Challenger Narrow Transport Folding Planter 9824-70VE Parts Catalog 652160
Brand: Challenger
Type of Machine: Narrow Transport Folding Planter
Model: Challenger 9824-70VE Narrow Transport Folding Planter
Part Number: 652160
Number of Pages: 768 Pages
Frame
Filter
Hitch And Stands
Tongue
Wing Fold Braces
Center Frame And Inner Wings
Wings - Outer
Markers - Lower
Markers - Upper
Hub - Marker
Gauge Wheel - Marker
Electrical - Tow Hitch
Tow Hitch - Rear
Wheel Lift
Hydraulic Cylinder - Lift
Hub Assembly
Wheel Lift Assist
Platform
Weight - Option
Front Weights
Marker Hub Assembly - Gauge Wheel
Hydraulic Hoses - Clamps
Hydraulics - Blower
Hydraulics - Fan
Tube
Flow Control Valve
Pto Pump
Mounting - Hydraulic Pto Drive Pump
Reservoir
Cooler
Electrical Harness - Cooler
Hydraulic Reservoir
Hydraulic Valve - Delta Force
Hydraulics - Delta Force
Hydraulic Hose Clamp Installation
Flow Control Valve Assembly - Blower
Central Fill System - Hydraulics
Control Valve - Blower
Hydraulics - Ground Drive
Hydraulics - Tractor Remote
Fertilizer Pump - Centrifugal
Electrical Harness - Fertilizer Pump
Down Force - Group
Sensor - Down Force
Electrical Connectors - Kit, Repair
Lighting
Light Assembly, Right - Outer
Light Assembly, Left - Outer
Light Harness
Transport Lights - Front
Sm300 Console
Pm400 Console
Harness - Sm400se
High Power Harness Kit - Sm400se
Mounting - Bridge Module
Harness - Bridge Module
Mounting - Ground Speed Sensor
Control Box - Fold System
Repair Kit - Harness
Radar Gun
Radar Y Harness
Electric Drive
Controls
Lift Switch
Module - Harness
Vacuum - Transducer
Controls - Central Fill System
Sensor And Tube - Seed Smart
Sensor And Tube - High Rate
Sensor Group - High Rate
Sensor And Tube
Harness - Speed Tube
Harness - Seed Sensor
Electrical Connectors - Deutsch And Metri-Pack
Electrical Connectors - Weather Pack
Electrical Connectors - Amp And Deutsch
Electrical Connectors - Amp, Deutsch And Metri-Pack
Product Containment
Hopper Assembly - Left Hand
Hopper Assembly - Right Hand
Hopper And Meter - Center Fill System
Hopper And Meter
Seed Meter
Mini Hopper
Hopper And Meter - Assembly
Hopper Assembly
Hopper And Meter - Mounting
Hopper And Meter - Speed Tube
Hopper And Meter - Cfs System
Hopper And Meter Kit
Hopper - Mounting
Hopper - Support
Hopper Support
Hopper Support - Mini Hopper
Support Group
Mounting - Row Unit
Parallel Link
Row Unit
Row Unit - Lower Assembly
Lever - Depth Adjustment
Gauge Wheel Arm - Left Hand
Central Fill System - Meter
Seed Meter - Components
Seed Disc Identification Chart
Soil Conditioning
Arm - Coulter
Spoke Tooth, 13 Inch - Left Hand
Spoke Tooth, 13 Inch - Right Hand
Wheel Assembly - Spoke Tooth, 10 Inch
Shark Tooth Wheel - Mounting
Shark Tooth - Left Hand
Shark Tooth - Right Hand
Opener Disc
Disc Assembly
Closing Wheel Assembly - Cast
Closing Wheel Assembly - Rubber
Bubble Blade
Ripple Blade - 16 Inch
Blade - Trash Master Kit
Fluted Blade - 8 Flute
Fluted Blade - 13 Flute
Drive Wheel Mud Scraper Kit
Residue Manager - Frame
Residue Manager - Spoke Tooth, 13 Inch
Residue Manager - Shark Tooth
Row Units
Row Unit Spacing
Row Spacing
Speed Tube
Drive Assembly
Mounting - Speed Tube
Delta Down Force - Group
Gauge Wheel - Row Unit
Angle Adjustment - Closing Wheel
Row Unit Coulter Kit - Without Blade
Gauge Wheel Arm - Right Hand
Scraper - Disc
Gauge Wheel Assembly
Gauge Wheel Arm
Scraper - Gauge Wheel
Mounting Frame - Opener Disc
Application System
Frame - Seed Module
Air Duct - Center
Blower - Air Duct
Air Duct - Group
Air Duct - Left Hand
Air Duct - Right Hand
Sensor - Seed Tube
Seed Module Blower And Mounting
Hopper Assembly - Central Fill System
Blower Assembly
Blower Assembly - Seed Module
Seed Module Plenums And Air Boxes
Air Duct - Without Hopper
Support - Hose
Hitch
Decals - Challenger
Safety Decals
Decals - Marker
Central Fill System - Ce
Central Fill System - Challenger
Seed Rate Chart
Reflector Plate Assembly, Left Hand
Reflector Plate Assembly, Right Hand
Slow Moving Vehicle Sign
Speed Tube - Kit
Housing - Seed Tube
Speed Tube - Conversion Kit
Meter Assembly
Speed Tube - Option
Wheel - Fertilizer Drive
Point Row Clutch Kit
Pto Coupler Kit - 1000 Rpm, 1-3 8 Inch
Closing Wheel Kit - Rubber
Delta Force - Kit
Cylinder - Delta Force
Load Sense - Sensor
Trash Master Kit - Row Unit Mounted
Residue Manager Kit
Residue Manager Kit - Spoke Tooth, 13 Inch
Residue Manager Kit - Shark Tooth, 13 Inch
Tow Hitch Kit
Stroke Control Segment Kit
Alternator - Kit
Console Kit - 20 20
Radar Gun Kit
Fertilizer Opener Mounting Kit - Long
Double Disc Opener Kit
Mounting - Fertilizer Opener Kit
Pto Coupler Kit - 1000 Rpm, 1-3 4 Inch
Angled Bracket Closing Wheel Kit
Housing - Disc
Residue Manager Kit - Spoke Tooth, 10 Inch
Tank - 750 Gallon
Fertilizer Opener Mounting Kit - Short
Ground Drive Transmission - Tensioner
Shutoff Clutch Kit - Point Row
Housing - Meter
Hopper And Meter - Vset
Shark Tooth Wheel With Depth Band - Right Hand
Wheel Assembly - Shark Tooth
Housing
Shark Tooth Wheel With Depth Band - Left Hand
Blades - Coulter
Point Row Clutch Kit - Components
Offset Shank Kit - 5-1 2 Inch
Radar Y Harness Kit
Closing Wheel
Sensor And Tube Kit - High Rate
Pressure Spring Kit - Heavy Duty
Single Closing Wheel Kit
Fertilizer Opener Mounting - Short
Residue Manager Attachment Kit - Spoke Tooth, 10 Inch
Fertilizer Tank Kit - 750 Gallon
Weight Kit
Gta C1000 Console Kit
C3000 Console And Mounting Kit
Decals - Seed Meter
Hopper And Meter - Dual Hybrid
Brand: Challenger
Part Number: 652160
Frame
Filter
Hitch And Stands
Tongue
Wing Fold Braces
Wings - Outer
Markers - Lower
Markers - Upper
Hub - Marker
Tow Hitch - Rear
Wheel Lift
Hub Assembly
Wheel Lift Assist
Platform
Weight - Option
Front Weights
Hydraulics - Blower
Hydraulics - Fan
Tube
Flow Control Valve
Pto Pump
Reservoir
Cooler
Hydraulic Reservoir
Down Force - Group
Sensor - Down Force
Lighting
Light Harness
Sm300 Console
Pm400 Console
Harness - Sm400se
Radar Gun
Radar Y Harness
Electric Drive
Controls
Lift Switch
Module - Harness
Vacuum - Transducer
Sensor And Tube
Product Containment
Hopper And Meter
Seed Meter
Mini Hopper
Hopper Assembly
Hopper - Mounting
Hopper - Support
Hopper Support
Support Group
Mounting - Row Unit
Parallel Link
Row Unit
Soil Conditioning
Arm - Coulter
Opener Disc
Disc Assembly
Bubble Blade
Row Units
Row Unit Spacing
Row Spacing
Speed Tube
Drive Assembly
Scraper - Disc
Gauge Wheel Arm
Application System
Frame - Seed Module
Air Duct - Center
Blower - Air Duct
Air Duct - Group
Sensor - Seed Tube
Blower Assembly
Support - Hose
Hitch
Decals - Challenger
Safety Decals
Decals - Marker
Seed Rate Chart
Speed Tube - Kit
Housing - Seed Tube
Meter Assembly
Speed Tube - Option
Delta Force - Kit
Load Sense - Sensor
Residue Manager Kit
Tow Hitch Kit
Alternator - Kit
Console Kit - 20 20
Radar Gun Kit
Housing - Disc
Tank - 750 Gallon
Housing - Meter
Housing
Blades - Coulter
Radar Y Harness Kit
Closing Wheel
Weight Kit
Decals - Seed Meter
