Challenger Planter 9202 9222 Parts Catalog 79036400
Brand: Challenger
Type of Machine: Planter
Model: Challenger 9202, 9222 Planter
Part Number: 79036400
Number of Pages: 746 Pages
Frame
Filters & Belts Guide
Support
Marker - Left Hand
Marker - Right Hand
Marker Hub Assembly
Mounting - Transport Chain
Tongue And Latch Mounting
Tongue And Latch Mounting - Hydraulic Drive
Jack Assembly
Blower Assembly - Hydraulic Drive
Hydraulic Motor - Blower
Main Frame
Mainframe And Wings
Latch - Center
Wheel Mounting
Wheel Arm - Outer
Wheel Arm - Inner
Transport Wheel
Wheel Hub - Transport Wheel
Wheel Hub - Outer
Wheel Hub - Drive Wheel
Wheel Arm
Wheel
Scraper - Drive Wheel
Offset Shank
Offset Shank Clamp
Clamp Plate - Double
Drive System
Ground Drive - Bearing Support
Ground Drive
Ground Drive - Drive Shaft
Mounting - Ground Drive Transmission
Ground Drive Transmission - Tensioner Arm
Drive Chains
Ground Drive Transmission - Sprocket
Sprocket Cluster - Transmission
Transmission Drive Sprocket
Sprocket And Tensioner - Ground Drive
Ground Drive - Without Fertilizer
Fertilizer Drive
Fertilizer Drive - Lockup
Arm - Fertilizer
Fertilizer Drive - Without Pump
Support - Shaft
Chain Drive - Chain
Sprocket And Tensioner - Without Swath
Drive Sprocket Assembly
Clutch Assembly
Point Row Clutch - Half Width
Point Row Clutch - Without Point Row Clutch
Flex Shaft Drive - Collar
Support And Braces - Flex Shaft Drive
Flex Shaft Drive
Mounting - Gearbox
Gearbox - Metering Unit
Hydraulic Drive
Mount - Drive
Drive Shaft - Drive
Motor - Drive
Hydraulic Motor - Drive
Seed Drive Motor And Valve
Valve - Hydraulic Assembly - Hoses
Hydraulic Drive - Hoses
Pto Pump And Mount - Ground Drive
Pump Assembly - Pto
Pto Pump And Mount
Pto Pump Assembly
Marker Hydraulics - Left Hand
Marker Hydraulics - Right Hand
Sequencing Valve - Hydraulic
Hydraulic Cylinder - Marker
Wheel Lift Hydraulics - Hydraulic Drive
Hydraulic Cylinder
Hydraulic Cylinder - Wheel Lift
Wheel Lift Hydraulics - Center
Hydraulic Cylinder - Flex
Blower Drive Hydraulics
Flow Control Valve Assembly - Blower
Filter - Hydraulic
Tractor Remote - Ground Drive
Blower Hydraulics - Hydraulic Drive
Tractor Remote - Hydraulic Drive
Blower Assembly
Hose And Duct Clamps - Manifold
Hydraulics - Wing
Wing Fold - Hydraulic
Hydraulic Cylinder - Wing Fold
Electrical Connectors - Kit, Repair
Electrical Connectors - Weather Pack
Electrical Connectors - Amp, Deutsch And Weatherpack
Electrical Connectors - Amp And Deutsch
Harness - Iso System
Harness - Without Iso System
Transport Lights
Harness - Row Sensor
Mounting - Lift Switch
Pm400 Console
Sensor And Tube - Seed Smart
Sensor And Tube - High Rate
Radar Gun
Radar Y Harness
Harness - Sm400se
Speed Sensor Testers
Mounting - Ground Speed Sensor
Harness - Swath Control
C3000 Console And Mounting Kit
Switch - Swath Control
Soil Conditioning
Opener - Liquid Injector
Floating Residue Manager
Short Arm Coulter - Left Hand
Short Arm Coulter - Right Hand
Mounting - Coulter
Arm - Coulter
Coulter - Without Blade
Blades - Coulter
Row Units
194_30 Inch Spacing - Hydraulic Drive
Parallel Link - Row Unit
Row Unit
Lower Assembly - Row Unit
Gauge Wheel Arm - Left Hand
Gauge Wheel Arm - Right Hand
Lever Assembly - Depth Adjustment
Gauge Wheel Assembly
Mounting - Row Unit
Scraper - Gauge Wheel
Gauge Wheel Scraper
Disc Assembly
Opening Disc Hub
Hopper And Meter - 2 Bushel Hopper
227_2 Bushel Hopper
Hopper And Meter - 3 Bushel Hopper
229_3 Bushel Hopper
Seed Meter - Components
Seed Meter
Seed Meter Funnel
Hopper Support
Hopper Support - Components
Seed Disc Identification Chart
Attaching Parts - No Closing Wheel
Angled Bracket - Closing Wheel
Closing Wheel Assembly - Rubber
Closing Wheel Assembly - Cast
Closing Wheel And Mounting - Single
Mounting - Scrapers
Down Pressure Springs - Standard
Down Pressure Springs - Heavy Duty
Double Disc Opener
Application System
Air Tubes - Center
Air Tubes - Left Hand
Air Tubes - Right Hand
Air Gauge And Mounting
Compressor Box
Compressor
257_2 Bushel Hopper
258_3 Bushel Hopper
Decals - Logo
Decals - Operational
Decals - 2 Bushel Hopper
Decals - 3 Bushel Hopper
Decals - Marker
Decals - Hydraulic Drive
Seed Rate Chart
Decals - Speed Sign
Slow Moving Vehicle Emblem
Hydraulic Direct Drive Kit
Transmission Shield Kit
Pressure Spring Kit - Standard
Pressure Spring Kit - Heavy Duty
Pneumatic Down Pressure Kit
Module - Swath Control
Closing Wheel Kit - Rubber
Closing Wheel Kit - Cast
Row Unit Coulter Mounting - Without Blade
Coulter Kit - Bubble Blade
Coulter Kit - Ripple Blade
Coulter Kit - 8 Flute
Coulter Kit - 25 Flute
Residue Manager - Spoke Tooth, 13 Inch
Wheel - Spoke Tooth, 13 Inch
Shark Tooth Residue Manager - Row Unit Mounted
Wheel Assembly - Shark Tooth, 13 Inch
Residue Manager Kit - Spoke Tooth, 10 Inch
Residue Manager Kit - Spoke Tooth, 13 Inch
Residue Manager Wheel Kit - Shark Tooth, 13 Inch
Residue Manager Attachment Kit
Residue Manager Kit - Short Shark Tooth
Residue Manager Kit
Drive Wheel Mud Scraper Kit
Opener Disc Flat Scraper Kit
Opener Disc Scraper Kit
Seed Meter Funnel Kit
Granular Herbicide Kit
Blower Inlet Kit
Fertilizer Opener Kit
Offset Shank Clamp Kit - 5-1 2 Inch
Liquid Fertilizer Piston Pump Drive Kit
Piston Pump Kit - Liquid Fertilizer
Liquid Fertilizer Strainer Kit
Fertilizer Drive Lock Up Kit
Piston Pump - Fertilizer Ground Drive Kit
Single Swath Control Kit - Pneumatic Clutch
Single Swath Control Kit - Air Compressor
Single Swath Control Kit - Valve Module
Single Swath Control Kit - Air Tank
Single Swath Control Kit - Switch
Single Swath Control Kit - Harness And Module
Dual Swath Control Kit - Pneumatic Clutch
Dual Swath Control Kit - Air Compressor
Dual Swath Control Kit - Valve Module
Dual Swath Control Kit - Air Tank
Dual Swath Control Kit - Harness And Module
Dual Swath Control Kit - Switch
Flex Shaft Drive Kit
Flex Shaft Drive - Support
Radar Gun Kit
Point Row Clutch Kit - Half Width
Control Box Assembly
Liquid Fertilizer Tank Mounting Kit - 200 Gallon
Fertilizer
Liquid Fertilizer Plumbing Kit
Liquid Fertilizer Flow Divider Kit
Piston Pump Outlet Manifold Kit - 12 Row
Liquid Fertilizer Opener Hose Kit
Liquid Fertilizer Tank Hose Kit
Sgr-1 Receiver And Cable Kit
Ground Drive Pto Pump Kit - 540 Rpm
Ground Drive Pto Pump Kit - 1000 Rpm, 1-3 8 Inch
Ground Drive Pto Pump Kit - 1000 Rpm, 1-3 4 Inch
Sensor And Tube Kit - High Rate
Sensor And Tube Kit - Seed Smart
Hopper And Meter Kit - 2 Bushel Hopper
366_2 Bushel Hopper
Hopper And Meter Kit - 3 Bushel Hopper
369_3 Bushel Hopper
371_2 Bushel Hopper
372_3 Bushel Hopper
Gta C1000 Console Kit
Brand: Challenger
Frame
Support
Marker - Left Hand
Marker - Right Hand
Marker Hub Assembly
Jack Assembly
Main Frame
Mainframe And Wings
Latch - Center
Wheel Mounting
Wheel Arm - Outer
Wheel Arm - Inner
Transport Wheel
Wheel Hub - Outer
Wheel Arm
Wheel
Offset Shank
Offset Shank Clamp
Drive System
Ground Drive
Drive Chains
Fertilizer Drive
Arm - Fertilizer
Support - Shaft
Chain Drive - Chain
Clutch Assembly
Flex Shaft Drive
Mounting - Gearbox
Hydraulic Drive
Mount - Drive
Drive Shaft - Drive
Motor - Drive
Pump Assembly - Pto
Pto Pump And Mount
Pto Pump Assembly
Hydraulic Cylinder
Filter - Hydraulic
Blower Assembly
Hydraulics - Wing
Transport Lights
Pm400 Console
Radar Gun
Radar Y Harness
Harness - Sm400se
Soil Conditioning
Mounting - Coulter
Arm - Coulter
Blades - Coulter
Row Units
Row Unit
Mounting - Row Unit
Gauge Wheel Scraper
Disc Assembly
Opening Disc Hub
227_2 Bushel Hopper
229_3 Bushel Hopper
Seed Meter
Seed Meter Funnel
Hopper Support
Mounting - Scrapers
Double Disc Opener
Application System
Air Tubes - Center
Compressor Box
Compressor
257_2 Bushel Hopper
258_3 Bushel Hopper
Decals - Logo
Decals - Marker
Seed Rate Chart
Decals - Speed Sign
Residue Manager Kit
Blower Inlet Kit
Radar Gun Kit
Fertilizer
366_2 Bushel Hopper
369_3 Bushel Hopper
371_2 Bushel Hopper
372_3 Bushel Hopper
