702,169
Challenger Planter 9102 9106 9108 9128 9122 Parts Catalog 79036289
Brand: Challenger
Type of Machine: Planter
Model: Challenger 9102, 9106, 9108, 9128, 9122 Planter
Part Number: 79036289
Number of Pages: 577 Pages
Frame
Filters
Mainframe - Rigid
Mainframe - 30 Inch Row
Mainframe
Mainframe - Vertical Fold
Center Frame
Tongue
Flat Fold Marker - Left Hand
Flat Fold Marker - Right Hand
Marker Rests
Folding Marker - Left Hand
Folding Marker - Right Hand
Folding Marker - Mounting
Solid Marker Disc
Rigid Marker
Marker - Left Hand
Marker - Right Hand
Folding Marker
Chain And Pin - Folding Marker
Mounting - Transport Chain
Notched Marker Disc - 14 Inch
Notched Marker Disc
Marker Hub Assembly
Jack Assembly
Row Unit Spacing
Row Unit Spacing - Left Wing
Row Unit Spacing - Right Wing
Row Unit Spacing - Center
Wheel Arm
054_6 Bolt Hub - Wheel Lift
Row Unit - Wheel Arm
Wheel Hub - Drive Wheel
Sprocket And Tensioner - Without Swath
Wheel And Tire Assembly - Inner
Wheel Arm - 2 Carrier Wheels
Transport Wheel - Lock Lever
Transport Wheel - 4 Carrier Wheels
Drive System
Fertilizer Drive
Tire And Wheel
Ground Drive - 12 Row
Ground Drive - 8 Row
Ground Drive
Tensioner - Chain
Clutch Assembly
Row Unit Drive
Row Unit Drive - Left Hand
Row Unit Drive - Right Hand
Drive Sprocket Assembly
Transmission Assembly
Ground Drive Transmission - 12 Foot
Sprocket Cluster - Transmission
Drive Chains
Shield - Transmission
Marker Hydraulics
Sequence Valve Assembly - Row Marker
Hydraulics - Wing Lift
Hydraulic Cylinder Assembly - Wing Lift
Hydraulic Cylinder - Marker
Hydraulic Cylinder Installation - Row Marker
Hydraulic Cylinder Assembly - Marker
Blower Assembly
Hydraulic Filter - Components
Wheel Lift Hydraulics
Hydraulic Cylinder Lockup
Blower - Ground Drive
Flow Control Valve - Hydraulic Blower Drive
Hydraulic Cylinder - Wheel Lift
Hydraulic Cylinder Assembly - Wheel Lift
Quick Couplers
Screen - Blower
Electrical Connectors - Kit, Repair
Transport Lights
Light Assembly, Left
Light Assembly, Right
Light Assembly - Front
Sensor Harness - 6 Row
Sensor Harness - 8 Row
Sensor Harness - 12 Row
Magnetic Distance Sensor
Mounting - Ground Speed Sensor
Sensor And Tube - High Rate
Sensor And Tube - Seed Smart
Sm300 Console
Control Box Kit - Fold System
Control Box Kit - Wiring Harness
Electrical Connectors - Deutsch And Metri-Pack
Electrical Connectors - Weather Pack
Electrical Connectors - Amp And Deutsch
Electrical Connectors - Amp, Deutsch And Metri-Pack
Product Containment
Hopper Support
Hopper Support - Components
Hopper And Meter - 2 Bushel Hopper
Hopper And Meter - 3 Bushel Hopper
147_2 Bushel Hopper
148_3 Bushel Hopper
Seed Meter - Components
Seed Disc Identification Chart
Seed Meter Funnel
Soil Conditioning
Arm - Coulter
Wheel - Spoke Tooth, 13 Inch
Wheel Assembly - Spoke Tooth, 10 Inch
Wheel Assembly - Spoke Tooth, 13 Inch
Wheel Assembly - Shark Tooth, 13 Inch
Disc Assembly
Closing Wheel Assembly - Cast
Closing Wheel Assembly - Rubber
Blade - Trash Master Kit
Residue Manager - Frame
Residue Manager - Spoke Tooth, 13 Inch
Residue Manager - Shark Tooth
Residue Manager - Row Unit
Shark Tooth Residue Manager - Row Unit Mounted
Shark Tooth Wheel With Depth Band
Shark Tooth Wheel With Depth Band - Left Hand
Shark Tooth Wheel With Depth Band - Right Hand
Trash Master Kit - Row Unit Mounted
Double Disc Opener
Bubble Blade
Ripple Blade - 16 Inch
Fluted Blade - 8 Flute
Fluted Blade - 13 Flute
Fluted Blade - 25 Flute
Wheel Mounting - Spoke Tooth, 13 Inch
Shark Tooth Wheel - Mounting
Row Unit Coulter Mounting - Without Blade
Mounting - Opener Disc
Offset Shank Kit - 5-1 2 Inch
Row Units
Parallel Link - Row Unit
Parallel Link - Without Angles
Parallel Link - With Angles
Row Unit
Lower Assembly - Row Unit
Lever Assembly - Depth Adjustment
Down Pressure Springs - Standard
Down Pressure Springs - Heavy Duty
Angle Adjustment - Closing Wheel
Gauge Wheel Arm - Left Hand
Gauge Wheel Arm - Right Hand
Gauge Wheel Assembly
Gauge Wheel Scraper
Mounting Frame - Opener Disc
Application System
Air Duct - Without Hopper
Air Duct
Air Duct - Left Hand
Air Duct - Right Hand
Air Duct - Center
Fertilizer Opener Bar Kit
Fertilizer Opener Mounting
Spindles And Wheels
Transport Wheel
229_6 Bolt Hub - Transport Wheel
Decals - Logo
Safety Decals
Safety Decals - No Text
Decals - 2 Bushel Hopper
Decals - 3 Bushel Hopper
Decals - Hopper
Seed Rate Chart
Decals - Seed Rate
Slow Moving Vehicle Emblem
Ground Drive Pto Pump Kit - 540 Rpm
Pto Pump Assembly - 540 Rpm
Ground Drive Pto Pump Kit - 1000 Rpm
Pto Pump Assembly - 1000 Rpm
Liquid Tank And Mounting Kit - 200 Gallon
Piston Pump Outlet Manifold Kit - 8 Row
Flow Divider Kit - 12 Row
Liquid Fertilizer Flow Divider Kit
Liquid Squeeze Pump And Drive Kit
Liquid Fertilizer Squeeze Pump Kit - 8 Row
Liquid Fertilizer Squeeze Pump Kit - 12 Row
Liquid Squeeze Pump And Drive Kit - 4 And 6 Row
Liquid Squeeze Pump And Drive Kit - 12 Row
Liquid Fertilizer Opener Hose Kit
Granular Fertilizer Kit - 8 Row
Granular Fertilizer Kit - Drives
Sm100 Monitor Kit - 16 Row
Sm100 Monitor Kit
Sm300 Monitor Kit
Radar Gun Kit
Radar Y Harness Kit
Sgr-1 Receiver And Cable Kit
Transmission Shield Kit
Blower Inlet Kit
Fertilizer Ground Drive Kit
Sensor And Tube Kit - High Rate
Sensor And Tube Kit - Seed Smart
Pressure Spring Kit - Standard
Pressure Spring Kit - Heavy Duty
Residue Manager Kit - Spoke Tooth, 10 Inch
Residue Manager Kit - Spoke Tooth, 13 Inch
Residue Manager Kit - Shark Tooth
Residue Manager Kit - Shark Tooth, 13 Inch
Residue Manager Attachment Kit - Spoke Tooth, 10 Inch
Residue Manager Attachment Kit - Spoke Tooth, 13 Inch
Closing Wheel Kit - Cast
Closing Wheel Kit - Rubber
Single Closing Wheel Kit
Gta C1000 Console Kit
C3000 Console And Mounting Kit
