Challenger Combine 660 Parts Catalog 79032856
Brand: Challenger
Type of Machine: Combine
Model: Challenger 660 Combine (East Europe)
Part Number: 79032856
Number of Pages: 436 Pages
Publication Information
Left Side & Front Labels
Right Side & Rear Labels
Engine & Mounts
Front Gear Housing
Flywheel And Housing
Camshaft And Valve Train
Intake & Exhaust Manifold
Turbocharger
Oil Sump & Pump
Oil Cooler & Filter
Centrifugal Oil Cleaner
Water Pump System
Injector Pump System
Fuel Filters
Engine Electrical
Alternator & Mounting
Starter Motor
Drive Belt System
Engine Overhaul Kits, Sisu
Air Intake And Exhaust
Main Engine Drives
Radiator Slinger
Rotary Screen, Door & Screen
Rotary Screen, Motor & Drive
Fuel Lines
Fuel Filter, Export
Frame & Mounting
Windows And Doors
Lh Door, Interior & Exterior Handles
Interior Coverings & Trim, Upper And Front
Interior Coverings & Trim, Lower And Rear
Platform, Left & Right
Pivoting Ladder Lh
Platform And Powerfold Ladder, Left Hand
Deck Extension, 145 Tread And Duals
Staircase Ladder & Platform
Mirrors & Extremity Lights, Electric Adjust
Windshield Wiper
Roof & Interior Exterior Lights
Control, Service Brakes
Brake Master Cylinder
Control, Park Brake & Hydro Propel Cable
Control, Gearshift
Control, Steering Column
Steering Column
Seat, Operator & Instructor
Seat, Base & Suspension
Seat, Cushion And Backrest
Hvac, Pressurizer Unit & Ducting
Hvac Control Panel, With Auto Temp Control
Hvac Pressurizer Unit, Evans-Tempcon, With Auto Temp Control
Air Conditioner, Lines
Air Conditioner, Compressor (Sanden)
Heater Lines
Feeder Electrical
Electrical Harnesses & Switches, Front
Engine & Battery Wiring
Cab Components, Controls & Switches
Cab Components, Fuse Panel & Hydro Handle
Cab Components, Upper Console
Cab Components, Radio And Antenna
Monitoring Systems, Digital Tachometer
Harnesses & Lighting, Grain Bin
Electrical Harnesses, Rear
Beacon Lights, Field Kit
High Intensity Lighting, Field Kit
Service Connectors, Harness Repair
Housing & Shields
Jack
Feed Floor
Pivot Shaft
Lh Pivot Drive
Jackshaft Drive, R.H. Feederhouse
Jackshaft & V.S. Idler, V.S. Header Drive
Hydraulic Lines, V.S. Header Drive
Jackshaft & C'shaft Drive Idler, Fixed Speed Header Drive
Countershaft, Variable & Fixed Speed Header Drive
Latch, Header
Conveyor
Feeder Reverser, Drive & Hydraulics
Reverser Motor, Clutch Housing & Shaft Assembly
Reverser Motor, Torque Motor Asy.
Housing
Anchors & Sensor
Hydraulic Cylinder
Hydraulics
Valve & Control
Front Beater
Main Countershaft
Main Countershaft, Drive And Idler
Front Beater, Drive Belt & Idler
Inlet Housing And Stone Trap
Concave & Controls
Power Concave Control
Rear Rotor Housing
Separator Grates
Rotor
Rotor Drive, Gearbox Shift Linkage
Rotor Drive, 2-Speed Gearbox
Jackshaft Drive
Straw Chopper Drive
Straw Chopper Housing, Redekop
Straw Chopper, Rotor
Straw Chopper Hood & Supports
Straw Spreader, Drive
Straw Spreader, Components
Chaff Spreader, Hydraulic Drive
Chaff Spreader, Fan Housing, Rekord
Chaff Spreader, Hydraulics, Rekord
Lower Auger Housing And Fanning Mill
Variable Speed Fan Drive
Separator Pan
Pitman Drive
Pitman Shaft
Shaker Shoe And Sieves
Grain Elevator Drive
Grain Elevator, Lower
Grain Elevator, Head Assembly
Grain Elevator, Bin Fill Auger
Return Elevator, Lower
Return Elevator, Upper
Return Elevator Drive
Unloading Auger, Lower
Unloading Auger, Vertical
Unloading Auger, Upper
Unloader Drive
Grain Bin, Lower Structure
Grain Bin, Upper Structure & Mounts
Bin Extensions
Fuel Tanks
Engine Covers
Rear Deck And Ladder
Side Shields, Left Side
Side Shields, Right Side
Mud Shields, Right Side
Mud Shields, Left Side
Hydraulic Pump & Lines
Pump, System
Control Valve & Lines
Valve Asy, Hydraulic
Valve Asy, Main Control
Steering & Header Functions
Header Supply Plumbing
Reel Fore Aft, Export
Steering Unit Plumbing
Steering Cylinder, Std. Adjustable Axle
Steering Cylinder, Rwa Axle
Accumulator, Parker
Header Lift Cylinders
Unloader Swing Cylinder
Priority Valve
Unloader Engage Lines
Unloader Engage Valve
Reservoir & Filter
Rotor Pump And Motor Lines
Propel Pump And Motor Lines
Grease Lines
Grease Lines, Lube Kit, Swivel Unloader
Hydrostatic Tandem Pumps
Propel Pump, Components, 1 Of 4
Propel Pump, Components, 2 Of 4
Propel Pump, Components, 3 Of 4
Propel Pump, Components, 4 Of 4
Rotor Pump, Components, 1 Of 4
Rotor Pump, Components, 2 Of 4
Rotor Pump, Components, 3 Of 4
Rotor Pump, Components, 4 Of 4
Motor, Hydro Propel & Rotor, Components
Front Axle And Final Drives
Final Drive, S41
4 Axle Risers, Final Drive, S41
Transmission, Gear, Pressure Lube & Hydro Motor
Transmission, Gear, Input Shaft & Gears
Transmission, Gear, Intermediate & Main Shaft
Transmission, Gear, Differential
Drum Brakes, Service & Parking
Drum Brakes, Lines & Fittings
Main Frame And Axle Supports
Rear Axle & Wheels, Adjustable Tread
Rear Axle & Wheels, Rear Wheel Assist
Rear Wheel Assist, Wheel Motor Unit
Rear Wheel Assist, Selector Valve & Flow Divider
Wheels, Drive
Belts, Left
Belts, Right
Chains, Drive
Yield Monitor System W 1 Hz Waas Dgps
Software Data Card
Recommended Dealer Stock
Brand: Challenger
Engine & Mounts
Front Gear Housing
Turbocharger
Oil Sump & Pump
Oil Cooler & Filter
Water Pump System
Fuel Filters
Engine Electrical
Starter Motor
Drive Belt System
Main Engine Drives
Radiator Slinger
Fuel Lines
Fuel Filter, Export
Frame & Mounting
Windows And Doors
Pivoting Ladder Lh
Windshield Wiper
Control, Gearshift
Steering Column
Heater Lines
Feeder Electrical
Housing & Shields
Jack
Feed Floor
Pivot Shaft
Lh Pivot Drive
Latch, Header
Conveyor
Housing
Anchors & Sensor
Hydraulic Cylinder
Hydraulics
Valve & Control
Front Beater
Main Countershaft
Concave & Controls
Rear Rotor Housing
Separator Grates
Rotor
Jackshaft Drive
Straw Chopper Drive
Separator Pan
Pitman Drive
Pitman Shaft
Unloader Drive
Bin Extensions
Fuel Tanks
Engine Covers
Pump, System
Accumulator, Parker
Priority Valve
Reservoir & Filter
Grease Lines
Final Drive, S41
Wheels, Drive
Belts, Left
Belts, Right
Chains, Drive
Software Data Card
