Boom
Valve Block Assembly, Autoboom, Raven
Hydraulic Block Installation, 120
Hydraulic Block Assembly, 120
Valve Block, 7 Bank, Without Autoboom, Large Boom
Hydraulic Block Installation, Without Autoboom, 120
Hydraulic Block Assembly, Without Autoboom, 120
Hydraulic Block Installation, Norac Small Boom
Hydraulic Block Installation, Norac Large Boom
Hydraulic Block Installation, Small Boom
Hydraulic Block Assembly, Small Boom
Hydraulic Block Assembly, Norac, Passive
Norac, Passive
Hydraulic Cap And Plug Installation
Hydraulic Hose Installation, 3x2
Hose Installation-Hydraulic, Boom Block, Rg
Hydraulic Pump, 45cc Ep Control
Hydraulic Damper Cylinder Installation, Norac, Small Boom
Hydraulic Damper Cylinder Installation, Norac, Large Boom
132 Foot Boom
Hydraulic Hose Installation, 120 Foot
80 90 100 Foot
Small Boom
Large Tree, 90 100
Hydraulic Hose Installation, 4x3
Large Tree, 120
90 100, Left Hand
90 100, Right Hand
Small Tree, 90 100
Passive
120 Foot, Left Hand
1Electrical System
Boom Sensor Arm Assembly
Breakaway Amber Flashing Warning Light Installation
100 Feet
120 Feet
90x10
90x15
90x20
90x50
100x10
100x15
100x20
100x50
120x10
120x15
120x20
120x50
Electric Installation, Norac, Passive
Box
Raven
No Boom
Norac 120
No Plumbing
Electric Installation, System
Electric Clamping Installation
Uc7
Reload
Harness, Flow Sensor
Nozzle Control Module Installation
Plug, -I O, Load, Simulator, 1500 Ohm
Rotating Beacon Lamp Assembly
System Installation, Single Injection, Rogator
Marker
Eame
Tail Light
1 Inch Mounting
Ultrasonic Sensor
Worklight Installation, #3, Dual Beam
#3
1Controller System
Boom Level Sensor Assembly , Norac
Norac
Roll Sensor Installation, Norac, Small Boom
Roll Sensor Installation, Norac, Large Boom
Small
Sensor Installation, Center Section, 80 90 100
Ultrasonic Sensor, Digital
Ultrasonic Sensor, Autoboom, Lh And Rh Mounting, 1.50 Inch
Sensor Installation, Center Section, 120
Sensor Installation, Norac, Boom, 90 100 Foot
Sensor Installation, Norac, Boom, 120 Foot
Sensor Assembly, Center, Norac, Small Boom
Sensor Assembly, Center, Norac, Large Boom
Autoboom
1Air System
Air Box Assembly, Boom Cleanout
Mounting Bracket Assembly, Air Box, Boom Cleanout, Small Tree
Mounting Bracket Assembly, Air Box, Boom Cleanout, Large Tree
1Decals
Option, Decal-Global
1Attachments
Raven Mount
Manifold
Without Chemical Eductor
Discharge Installation, Rear
License Bracket Installation, Liquid System
Center, Small, 100 Foot
Center, Large, 100 Foot
Center, Large, 120 Foot
Pressure Washer Plumbing Installation
Speed Indicator Symbol Installation, 35 Mph
Speed Indicator Symbol Installation, 55 Kph
1Accessories
Field Accessories, 3.00 Sump Valve, Electric
Field Accessories, 4.00 Sump Valve, Electric
Field Accessories, Control Box, Nozzle Prostop
Field Accessories, Eductor, Poly, Cleanload
Field Accessories, Endrow, 90 100 Foot
Field Accessories, Endrow, 120 Foot
Field Accessories, Foam Marker Power Unit And Plumbing
Field Accessories, Injection Mixer, 2.00 Inch
Field Accessories, Injection Mixer, 3.00 Inch
Field Accessories, Injection Plumbing, 2 Pumps, 2 Tanks
Iso System
Field Kit, Boom Valve Relocation
Cylinder, Norac Passive
Field Kit, Main System Harness
Field Service Kits
Package Parts, Prostop-E
