Challenger Rectangular Baler LB34 Parts Catalog 00721378
Brand: Challenger
Type of Machine: Rectangular Baler
Model: Challenger LB34 Rectangular Baler
Part Number: 00721378
Number of Pages: 531 Pages
Publication Information
Drives - Tongue, Hitch And Safety Chain
Drives - Jack Assembly
Drives - Tongue, Drive Shaft, And Mtg. Shield, (S.N. Hl74461 Thru Hl74480), (Standard)
Drives - Tongue, Drive Shaft, Mtg. And Shield, (S.N. Hl74481 And Later), (Standard)
Drives - Tongue, Drive Shaft, Mtg. And Shield, (S.N. Hn74163 And Later), (Bc Electronics)
Drives - Flywheel Clutch Assembly
Drives - Implement Driveline-Type 2, (1-3 8 Inch Diameter X 21 Spline)
Drives - Implement Driveline Assembly (Type 3), (1-3 4 Inch Diameter X 20 Spline)
Drives - Flywheel Brake Mounting
Drives - Gearbox Mounting
Drives - Gearbox, Flywheel And Crank Arm, (Standard)
Drives - Gearbox, Flywheel And Crank Arm, (Bc Electronics)
Drives - Gearbox Assembly, (700721657 Gearbox Assembly)
Drives - Auxiliary Drive (Left)
Drives - Auxiliary Drive (Right), (Standard)
Drives - Auxiliary Drive (Right), (Bc Electronics)
Drives - Shaft And Sprocket
Drives - Slip Clutch Assembly
Drives - Cutter Drive (Left)
Drives - Cutter Gearbox Assembly, (700140040 Gearbox Assembly)
Drives - Cutter Slip Clutch Assembly, (700140066 Slip Clutch Assembly)
Pickup - Pickup Mounting, (Without Cutter)
Pickup - Pickup Mounting, (With Cutter)
Pickup - Wrapper And Shields, (Without Cutter)
Pickup - Wrapper And Shields, (S.N. Hl74461 Thru Hp74100), (With Cutter)
Pickup - Wrapper And Shields, (S.N. Hp74101 And Later), (With Cutter)
Pickup - Pickup Flotation
Pickup - Pickup Drive (Left), (Without Cutter)
Pickup - Pickup Drive (Left), (S.N. Hl74461 Thru Hp74100), (With Cutter)
Pickup - Pickup Drive (Left), (S.N. Hp74101 And Later), (With Cutter)
Pickup - Pickup Drive (Right), (Without Cutter)
Pickup - Pickup Drive (Right), (S.N. Hl74461 Thru Hp74100), (With Cutter)
Pickup - Pickup Drive (Right), (S.N. Hp74101 And Later), (With Cutter)
Pickup - Pickup Clutch, (S.N. Hl74461 Thru Hl74480)
Pickup - Pickup Clutch, (S.N. Hl74481 And Later)
Pickup - Rotor
Pickup - Angle Assembly-Left
Pickup - Angle Assembly-Right
Pickup - Pickup Shields (Left), (Without Cutter)
Pickup - Pickup Shields (Left), (S.N. Hl74461 Thru Hp74100), (With Cutter)
Pickup - Pickup Shields (Left), (S.N. Hp74101 And Later), (With Cutter)
Pickup - Pickup Shields (Right), (Without Cutter)
Pickup - Pickup Shields (Right), (S.N. Hl74461 Thru Hp74100), (With Cutter)
Pickup - Pickup Shields (Right), (S.N. Hp74101 And Later), (With Cutter)
Pickup - Pickup Gauge Wheel, (Left Side Shown, Right Side Opposite)
Pickup - Windguard, (S.N. Hl74461 Thru Hp74100), (Without Cutter)
Pickup - Windguard, (S.N. Hp74101 And Later), (Without Cutter)
Pickup - Windguard, (S.N. Hl74461 Thru Hp74100), (With Cutter)
Pickup - Windguard, (S.N. Hp74101 And Later), (With Cutter)
Pickup - Cutter Mounting
Pickup - Cutter Assembly
Pickup - Rotor, (700139320 Rotor Assembly), (S.N. Hl74461 Thru Hp74100)
Pickup - Rotor, (S.N. Hp74101 And Later)
Pickup - Bearing
Pickup - Knife Mounting
Pickup - Knife Mounting, (Continued)
Electrical - Electrical Wiring And Sensors, (Standard)
Electrical - Wiring-Control Box, (Bc Electronics)
Electrical - Control Wiring (Upper), (Bc Electronics)
Electrical - Control Wiring (Upper), (Bc Electronics), (Continued)
Electrical - Control Wiring (Lower), (Bc Electronics)
Electrical - Cutter Wiring (Bc Electronics)
Electrical - Road Lights (Front)
Electrical - Road Lights (Rear)
Electrical - Work Lights
Electrical - Bale Ejector Electrical, (Standard)
Electrical - Console Control Box, (Standard)
Electrical - Electrical Harness Service Parts
Electrical - Electrical Service Parts, (Continued)
Electrical - Electrical Harness Service Parts, (Continued)
Charge And Plunger - Feeder Crank Mounting
Charge And Plunger - Charge Mounting, (S.N. Hl74661 Thru Hn74180)
Charge And Plunger - Charge Mounting, (S.N. Hn74181 And Later)
Charge And Plunger - Dog Clutch
Charge And Plunger - Brake
Charge And Plunger - Feeder Chute
Charge And Plunger - Feeder Chute, (Without Cutter)
Charge And Plunger - Feeder Chute, (With Cutter)
Charge And Plunger - Feeder Linkage And Door
Charge And Plunger - Finger Mounting
Charge And Plunger - Plunger Roller
Charge And Plunger - Plunger Cam And Crank Arm Bearings
Charge And Plunger - Ejector And Mounting
Charge And Plunger - Ejector Channel
Knotter And Lube - Needle And Mounting
Knotter And Lube - Tensioner, (S.N. Hl74461 Thru Hl74480)
Knotter And Lube - Tensioner, (S.N. Hl74481 And Later)
Knotter And Lube - Tensioner Assembly, (6845077 Tensioner Assembly), (S.N. Hl74461 Thru Hl74480)
Knotter And Lube - Tensioner Assembly, (700139336 Tensioner Assembly), (700139338 Tensioner Assembly), (S.N. Hl74481 And Later)
Knotter And Lube - Tension Arm
Knotter And Lube - Knotter Mounting
Knotter And Lube - Knotter Frame
Knotter And Lube - Drive And Cam Assembly
Knotter And Lube - Knotter Head Assembly, (700113321 Knotter Head Assembly)
Knotter And Lube - Knotter Head Assembly, (Continued)
Knotter And Lube - Drive Clutch Assembly (Knotter Cam)
Knotter And Lube - Knotter Brake
Knotter And Lube - Knotter Twine Finger And Hay Dogs, (S.N. Hl74461 Thru Hl74480)
Knotter And Lube - Knotter Twine Finger And Hay Dogs, (S.N. Hl74481 And Later)
Knotter And Lube - Knotter Arm
Knotter And Lube - Starwheel Mounting, (S.N. Hl74461 Thru Hl74480)
Knotter And Lube - Starwheel Mounting, (S.N. Hl74481 And Later)
Knotter And Lube - Lube Pump And Line-Twine Finger
Knotter And Lube - Lube Pump And Line-Knotter
Knotter And Lube - Knotter Lube
Knotter And Lube - Lube Knotter Kit, (700710807 Lube Knotter Kit)
Knotter And Lube - Knotter Monitor
Knotter And Lube - Lube (Front), (Standard)
Knotter And Lube - Lube (Front), (Bc Electronics)
Knotter And Lube - Lube (Rear)
Knotter And Lube - Lube (Packer Crank)
Knotter And Lube - Lube Pump Assembly, (700720087 Lube Pump Assembly), (Standard)
Knotter And Lube - Lube Pump Assembly, (700725825 Lube Pump Assembly), (Bc Electronics)
Knotter And Lube - Harness-Rear Valve
Knotter And Lube - Harness-Front Valve, (Without Cutter)
Knotter And Lube - Harness-Front Valve, (With Cutter)
Knotter And Lube - Harness-Primary Valve
Knotter And Lube - Lube (Harness Service Parts), (700720098 Kit-Baler Lube System)
Knotter And Lube - Lube Reservoir-Centralized
Knotter And Lube - Manual Fill Lube Kit, (700726183 Manual Fill Lube Kit)
Frame, Wheels And Shields - Plunger Rails, Knives And Hay Dogs
Frame, Wheels And Shields - Bale Density Door And Arms
Frame, Wheels And Shields - Front And Idl Shields, (Standard)
Frame, Wheels And Shields - Front And Idl Shields, (Bc Electronics)
Frame, Wheels And Shields - Top Shields
Frame, Wheels And Shields - Knotter Shields
Frame, Wheels And Shields - Main Shields (Left), (Without Cutter)
Frame, Wheels And Shields - Main Shields (Right), (Without Cutter)
Frame, Wheels And Shields - Main Shields (Left), (With Cutter)
Frame, Wheels And Shields - Main Shields (Right), (With Cutter)
Frame, Wheels And Shields - Cutter Shields-Left
Frame, Wheels And Shields - Cutter Shields-Right
Frame, Wheels And Shields - Shield-Tandem (With Cutter)
Frame, Wheels And Shields - Shield-Tandem (Without Cutter)
Frame, Wheels And Shields - Shields-Single (With Cutter)
Frame, Wheels And Shields - Shields-Single (Without Cutter)
Frame, Wheels And Shields - Twine Box Mounting
Frame, Wheels And Shields - Twine Box Assembly (Front-Left), (700138112 Twine Box Assembly), (S.N. Hl74461 Thru Hl74480)
Frame, Wheels And Shields - Twine Box Assembly (Front-Left), (700139344 Twine Box Assembly), (S.N. Hl74481 And Later)
Frame, Wheels And Shields - Twine Box Assembly (Rear-Left), (700138121 Twine Box Assembly), (S.N. Hl74461 Thru Hl74480)
Frame, Wheels And Shields - Twine Box Assembly (Rear-Left), (700139349 Twine Box Assembly), (S.N. Hl74481 Thru Hr74388)
Frame, Wheels And Shields - Twine Box Assembly (Rear-Left), (700139828 Twine Box Assembly), (S.N. Hr74389 And Later)
Frame, Wheels And Shields - Twine Box Assembly (Front-Right), (700138117 Twine Box Assembly), (S.N. Hl74461 Thru Hl74480)
Frame, Wheels And Shields - Twine Box Assembly (Front-Right), (700139354 Twine Box Assembly), (S.N. Hl74481 And Later)
Frame, Wheels And Shields - Twine Box Assembly (Rear-Right), (700140299 Twine Box Assembly), (S.N. Hl74461 Thru Hl74480)
Frame, Wheels And Shields - Twine Box Assembly (Rear-Right), (700139358 Twine Box Assembly), (S.N. Hl74481 Thru Hr74388)
Frame, Wheels And Shields - Twine Box Assembly (Rear-Right), (700139831 Twine Box Assembly), (S.N. Hr74389 And Later)
Frame, Wheels And Shields - Ladder And Shield Mounting (Single Axle)
Frame, Wheels And Shields - Ladder And Shield Mounting (Tandem)
Frame, Wheels And Shields - Shields-Right (Tandem)
Frame, Wheels And Shields - Hand Rails And Mounting
Frame, Wheels And Shields - Axle (Single), (W O Brakes)
Frame, Wheels And Shields - Axle (Single), (W Brakes)
Frame, Wheels And Shields - Brake Assembly-Left (Single Axle), (700140468 Brake And Spindle Assembly)
Frame, Wheels And Shields - Brake Assembly-Right (Single Axle), (700140469 Brake And Spindle Assembly)
Frame, Wheels And Shields - Axles (Tandem)
Frame, Wheels And Shields - Axle Assembly-Rigid, Tandem (W O Brakes), (700720509 Axle Assembly Rigid)
Frame, Wheels And Shields - Axle Assembly-Rigid, Tandem (W Brakes), (700720484 Axle Assembly-Rigid)
Frame, Wheels And Shields - Axle Asm-Steering, Tandem (W O Brakes), (700720510 Axle Assembly-Steering)
Frame, Wheels And Shields - Axle Asm-Steering, Tandem (W Brakes), (700720483 Axle Assembly-Steering)
Frame, Wheels And Shields - Axle Asm-Steering, Tandem (Left), (W Brakes), (Continued)
Frame, Wheels And Shields - Axle Asm-Steering, Tandem (Right), (W Brakes), (Continued)
Frame, Wheels And Shields - Park Brake (Single)
Frame, Wheels And Shields - Park Brake (Tandem)
Frame, Wheels And Shields - Actuator Assembly-Park Brake, (700721855 Actuator Assembly)
Frame, Wheels And Shields - Wheel And Mounting (Single Axle), (W O Brakes)
Frame, Wheels And Shields - Wheel (Single Axle), (W Brakes)
Frame, Wheels And Shields - Wheel (Tandem)
Hydraulics - Hydraulics (Front), (Standard)
Hydraulics - Hydraulics (Front), (Bc Electronics)
Hydraulics - Control Valve Assembly (Bale Density), (700720279 Valve Assembly), (Standard)
Hydraulics - Control Valve Assembly (Bale Density), (700725828 Control Valve Assembly), (Bc Electronics)
Hydraulics - Hydraulic Cylinder Assembly, (700712122 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Bale Density
Hydraulics - Hydraulic Cylinder Asm.-Density Control, (700715969 Hydraulic Cylinder Assembly)
Hydraulics - Bale Ejector Hydraulics, (Standard)
Hydraulics - Bale Ejector Hydraulics, (Bc Electronics)
Hydraulics - Hydraulic Control Valve Assembly, (700725830 Control Valve Assembly), (Bc Electronics)
Hydraulics - Hydraulic Cylinder Asm. (Bale Ejector), (700713998 Hydraulic Cylinder Assembly)
Hydraulics - Cutter Hydraulics
Hydraulics - Cutter Valve Assembly-Cross Port Relief, (700720347 Valve Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Cutter Bed), (700720351 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulics (Tandem)
Hydraulics - Hydraulics (Tandem), (Continued)
Hydraulics - Brakes (Single)
Hydraulics - Brakes (Tandem)
Hydraulics - Brakes (Tandem), (Continued)
Hydraulics - Knotter Blower Mounting
Hydraulics - Knotter Blower Mounting, (Continued), (S.N. Hl74461 Thru Hr74496)
Hydraulics - Knotter Blower Mounting, (Continued), (S.N. Hr74497 And Later)
Hydraulics - Blower And Reservoir
Hydraulics - Blower Assembly, (700717713 Blower Assembly)
Hydraulics - Hydraulic Pump Assembly, (700717866 Hydraulic Pump Assembly), (S.N. Hl74461 Thru Hl74480)
Hydraulics - Hydraulic Pump Assembly, (700722236 Hydraulic Pump Assembly), (S.N. Hl74481 And Later)
Hydraulics - Hydraulic Motor Assembly, (700717759 Hydraulic Motor Assembly), (S.N. Hl74461 Thru Hn74565)
Hydraulics - Hydraulic Motor Assembly, (700723555 Hydraulic Motor Assembly), (S.N. Hn74566 And Later)
Decals And Kits - Decals And Location Diagram, (S.N. Hl74461 Thru Hn74163), (Without Cutter)
Decals And Kits - Decals And Location Diagram, (S.N. Hn74164 And Later), (Without Cutter)
Decals And Kits - Decals And Location Diagram, (S.N. Hl74461 Thru Hn74163), (With Cutter)
Decals And Kits - Decals And Location Diagram, (S.N. Hn74164 And Later), (With Cutter)
Decals And Kits - Decals-Operational
Decals And Kits - Decals-Operational, (Continued)
Decals And Kits - Safety Tread And Twine Box Decals, (S.N. Hl74461 Thru Hl74480)
Decals And Kits - Safety Tread And Twine Box Decals, (S.N. Hl74481 And Later)
Decals And Kits - Decals-Ejector
Decals And Kits - Electrical Kit (Box Of Service Parts), (700154471 Box Of Service Parts)
Decals And Kits - Lube Kit-Centralized (Box Of Parts), (700114079 Box Of Service Parts)
Decals And Kits - Knotter Service Kit, (700150670 Box Of Parts)
Decals And Kits - Shear Bolt Kits
Decals And Kits - Implement Driveline-Type 2 Kit, (Bk41070 Implement Driveline-Type 2 Kit)
Decals And Kits - Implement Driveline-Type 3 Kit, (Bk41071 Implement Driveline-Type 3 Kit)
Decals And Kits - Knotter Blower Kit, (Bk40954 Knotter Blower Kit)
Decals And Kits - Knotter Blower Kit, (Continued)
Decals And Kits - Blower And Reservoir
Decals And Kits - Blower Assembly, (700717713 Blower Assembly)
Decals And Kits - Hydraulic Pump Assembly, (700722236 Hydraulic Pump Assembly)
Decals And Kits - Hydraulic Motor Assembly, (700723555 Hydraulic Motor Assembly)
Decals And Kits - Bale Chute Kit, (Bk41084 Bale Chute Kit)
Decals And Kits - Bale Chute-Roller Kit, (Bk40934 Bale Chute Roller Kit), (Standard)
Decals And Kits - Bale Chute-Roller Kit, (Continued)
Decals And Kits - Bale Chute-Roller Kit, (Bk41086 Bale Chute-Roller Kit), (Bc Electronics)
Decals And Kits - Accumulator Mounting Kit, (Bk40964 Accumulator Mounting Kit), (Standard)
Decals And Kits - Accumulator Mounting Kit, (Bk41128 Accumulator Mounting Kit), (Bc Electronics)
Decals And Kits - Accumulator Mounting Kit, (Continued)
Decals And Kits - Fieldstar Monitor Kit, (Bk41106 Fieldstar Monitor Kit)
Decals And Kits - Hydraulic Load Sensing Kit, (Bk41152 Hydraulic Load Sensing Kit)
Decals And Kits - Decal Kit (Spanish), (700724259 Decal Kit-Spanish)
Decals And Kits - Decal Kit (French), (700724258 Decal Kit-French)
Accumulator - Mainframe And Caster Mounting
Accumulator - Cart (Unlatching)
Accumulator - Bale Shift Bar And Linkage
Accumulator - Caster, Hub And Wheel, (Left Shown, Right Opposite)
Accumulator - Hitch And Bale Support
Accumulator - Cart-Left
Accumulator - Cart-Right
Accumulator - Frame And Panel (Rear)
Accumulator - Lube (Centralized For Accumulator)
Accumulator - Lube-Accumulator Kit, (700710808 Lube Accumulator Kit)
Accumulator - Electrical
Accumulator - Electrical Control Box Assembly, (6811137 Control Box Assembly)
Accumulator - Selector Valve Mounting
Accumulator - Hydraulic And Electrical
Accumulator - Road Light
Accumulator - Electrical Harness Service Parts
Accumulator - Hydraulic Cylinder Assembly, (7896079 Hydraulic Cylinder Assembly)
Accumulator - Decal And Location Diagram
Accumulator - Bale Weight Kit, (Bk41118 Bale Weight Kit)
Accumulator - Bale Weight Kit, (Continued)
Accumulator - Accumulator Mounting Kit, (Bk41225 Accumulator Mounting Kit), (For Accumulator S.N. Hs35101 And Later)
Recommended Dealer Stock - Recommended Dealer Stock
Brand: Challenger
Pickup - Rotor
Pickup - Bearing
