Challenger Combine 670 Parts Catalog 79021532
Brand: Challenger
Type of Machine: Combine
Model: Challenger 670 Combine
Part Number: 79021532
Number of Pages: 538 Pages
Publication Information
Left Side & Front Labels
Right Side & Rear Labels
Engine & Mounts
Cooling Fan Drive, (Tier 2 Eng. Prior S N Hp36176)
Cooling Fan Drive, (Tier 3 Engine), (Eff. S N Hp36176 Thru Prod'n Mid-Run)
Cooling Fan Drive, (Tier 3 Engine), (Eff. S N Hp36--- Prod'n Mid-Run)
Air Intake & Exhaust
Main Engine Drives
Radiator Slinger
Rotary Screen, Door & Screen
Rotary Screen, Motor & Drive
Fuel Lines, (Prior S N Hp36101)
Fuel Lines, (Eff. S N Hp36101)
Frame & Mounting
Windows And Doors
Lh Door, Interior & Exterior Handles
Interior Coverings & Trim, Upper And Front
Interior Coverings & Trim, Lower And Rear
Platform, Left & Right
Pivoting Ladder Lh
Platform And Powerfold Ladder, Left Hand
Deck Extension, 145 Tread And Duals
Staircase Ladder & Platform
Mirrors & Extremity Lights, Manual & Electric Adjust
Windshield Wiper
Roof & Interior Exterior Lights
Control, Service Brakes
Brake Master Cylinder
Control, Park Brake & Hydro Propel Cable
Control, Gearshift
Control, Steering Column
Steering Column
Seat, Operator & Instructor
Seat, Base & Suspension
Seat, Cushion And Backrest
Hvac, Pressurizer Unit & Ducting
Hvac, Control Panel, With Manual Temp Control
Hvac Control Panel, With Auto Temp Control
Hvac Pressurizer Unit, Evans-Tempcon, With Manual Temp Control
Hvac Blower Asy., Evans Tempcon, With Manual Temp Control
Hvac Pressurizer Unit, Evans-Tempcon, With Auto Temp Control
Air Conditioner, Lines
Air Conditioner, Compressor (Sanden)
Heater Lines
Feeder Electrical, (Prior S N Hs36101)
Feeder Electrical, (Eff. S N Hs36101)
Electrical Harnesses & Switches, Front
Engine & Battery Wiring, (Prior S N Hr36101)
Engine & Battery Wiring, (Eff. S N Hr36101)
150 Amp
Cab Components, Controls & Switches
Cab Components, Fuse Panel & Hydro Handle
Cab Components, Upper Console
Cab Components, Radio And Antenna
Monitoring Systems, Digital Tachometer
Harnesses & Lighting, Grain Bin
Electrical Harnesses, Rear
Beacon Lights, Field Kit
High Intensity Lighting, Field Kit
Service Connectors, Harness Repair
Housing & Shields, (Prior S N Hp36101)
Housing & Shields, (Eff. S N Hp36101)
Jack
Feed Floor, (Prior S N Hs36101)
Floor, Middle, (Eff. S N Hs36101)
Pivot Shaft, (Prior S N Hp36101)
Pivot Shaft, (Eff. S N Hp36101)
Lh Pivot Drive, (Eff. S N Hp36101)
Rh Drive, (Prior S N Hp36101)
Jackshaft Drive, R.H. Feederhouse, (Eff. S N Hp36101)
Jackshaft & V.S. Idler, V.S. Header Drive, (Eff. S N Hp36101)
Hydraulic Lines, V.S. Header Drive, (S N Hp36101-Hr36999)
Hydraulic Lines, V.S. Header Drive, (Eff. S N Hs36101)
Jackshaft & C'shaft Drive Idler, Fixed Speed Header Drive, (Eff. S N Hp36101)
Countershaft, Header Drive, (Prior S N Hp36101)
Countershaft, Variable & Fixed Speed Header Drive, (Eff. S N Hp36101)
Latch, Header
Conveyor, (Prior S N Hp36101)
Conveyor, (Eff. S N Hp36101)
Feeder Reverser, Lines & Fittings, (Prior S N Hp36101)
Feeder Reverser, Drive & Hydraulics, (Eff. S N Hp36101)
Reverser Motor & Clutch, Components, (Prior S N Hp36101)
Reverser Motor, Clutch Housing & Shaft Assembly, (Eff. S N Hp36101)
Reverser Motor, Torque Motor Asy., (Eff. S N Hp36101)
Housing
Anchors & Sensor
Hydraulic Cylinder, (Eff. S N Hn36101)
Hydraulics
Valve & Control, (Prior S N Ht36101)
Valve & Control, (Eff. S N Ht36101)
Front Beater
Main Countershaft
Main Countershaft, Drive And Idler
Front Beater, Drive Belt & Idler
Inlet Housing & Stone Trap (N. America)
Concave & Controls
Power Concave Control
Rear Rotor Housing
Separator Grates
Separator Grate Supports, Rice, N. America
Rotor
Rotor Drive, Gearbox Shift Linkage
Rotor Drive, 2-Speed Gearbox
Motor, Hydrostatic Rotor
Jackshaft Drive
Straw Chopper Drive
Straw Chopper Drive Kit, Heavy Duty
Straw Chopper Housing, Redekop
Straw Chopper, Rotor
Straw Chopper Hood & Supports
Straw Spreader, Drive
Straw Spreader, Components
Chaff Spreader, Hydraulic Drive, (Prior S N Hs36101)
Chaff Spreader, Hydraulic Drive, (Eff. S N Hs36101)
Chaff Spreader, Fan Housing, Rekord, (Prior S N Hs36101)
Chaff Spreader, Fan Housing, Rekord, (Eff. S N Hs36101)
Chaff Spreader, Hydraulics, Rekord
Lower Auger Housing And Fanning Mill
Variable Speed Fan Drive
Separator Pan, (Prior S N Hs36144)
Separator Pan, (Eff. S N Hs36144)
Pitman Drive, (Prior S N Hs36101)
Pitman Drive, (Eff. S N Hs36101)
Pitman Shaft, (Eff. S N Hs36144)
Shoe Shaker Update Kit, (Prior S N Hs36144)
Shaker Shoe And Sieves, (Prior S N Hs36144)
Shoe Shaker, (Eff. S N Hs36144)
Cleaning Shoe, Upper Frame & Sieves, (Eff. S N Hs36144)
Cleaning Shoe, Lower Pan, (Eff. S N Hs36144)
Grain Elevator Drive, (Prior S N Hp36101)
Grain Elevator Drive, (Eff. S N Hp36101)
Grain Elevator, Lower
Grain Elevator, Head Assembly
Grain Elevator, Bin Fill Auger
Return Elevator, Lower, (Prior S N Hp36101)
Return Elevator, Lower, (Eff. S N Hp36101)
Return Elevator, Upper
Stainless Steel Elevator Package, Rice
Return Elevator Drive
Unloading Auger, Lower
Unloading Auger, Vertical, (Prior S N Hn36101)
Unloading Auger, Vertical, (Effective S N Hn36101)
Unloading Auger, Upper
Unloader Drive
Grain Bin, Lower Structure
Grain Bin, Upper Structure & Mounts
Bin Extensions
Fuel Tanks
Engine Covers
Rear Deck And Ladder
Side Shields, Left Front And Middle
Side Shields, Left Side
Side Shields, Right Front And Middle
Side Shields, Right Side
Mud Shields, Right Side, (Prior S N Hs36101)
Mud Shields, Right Side, (Eff. S N Hs36101)
Mud Shields, Left Side, (Prior S N Hp36101)
Mud Shields, Left Side, (Eff. S N Hp36101)
Hydraulic Pump & Lines, (Prior S N Hs36101)
Hydraulic Pump & Lines, (Eff. S N Hs36101)
Pump, System
Steering & Header Functions, (Prior S N Hs36101)
Control Valve & Lines, (Eff. S N Hs36101)
Valve Asy, Hydraulic, (Eff. S N Hs36101)
Valve Asy, Main Control, (Eff. S N Hs36101)
Steering & Header Functions, (Eff. S N Hs36101)
Header Supply Plumbing, (Eff. S N Hs36101)
Single Point Attachment Kit, Permanent, (Prior S N Hs36101)
Single Point Attachment Kit, Temporary, (Prior S N Hs36101)
Reel Fore Aft, Export, (Eff. S N Hs36101)
Steering Unit Plumbing, (Eff. S N Hs36101)
Steering Cylinder, Std. Adjustable Axle, (Prior S N Hp36101)
Steering Cylinder, Std. Adjustable Axle, (Eff. S N Hp36101)
Steering Cylinder, Rwa Axle
Accumulator, Parker
Header Lift Cylinders
Unloader Swing Cylinder
Priority Valve
Valve Stack, Main Control, (Prior S N Hs36101)
Header Lift Valve
Reel Lift Valve
Feeder Reverser Valve
Unloader Swing Valve
Reel Drive Valve, (Prior S N Hs36101)
Rotary Screen Valve & Motor
Rotary Screen Motor Lines, (Prior S N Hs36101)
Unloader Engage Lines, (Prior S N Hp36101)
Unloader Engage Lines, (Eff. S N Hp36101)
Unloader Engage Valve
Reservoir & Filter
Rotor Pump And Motor Lines
Propel Pump And Motor Lines
Grease Lines
Grease Lines, Lube Kit, Swivel Unloader
Propel Pump, Components, 1 Of 4
Propel Pump, Components, 2 Of 4
Propel Pump, Components, 3 Of 4
Propel Pump, Components, 4 Of 4
Motor, Hydro Propel, Components
Rotor Pumps, Tandem Pump
Rotor Pump, Front, 1 Of 4
Rotor Pump, Front, 2 Of 4
Rotor Pump, Front, 3 Of 4
Rotor Pump, Front, 4 Of 4
Rotor Pump, Rear, 1 Of 4
Rotor Pump, Rear, 2 Of 4
Rotor Pump, Rear, 3 Of 4
Rotor Pump, Rear, 4 Of 4
Final Drive, S39, (Prior S N Hs36101)
Front Axle And Final Drives, (Eff. S N Hs36101)
Final Drive, S40 & S41, (Eff. S N Hs36101)
4 Axle Risers, Final Drive, S39, (Prior S N Hs36101)
4 Axle Risers, Final Drive, S40 & S41, (Eff. S N Hs36101)
Transmission, Gear, Pressure Lube & Hydro Motor
Transmission, Gear, Input Shaft & Gears
Transmission, Gear, Intermediate & Main Shaft
Transmission, Gear, Differential
Drum Brakes, Service & Parking
Drum Brakes, Lines & Fittings
Main Frame And Axle Supports
Rear Axle & Wheels, Adjustable Tread, (Prior S N Hp36101)
Rear Axle & Wheels, Adjustable Tread, (Eff. S N Hp36101)
Rear Axle & Wheels, Rear Wheel Assist
Rear Wheel Assist, Wheel Motor Unit
Rear Wheel Assist, Selector Valve & Flow Divider
Wheels, Drive
Belts, Left
Belts, Right
Chains, Drive
Yield Monitor System W 1 Hz Waas Dgps
Software Data Card
Recommended Dealer Stock
Brand: Challenger
Engine & Mounts
Main Engine Drives
Radiator Slinger
Frame & Mounting
Windows And Doors
Pivoting Ladder Lh
Windshield Wiper
Control, Gearshift
Steering Column
Heater Lines
150 Amp
Jack
Latch, Header
Housing
Anchors & Sensor
Hydraulics
Front Beater
Main Countershaft
Concave & Controls
Rear Rotor Housing
Separator Grates
Rotor
Jackshaft Drive
Straw Chopper Drive
Unloader Drive
Bin Extensions
Fuel Tanks
Engine Covers
Pump, System
Accumulator, Parker
Priority Valve
Header Lift Valve
Reel Lift Valve
Reservoir & Filter
Grease Lines
Wheels, Drive
Belts, Left
Belts, Right
Chains, Drive
Software Data Card
