Challenger Planter 8824-70CM Parts Catalog 00738304
Brand: Challenger
Type of Machine: Planter
Model: Challenger 8824-70CM Planter
Part Number: 00738304
Number of Pages: 377 Pages
Publication Information
Drives - Ground Drive Shafts And Mounting
Drives - Ground Drive Speed Sensor And Mounting
Drives - Drive Bearing Support Assembly-Left
Drives - Drive Bearing Support Assembly-Right
Drives - Ground Drive Transmission Mounting
Drives - Ground Drive Transmission, (Continued)
Drives - Transmission Sprocket Assembly, (Lower Rear Cluster)
Drives - Transmission Sprocket Assembly, (Front Cluster)
Drives - Transmission Sprocket Assembly, (Rear Shaft)
Drives - Row Unit Drive-Center
Drives - Row Unit Drive-Inner (Left And Right)
Drives - Row Unit Drive (Left Wing)
Drives - Row Unit Drive (Right Wing)
Drives - Transmission Drive Chains
Drives - Drive Chains
Air Tubes - Ducts-Air, Center
Air Tubes - Ducts-Air, Center, Inner, (Left And Right)
Air Tubes - Ducts-Air, Left Wings
Air Tubes - Ducts-Air, Right Wings
Air Tubes - Air Gauge And Mounting (Left And Right)
Electrical - Transport Lights-Front
Electrical - Transport Lights-Rear
Electrical - Transport Lights-Rear, (Continued)
Electrical - Flasher Lights-Outer
Electrical - Transport Light Assemblies
Electrical - Control Box Assembly, (Sn12321 Control Box Assembly)
Electrical - Console Assembly (Pm400)
Electrical - Harness Assembly-Low Power (Sm400se)
Electrical - Marker, Fold & Lift Electrical Harness
Electrical - Tongue-Center Frame Connection, Marker
Electrical - Frame Height Switch And Mounting
Electrical - Bridge Module Harness
Electrical - Row Sensor Bridge Module And Mounting
Electrical - Row Sensor-Interface Module, (Rows 1, 2, 3 And 4)
Electrical - Row Sensor-Interface Module, (Rows 5, 6, 7 And 8)
Electrical - Row Sensor-Interface Module, (Rows 9, 10, 11 And 12)
Electrical - Row Sensor-Interface Module, (Rows 13, 14, 15 And 16)
Electrical - Row Sensor-Interface Module, (Rows 17, 18, 19 And 20)
Electrical - Row Sensor-Interface Module, (Rows 21, 22, 23 And 24)
Electrical - Gta I Console And Mounting
Electrical - Gta Mounting, (Optional Parts)
Electrical - Gta Ii Console And Mounting
Electrical - Gta Console Harness (Implement Switch)
Electrical - Gta Console Ext. Harness And Test Switch
Electrical - Test Switch Storage Tube And Mounting
Electrical - Radar Gun
Electrical - Radar Y Harness
Electrical - Radar Distance Sensor And Mounting
Electrical - Sensor And Tube (High Rate)
Electrical - Sensor And Tube (Seed Smart)
Electrical - Point Row Shutoff Clutch And Mounting
Electrical - Point Row Shutoff Clutch Assembly-Left, (N858732 Point Row Clutch Assembly)
Electrical - Point Row Clutch Assembly-Right, (N858733 Point Row Clutch Assembly)
Electrical - Electrical Service Parts
Electrical - Electrical Service Parts, (Continued)
Row Units - Row Unit Mounting
Row Units - Row Unit (With Front Bracket)
Row Units - Row Unit Chain Tightener
Row Units - Row Unit-Lower
Row Units - Disc Assembly, (700164107 Disc Assembly)
Row Units - Seed Meter
Row Units - Seed Disc Identification Chart
Row Units - 2 Bushel Hopper And Mounting
Row Units - 3 Bushel Hopper And Mounting
Row Units - Seed Meter Funnel
Row Units - Gauge Wheel Mounting
Row Units - Gauge Wheel-Left
Row Units - Gauge Wheel-Right
Row Units - Gauge Wheel Assembly, (700727657 Gauge Wheel Assembly)
Row Units - Depth Adjustment
Row Units - Closing Wheel And Mounting (Rubber)
Row Units - Closing Wheel Assembly (Rubber), (700727676 Closing Wheel Assembly)
Row Units - Closing Wheel And Mounting (Cast)
Row Units - Closing Wheel Assembly (Cast), (854077 Closing Wheel Assembly), (Left Shown, Right Opposite)
Row Units - Single Closing Wheel And Mounting
Row Units - Gauge Wheel Scraper
Row Units - Scrapers Rotary Flat
Markers - Markers-Lower, (Left Shown, Right Opposite)
Markers - Markers-Upper, (Left Shown, Right Opposite)
Markers - Marker Hub Assembly, (700157278 Marker Hub Assembly), (Left Shown, Right Opposite)
Markers - Marker Gauge Wheel Assembly, (Right Shown, Left Opposite)
Tongue, Frame And Wheels - Hitch And Stands
Tongue, Frame And Wheels - Tongue And Latch Mounting
Tongue, Frame And Wheels - Wing Fold Braces And Mounting
Tongue, Frame And Wheels - Center Frame And Inner Wings
Tongue, Frame And Wheels - Outer Wings And Mounting
Tongue, Frame And Wheels - Tow Hitch And Mounting
Tongue, Frame And Wheels - Rear Tow Hitch Assembly, (700731847 Tow Hitch Assembly)
Tongue, Frame And Wheels - Wheel Lift Mounting-With Master Cylinder
Tongue, Frame And Wheels - Wheel Lift Mounting-With Slave Cylinder
Tongue, Frame And Wheels - Wheel Lift Mounting-With Wing Slave
Tongue, Frame And Wheels - Wheel Lift Mounting-With Wing Assist
Tongue, Frame And Wheels - Hub Assembly, (Sn13262 Hub Assembly)
Hydraulics - Hydraulics-Blower Drive, Tractor Remote
Hydraulics - Hydraulics-Blower Drive, Front
Hydraulics - Hydraulics-Blower Drive, Left
Hydraulics - Hydraulics-Blower Drive, Right
Hydraulics - Hydraulic Flow Control Valve Assembly, (N856657 Flow Control Valve Assembly)
Hydraulics - Hydraulic Valve And Mounting
Hydraulics - Hydraulic Sequencing Valve Assembly, (700157702 Hydraulic Valve Assembly)
Hydraulics - Hydraulic Valve Assembly-Fold, (Sn13539 Valve Assembly-Fold)
Hydraulics - Hydraulic Valve Assembly-Lift, (Sn13530 Valve Assembly-Lift)
Hydraulics - Hydraulics-Tongue Lift
Hydraulics - Hydraulics-Forward Fold
Hydraulics - Forward Fold Hydraulics And Mounting
Hydraulics - Fold-Hydraulic Cylinder Assembly, (Sn13815 Cylinder Assembly-Hydraulic)
Hydraulics - Hydraulics-Wheel Lift, Center
Hydraulics - Hydraulics-Wheel Lift, Wings
Hydraulics - Hydraulics-Wheel Lift, Assist
Hydraulics - Hydraulics-Wheel Lift, Wing Assist
Hydraulics - Hydraulic Cylinder Assembly-Lift, (Sn13259 Cylinder Assembly-Hydraulic), (Rephasing Cylinder)
Hydraulics - Hydraulic Cylinder Assembly-Lift, (Sn13922 Cylinder Assembly-Hydraulic), (Rephasing Cylinder)
Hydraulics - Hydraulic Cylinder Assembly-Lift, (Sn13923 Cylinder Assembly-Hydraulic)
Hydraulics - Marker Hydraulics
Hydraulics - Marker Hydraulic Cylinder Assembly, (Sn13783 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Lockup Storage
Hydraulics - Blower
Hydraulics - Hydraulic Hose Clamps And Mounting
Decal And Kits - Decal-Challenger, Russian
Decal And Kits - Decal-Challenger, English
Decal And Kits - Decals-Tongue And Mainframe
Decal And Kits - Decals-Frame, Row Units (Left And Right)
Decal And Kits - Decals-Wing, Left And Right
Decal And Kits - Decals-Challenger, Russian, (Continued)
Decal And Kits - Decals-Challenger, English, (Continued)
Decal And Kits - Decals-Marker
Decal And Kits - Fertilizer Decal
Decal And Kits - Hydraulic Cylinder Lockup Decal
Decal And Kits - Slow Moving Vehicle Emblem
Decal And Kits - Hopper Lid Hook Kit (2 Bushel), (6001002 Hopper Lid Hook Kit)
Decal And Kits - Seed Meter Funnel Kit, (6000628 Seed Meter Funnel Kit)
Decal And Kits - Reflectors-Row Unit (Left And Right)
Decal And Kits - Seed Rate Decal
Decal And Kits - Seed Disc Identification Chart
Decal And Kits - Row Unit Coulter Kit (25 Flute), (6000932 Coulter Kit)
Decal And Kits - Row Unit Coulter Mounting Kit-Less Blade, (6400043 Row Unit Coulter Mounting Kit)
Decal And Kits - Fertilizer Opener Mounting Kit, (6400218 Fertilizer Opener Mount Kit)
Decal And Kits - Fertilizer Opener Mounting Kit, (6400219 Fertilizer Opener Mount Kit)
Decal And Kits - Opener Kit, (6001067 Opener Kit)
Decal And Kits - Opener Kit (Continued), (6001067 Opener Kit)
Decal And Kits - Opener Kit, (6001216 Opener Kit)
Decal And Kits - Opener Kit (Continued), (6001216 Opener Kit)
Decal And Kits - Offset Shank Kit (5-1 2 Inch), (6400188 Offset Shank Kit, 5-1 2 Inch)
Decal And Kits - Offset Shank Clamp Kit (5-1 2 Inch), (6400189 Offset Shank Clamp Kit)
Decal And Kits - Offset Shank Kit (5-1 2 Inch), (6001068 Offset Shank Kit, 5-1 2 Inch)
Decal And Kits - Clamp Plate Kit-Double Disc Opener, (6400225 Clamp Plate Kit)
Decal And Kits - Point Row Shutoff Clutch Kit, (6001019 Point Row Shutoff Kit)
Decal And Kits - Point Row Shutoff Clutch Kit, (6001206 Point Row Shutoff Kit)
Decal And Kits - Point Row Shutoff Clutch Kit, (N858732 Point Row Clutch Assembly-Left), (Kit Continued)
Decal And Kits - Point Row Shutoff Clutch Kit, (N858733 Point Row Clutch Asm.-Right), (Kit Continued)
Decal And Kits - Fertilizer Tank Kit, (6001207 Fertilizer Tank Kit)
Decal And Kits - Fertilizer Pump And Drive Kit, (6001021 Fertilizer Pump And Drive Kit)
Decal And Kits - Fertilizer Pump And Drive Kit, (Continued)
Decal And Kits - Drive Wheel Mud Scraper Kit, (6001230 Drive Wheel Mud Scraper Kit)
Decal And Kits - Fertilizer Piston Pump Assembly, (700730742 Piston Pump Assembly)
Decal And Kits - Fertilizer Plumbing Kit, (6400210 Liquid Fertilizer Plumbing Kit)
Decal And Kits - Liquid Fertilizer Flow Divider Kit, (6100199 Liquid Fert. Flow Divider Kit), (24 Row)
Decal And Kits - Liquid Fertilizer Opener Hose Kit, (6100200 Liquid Fert. Opener Hose Kit)
Decal And Kits - Piston Pump Outlet Manifold Kit, (6000361 Pist. Pump Outlet Manifold Kit)
Decal And Kits - Liquid Piston Pump Plumbing Kit, (6001055 Piston Pump Plumbing Kit)
Decal And Kits - Fertilizer Opener Adapter Fitting Kit, (6400221 Opener Adapter Fitting Kit)
Decal And Kits - Central Fill System Kit, (6001243 Central Fill System Kit)
Decal And Kits - Central Fill System Kit, (6001243 Central Fill System Kit), (Continued)
Decal And Kits - Stroke Control Segment Kit, (6001090 Stroke Control Segment Kit), (3 4 To 2 Inch Shaft)
Decal And Kits - Tow Hitch Kit, (6001217 Tow Hitch Kit), (Continued)
Decal And Kits - Meter Screen Kit, (6000941 Meter Screen Kit)
Recommended Dealer List - Recommended Dealer List, For 1-5 Units
Recommended Dealer List - Recommended Dealer List, For 6-10 Units
Brand: Challenger
Hydraulics - Blower
