Challenger Large Rectangular Baler 2370 UHD Parts Catalog 652352
Brand: Challenger
Type of Machine: Large Rectangular Baler
Model: Challenger 2370 UHD Large Rectangular Baler
Part Number: 652352
Number of Pages: 440 Pages
Drive System
Filter
Main Drive
Secondary Drive Shaft
Primary Drive Shaft - Non-Ce
Primary Drive Shaft - Ce
Mounting - Gearbox
Mounting - Flywheel
Clutch - Flywheel
Brake - Flywheel
Auxiliary Drive - Left Hand
Shaft And Sprocket - Auxiliary
Auxiliary Drive - Right Hand
Slip Clutch - Auxiliary
Drive - Cutter
Clutch - Cutter
Chain Lube - Packer
Pump - Chain Lube
Chain Lube - Cutter
Pickup - Hydraulics
Hydraulic - Front
Hydraulic Valve Assembly - Bale Density
Hydraulic Reservoir
Oil Cooler - Hydraulic
Bale Density - Hydraulics
Brake Hydraulics
Steering Lock
Blower Hydraulics
Blower
Cutter - Lift
Valve - Hydraulic
Cutter - Knife
Hydraulics - Bale Ejector
Hydraulic Valve Assembly - Bale Ejector
Jack - Hydraulic
Gta C1000 Console And Mounting - Non-Ce
Gta C1000 Console And Mounting - Ce
C2100 Console And Mounting - Non Ce
C2100 Console And Mounting - Ce
Electrical - Main
Electrical - Upper
Electrical - Lower
Electrical - Lighting
Light Harness - Non-Ce
Light Harness - Ce
Electrical - Twine Can
Wiring - Pickup
Electrical - Roller Bale Chute
Bale Feeding System
Windguard
Wrapper, Wear Plate And Scraper - Mounting
Pickup Flotation
Stop - Pickup
Pickup Augers - Upper
Pickup Augers - Lower
Pickup Drive - Left Hand
Pickup Drive - Right Hand
Pickup Reel
Pickup Shields
Gauge Wheel - Pickup
Mounting - Cutter
Cutter
Rotor
Knife Assembly - Mounting
Knife Assembly
Bale Forming System
Mounting - Packer Crank
Crank - Packer
Stuffer Drive - Left Hand
Clutch - Dog
Stuffer Drive - Right Hand
Brake Assembly
Chute - Feeder
Holding Finger - Stuffer Chamber
Struts And Wrappers - Packer
Linkage - Stuffer Clutch
Mounting - Connecting Rods
Connecting Rod Lube
Mounting - Plunger
Plunger
Mounting - Stripper
Bale Knotting System
Mounting - Needle
Knotter Mounting
Knotter
Main Shaft Assembly - Knotter
Head - Knotter
Knotter Slacker - Upper
Mounting - Tensioner
Tensioner - Lower
Knotter Monitor
Knotter Control - Sensor
Knotter Clutch
Star Wheel
Knotter Brake
Twine Finger And Hay Dog - Knotter
Tensioner - Left Hand
Tensioner - Right Hand
Mounting - Knotter Lube Pump
Knotter Lube Pump
Knotter Lube
Knotter Lube - Primary
Knotter Lube - Secondary
Bale Ejecting System
Mounting - Bale Ejector
Selectable Ejector
Mounting - Roller Bale Chute
Bale Chute - Roller
Bale Weight - Mounting
Hitch And Jack Mounting
Hitch And Jack Mounting - Ce
Tongue
Step Assembly
Plunger Rails, Knives And Hay Dog
Bale Density Doors
Bonnet
Knotter Shields
Twine Box Mounting
Tensioner - Twine Can
Twine Can
Door Assembly - Left Hand
Door Assembly - Right Hand
Drive Shields - Auxiliary
Guard - Packer
Guard - Cutter
Shields - Wheel
Mounting - Shields
Latches - Non-Ce
Latch - Non-Ce
Latch - Ce
Mounting - Handrail
Decals - Logo
Decals - Operational
Decals - Bale Ejector
Decals - Non-Ce
Decals - Ce
Axles, Spindles, And Wheels
Suspension
Axle - Rigid
Axle - Steering
Brake Assembly - Rigid
Brake System - Steering
Park Brake
Actuator Assembly - Park Brake
Mounting - Air Brake
Air Brake
Drive Shaft Kit - Primary
Gta C1000 Console Kit - Non-Ce
Gta C1000 Console Kit - Ce
C2100 Console Kit - Non Ce
C2100 Console Kit - Ce
Hydraulic Jack Kit
Extension Kit - Hitch
