Challenger Large Rectangular Baler 2250 Parts Catalog 79035930
Brand: Challenger
Type of Machine: Large Rectangular Baler
Model: Challenger 2250 Large Rectangular Baler
Part Number: 79035930
Number of Pages: 533 Pages
Drive System
Filter
Main Drive
Clutch - Flywheel
Drive Shaft
Secondary Drive Shaft
Primary Drive Shaft - Non-Ce
Primary Drive Shaft - Ce
Brake - Flywheel
Mounting - Flywheel
Mounting - Gearbox
Gearbox Assembly
Auxiliary Drive - Left Hand
Auxiliary Drive - Right Hand
Shaft And Sprocket - Auxiliary
Slip Clutch - Auxiliary
Tensioner
Drive - Cutter
Gearbox Assembly - Cutter
Slip Clutch - Cutter
Chain Lube
Pick-Up - Hydraulics
Hydraulic - Front
Hydraulic Valve Assembly - Bale Density
Hydraulic Reservoir
Bale Density - Hydraulics
Brake Hydraulics - Single Axle
Brake Hydraulics - Tandem Axle
Steering Lock - Tandem Axle
Blower Hydraulics
Blower
Hydraulics - Cutter
Hydraulic Cylinder Assembly
Hydraulics - Packer Cutter
Hydraulics - Bale Ejector
Hydraulics - Bale Chute Lift
Jack - Hydraulic
Electrical Connectors - Kit, Repair
Gta C1000 Console And Mounting - Non-Ce
Gta C1000 Console And Mounting - Ce
Gta Mounting - Option
Wiring - Control Box
Wiring - Upper
Wiring - Lower
Electrical Kit
Wiring - Cutter
Wiring - Packer Cutter
Lights - Non-Ce
Lights - Ce
Bale Chute - Roller
Electrical Connectors - Weather Pack
Electrical Connectors - Amp, Deutsch And Weatherpack
Electrical Connectors - Amp And Deutsch
Electrical Connectors - Deutsch And Metri-Pack
Bale Feeding System
Windguard
Windguard Support Chains
Roller - Windguard
Wrapper, Wear Plate And Scraper - Mounting
Pickup Flotation
Pickup Augers
Pickup Drive - Left Hand
Pickup Drive - Right Hand
Pickup Clutch
Pickup Reel
Pickup Shields - Left Hand
Pickup Shields - Right Hand
Shield Mounting - Left Hand
Shield Mounting - Right Hand
Gauge Wheel - Pick-Up
Pickup Augers - Adapter
Mounting - Cutter
Cutter
Rotor - Cutter
Knife Assembly
Bale Forming System
Packer - Feeding Auger
Mounting - Packer Crank
Crank - Packer
Stuffer Drive - Left Hand
Stuffer Drive - Right Hand
Clutch - Dog
Brake Assembly
Chute - Feeder
Struts And Wrappers - Packer
Struts And Wrappers - Packer Cutter
Knife Bed - Packer Cutter
Linkage - Stuffer Clutch
Holding Finger - Stuffer Chamber
Mounting - Connecting Rods
Connecting Rod Lube
Plunger
Mounting - Stripper
Bale Knotting System
Mounting - Needle
Knotter Mounting
Knotter
Knotter Slacker - Upper
Main Shaft Assembly - Knotter
Head - Knotter
Knotter Clutch
Knotter Brake
Twine Finger And Hay Dog - Knotter
Mounting - Star Wheel
Star Wheel Tower
Linkage - Star Wheel
Star Wheel
U-Joint - Star Wheel
Knotter Arm Mounting
Tensioner - Lower
Tension Arm
Knotter Monitor
Mounting - Knotter Lube Pump
Knotter Lube Pump
Knotter Lube
Knotter Lube Valve - Primary
Knotter Lube Valve - Secondary
Knotter - Service Parts
Bale Ejecting System
Selectable Ejector
Mounting - Bale Ejector
Mounting - Roller Bale Chute
Bale Weight - Mounting
Hitch And Jack Mounting
Hitch - Ce
Plunger Rails, Knives And Hay Dog
Bale Density Doors
Hood And Mounting
Shields - Top
Knotter Shields - Non-Ce
Knotter Shields - Ce
Twine Box Mounting - Left Hand
Twine Box Mounting - Right Hand
Twine Box - Left Hand
Twine Box - Right Hand
Support - Left Hand
Support - Right Hand
Door Assembly - Left Hand
Door Assembly - Right Hand
Shield Assembly - Left Hand
Shield Assembly - Right Hand
Drive Shields - Auxiliary
Shields - Single Axle
Shields - Tandem Axle
Mounting - Handrail
Tool Box
Decals - Logo
Decals - Operational
Axles, Spindles, And Wheels
Axle Mounting - Single Axle
Hub And Spindle - Single Axle
Axle Assembly - Tandem Axle
Axle Assembly - Rigid
Axle Assembly - Steering
Hub Assembly - Steering
Brake Assembly - Single Axle
Brakes - Rigid
Brakes - Steering
Park Brake - Single Axle
Park Brake - Tandem Axle
Actuator Assembly - Park Brake
Air Brakes - Single Axle
Air Brakes - Tandem Axle
Auto Brake - Ce
Accumulator
Linkage And Wing Latch
Control Box - Accumulator
Cart - Left Hand
Cart - Right Hand
Cart - Unlatching
Wing - Left Hand
Wing - Right Hand
Frame And Paddle - Rear
Shield And Paddle - Rear
Shields
Electrical
Hub And Wheels - Caster
Hydraulics
Centralized Lube
Bale Shift Bar And Linkage
Road Lights
Decals - Accumulator
Lube System Kit
Decal Kit - Accumulator
Drive Shaft Kit - Primary
Bale Chute Kit
Roller Bale Chute Kit
Accumulator Mounting Kit
Valve Assembly - Accumulator
Shear Bolt Kits
Gta C1000 Console Kit - Non-Ce
Gta C1000 Console Kit - Ce
Bale Weight Kit
Module Kit
Module Harness Kit
Knotter Trip Kit
Knotter Trip Kit - Motor
Decal Kit - French
Decal Kit - Spanish
Telemetry Kit
Telemetry Installation Kit
Hydraulic Jack Kit
Blower Relief Valve Kit
Gauge Wheel Kit - Removable
Roller Kit - Windguard
Extension Kit - Hitch
