BigBoss1
106
307,104
Challenger Multapplier Terragator C System NL L5000G5 (2019-2024) Part Book
Brand: Challenger
Type of Machine: Terragator
Type of Manual: Parts Book
Model: Challenge NL L5000G5 Multapplier Terragator C System
Serial Number: ..KXXX1001-..RXXX9999
Year of Manufacture: 2019-2024
Number of Pages: 364 Pages
Filters Guide & Belts Guide - Nl5000g5 Edge
Angle Group, 14-16 Foot - Fender
Bed Sheet, New Leader
Box Assembly - Tarp Hardware & Grommet
Multapplier, 409ss, 14_7 Foot
Multibin, 409ss, 14 Foot
Hardware Kit - Multibin
Endgate - Nl5000g5, 409ss, 14 Foot, #4 Belt Over Chain, Full Flare
Endgate Hardware Kit
Feedgate - Dual Micro Multibin
Feedgate - Multapplier
Feedgate - Multibin
Fenders - 14 Foot, 132 Inch, 409ss
Foot Support
Guard - Front Conveyor
Gear Case & Tube
Gear Case
Hydraulic Motor, 1 1_4
Direct Drive Group, 24 Inch - Multibin
Drive Idler - 30_
Idler Group, 24 Inch - Multibin
Inverted Vee Kit, 13 - 14 Foot, High Yield, 409ss
Inverted Vee Kit - Hardware Kit, 8 - 12 Foot V, Ss
Mudguard - Front
Mudguard - Rear
Gaskets - Multapplier_Multibin
Window - Glass
Primary Product Distribution
Conveyor And Shield Assembly, 304ss, 14 Foot - #4 Belt Over Chain
Conveyor, #4 Belt Over Chain, 75 Links
Hillside Divider Assembly, 30 Inch - #4 Belt Over Chain
Hillside Divider - Dual Micro Multibin
Hillside Divider Kit & Cover
Shield & Chain - Dual Micro Multibin
Shield & Chain - Multapplier, 7 Foot
Spinner Assembly - 30 Inch, G5, 304ss
Spinner Assembly, G5 - 304ss
Spinner Frame - Assembly
Disc Assembly, Left Hand, 24 Inch
Disc Assembly, Right Hand, 24 Inch
Spinner Deflector - G5
Divider
Vane - G5
Hydraulic Installation, L5000g5, 73xx_8xxx - Load Sense
Hydraulic Installation, L5000g5, 93xx - Load Sense
Hydraulic Installation, L5000g4_Ma, 73xx_8xxx - Load Sense, Rexroth
Hydraulic Installation, L5000g4_Ma, 93xx - Load Sense
Hydraulic Installation, L5000g5_Multibin, 73xx_8xxx - Load Sense
Hydraulic Installation, L5000g5_Multibin, 93xx - Load Sense
Hydraulic Installation, Routing Accessories - New Leader
Hydraulic Hose Installation, L5000g4 - 73xx_8xxx
Hydraulic Hose Installation, L5000g4 - 93xx
Hydraulic Hose Installation, L5000g4ma - Load Sense, Rexroth
Hydraulic Hose Installation, L5000g4ma, 93xx
Hydraulic Hose Installation, L5000g4_Multibin - 73xx_8xxx
Hydraulic Hose Installation, L5000g4_Multibin - 93xx
Hydraulic Assembly, Main System, 14 Foot, G5
Hydraulic Assembly, Main System - Multi Product, 14 Foot
Hydraulic Group, 14 Foot - Single Bin
Hydraulic Group - Multi Product, 14 Foot
Hydraulic Group, Multapplier_Multibin - 7 Foot
Hydraulic Group, Multapplier, 14 Foot
Dual Micro Hydraulic Group, Multibin - 14 Feet
Hydraulic Motor (Components)
Hydraulic Pump, L4000g4 Edge
Hydraulic Pump - L4500g4 Edge
Hydraulic Tank - G5
Hydraulic Tank (Components) - G5
Hydraulic Tank Heater
Cap Installation, Hydraulic, Standard - Loose System Only
Cap Installation, Hydraulic, Multapplier - Loose System Only
Cartridge, T, 9gpm Servo
Chain Oiler
Chain Oiler - Tank
Chain Oiler - Pump_Assembly With Connector
Chain Oiler Nozzle - Left Side
Chain Oiler Nozzle - Right Side
Cover Cylinder
Cylinder Control Valve
Fitting Group -20 Orfs
Lid Control Valve
Piston Pump, 100 Cc, Right Hand
Spreader Control Valve - Pwm Control Valve Assembly
Spreader Control Valve - Nl5000g5 Edge
Sensor Group - Hydraulic Tank
Speed Sensor
Suction Fittings, 32jic
Valve Assembly
Valve Assembly, Sfp 5gpm - Pwm Control Valve Assembly
Valve Assembly - 5 Gpm-A, Spf
Valve Assembly - 5 Gpm-B, Spf
Hydraulic Servo, 9gpm - Pwm Control Valve Assembly
Valve Assembly, Sfp 9gpm
Valve Assembly, Sfp 9gpm - Pwm Control Valve Assembly
Valve Assembly, Sfp 10gpm
Spinner Motor
Spinner Motor
Lighting - Rotary Beacon
Wiring Harness - Multapplier
Wiring Harness - Dual Micro Multibin
Electrical Installation - New Leader
Wiring Harness - Mounting Parts
Roll Tarp - Electric
No Roll Tarp, New Leader
Reversing Camera - New Leader
Reversing Camera - Multibin
Reversing Camera - Multapplier_Multibin
Taillight Installation, Euro
Taillight Installation, Euro - Fender
Work Lights
Work Lights - #3
Controller System
1 Product And Swath Controls - 13 Foot - 14 Foot
2 Product And Swath Controls - 14 Feet
2 Product And Swath Controls - Master Module
4 Product And Swath Controls - 14 Feet
Bin Level Sensor
Dual Spinner Speed - Sensor
Spinner Sensor Assembly Kit - G5
Enclosure - Module
Enclosure - Mount Assembly
Encoder And Bracket, Dickey-John 360 - Multapplier_Multibin
Encoder, Dickey-John 360, With 12 Inch Cable
Rate Sensor Mount Installation, Dickey John
Slave Module Group - 14 Feet
1 Product And Swath Controls - 14 Feet
Air System
Air Plumbing Installation - Multibin
Decal Installation - Nl5000g5 Edge
Decal Group, Nl5000 - Dual Micro Multibin
Decal Group, Nl5000 - Multapplier
Decal Group, Safety Multapplier
Safety Decals - Body
Cover - Multibin
Dual Bin Panel
Dual Bottom Micro - 360 Encoder
Dual Bottom Micro
Dual Bottom Micro - Metering Wheel Shaft Assembly
Lube Bank - Main
Lube Bank - 7 Foot Insert
Roll Tarp - 14 Feet
Roll Tarp Kit, Electric, 14 Foot Box
Roll Tarp - Multibin
Multapplier Wiper
Wiper Belt - Multibin
Wiper, Front, 304ss
Side Board - 7 Foot
System Holddowns - Dry System
Pattern Test Kit - New Leader
Test Kit, Size Grade Number And Hardness
