Challenger Forward Fold Planter 8182 8186 Parts Catalog 00730632
Brand: Challenger
Type of Machine: Forward Fold Planter
Model: Challenger 8182, 8186 Forward Fold Planter
Serial Number: HS18200101 And Later, HS18600101 And Later
Part Number: 00730632
Number of Pages: 341 Pages
Publication Information
Drives - Ground Drive-Left (8182)
Drives - Ground Drive-Right (8182)
Drives - Ground Drive-Left (8186)
Drives - Ground Drive-Right (8186)
Drives - Transmission
Drives - Transmission Sprocket Assembly, (Rear Cluster)
Drives - Transmission Sprocket Assembly, (Front Cluster)
Drives - Transmission Drive Sprocket Assembly
Drives - Row Unit Drive-Left (8182)
Drives - Row Unit Drive-Right (8182)
Drives - Row Unit Drive-Left (8186)
Drives - Row Unit Drive-Right (8186)
Drives - Drive Chains
Air Tubes - Air Ducts-Center (8182 8186)
Air Tubes - Air Ducts-Left (8182)
Air Tubes - Air Ducts-Right (8182)
Air Tubes - Air Ducts-Left (8186)
Air Tubes - Air Ducts-Right (8186)
Air Tubes - Air Pressure Gauge And Mount
Electrical - Transport Lights (8182 8186)
Electrical - Fold Sensors-2 Carrier Wheels (8182)
Electrical - Fold Sensors-4 Wheels (8182)
Electrical - Fold Sensors-4 Wheels (8186)
Electrical - Row Sensor Harness-Left (8182)
Electrical - Row Sensor Harness-Center (8182)
Electrical - Row Sensor Harness-Right (8182)
Electrical - Row Sensor Harness-Bridge (8182)
Electrical - Row Sensor Harness-Left (8186)
Electrical - Row Sensor Harness-Left, Center (8186)
Electrical - Row Sensor Harness-Center (8186)
Electrical - Row Sensor Harness-Right, Center (8186)
Electrical - Row Sensor Harness-Right (8186)
Electrical - Row Sensor Harness-Bridge (8186)
Electrical - Console Assembly (Sm400se)
Electrical - Harness Assembly-Low Power (Sm400se)
Electrical - Sensor And Tube (Seed Smart)
Electrical - Sensor And Tube (High Rate)
Electrical - Radar Distance Sensor And Mounting
Electrical - Radar Y Harness
Electrical - Sm4000-Magnetic Distance Sensor Harness
Electrical - Magnetic Distance Sensor And Mounting
Electrical - Electrical Harness Service Parts
Row Units - Row Unit Mounting
Row Units - Row Unit (Without Angles)
Row Units - Row Unit (With Angles)
Row Units - Row Unit (With Front Bracket)
Row Units - Row Unit Chain Tighteners
Row Units - Row Unit-Lower
Row Units - Disc Assembly, (700732973 Disc Assembly)
Row Units - Gauge Wheel Mounting
Row Units - Gauge Wheel Assembly-Left
Row Units - Gauge Wheel Assembly-Right
Row Units - Gauge Wheel Assembly, (700727657 Gauge Wheel Assembly)
Row Units - Depth Adjustment
Row Units - 2 Bushel Hopper And Mounting
Row Units - 3 Bushel Hopper And Mounting
Row Units - Seed Meter
Row Units - Seed Disc Identification Chart
Row Units - Closing Wheel And Mounting (Rubber)
Row Units - Closing Wheel Assembly (Rubber), (700727676 Closing Wheel Assembly)
Row Units - Closing Wheel And Mounting (Cast)
Row Units - Closing Wheel Assembly (Cast), (854077 Closing Wheel Assembly)
Row Units - Single Closing Wheel And Mounting
Row Units - Seed Meter Funnel
Markers - Marker-Left (Folding)
Markers - Marker-Right (Folding)
Markers - Marker Chains-Folding, (Left Shown, Right Opposite)
Markers - Marker Extension (8186), (Left Shown, Right Opposite)
Markers - Notched Marker Disc-Left And Right
Markers - Solid Marker Disc-Left And Right
Markers - Marker-Left And Right (8186), (Left Shown, Right Opposite), (S.N. Hs18600101 Thru Hu18600100)
Markers - Marker-Left And Right (8186), (Left Shown-Right Opposite), (S.N. Hs18600101 Thru Hu18600100)
Markers - Marker Hub Assembly, (700157278 Marker Hub Assembly), (Left Shown, Right Opposite), (S.N. Hs18600101 Thru Hu18600100)
Markers - Marker Gauge Wheel-Left And Right (8186), (S.N. Hs18600101 Thru Hu18600100)
Markers - Marker Base (8186), (Left Shown-Right Opposite), (S.N. Hu18600101 And Later)
Markers - Marker Assembly (8186), (Left Shown, Right Opposite), (S.N. Hu18600101 And Later)
Markers - Marker Hub Assembly, (700167578 Marker Hub Assembly), (Left Shown, Right Opposite), (S.N. Hu18600101 And Later)
Markers - Marker Gauge Wheel (8186), (700169233 Gauge Wheel Assembly), (Left Shown, Right Same), (S.N. Hu18600101 And Later)
Markers - Flat Fold Marker-Left (8182)
Markers - Flat Fold Marker-Right (8182)
Markers - Flat Fold Marker Rest (8182)
Tongue, Frame And Wheels - Tongue (8182 8186)
Tongue, Frame And Wheels - Mainframe (8182 8186)
Tongue, Frame And Wheels - Transport Latch
Tongue, Frame And Wheels - Wheel Arm And Mounting
Tongue, Frame And Wheels - Hub And Axle
Tongue, Frame And Wheels - Transport Wheel-Center Left
Tongue, Frame And Wheels - Transport Wheel-Center Right
Tongue, Frame And Wheels - Transport Wheel-Outer, Left And Right
Tongue, Frame And Wheels - Wheel And Mounting
Hydraulics - Tongue Hydraulics (8182 8186)
Hydraulics - Wheel Lift Hydraulics-Left (8182), (Two Carrier Wheels)
Hydraulics - Wheel Lift Hydraulics-Right (8182), (Two Carrier Wheels)
Hydraulics - Wheel Lift Hydraulics-Left (8182), (Four Carrier Wheels)
Hydraulics - Wheel Lift Hydraulics-Right (8182), (Four Carrier Wheels)
Hydraulics - Wheel Lift Hydraulics-Left (8186), (Four Carrier Wheels)
Hydraulics - Wheel Lift Hydraulics-Right (8186), (Four Carrier Wheels)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (853916 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (853920 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (853921 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (853923 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Control Valve Assembly (Delta), (700727484 Control Valve Assembly)
Hydraulics - Wheel Rotation Hydraulics (8182), (Two Carrier Wheels)
Hydraulics - Wheel Rotation Hydraulics (8182 8186), (Four Carrier Wheels)
Hydraulics - Frame Fold Hydraulics (8182 8186)
Hydraulics - Hydraulic Cylinder Assembly, (853922 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly, (853924 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly, (700725688 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Blower Mounting
Hydraulics - Blower, (Prior To S.N. Hu)
Hydraulics - Blower, (S.N. Hu And Later)
Hydraulics - Hydraulic Blower Motor Assembly, (700728460 Hydraulic Blower Motor Asm.), (Prior To S.N. Hu)
Hydraulics - Blower Flow Control Valve Assembly, (W247849b Blower Flow Control Valve Asm), (Earlier)
Hydraulics - Hydraulic Flow Control Valve (Blower), (N856657 Hydraulic Valve Assembly), (Later)
Hydraulics - Filter Assembly (Ground Drive), (W247850b Filter Assembly)
Hydraulics - Blower Hydraulic Hoses (8182)
Hydraulics - Blower Hydraulic Hoses (8186)
Hydraulics - Marker Hydraulics-Left (8182)
Hydraulics - Marker Hydraulics-Right (8182)
Hydraulics - Marker Hydraulics-Left (8186), (With Extension)
Hydraulics - Marker Hydraulics-Right (8186), (With Extension)
Hydraulics - Marker Extension Hydraulics (8186)
Hydraulics - Marker Extension Cylinder Mount (8186), (Right Shown-Left Opposite)
Hydraulics - Hydraulic Cylinder Assembly, (700724410 Hydraulic Cylinder Assembly)
Hydraulics - Marker Hydraulics-Left (8182), (Flat Fold Marker Without Gauge Wheels)
Hydraulics - Marker Hydraulics-Right (8182), (Flat Fold Marker Without Gauge Wheels)
Hydraulics - Marker Hydraulics-Left (8186), (Flat Fold Marker With Gauge Wheels)
Hydraulics - Marker Hydraulics-Right (8186), (Flat Fold Marker With Gauge Wheels)
Hydraulics - Hydraulic Sequence Valve Assembly, (N851998 Sequence Valve Assembly)
Hydraulics - Hydraulic Cylinder Assembly, (700724408 Hydraulic Cylinder Assembly)
Hydraulics - Marker Hydraulic Cylinder Asm. (8186), (Sn12855 Hydraulic Cylinder Assembly)
Hydraulics - Marker Hydraulic Cylinder Asm. (8182), (855104 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Direct Drive (Ground Drive)
Hydraulics - Pto Pump And Mount-Ground Drive(540 Rpm)
Hydraulics - Pto Pump Assembly (540 Rpm), (W247844b Pto Pump Assembly)
Hydraulics - Pto Pump & Mount-Ground Drive (1000 Rpm), (1-3 8 Inch Shaft)
Hydraulics - Pto Pump Assembly (1000 Rpm,1-3 8 Shaft), (W247845b Pto Pump Assembly)
Hydraulics - Pto Pump & Mount-Ground Drive (1000 Rpm), (1-3 4 Inch Shaft)
Hydraulics - Pto Pump Assembly (1000 Rpm,1-3 4 Shaft), (855009 Pto Pump Assembly)
Decal And Kits - Tongue Decals
Decal And Kits - Marker And Mainframe Decals
Decal And Kits - Mainframe And Row Unit Decals
Decal And Kits - Hopper Decals
Decal And Kits - Slow Moving Vehicle Emblem
Decal And Kits - Seed Rate Chart Decal And Mounting
Decal And Kits - Drive Wheel Kit, (6001164 Drive Wheel Kit), (Left Side Shown, Right Side Opposite)
Decal And Kits - Drive Wheel Kit, (Continued), (700724408 Hydraulic Cylinder Assembly)
Decal And Kits - Seed Disc Identification Chart
Decal And Kits - Seed Meter Funnel Kit, (6000628 Seed Meter Funnel Kit)
Decal And Kits - Monitor Bridge Kit, (6000816 Monitor Bridge Kit)
Decal And Kits - Transport Wheel Kit, (6000784 Transport Wheel Kit-Set Of Two), (Left Shown, Right Same)
Decal And Kits - Transport Wheel Kit, (Continued-Wheel, Hub And Axle), (Left Shown, Right Same)
Decal And Kits - Transport Wheel Kit, (Continued-Left Shown, Right Opposite), (Wheel Lift Hydraulics)
Decal And Kits - Transport Wheel Kit, (Continued-Set Of Two), (853920 Hydraulic Cylinder Assembly)
Decal And Kits - Transport Wheel Kit, (Continued-Left Shown, Right Opposite), (Wheel Rotation Hydraulics)
Decal And Kits - Transport Wheel Kit, (Continued-Set Of Two), (853923 Hydraulic Cylinder Assembly)
Decal And Kits - Opener Disc Flat Scraper Kit, (6001239 Opener Disc Flat Scraper Kit), (One Row Shown, Four Rows Per Kit)
Decal And Kits - Opener Disc Rotary Scraper Kit, (6001375 Opener Disc Rotary Scraper Kit), (One Row Shown, Four Rows Per Kit)
Recommended Dealer Stock - Recommended Dealer Stock
