702,019
Challenger NL L4258G4 Multapplier Rogator System Parts Catalog 558890D1
Brand: Challenger
Type of Machine: Applicators
Model: Challenger NL L4258G4 Multapplier Rogator System (2012-2017)
Serial Number: ..CXXX1001 - ..HXXX9999
Part Number: 558890D1
Number of Pages: 1469 Pages
Product Containment
Rg L4258g4 Filters
Nl4258g4, 409ss, 11 Foot, #4 Belt Over Chain, Full Flare
Endgate Installation, L4258
Endgate Assembly, Bolt-In, 409ss, 120 Inch Sf
Decal Group, Endgate, L4258
Front Conveyor Guard Group
Gauge Kit, 5000 Psi
Hillside Divider Kit, #4, 304ss
Inverted Vee Kit, 11 And 12 Foot, 409ss
12 Foot V, Ss
Spinner Guard Group, 304ss
Material Divider Assembly
Shield Bracket Assembly
Fan Frame Hardware Kit
Conveyor And Shield Assembly, 409ss, 11 Foot
Chain Shield Group, 11 Foot, 409ss, #4 Belt Over Chain
Wiper, Front, 304ss
Chain Assembly, #4 Box 11 Foot
Gear Case And Tube Assembly
Gear Case
Oiler Assembly
Nozzle And Hose Assembly
Tank
Pump Assembly With Connector
Hydraulic Assembly, L4258, Mr, Pwm, Standard Relief
Hydraulic Assembly, L4258, Multapplier Ready
Mounting Assembly, Hydraulic Tank
Tank Cooler Assembly
Cooler Assembly, Hydac Eld4.5
Hydraulic Tank Assembly
Return Filter
Suction Fittings, Mr L4000
Ball Valve, 2.00 Inch Npt
Encoder, Dickey-John 360, With 12 Inch Cable
Decal Group, Decor
Decal Group, Decor, L4258
2017
2018
Full Flare
Endgate Hardware Kit
Gauge Kit, Dual
Gauge Group, 3000 Psi
Double Pinion Gear Case
Gearcase Breather Tube Assembly
Suction Fittings, L4000 Mc
Suction Fittings, Mc L4000
Ball Valve, 1.25 Inch Npt
2015
Conveyor Assembly, #4 Belt Over Chain, 54 Links
Cover Kit, Rear
Decal Group, Multapplier, L4258
Multibin
Feedgate Assembly
Foot Mount Group
Hydraulic Group, Multapplier
Hydraulic Motor Assembly
Multapplier Wiper
Multapplier Sealer And Front Feedgate
Sealer Assembly Front 120in Standard Flare, Multapplier
Seal Assembly
Multapplier, 5 Foot
Zerks, Idler, Rear
Hydraulic Kit, Multapplier, 11 Foot, Sfp
Valve Assembly, Sfp 9gpm
Hydraulic Servo, 9gpm
Relief Valve Assembly, Soft Start
Multapplier
Feedgate Group Front
Multapplier Multibin
Multapplier Ready
Pattern Test Kit, New Leader
Multapplier Complete
2013
Drive Assembly, 30 Inch, Left Hand, Ss
Shaft Assembly, 30 Inch Drive
Drive Assembly, 30 Inch, Left Hand, With Sensor Mount
Conveyor
Feedgate
Handrail Installation, Rear
Hillside Divider, For Chain Conveyor
Idler, 30 Inch Conveyor 6 Bolt Frame Ss Assembly
Idler Shaft Assembly, 30 Inch Conveyor
Idler, 30 6 Bolt Frame
Motor Kit, Srt2
Tarp Motor Group, Srt
Ratchet Assembly, 1.00 Inch, Ss
Slow Moving Vehicle Sign Installation, New Leader
Tarp Installation, L4258g4
Tarp Kit, Srt2, New Leader, 4258, 120 X 132
Cable Spool Kit, Short
Window Installation
Spinner Sensor Kit, Without Cable
Sensor Assembly, With Block
Primary Product Distribution
Disc Assembly, Left Hand, 24 Inch
Disc Assembly, Right Hand, 24 Inch
Frame Assembly, 24 Inch, Twin Spinner, 304
Motor Assembly, Left Hand, Style Ii
5.10 Cir
Motor Assembly, Right Hand, Style Ii
Chain Oiler Hardware Kit
Hydraulic Motor, 1 1 4
Pump Assembly, L3220g4 Multapplier, 84s
Tandem Pump, 4.5 X 1.29cid, Right Hand
Pump Installation, L3220g4 Multapplier, 13
Hose Installation, L4330g4, 13
Nozzle And Hose Assembly, 30 Inch Bottom, 45 Degree
Valve Assembly, Sfp 40gpm
Hydraulic Servo, 40gpm
Pwm Control Valve Assembly
Hydraulic Valve, Electrical Pwm
Soft Start Relief Valve
Tee, 1.00 Mo-R X 1.00mjic
New Leader Dry System
Hydraulic Installation, New Leader 4258
Hydraulic Pump Installation, Nl4258g4
Pump Assembly, Nl4258g4
Hydraulic Pump Installation, Nl4258, 13xx
Hydraulic Installation, New Leader 4258 Multapplier
Hose Installation, L4330g4 Multapplier, 13
Hydraulic Pump Installation, Nl4258ma
Hydraulics Installation, Nl4258ma, 11xx
Service Kit
2016
Tee, 1.00 Mo-R X 1.00mjic (2)
Valve And Hose Assembly
900 1100 System Pump Bolts, Bosch Rexroth
900 1100 System Pump Bolts, Sauer Danfoss
1300 System Pump Bolts, Bosch Rexroth
1300 System Pump Bolts, Sauer Danfoss
Kit, Repair
Boom And Speed Node, Raven
Bracket Assembly, Ladder Clip, Tube, 4x3
Clamping Installation, Nl4330, Rogator
Electrical Box Installation, Input Output, Nl4330, Rogator
Electric Box Assembly, Input Output, New Leader, Rogator
2019
Taillight Installation, New Leader, Rogator
Taillight Assembly, Led, Speaker, Molded, Ss
Box Bracket Assembly, Inlet Outlet, L4330g4, Rogator
Electrical Installation, Raven, New Leader, Rogator
Electrical Installation, Multapplier, Raven, New Leader
Electrical Installation, Topcon, New Leader, Rogator
Electrical Installation, Multapplier, Topcon, Nl, Rogator
Harness Installation, Roll Tarp, Rogator
No Worklight #3
Switch Installation, Oiler
New Leader
Controller System
Rate Sensor Mount Installation, Dickey John
Decal Group, Hydraulic Tank
Decal Installation, Speed Indicator Symbol, 35 Mph
Decal Installation, New Leader, Rogator
Decal, Speed Indication Sign, New Leader, 55kph
Lubrication Decal And Chain Conveyor Assembly
Fitting Kit, Suction, Hydraulic
2016-2017
Catch Pan Installation
Belly Pan
Divider Hardware Kit
Assembly
Chain Guides
Tiedown Installation, Liquid System
Common Parts, New Leader, Rogator
