Challenger Planter 9523VER 24R HZ FF PP Parts Catalog 652346
Brand: Challenger
Type of Machine: Planter
Model: Challenger 9523VER 24R HZ FF PP Planter 2019
Part Number: 652346
Number of Pages: 1247 Pages
Frame
Hitch And Tongue Braces
Tongue And Latch Mounting - 30 Foot
Tongue And Latch Mounting - 40 Foot
Tongue And Latch Mounting - 45 Foot
Mainframe And Wings - 30 And 40 Foot
Mainframe And Wings - 45 Foot
Wings - 30 Foot
Wings - 40 Foot
Wings - 45 Foot
Marker, Tri-Fold - 30 Foot
Folding Marker - Left Hand
Folding Marker - Right Hand
Hub - Marker Disc
Marker Hub Assembly
Notched Marker Disc
Row Unit Spacing - Center
Harness And Test Switch
Parallel Link - With Angles
Row Unit
Lower Assembly - Row Unit
Lever - Depth Adjustment
Lockup
Parallel Link - Extension
Row Unit Spacing - Left Wing
Parallel Link
Row Unit Spacing - Right Wing
Row Unit Spacing - Wing
Main Frame Lift Wheel
Hub Assembly-Wheel - Main Frame Lift Wheel
Wheel And Tire Assembly
Wing Lift Wheel
Wheel Hub Assembly - Wing Lift Wheel
Drive System
Chain - Row Unit
Row Unit Chain - Set Back
Chain Drive - Center
Sprocket And Tensioner - Without Swath
Support - Shaft
Chain Drive - Left Wing
Chain Drive - Right Wing
Drive Sprocket Assembly
Drives - Center
Tensioner
Lift Switch
Drives - Left Wing
Storage Tube
Drives - Right Wing
Drives - Upper
Driveline Assembly
Mounting - Motor
Flex Shaft Drive
Mounting - Gearbox
Gearbox - Metering Unit
Flex Shaft Drive - Center
Support And Braces - Flex Shaft Drive
Flex Shaft Drive - Left Wing
Flex Shaft Drive - Right Wing
Point Row Clutch
Point Row Clutch Kit - Components
Without Point Row Clutch
Clutch - Point Row Shutoff
Drive Chains
Hydraulics - Central Fill System
Center Fill Blower Control Valve Assembly
Air Compressor
Pto Pump And Mount
Pump And Reservoir - Pto
Rear Hydraulics - 30 Foot
Blower Assembly
Rear Hydraulics - 40 Foot
Rear Hydraulics - 45 Foot
Hydraulic Valve, Load Sense Blocking
Control Valve - Dual Flow Control
Blower Motor - Hydraulic
Hydraulic Drive Motor
Hydraulic Motor Assembly
Blower Hydraulics - Center Fill
Control Valve - Blower
Tongue Lift - Hydraulics
Hydraulic Cylinder Assembly - Tongue Lift
Lift And Lower Hydraulics
Flow Divider - Hydraulic
Hydraulic Control Valve
Lift - Left Hand
Lift And Lower Hydraulics - Right Hand
Lift And Lower Hydraulics - Left Hand
Frame Fold Hydraulics - Left Hand
Frame Fold Hydraulics - Right Hand
Frame Fold Hydraulics - Center
Hydraulic Cylinder Assembly - Fold
Wheel Lift Hydraulics - Center And Left Wing
Wheel Lift Hydraulics - Center And Right Wing
Wing Wheel Lift Hydraulics
Hydraulic Cylinder Assembly - Wheel Lift
Hydraulic Cylinder - Wheel Lift
Hydraulic Flow Divider Assembly - Wheel Lift
Marker Hydraulics - Front
Sequencing Valve - Hydraulic
Marker Hydraulics - Left Hand
Marker Hydraulics - Right Hand
Marker Hydraulic - Right Hand
Hydraulic - Fold
Fold - Hydraulic
Marker Hydraulics
Hydraulic Cylinder - Marker
Hydraulic Cylinder
Hydraulics - Marker Mounting Hydraulics
Hydraulics - Marker Hydraulic Cylinder Assembly
Quick Coupler
Electrical Connectors - Kit, Repair
Row Sensor, Tongue - Harness
Row Sensor - Mounting
Row Sensor, Left
Row Sensor, Center Left
Row Sensor, Center Right
Row Sensor, Right
Iso Harness - Hydraulic Drive System
Iso Harness - Monitor
Harness - Hydraulic Drive, Actuator
Point Row Clutch - Harness
Lighting
Lighting - 20 Inch Row
Lighting - 30 Foot
Lighting - 40, 45 Foot
Transport Lights
Harness - Gta Console
Harness And Test Switch - Gta Console
Wire Harness - Test Switch
Radar Gun
Radar Y Harness
Mounting - Lift Switch
Repair Kit - Harness
Seed Tube - Attaching Parts
Sensor And Tube - Seed Smart
Sensor And Tube - High Rate
Swath Control Harness - Frame
Swath Control Harness - Center
Swath Control Harness - Left Wing
Swath Control Harness - Right Wing
Electrical Connectors - Deutsch And Metri-Pack
Electrical Connectors - Weather Pack
Electrical Connectors - Amp And Deutsch
Electrical Connectors - Amp, Deutsch And Metri-Pack
Product Containment
373_2 Bushel Hopper
374_3 Bushel Hopper
Hopper Support - Components
Hopper Support
Hopper And Meter - 2 Bushel Hopper
Hopper And Meter Kit - 3 Bushel Hopper
379_3 Bushel Hopper
Seed Meter - Components
Hopper And Meter - Central Fill System
Central Fill System
Seed Tube
Manifold - Central Fill System
Decals - Central Fill System
Seed Module And Mounting
Seed Module Plenums And Air Boxes - Left Hand
Tank - Left Hand
Seed Module Plenums And Air Boxes - Right Hand
Tank - Right Hand
Decal Location - Central Fill System
Hopper - Support
Seed Module
Seed Tube Divider
Seed Disc Identification Chart
Soil Conditioning
Coulter - Without Blade
Arm - Coulter
Bubble Blade
Fluted Blade - 8 Flute
Fluted Blade - 13 Flute
Fluted Blade - 25 Flute
Ripple Blade
Shark Tooth Wheel - Mounting
Wheel Assembly - Shark Tooth, 13 Inch
Shark Tooth Wheel With Depth Band - Mounting
Shark Tooth Wheel With Depth Band - Left Hand
Shark Tooth Wheel With Depth Band - Right Hand
Wheel Assembly - Spoke Tooth, 10 Inch
Spoke Tooth, 13 Inch - Left Hand
Spoke Tooth, 13 Inch - Right Hand
Row Units
Down Pressure Springs - Heavy Duty
Down Pressure Springs - Standard
Pneumatic Down Pressure - Center
Pneumatic Down Pressure - Set Back
Pneumatic Down Pressure - Left Wing
Pneumatic Down Pressure - Right Wing
Pneumatic Down Pressure - Wing
Attaching Parts - No Closing Wheel
Angled Bracket - Closing Wheel
Closing Wheel - Cast
Closing Wheel - Rubber
Closing Wheel Assembly - Rubber
Single Closing Wheel Kit
Closing Wheel
Mounting - Opener Disc
Disc Assembly
Opening Disc Hub
Gauge Wheel Assembly
Gauge Wheel Arm - Left Hand
Gauge Wheel Arm - Right Hand
Scraper - Gauge Wheel
Residue Manager - Frame
Residue Manager - Row Unit
Residue Manager - Shark Tooth
Residue Manager - Spoke Tooth, 13 Inch
Mounting - Coulter
Row Unit Coulter Mounting - Without Blade
Seed Meter Funnel
Shark Tooth Residue Manager - Row Unit Mounted
Trash Master - Row Unit Mounted
Blade - Trash Master Kit
Residue Manager Kit - Shark Tooth
Application System
Air Duct - Without Hopper
Blower Assembly - Seed Module
Compressor
Manifold Assembly
Air Duct - 30 Foot
Air Duct - 40 Foot
Air Duct - 45 Foot
Air Duct - Center
Air Duct - Left Hand
Air Duct - Right Hand
Decal Installation - Challenger
Decal Installation - Center
Decal Installation - Left Wing
Decal Installation - Right Wing
Decal Location - 30 Foot
Decal Installation
Reflector Plate - Orange
Reflector Plate - Red
Reflector Plate - Yellow
Slow Moving Vehicle Emblem
Bracket Assembly - Angle Closing Wheel
Blower Inlet Kit
Control Box - Fold System
Control Box Kit - Wiring Harness
Service Connectors, Harness Repair
Sgr-1 Receiver And Cable Kit
Switch - Swath Control
Module - Swath Control
Pto Coupler Kit - 1000 Rpm, 1-3 4 Inch
Closing Wheel Kit - Rubber
Closing Wheel Kit - Cast
Pneumatic Down Pressure Kit - Compressor Box
Pressure Spring Kit - Heavy Duty
Residue Manager Attachment Kit - Spoke Tooth, 10 Inch
Residue Manager Attachment Kit - Spoke Tooth, 13 Inch
Residue Manager Kit - Shark Tooth, 13 Inch
Residue Manager Kit - Spoke Tooth, 10 Inch
Residue Manager Kit - Spoke Tooth, 13 Inch
Closing Wheel And Mounting - Single
Blades - Coulter
Trash Master Kit - Row Unit Mounted
Sensor And Tube Kit - High Rate
