Challenger Large Rectangular Baler 2260 Parts Catalog 652050
Brand: Challenger
Type of Machine: Large Rectangular Baler
Model: Challenger 2260 Large Rectangular Baler
Serial Number: GHBXX101 And Later
Part Number: 652050
Number of Pages: 643 Pages
Drive System
Belts & Filters Guide
Main Drive
Clutch - Flywheel
Drive Shaft
Secondary Drive Shaft
Primary Drive Shaft - Non-Ce
Primary Drive Shaft - Ce
Brake - Flywheel
Mounting - Gearbox And Flywheel
Gearbox Assembly
Auxiliary Drive - Left Hand
Auxiliary Drive - Right Hand
Shaft And Sprocket - Auxiliary
Slip Clutch - Auxiliary
Drive - Cutter
Slip Clutch - Cutter
Gearbox Assembly - Cutter
Chain Lube
Pump - Chain Lube
Chain Lube - Cutter
Pick-Up - Hydraulics
Pickup - Hydraulics
Hydraulic Cylinder - Pickup Lift
Hydraulic - Front
Hydraulic Valve Assembly - Bale Density
Hydraulic Reservoir
Bale Density - Hydraulics
Brake Hydraulics - Single Axle
Brake Hydraulics - Tandem Axle
Steering Lock - Tandem Axle
Blower Hydraulics
Blower
Cutter - Lift
Valve - Hydraulic
Cutter - Knife
Hydraulics - Bale Ejector
Hydraulics - Bale Chute Lift
Hydraulic Cylinder Assembly
Jack - Hydraulic
Electrical Connectors - Kit, Repair
Gta C1000 Console And Mounting - Non-Ce
Gta C1000 Console And Mounting - Ce
C2100 Console And Mounting - Non Ce
C2100 Console And Mounting - Ce
Gta Mounting - Option
Wiring - Control Box
Wiring - Pickup
Wiring - Upper
Wiring - Lower
Electrical Kit
Wiring - Cutter
Lights - Non-Ce
Lights - Ce
Bale Chute - Roller
Module - Rear
Electrical Connectors - Weather Pack
Electrical Connectors - Amp, Deutsch And Weatherpack
Electrical Connectors - Amp And Deutsch
Electrical Connectors - Deutsch And Metri-Pack
Bale Feeding System
Windguard
Roller - Windguard
Wrapper, Wear Plate And Scraper - Mounting
Pickup Flotation
Pickup Augers
Pickup Drive - Left Hand
Pickup Drive - Right Hand
Pickup Clutch
Pickup Reel
Pickup Shields - Left Hand
Shield Mounting - Left Hand
Pickup Shields - Right Hand
Shield Mounting - Right Hand
Gauge Wheel - Pick-Up
Pickup Augers - Adapter
Mounting - Cutter
Cutter
Rotor - Cutter
Knife Assembly - Mounting
Knife Assembly
Bale Forming System
Packer - Feeding Auger
Mounting - Packer Crank
Crank - Packer
Stuffer Drive - Left Hand
Stuffer Drive - Right Hand
Clutch - Dog
Brake Assembly
Chute - Feeder
Struts And Wrappers - Packer
Linkage - Stuffer Clutch
Holding Finger - Stuffer Chamber
Mounting - Connecting Rods
Connecting Rod Lube
Plunger
Mounting - Stripper
Bale Knotting System
Mounting - Needle
Knotter Mounting
Knotter
Main Shaft Assembly - Knotter
Knotter Slacker - Upper
Head - Knotter
Knotter Clutch
Knotter Brake
Twine Finger And Hay Dog - Knotter
Tensioner
Mounting - Star Wheel
Star Wheel Tower
Linkage - Star Wheel
Star Wheel
U-Joint - Star Wheel
Knotter Arm Mounting
Tensioner - Lower
Tension Arm
Knotter Monitor
Mounting - Knotter Lube Pump
Knotter Lube Pump
Knotter Lube
Knotter Lube Valve - Primary
Knotter Lube Valve - Secondary
Bale Ejecting System
Selectable Ejector
Mounting - Bale Ejector
Mounting - Roller Bale Chute
Bale Weight - Mounting
Hitch And Jack Mounting
Hitch - Ce
Plunger Rails, Knives And Hay Dog
Bale Density Doors
Hood And Mounting - Non-Ce
Hood And Mounting - Ce
Shields - Top
Knotter Shields - Non-Ce
Knotter Shields - Ce
Twine Box Mounting - Left Hand
Twine Box Mounting - Right Hand
Twine Can - Left Hand
Twine Can - Right Hand
Support - Left Hand
Support - Right Hand
Door Assembly - Left Hand
Door Assembly - Right Hand
Drive Shields - Auxiliary
Shields - Single Axle
Step Assembly
Shields - Tandem Axle
Mounting - Handrail
Tool Box
Decals - Logo
Decals - Operational
Axles, Spindles, And Wheels
Axle Mounting - Single Axle
Hub And Spindle - Single Axle
Axle Assembly - Tandem Axle
Axle - Rigid
Hub Assembly
Axle - Steering
Hub Assembly - Steering
Brake Mounting - Single Axle
Brake Assembly - Left Hand
Brake Assembly - Right Hand
Brake System - Rigid
Brake System - Steering
Dust Cover - Brake System
Park Brake - Single Axle
Park Brake - Tandem Axle
Actuator Assembly - Park Brake
Air Brake - Single Axle
Air Brake - Tandem Axle
Auto Brake - Ce
Accumulator
Mounting - Caster
Mainframe
Wheel Assembly - Caster
Hitch
Mounting - Hydraulic
Control Box - Accumulator
Electrical
Cart - Unlatching
Bale Shift Bar And Linkage
Cart - Left Hand
Cart - Right Hand
Frame And Panel - Rear
Centralized Lube
Decals - Accumulator
Road Lights
Bale Weight Kit
Lube System Kit
Decal Kit - Accumulator
Drive Shaft Kit - Primary
Roller Bale Chute Kit
Roller Bale Chute
Gta C1000 Console Kit - Non-Ce
Gta C1000 Console Kit - Ce
C2100 Console Kit - Non Ce
C2100 Console Kit - Ce
Accumulator Mounting Kit
Valve Assembly - Accumulator
Shear Bolt Kits
Module Kit
Module Harness Kit
Knotter Trip Kit
Motor Assembly - Trip
Telemetry Installation Kit
Telemetry Kit
Hydraulic Jack Kit
Extension Kit - Hitch
Decal Kit - French
Decal Kit - Spanish
Shield Kit - Single Axle
Kit - Air Brake
