BigBoss1
106
307,104
Challenger Edge Multapplier Terragator NL L4500G4 C System (2019-2024) Part Book
Brand: Challenger
Type of Machine: Terragator
Type of Manual: Parts Book
Model: Challenger NL L4500G4 Edge Multapplier Terragator C System
Serial Number: ..KXXX1001-..RXXX9999
Year of Manufacture: 2019-2024
Number of Pages: 456 Pages
Filters Guide & Belts Guide - Nl4500g4 Edge
Nl4500g4 Edge, 409ss, 14 Foot - Multapplier Ready
Nl4500g4 Edge, 409ss, 14 Foot - Full Flare
Nl4500g4 Edge, Multapplier, 14_5 Foot
Multapplier, 5 Foot - L4500g4 Edge
Nl4500g4 Edge, Multapplier, 14_7 Foot
Multapplier, 7 Foot - L4500g4 Edge
Nl4500g4 Multibin, 409ss, 14 Foot - Edge
Dual Micro Multibin - L4500g4 Edge
Nl4500hp, 409ss, 14 Foot, #3 Belt Over Chain - Multapplier Ready
Nl4500hp, 409ss, 15 Foot, #3 Belt Over Chain - Multapplier Ready
Nl4500hp, 409ss, 15 Foot, #4 Belt Over Chain - Multapplier Ready
Bed Sheet, New Leader
Conveyor And Shield Assembly, 409ss, 14 Foot, #3
Conveyor And Shield Assembly, 409ss, 14 Foot, #4
Conveyor And Shield Assembly, 409ss, 15 Foot, #3
Conveyor And Shield Assembly, 409ss, 15 Foot, #4
Deflector
Fender Group _ Angle Group - 14-16 Foot 132 Inch, 304ss
Fender Group _ Angle Group - 14-16 Foot 132 Inch, Full Flare
Drive Idler
Idler Shaft Assembly, 30 Inch Conveyor
Direct Drive Group, 24 Inch - Multibin
Drive Shaft - Multibin
Idler Group, 24 Inch - Multibin
Idler Group, 24 Inch - Assembly
Endgate Assembly, 409ss - Multapplier Ready
Endgate Assembly, 409ss - L4500g4 Edge
Endgate Hardware Kit
Feedgate - 409ss
Feedgate - Multapplier
Feedgate
Feedgate - Multibin
Foot Support
Gear Case - Double Pinion Gear Case
Gear Case - Double
Gear Case - Dual 14.1 Cid
Gear Case
Hydraulic Motor
Gear Case Breather Tube
Inverted Vee Kit, 13-14 Foot, High Yield
Inverted Vee Kit, 13 - 14 Foot, High Yield, 409ss
Inverted Vee, 15-16 Foot, 304
Inverted Vee, 15-16 Foot, High Yield, 409ss
Inverted Vee Kit - Hardware Kit, 8 - 12 Foot V, Ss
Inverted Vee Kit - Hardware Kit, 13 - 16 Foot V, Ss
Mudguard - Front
Mudguard - Rear
Window - Glass
Primary Product Distribution
Conveyor, #4 Belt Over Chain, 54 Links - Multapplier
Conveyor, #4 Belt Over Chain, 75 Links
Hillside Divider Kit, #4, 304ss - Divider
Divider - Multapplier
Divider - Multibin
Divider - Rear
Shield & Chain - Left Side
Shield & Chain - Right Side
Shield & Chain - Multapplier, 5 Foot
Shield & Chain - Multapplier, 7 Foot
Spinner Guard
Spinner Guard - High Performance
Spinner Guard - L4258g4 _ L4500g4
Spinner Assembly - L4258g4 _ L4500g4
Spinner Assembly - High Performance
Disc Assembly, Left Hand, 24 Inch
Disc Assembly, Right Hand, 24 Inch
Spinner Motor - 5.10 Cir
Spinner Motor, New Leader - 5.10 Cir
Hydraulic Assembly, Main System
Hydraulic Assembly, Main System - Pipes
Hydraulic, Main, Hp_Multapplier Ready, 14 Feet
Hydraulic, Main, Hp_Multapplier Ready, 15 Feet
Hydraulic Assembly, Main System, Multapplier Ready, 14 Foot
Hydraulic Assembly - Multibin
Hydraulic Installation, L4000g4 Hp, 9300 - Load Sense
Hydraulic Installation, L4500g4 Edge, 73xx_83xx
Hydraulic Installation, L4500g4, 93xx
Hydraulic Installation, L4500g4ma, 93xx
Hydraulic Installation, L4500g4mb, 73xx_83xx
Hydraulic Installation, L4500g4mb, 93xx
Hydraulic Installation, L4500hpg4
Hydraulic Installation, Routing Accessories - New Leader
Hydraulic Hose Installation, L4000g4hp
Hydraulic Hose Installation, L4500g4, 93xx
Hydraulic Hose, L4500g4 Edge, 73_83xx
Hydraulic Hose Installation, L4500g4hp
Hydraulic Hose Installation, L4500g4ma
Hydraulic Hose Installation, L4500g4ma, 93xx
Hydraulic Hose Installation, L4500g4mb
Hydraulic Hose Installation, L4500g4mb - 9300
Hydraulic Motor (Components)
Hydraulic Pump - L4500g4 Edge
Piston Pump, 100 Cc, Right Hand - Piston
Hydraulic Pump, L4000g4 Edge
Hydraulic Pump Installation, L4500g4ma
Hydraulic Pump Installation, L4000g4hp
Hydraulic Tank Heater
Hydraulic Tank And Cooler
Hydraulic Tank (Components) - New Leader G4 Edge
Hydraulic Tank And Cooler - High Performance
Radiator - High Performance
Hydraulic Tank (Components) - High Performance
Radiator - Hydac Eld4.5
Valve Block
Spreader Control Valve - Pwm Control Valve Assembly
Hydraulic Valve (Components) - 30 Gpm
Hydraulic Valve (Components) - 40 Gpm
Spreader Control Valve - 40_20 Gpm
Hydraulic Valve (Components) - 40_20 Gpm
Cap Installation, Hydraulic, Multapplier - Loose System Only
Cap Installation, Hydraulic, Standard - Loose System Only
Cartridge, 40gpm Servo
Cartridge, T, 9gpm Servo
Chain Oiler
Chain Oiler Nozzle - Left Side
Chain Oiler Nozzle - Right Side
Chain Oiler - Tank
Chain Oiler - Pump_Assembly With Connector
Cover Cylinder
Lid Control Valve
Return Filter
Suction Fittings, 20jic
Suction Fittings, 32jic
Valve Installation - High Performance
Valve Assembly
Valve Assembly, Sfp 5gpm
Hydraulic Servo, 9gpm - Pwm Control Valve Assembly
Valve Assembly, Sfp 9gpm
Valve Assembly, Sfp 9gpm - With Relief
Lighting - Rotary Beacon
Electrical Installation - New Leader
Electrical Installation, Roll Tarp - 15 Foot
Roll Tarp - Electric
No Roll Tarp, New Leader
Reversing Camera - New Leader
Taillight Installation, Euro
Taillight Installation, Euro - Fender
Work Lights
Work Lights - #3
Work Lights - #3
Controller System
Control - 15-16 Foot
Enclosure - Mount Assembly
Enclosure - Module
Enclosure - Module
Encoder, Dickey-John 360, With 12 Inch Cable
Encoder And Bracket, Dickey-John 360 - Multapplier_Multibin
Master Module - 13 Foot - 14 Foot
Bin Level Sensor
Sensor Group - Dual Spinner Speed
Sensor Group - Hydraulic Tank
Sensor Kit, 18 Inch Lead - Multibin
Sensor Kit, 102 Inch Lead - Multibin
Slave Module Group - 13 Foot - 14 Foot
Slave Module Group - 15-16 Foot
Slave Module Group - Multibin
Air System
Air Plumbing Installation - Multibin
Decal Installation - L4500
Decals - High Performance
Decal Group, Multibin - Multibin
Decals - Nl4500g4 Edge, 409ss, 14 Foot, #4 Belt Over Chain, Full Flare
Safety & Warning
Cover - Multapplier
Cover - Multibin
Dual Bin Panel
Dual Bottom Micro - 360 Encoder
Dual Bottom Micro
Dual Bottom Micro - Metering Wheel Shaft Assembly
Front Seal - Multibin
Grease Bank - Main
Hardware Kit - Multibin
Lube Bank - Endgate
Lube Bank - Multapplier, 5 Foot
Lube Bank - Multapplier, 7 Foot
Pivot Mount Hardware Kit, Sst
Side Board - 7 Foot
Side Board - 9 Foot
System Holddowns - Dry System
Roll Tarp - 14 Feet
Roll Tarp Kit, Electric, 14 Foot Box
Tarp Installation, 15 Foot, New Leader - Electric
Roll Tarp Kit, Electric, 15 Foot Box
Tarp Installation, New Leader - Multibin
Roll Tarp - Multibin
Multapplier Wiper
Wiper Belt - Multibin
Field Accessories, End Gate - 304ss
Field Accessories, End Gate - 409ss
Field Accessories - Multapplier, 5 Foot
Field Accessories - Multapplier, 7 Foot
Field Accessories - Pump And Hose Kit, Multapplier, 73_83_8400
Pattern Test Kit - New Leader
Field Accessories - Chain Guide
Sideboard, 14 Foot Nl, With 5 Foot Multappler, F_A
Sideboard, 14 Foot Nl, With 7 Foot Multappler, F_A
Sideboard Kit, Multapplier, 14 Foot
Test Kit, Size Grade Number And Hardness
Wiper Belt Conveyor Kit, Spinner
Wiper, Belt Spinner And Conveyor Assembly
