Challenger Grain Headers FH RH Parts Catalog 79021527
Brand: Challenger
Type of Machine: Harvesting Attachment, Grain Headers
Model: Challenger FH, RH Grain Headers
Serial Number: HM84101
Part Number: 79021527
Number of Pages: 139 Pages
Publication Information
Housing - Housing, Flex Fh
Housing - Skid Assemblies, Flex Fh
Housing - Stabilizer, Flex Fh
Housing - Tilt Arms, Flex Fh
Housing - Housing, Rigid Rh
Dividers - Dividers, Flex Fh
Dividers - Stabilizer & Spring Asy., Flex Fh
Dividers - Long Wing Divider, Flex Fh
Dividers - Divider - Short, Rigid Rh
Auger - Conveyor, Prior S N Hp84101
Auger - Conveyor, Effective S N Hp84101
Auger - Conveyor, Full Finger
Auger - Finger Shaft Asy, Full Finger
Auger - Auger Weights, Full Finger
Auger - Center Extensions, Full Finger
Drives - Sickle Drive, Flex Fh
Drives - Spring Tensioner Kit, Sickle Drive Belt, Flex Fh
Drives - Sickle Drive, Rigid Rh
Drives - Conveyor Drive, Prior S N Hp84101
Drives - Improved Gudgeon Service Kit, Headers Prior To S N Hp84101
Drives - Conveyor Drive, Effective S N Hp84101
Drives - Main Drive Shafts
Drives - Driveshaft-Pto, Components
Reel - Reel Supports, Electric Reel Adjustment Fore-Aft
Reel - Standard Bat Reel, Reel & Hangers, Rigid Rh
Reel - Pickup Reel (Hcc), Level ( 2 ), 6 Inch Finger Spacing
Reel - Orbit Reel Kits, Flex Fh
Reel - Pickup Reel (Uhc U-Ii)
Cutter Bar - Sickles & Guards, Flex Fh
Cutter Bar - Sickles & Guards, Rigid Rh
Cutter Bar - Sickles & Guards, Narrow Spaced, Clean Cut, Flex Fh
Cutter Bar - Sickles & Guards, Schumacher, 20 25 30 Feet, Flex Fh
Cutter Bar - Guard & Spacer Location, Schumacher, 20 25 30 Feet, Flex Fh
Cutter Bar - Wobble Box
Header Height & Lateral Tilt - Header Height, Controls, Flex Fh
Header Height & Lateral Tilt - Position Sensors & Brackets, Rigid Hdr
Hydraulics - Reel Lift, Lines & Fittings
Hydraulics - Hydro Reel Drive, Motor
Hydraulics - Hydro Reel Motor
Hydraulics - Hydro Reel Drive, Lines & Fittings
Hydraulics - Cylinder Reel Lift, Master
Hydraulics - Cylinder Reel Lift, Slave
Shields - Shields, Rh Side
Shields - Shields, Lh Side & Rh Feeder Opening
Electrical - Wire Harness
Electrical - Harness Adapters
Electrical - Clearance Lights
Mounting Kits - Header Adapter Package, 660 Combine
Mounting Kits - Header Adapter Package, Headers S N Hm84101 To S N Hp84101, 670 Combine
Mounting Kits - Header Adapter Package, Headers Effective S N Hm84101, 670 Combine
Accessories - Headers, Raised Feather Sheets, Flex Fh
Accessories - Rubber Curtain Package
Accessories - Dust Diverter Iii
Accessories - Fan Housing Assembly, Dust Diverter Iii, 71405886
Accessories - Single Point Hook-Up, Hydraulic Electrical, Permanent, 71530660
Accessories - Single Point Hook-Up, Hydraulic Electrical, Temporary, 71530661
Accessories - Multi Coupler, 71412110
Recommended Dealer Stock - Recommended Dealer Stock
