Challenger Planter 8816 8824 Parts Catalog 00732077
Brand: Challenger
Type of Machine: Planter
Model: Challenger 8816, 8824 Planter
Part Number: 00732077
Number of Pages: 811 Pages
Frame
Filters & Belts Guide
Markers - Upper
Marker Hub Assembly
Markers - Lower
Markers
Hydraulic Cylinder - Marker
Marker Gauge Wheels
Gauge Wheel - Marker
Draw Bar Hitch
Hitch And Stands
Tongue And Latch Mounting
Tow Hitch - Rear
Wing Fold Braces
Center Frame And Inner Wings
Outer Wings
Wheel Lift
Hydraulic Cylinder - Lift
Hub - Lift Wheel
Frame - Seed Module
Handrails - Seed Module
Platform & Ladder - Seed Module
Drive System
Ground Drive Shafts And Mounting
Ground Drive
Ground Drive Transmission - Dual Transmission
Ground Drive Bearing Support - Left Hand
Ground Drive Bearing Support - Right Hand
Mounting - Ground Drive Transmission
Ground Drive Transmission - Tensioner Arm
Ground Drive Transmission - Sprocket
Sprocket Cluster - Transmission
Row Unit Drive - Inner
Row Unit Drive - Inner Right
Row Unit Drive - Inner Left
Row Unit Drive - Center
Row Unit Drive - Outer Left
Row Unit Drive - Outer Right
Row Unit Drive - Outer Left And Right
Drive Chains
Chains - Transmission
Chain Drive
Sprocket And Tensioner - Chain Drive
Flex Shaft Drive - Collar
Flex Shaft Drive - Support
Flex Shaft Drive - Clutch Cable
Flex Shaft Drive - Gearbox Meter
Mounting - Hydraulic Drive
Mounting - Hydraulic Pto Drive Pump
Mounting - Hydraulic Reservoir
Hydraulic Drive - Tractor Remote
Flow Divider - Hydraulic Drive
Hydraulic Hose Clamps
Valve Assembly - Flow Divider
Mounting - Hydraulic Valve, Load Sense Blocking
Sequencing Valve - Hydraulics
Hydraulic Valve, Load Sense Blocking - Fold
Hydraulic Valve, Load Sense Blocking - Lift
Lift Hydraulics - Tongue
Forward Fold - Hydraulics
Mounting - Forward Fold Hydraulics
Hydraulic Cylinder - Fold
Marker Hydraulics
Wheel Lift Hydraulics - Center
Wheel Lift Hydraulics - Wings
Wheel Lift Hydraulics - Wing Assist
Blower Drive Hydraulics - Left Hand
Blower Drive Hydraulics - Right Hand
Hydraulic Blower Drive - Left Hand
Hydraulic Blower Drive - Right Hand
Flow Control Valve Assembly - Blower
Valve Assembly - Hydraulic Pump
Return - Blower Cooler
Mounting - Blower
Blower Hydraulics - Ground Drive
Blower Hydraulics - Left Hand
Blower Hydraulics - Right Hand
Blower Assembly - Mounting
Hydraulic Cylinder Lockup Storage
Blower Hydraulics - Center Fill
Center Fill Blower Control Valve Assembly
Transport Lights - Front
Transport Lights - Rear
Control Box Assembly
Console Assembly - Sm400se
Harness - Sm400se
Gta I Console And Mounting - Non-Ce
Gta Mounting - Option
Gta Ii Console And Mounting
Gta C1000 Console And Mounting
Harness - Gta Console
Harness And Test Switch - Gta Console
C3000 Console And Mounting Kit
Electrical - Tow Hitch
Test Switch Storage
Radar Gun
Radar Y Harness
Sensor And Tube Kit - High Rate
Sensor And Tube - Seed Smart
Sensor And Tube Kit - Seed Smart
Fold And Lift Electrical Harness
Connection Assembly - Marker
Mounting - Lift Height Switch
Wiring Harness - Swath Control
Harness - Bridge Module
Mounting - Bridge Module
Mounting - Speed Sensor
Interface Module - Row Sensor
Row Sensor - Without Sensor
Harness - Iso 4 Channel Actuator
Harness - Shaft Speed Sensor And Solenoid
Mounting - Point Row Shutoff
Point Row Clutch Assembly - Left Hand
Point Row Clutch Assembly - Right Hand
Field Height Drive Shutoff Switch
Electrical Connectors - Deutsch And Metri-Pack
Electrical Connectors - Weather Pack
Electrical Connectors - Amp And Deutsch
Electrical Connectors - Amp, Deutsch And Metri-Pack
Product Containment
218_2 Bushel Hopper
219_3 Bushel Hopper
Seed Hopper Assembly - Left Hand
Seed Hopper Assembly - Right Hand
Soil Conditioning
Frame - Residue Manager
Row Units
Mounting - Row Unit
Row Unit
Row Unit - Lower
Row Unit Chain Tightener
Disc Assembly
Seed Meter
Seed Meter Funnel
Meter Cover
Tie - Without Hopper
Seed Disc Identification Chart
Depth Adjustment
Gauge Wheel - Right Hand
Gauge Wheel Assembly
Gauge Wheel - Left Hand
Mounting - Gauge Wheel
Mounting - Closing Wheel
Single Closing Wheel And Mounting
Angle Closing Wheel
Closing Wheel Kit - Rubber
Closing Wheel Kit - Cast
Scraper - Gauge Wheel
Scraper - Mud
Application System
Air Duct - Center
Air Duct - Left Hand
Air Duct - Right Hand
Air Gauge And Mounting
Air Gauge And Mounting - Left Hand
Air Gauge And Mounting - Right Hand
Central Fill Air Tubes - Left Hand
Central Fill Air Tubes - Center
Central Fill Air Tubes - Right Hand
Pneumatic Down Force
Mounting - Pneumatic Down Force
Hoses - Pneumatic Down Force
Seed Module Plenums And Air Boxes
Seed Module Blower And Mounting
Blower Assembly - Seed Module
Seed Hopper And Mounting - Left Hand
Seed Hopper And Mounting - Right Hand
Compressor Box
Compressor
Decals - Logo
Decals - Operational
Decals - Hopper
Decals - Center Fill
Decals - Marker
Decals - Fertilizer
Slow Moving Vehicle Emblem
Decals - Seed Rate
Hopper And Meter Kit - 2 Bushel
Hopper And Meter Kit - 3 Bushel
Hopper Lid Hook Kit - 2 Bushel
Seed Hopper Lid Kit
Module - Swath Control
Switch - Swath Control
Pto Coupler Kit - 1000 Rpm, 1-3 8 Inch
Pto Coupler Kit - 1000 Rpm, 1-3 4 Inch
Blower Inlet Screen Kit - Hydraulic Drive
Seed Meter Funnel Kit
Point Row Clutch Kit
Point Row Clutch Kit - Components
Ground Speed Sensor Kit
Row Unit Extension Kit
Ladder Extension
Field Height Drive Shutoff Switch Kit
Drive Wheel Mud Scraper Kit
Offset Shank Kit - 5-1 2 Inch
Offset Shank Clamp Kit - 5-1 2 Inch
Fertilizer Opener Mounting Kit
Clamp Plate Kit - Double Disc Opener
Tow Hitch Kit
Coulter Mounting Kit - Without Blade
Coulter Kit - Bubble Blade
Coulter Kit - Ripple Blade
Coulter Kit - 8 Flute
Coulter Kit - 13 Flute
Coulter Kit - 25 Flute
Mounting - Scrapers
Residue Manager Kit - Short Shark Tooth
Residue Manager Kit - Spoke
Residue Manager Attachment Kit
Residue Manager Kit
Flex Shaft Drive Kit
Fertilizer Tank Kit
Fertilizer Pump And Drive Kit - Single
Fertilizer Pump And Drive Kit - Double
Liquid Fertilizer Plumbing Kit
Fertilizer Outlet Plumbing Kit
Piston Pump Outlet Manifold Kit
Liquid Fertilizer Plumbing Kit - Cart
Flow Divider Plumbing - 20 Row
Flow Divider Kit - Fertilizer
Flow Divider Kit - 12 Row
Flow Divider - 12 Row
Fertilizer Opener Adapter Fitting Kit
Piston Pump Outlet Manifold Kit - 12 Row
Granular Herbicide Kit
Opener Disc Scraper Kit
Opener Disc Flat Scraper Kit
Double Disc Opener Kit
Coulter Kit - Notched Blade
Speed Sensor Testers
Pressure Spring Kit - Standard
Pressure Spring Kit - Heavy Duty
Pneumatic Down Pressure Kit
Sgr-1 Receiver And Cable Kit
