Challenger Large Rectangular Baler 2270 2270XD Parts Catalog 652010
Brand: Challenger
Type of Machine: Large Rectangular Baler
Model: Challenger 2270, 2270XD Large Rectangular Baler
Serial Number: GHBXX101 And Later
Part Number: 652010
Number of Pages: 338 Pages
Drive System
Belts & Filters Guide
Main Drive
Clutch - Flywheel
Drive Shaft
Secondary Drive Shaft
Primary Drive Shaft - Non-Ce
Primary Drive Shaft - Ce
Brake - Flywheel
Mounting - Gearbox And Flywheel
Gearbox Assembly
Auxiliary Drive - Left Hand
Auxiliary Drive - Right Hand
Shaft And Sprocket - Auxiliary
Slip Clutch - Auxiliary
Drive - Cutter
Slip Clutch - Cutter
Gearbox Assembly - Cutter
Chain Lube
Pump - Chain Lube
Chain Lube - Cutter
Pick-Up - Hydraulics
Pickup - Hydraulics
Hydraulic Cylinder - Pickup Lift
Hydraulic - Front
Hydraulic Valve Assembly - Bale Density
Hydraulic Reservoir
Bale Density - Hydraulics
Brake Hydraulics - Single Axle
Brake Hydraulics - Tandem Axle
Steering Lock - Tandem Axle
Blower Hydraulics
Blower
Cutter - Lift
Valve - Hydraulic
Cutter - Knife
Hydraulics - Bale Ejector
Hydraulics - Bale Chute Lift
Hydraulic Cylinder Assembly
Jack - Hydraulic
Electrical Connectors - Kit, Repair
Gta C1000 Console And Mounting - Non-Ce
Gta C1000 Console And Mounting - Ce
C2100 Console And Mounting - Non Ce
C2100 Console And Mounting - Ce
Gta Mounting - Option
Wiring - Control Box
Wiring - Pickup
Wiring - Upper
Wiring - Lower
Electrical Kit
Wiring - Cutter
Lights - Non-Ce
Lights - Ce
Bale Chute - Roller
Module - Rear
Electrical Connectors - Weather Pack
Electrical Connectors - Amp, Deutsch And Weatherpack
Electrical Connectors - Amp And Deutsch
Electrical Connectors - Deutsch And Metri-Pack
Bale Feeding System
Windguard
Roller - Windguard
Windguard - Stop Plate
Wrapper, Wear Plate And Scraper - Mounting
Pickup Flotation
Pickup Augers
Pickup Drive - Left Hand
Pickup Drive - Right Hand
Pickup Clutch
Pickup Reel
Pickup Shields - Left Hand
Shield Mounting - Left Hand
Pickup Shields - Right Hand
Shield Mounting - Right Hand
Gauge Wheel - Pick-Up
Pickup Augers - Adapter
Mounting - Cutter
Cutter
Rotor - Cutter
Knife Assembly - Mounting
Knife Assembly
Bale Forming System
Packer - Feeding Auger
Mounting - Packer Crank
Crank - Packer
Stuffer Drive - Left Hand
Stuffer Drive - Right Hand
Clutch - Dog
Brake Assembly
Chute - Feeder
Struts And Wrappers - Packer
Linkage - Stuffer Clutch
Holding Finger - Stuffer Chamber
Mounting - Connecting Rods
Connecting Rod Lube
Plunger
Mounting - Stripper
Bale Knotting System
Mounting - Needle
Knotter Mounting
Knotter
Main Shaft Assembly - Knotter
Knotter Slacker - Upper
Head - Knotter
Knotter Clutch
Knotter Brake
Twine Finger And Hay Dog - Knotter
Tensioner
Mounting - Star Wheel
Star Wheel Tower
Linkage - Star Wheel
Star Wheel
U-Joint - Star Wheel
Knotter Arm Mounting
