Challenger Planter 8104 8106 8108 8122 8128 8138 Parts Catalog 00730999
Brand: Challenger
Type of Machine: Planter
Model: Challenger 8104, 8106, 8108, 8122, 8128, 8138 Planter EFFECTIVE
Serial Number: HS And Later
Part Number: 00730999
Number of Pages: 371 Pages
Publication Information
Drives - Row Unit Drive-Left (8104)
Drives - Row Unit Drive-Right (8104)
Drives - Row Unit Drive-Left (8106)
Drives - Row Unit Drive-Right (8106)
Drives - Row Unit Drive-Left (8108)
Drives - Row Unit Drive-Right (8108)
Drives - Row Unit Drive-Left (8122)
Drives - Row Unit Drive-Right (8122)
Drives - Row Unit Drive-Left (8128)
Drives - Row Unit Drive-Right (8128)
Drives - Row Unit Drive-Left (8138)
Drives - Row Unit Drive-Right (8138)
Drives - Ground Drive-Left, (8106 8108 8122)
Drives - Ground Drive-Right, (8106 8108 8122)
Drives - Ground Drive-Left And Right (8104)
Drives - Ground Drive-Left (8128)
Drives - Ground Drive-Right (8128)
Drives - Ground Drive-Left (8138)
Drives - Ground Drive-Right (8138)
Drives - Transmission
Drives - Transmission-Hydraulic Drive
Drives - Transmission Sprocket Assembly, (Rear Cluster)
Drives - Transmission Sprocket Assembly, (Front Cluster)
Drives - Transmission Sprocket Assembly, (Rear Shaft)
Drives - Transmission Drive Sprocket Assembly, (Main Drive Shaft Sprocket Shear Bolt)
Drives - Drive Chains
Air Tubes - Air Duct-Left (8104 Narrow)
Air Tubes - Air Duct-Center (8104 Narrow)
Air Tubes - Air Duct-Right (8104 Narrow)
Air Tubes - Air Duct-Left (8104 Wide)
Air Tubes - Air Duct-Center (8104 Wide)
Air Tubes - Air Duct-Right (8104 Wide)
Air Tubes - Air Duct-Left (8106)
Air Tubes - Air Duct-Center (8106)
Air Tubes - Air Duct-Right (8106)
Air Tubes - Air Duct-Left (8108)
Air Tubes - Air Duct-Center (8108)
Air Tubes - Air Duct-Right (8108)
Air Tubes - Air Duct-Left (8122)
Air Tubes - Air Duct-Center (8122)
Air Tubes - Air Duct-Right (8122)
Air Tubes - Air Duct-Left (8128)
Air Tubes - Air Duct-Center (8128)
Air Tubes - Air Duct-Right (8128)
Air Tubes - Air Duct-Left (8138)
Air Tubes - Air Duct-Center (8138)
Air Tubes - Air Duct-Right (8138)
Electrical - Transport Lights (8104 8106)
Electrical - Transport Lights (8108)
Electrical - Transport Lights (8122)
Electrical - Transport Lights (8128 8138)
Electrical - Row Sensor Harness-Left (8122)
Electrical - Row Sensor Harness-Center (8122)
Electrical - Row Sensor Harness-Right (8122)
Electrical - Magnetic Distance Sensor Assembly
Electrical - Sensor And Tube (Seed Smart)
Electrical - Sensor And Tube (High Rate-Seed Sensor)
Electrical - Console Assembly (Sm100)
Electrical - Console Assembly (Sm300)
Electrical - Radar Distance Sensor And Mounting
Electrical - Radar Distance Sensor And Mounting Asm.
Electrical - Radar Y Harness
Electrical - Monitor Harness-4 Row (High Rate)
Electrical - Monitor Harness Kit-6 Row (High Rate)
Electrical - Monitor Harness Kit-8 Row (High Rate)
Electrical - Hydraulic Drive Harness & Mounting(8122)
Electrical - Hydraulic Drive Harness & Mounting(8122), (Continued)
Electrical - Test Switch
Electrical - Gta I Console And Mounting
Electrical - Gta Ii Console And Mounting
Electrical - Gta Mounting, (Optional Parts)
Electrical - Console Assembly (Sm400se)
Electrical - Harness Assembly-Low Power (Sm400se)
Electrical - Harness Assembly-High Power (Sm400se)
Electrical - Electrical Harness Service Parts
Electrical - Electrical Service Parts, (Continued)
Row Units - Row Unit (With Front Bracket)
Row Units - Row Unit (With Angles)
Row Units - Row Unit Chain Tighteners
Row Units - Row Unit-Lower
Row Units - Disc Assembly, (700164107 Disc Assembly)
Row Units - Gauge Wheel Mounting
Row Units - Gauge Wheel-Left
Row Units - Gauge Wheel-Right
Row Units - Gauge Wheel Assembly, (700727657 Gauge Wheel Assembly)
Row Units - Depth Adjustment
Row Units - 2 Bushel Hopper And Mounting
Row Units - 3 Bushel Hopper And Mounting
Row Units - Seed Meter Funnel
Row Units - Seed Rate Chart Decal And Mounting
Row Units - Seed Disc Identification Chart
Row Units - Storage Tube
Row Units - Closing Wheel And Mounting (Rubber)
Row Units - Closing Wheel Assembly (Rubber), (700727676 Closing Wheel Assembly)
Row Units - Closing Wheel And Mounting (Cast)
Row Units - Closing Wheel Assembly (Cast), (854077 Closing Wheel Assembly)
Row Units - Single Closing Wheel And Mounting
Row Units - Row Unit Mounting
Markers - Marker-Left (Rigid)
Markers - Marker-Right (Rigid)
Markers - Marker-Left (Folding)
Markers - Marker-Right (Folding)
Markers - Folding Marker Chains And Mounting, (Left Side Shown, Right Side Opposite)
Markers - Solid Marker Disc (8104 And 8106)
Markers - Solid Marker Disc, (8108 8122 8128 8138)
Markers - Notched Marker Disc
Markers - Flat Fold Marker-Left (8108)
Markers - Flat Fold Marker-Right (8108)
Markers - Marker Hub Assembly, (700167578 Marker Hub Assembly), (Left Shown, Right Opposite)
Tongue, Frame And Wheels - Hitch, Tongue And Jack
Tongue, Frame And Wheels - Jack Assembly
Tongue, Frame And Wheels - Mainframe And Fertilizer Bar (Rigid)
Tongue, Frame And Wheels - Mainframe And Fert. Bar (Vertical Fold)
Tongue, Frame And Wheels - Wheel Mounting
Tongue, Frame And Wheels - Wheel, Hub And Frame
Tongue, Frame And Wheels - Wheel, Hub And Frame (With Stiffener), (8104, 8106, 8122)
Tongue, Frame And Wheels - Hub Assembly
Hydraulics - Hydraulic Direct Drive (Ground Drive)
Hydraulics - Pto Pump & Mount-Ground Drive (540 Rpm)
Hydraulics - Pto Pump Assembly (540 Rpm), (W247844b Pto Pump Assembly)
Hydraulics - Pto Pump & Mount-Ground Drive (1000 Rpm), (1-3 8 Inch Shaft)
Hydraulics - Pto Pump Assembly (1000 Rpm), (W247845b Pto Pump Assembly), (1-3 8 Inch Shaft)
Hydraulics - Pto Pump & Mount-Ground Drive (1000 Rpm), (1-3 4 Inch Shaft)
Hydraulics - Pto Pump Assembly (1000 Rpm), (855009 Pto Pump Assembly), (1-3 4 Inch Shaft)
Hydraulics - Blower (Ground Drive), (S.N. Prior To Hu)
Hydraulics - Hydraulic Blower Motor Assembly, (700728460 Hydraulic Blower Motor Asm.)
Hydraulics - Filter Assembly (Ground Drive), (W247850b Filter Assembly)
Hydraulics - Blower Flow Control Valve Assembly, (W247849b Blower Flow Cont. Valve Asm.)
Hydraulics - Blower (Ground Drive), (S.N. Hu And Later)
Hydraulics - Hydraulic Flow Control Valve (Blower), (N856657 Hydraulic Valve Assembly)
Hydraulics - Hydraulic Drive
Hydraulics - Hydraulic Valve Assembly, (N858339 Hydraulic Valve Assembly)
Hydraulics - Blower (Hydraulic Drive), (S.N. Prior To Hu)
Hydraulics - Blower (Hydraulic Drive), (S.N. Hu And Later)
Hydraulics - Hydraulic Blower Motor Assembly, (W247830b Hydraulic Blower Motor Asm.)
Hydraulics - Wheel Lift Hydraulics (8104)
Hydraulics - Wheel Lift Hydraulics (8106)
Hydraulics - Wheel Lift Hydraulics (8108)
Hydraulics - Wheel Lift Hydraulics-Left (8122)
Hydraulics - Wheel Lift Hydraulics-Right (8122)
Hydraulics - Wheel Lift Hydraulics (8128)
Hydraulics - Wheel Lift Hydraulics (8138)
Hydraulics - Hydraulic Sequence Valve Assembly, (N851998 Sequence Valve Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (700724408 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (N857749 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (N857750 Hydraulic Cylinder Assembly)
Hydraulics - Wing Lift Hydraulics (8122)
Hydraulics - Wing Lift Hydraulics (8128)
Hydraulics - Wing Lift Hydraulics (8138)
Hydraulics - Manifold Valve Assembly, (851960 Manifold Valve Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Wing Lift), (N851980 Hydraulic Cylinder W O Clevis)
Hydraulics - Marker Hydraulics (8104)
Hydraulics - Marker Hydraulics (8106)
Hydraulics - Marker Hydraulics (8108)
Hydraulics - Marker Hydraulics (8122)
Hydraulics - Marker Hydraulics (8128)
Hydraulics - Marker Hydraulics (8138)
Hydraulics - Marker Hydraulic Cylinders And Mounting
Hydraulics - Hydraulic Cylinder Assembly (Marker), (700724408 Hydraulic Cylinder Assembly)
Hydraulics - Flat Fold Marker Hyd Cylinders (8108)
Hydraulics - Marker Hydraulic Cylinder Assembly, (855104 Hydraulic Cylinder Assembly)
Decals And Kits - Decals-Tongue, Hs---00101 Thur Hu---00100
Decals And Kits - Decals-Tongue, Hu---00101 And Later
Decals And Kits - Decals-Row Unit (Rigid Frame)
Decals And Kits - Decals-Row Unit (Vertical Fold)
Decals And Kits - Decals (Hoppers)
Decals And Kits - Decals-Wings
Decals And Kits - Transport Safety Chain
Decals And Kits - Slow Moving Vehicle Emblem
Decals And Kits - Seed Meter Funnel Kit, (6000628 Seed Meter Funnel Kit)
Decals And Kits - Seed Disc Identification Chart
Decals And Kits - Blower Inlet Kit, (6000797 Blower Inlet Kit)
Decals And Kits - Monitor Bridge Kit, (6000816 Monitor Bridge Kit)
Decals And Kits - Hopper Lid Hook Kit, (6001002 Hopper Lid Hook Kit)
Decals And Kits - Opener Disc Scraper Kit, (6001286 Opener Disc Scraper Kit), (One Row Shown, Four Rows Per Kit)
Decals And Kits - Opener Disc Flat Scraper Kit, (6001239 Opener Disc Flat Scraper Kit), (One Row Shown, Four Rows Per Kit)
Recommended Dealer Stock - Recommended Dealer Stock
