Challenger Combine 680B Parts Catalog 79024155
Brand: Challenger
Type of Machine: Combine
Model: Challenger 680B Combine
Serial Number: Combine
Part Number: 79024155
Number of Pages: 429 Pages
Publication Information
Decals, Left Side And Front
Decals, Right Side And Rear
Decals-Brand, Left Side And Front
Decals-Brand, Right Side And Rear
Decals, Cab
Engine & Mounts
Front Engine Drives, Fan, Alternator, Compressor
Air Intake & Exhaust
Pto And Pumps
Main Pump Drives
Radiator Slinger
Rotary Screen, Door & Screen
Rotary Screen, Motor & Drive
Fuel Lines
Frame & Mounting
Windows And Doors
Lh Door, Interior & Exterior Handles
Interior Coverings & Trim, Upper And Front
Interior Coverings & Trim, Lower And Rear
Platform, Left & Right
Pivoting Ladder Lh
Deck Extension, 145 Tread And Duals
Mirrors & Extremity Lights, Remote Electric Adjust
Windshield Wiper
Roof & Interior Exterior Lights
Control, Service Brakes
Brake Master Cylinder
Control, Park Brake & Hydro Propel Cable
Control, Gearshift
Control, Steering Column
Steering Column, Components
Seat, Operator & Instructor
Seat, Base & Suspension
Seat, Cushion And Backrest
Hvac, Pressurizer Unit & Ducting
Hvac, Control Panel, (W O Automatic Temp Control)
Hvac Control Panel, (W Automatic Temp Control)
Hvac, Pressurizer Unit, Evans-Tempcon, (W O Automatic Temp Control)
Hvac, Blower Asy., Evans Tempcon, (W O Automatic Temp Control)
Hvac Pressurizer Unit, Evans-Tempcon, (W Automatic Temp Control)
Air Conditioner, Lines
Heater Lines
Feeder Electrical
Harnesses & Monitoring, Front
Harnesses & Monitoring, Rear
Engine Wiring
Batteries & Cables
Cab Components, Controls & Switches
Cab Components, Fuse Panel & Hydro Handle
Cab Components, Upper Console
Cab Components, Radio And Antenna
Harnesses & Lighting, Grain Bin
Taillight Harness
Beacon Lights, Field Kit
High Intensity Lighting, Field Kit
Housing & Shields
Jack
Floor, Middle
Pivot Shaft
Lh Pivot Drive
Jackshaft Drive, R.H. Feederhouse
Jackshaft & V.S. Idler, V.S. Header Drive
Hydraulic Lines, V.S. Header Drive
Jackshaft & C'shaft Drive Idler, Fixed Speed Header Drive
Countershaft, Variable & Fixed Speed Header Drive
Latch, Header
Conveyor
Feeder Reverser, Drive & Hydraulics
Reverser Motor, Clutch Housing & Shaft Assembly
Reverser Motor, Torque Motor Asy.
Housing
Hydraulic Cylinder
Anchors & Sensor
Hydraulics
Valve & Control
Front Beater
Front Beater, Drive Belt And Idler
Main Countershaft
Main Countershaft, Drive And Idler
Inlet Housing And Stone Trap
Cage & Concave Adjusters
Concaves
Concave Blanks
Separator Grates
Cover Panels & Deflectors
Rotor Discharge Housing
Rotor
Rotor Drive, Gearbox Shift Linkage
Rotor Drive, 3-Speed Gearbox
Jackshaft Drive
Chopper, Secondary Drive
Chopper Hood & Supports
Chopper Housing, Redekop
Straw Chopper, Rotor
Spreader Secondary Drive
Straw Spreader, Drive Group & Housing
Straw Spreader, Paddle & Guards Group
Straw Spreader, Drive Shields (Early Prod'n)
Chaff Spreader, Hydraulic Drive
Chaff Spreader, Fan Housing, Rekord, 71411972
Chaff Spreader, Hydraulics, Rekord, 71411972
Lower Fan & Auger Housing
Cleaning Fan & Leaf Screen
Variable Speed Fan Drive
Separator Pan
Pitman Shaft
Shoe Shaker
Cleaning Shoe, Upper Frame & Sieves
Cleaning Shoe, Lower Pan
Electric Adjustable Sieves
Pitman Drive
Grain Elevator Drive
Grain Elevator, Lower
Grain Elevator, Head Assembly
Grain Elevator, Bin Fill Auger
Grain Elevator, Head Mounting & Supports
Return Elevator, Lower
Return Elevator, Upper
Return Elevator Drive
Unloading Auger, Lower Cross Auger
Unloading Auger, Upper, Inside
Unloading Auger, Upper, External
Unloading Auger Assembly, Outboard
Unloader, Spout & Spill Saver, (Early Production)
Unloader, Spill Reducer, (Later '07 Producton)
Covers, Lower Cross Unloading Auger
Unloader Drive And Clutch
Grain Bin, Lower Structure
Grain Bin, Upper Components
Fuel Tanks
Bin Extensions
Engine Cover
Engine Deck
Rear Handrails
Rear Ladders
Side Shields, Left Side
Shield Group, Left Front
Shield Group, Left Rear
Side Shields, Right Side
Shield Group, Right Front
Shield Group, Right Middle
Shield Group, Right Rear
Mud Shields, Left Side
Mud Shields, Right Side
Cylinders, Header Lift
Reservoir, Mounting And Plumbing
Reservoir
Priority Valve
Hydro Suction Plumbing
Hydro Plumbing, Engine Left
Propel Motor Plumbing
Rotor Motor Plumbing
System Pump
Steering Control Plumbing, Upper
Steering Unit Plumbing
Steering Plumbing, Rear Cylinders
Steering Cylinder Trailing Axle, (71408752 Cylinder Assembly-Steering)
Steering Cylinder, Rwa Axle
Accumulator, Parker
Unloader Swing And Clutch
Control Valve Supply, Right Side
Control Valve And Accumulator, Right Side
Hydraulic Control Valve, (71406988 Valve Assembly)
Rotary Screen Motor Plumbing
Oil Cooler Plumbing, Right Side
Header Supply Plumbing
Reel Fore Aft, Export
Feeder Lift Cyl. Plumbing
Drum Brake, Lines And Fittings
Grease Lines, Front Feeder
Grease Lines, Left Side
Grease Lines, Left Rear
Grease Lines, Right Side
Rotor Pumps, Tandem Pump
Rotor Pump, Front, 1 Of 4
Rotor Pump, Front, 2 Of 4
Rotor Pump, Front, 3 Of 4
Rotor Pump, Front, 4 Of 4
Main Side Frames
Front Axle And Final Drives
Final Drive, S41
4 Axle Risers, Final Drive
Transmission, Gear, Pressure Lube & Hydro Motor
Transmission, Gear, Input Shaft & Gears
Transmission, Gear, Intermediate & Main Shaft
Transmission, Gear, Differential
Drum Brakes, Service & Parking
Motor, Hydro Propel, Components
Rear Axle, Support And Center Beam
Rear Trailing Axle, Adjustable Tread
Spindle Housing Assembly
Axle And Wheels, Rear Wheel Assist
Axle Assembly, Rear Wheel Assist
Wheel Motor Unit, Rear Wheel Assist
Rwa Plumbing
Selector And Flow Divider Valve, Rear Wheel Assist
Wheels, Front Drive
Belts, Left
Belts, Right
Chains, Drive
Yield Monitor System W 1 Hz Waas Dgps
Software Data Card
Recommended Dealer Stock
Brand: Challenger
Decals, Cab
Engine & Mounts
Pto And Pumps
Main Pump Drives
Radiator Slinger
Fuel Lines
Frame & Mounting
Windows And Doors
Pivoting Ladder Lh
Windshield Wiper
Control, Gearshift
Heater Lines
Feeder Electrical
Engine Wiring
Batteries & Cables
Taillight Harness
Housing & Shields
Jack
Floor, Middle
Pivot Shaft
Lh Pivot Drive
Latch, Header
Conveyor
Housing
Hydraulic Cylinder
Anchors & Sensor
Hydraulics
Valve & Control
Front Beater
Main Countershaft
Concaves
Concave Blanks
Separator Grates
Rotor
Jackshaft Drive
Separator Pan
Pitman Shaft
Shoe Shaker
Pitman Drive
Fuel Tanks
Bin Extensions
Engine Cover
Engine Deck
Rear Handrails
Rear Ladders
Reservoir
Priority Valve
System Pump
Accumulator, Parker
Main Side Frames
Final Drive, S41
Rwa Plumbing
Wheels, Front Drive
Belts, Left
Belts, Right
Chains, Drive
Software Data Card
