702,019
Challenger Combine 654 658 Parts Catalog 3906010
Brand: Challenger
Type of Machine: Combine
Model: Challenger 654, 658 Combine
Part Number: 3906010
Number of Pages: 609 Pages
Table
Knives And Fingers - Freeflow - 20-22'
Table Auger Right Hand - Freeflow - 20-22'
Table Auger Left Hand - Freeflow - 20-22'
Guarding And Transmissions - Freeflow - 20-22'
Table Housing And Guarding - Freeflow - 20-22'
Knives And Fingers - Powerflow - 18'-20'-22'
Table Auger Right Hand - Powerflow - 18'-20'-22'
Tabel Auger Left Hand - Powerflow - 18'-20'-22'
Guarding And Transmissions - Powerflow - 20'
Table Housing And Guarding - Powerflow - 18'-20'-22' - From 942482
Table Housing And Guarding - Powerflow - 20-22' Up To 942481
Knives And Fingers - Powerflow - 25'
Feeder Drum Right Hand - Powerflow- - 25'
Feeder Drum Left Hand - Powerflow - 25'
Guarding And Transmissions - Powerflow - 18'-20'-22'-25'
Table Housing And Guarding - Powerflow - 25' - From 942482
Table Housing And Guarding - Powerflow - 25' - Up To 942481
Powerflow Band - Rear - 18'-20'-22'
Powerflow Band - Front - 18'-20'-22'
Powerflow Band - Rear - 25'
Powerflow Band - Front - 25'
Oilseed Rape Auger - From Serial No 942482
Oilseed Rape Auger - Up To 942481
Straw Dividers - From 61365 - Up To 62017
Straw Dividers - From 62018
Straw Dividers - Up To 61364
Table Trailer
Table Trailer - With Trailor Braking - World Wide Hook Up - From Serial No 942482
Lightening Bracket
Electric Vertical Knife
Multi-Coupling
Reel
Reel - Right Hand
Reel Suspension And Hydraulic Motor
Reel - Left Hand
Reel Suspension And Hydraulic Cylinders
Table Channel
Elevator Shaft - Top And Pivot - World Wide Hook Up - From Serial No 61490
Feeder Chain And Protective Plates - World Wide Hook Up - From Serial No 61490
Hydraulic Cylinder - World Wide Hook Up - From Serial No 61490
Feeder Shaft - Lower - World Wide Hook Up - From Serial No 61490
Transmission - Autolevel - Standard - World Wide Hook Up - From Serial No 61490
Adapter - Autolevel - World Wide Hook Up - From Serial No 61490
Adapter - Standard - World Wide Hook Up - From Serial No 61490
Adapter And Cover Plate - World Wide Hook Up - From Serial No 61490
Hydraulic Reversing - World Wide Hook Up - From Serial No 61490
Elevator Shaft - Top And Pivot - Up To 61489
Table Clutch - Up To 61489
Feeder Chain And Protective Plates - Up To 61489
Hydraulic Cylinder - Up To 61489
Feeder Shaft - Lower - Up To 61489
Transmission Auto Level Combine - Up To 61489
Transmission Auto Level - Table - Up To 61489
Transmission Std. Combine - Up To 61489
Adapter And Cover Plate - Up To 61489
Hydraulic Reversing - Up To 61489
Concave, Threshing Drum And Rear Beater
Concave
Concave Adjustment
Threshing Drum
Drum Cover And Stone Trap
Rear Beater
Check Flaps
Concave, Cylinder And Grain Separator
Straw Shaker
Straw Shaker And Cranks
Second Grain Pan
Straw Walker Transmission
Straw Walker Transmission - Up To 7826 (61114)
Cleaning Unit And Main Fan
Fan Housing, Mantle And Rotary Air Intake
Fan Housing And Guarding
Main Fan Blade And Bottom Auger
Fan Housing - Doors And Batteries
Main Fan Variator
Counter Drive
Eccentric Drive
Lower Shaker Shoe And Sieves
Lower Shaker Shoe And Suspension
Upper Shaker Shoe And Sieves
Upper Shaker Shoe And Suspension
Conveyor Pan And Suspension
Chaff Spreader - Rekord
Hydraulic Pump For Chaff Spreader
Windbreak And Side Guard For Chaff Spreader
Electric Screen
Elevators
Filling Elevator
Filling And Return Elevator Transmissions
Filler Pipe
Return Elevator
Returns Thresher
Engine - Cylinder Block - 645 Dsbael Egine
Cylinder Block Equipment
Engine - Cylinder Block - 84cta-4v Engine - From R16351
Engine - Timing Gear Housing - 645 Dsbael Egine
Engine - Timing Gear Housing - 84cta-4v Engine - From R16351
Engine - Flywheel
Engine - Flywheel - Flywheel - 84cta-4v Engine - From R16351
Engine - Crankshaft, Pistons & Piston Rod - 658
Engine - Crankshaft, Pistons & Piston Rod - 654
Engine - Crankshaft, Pistons & Piston Rod - 84cta-4v Engine - From R16351
Engine - Camshaft & Rocker Arm - 645 Dsbael Egine
Engine - Camshaft & Rocker Arm - 84cta-4v Engine - From R16351
Engine - Cylinder Head
Engine - Cylinder Head - 84cta-4v Engine - From R16351
Engine - Cylinder Head Cover
Engine - Oil Sump
Engine - Oil Pump
Engine - Oil Cooler
Drive Shaft - Fan Engine
Engine - Water Pump - 645 Dsbael Egine
Engine - Water Pump - 84cta-4v Engine - From R16351
Engine - Injection Pump - 645 Dsbael Egine
Engine - Injection Pump - 84cta-4v Engine - From R16351
Centrifugal Oil Filter
Feed Pump
Engine - Fuel Pipe - 658
Engine - Fuel Pipe - 654
Engine - Injector
Engine - Intake & Exhaust Manifold - 658
Engine - Intake & Exhaust Manifold - 84cta-4v Engine - From R16351
Engine - Fuel Filter - 645 Dsbael Egine
Engine - Fuel Filter - 84cta-4v Engine - From R16351
Sedimenter
Engine - Turbo Compressor - 645 Dsbael Egine
Engine - Turbo Compressor - 84cta-4v Engine - From R16351
Belt Tensioner - 645 Dsbael Egine
Belt Tensioner - 84cta-4v Engine - From R19124 - Up To T11850
Belt Tensioner - 84cta-4v Engine - From T11851
Alternator - 645 Dsbael Egine
Alternator - 84cta-4v Engine - From R16351
Starter - 645 Dsbael Egine
Starter - 84cta-4v Engine - From R16351
Stop Magnet
Engine - Thermostat
Electronic Engine Management - 84cta-4v Engine - From R16351
Joints And Gaskets - 645 Dsbael Egine
Joints And Gaskets - 84cta-4v Engine - From R16351
Engine - Repair Kit - 645 Dsbael Egine
Engine - Repair Kit - 84cta-4v Engine - From R16351
Grain Tank - Guards
Unloading Auger -Swivel Part
Discharge Auger Pipe
Unloading Auger - Transmission
Guards - Grain Tank Top
Guards - Grain Tank Bottom
Grain Tank Covers
Drive Unit
Hydraulic Cooler
Cooling System And Ventilator Screen
Rotary Screen
Engine Bracket
Prop. Pump And Hydr. Pump
Power Take-Off
Fan Housing
Engine Bonnet
Exhaust & Air Filter
Fuel Tank - 750 L
Transmissions
Countershaft
Cylinder Transmission
Belt Mounting, Left Side
Belt Mounting, Right Side
Final Drives - Std. Combine
Final Drives - Auto Level
Front Axle And Gearbox - Standard Combine
Front Axle And Gearbox - Auto Level
Rear Axle
181_4 Wheel Drive
Working Brake
Pressure Lube And Parking Brake - Gearbox D46140058
Intermediate Shaft & First Motion Shaft - Gearbox D46140058
Imput Shaft And Pinions - Gearbox D46140058
Differential - Gearbox D46140058
Final Drive
Traction Wheel And Rear Wheel - Standard
Traction Wheel And Rear Wheel - Auto Level And 4wd
Operator Platform
Back Plate, Platform And Bottom Mat
Cab Roof And Side Members
Brake Pedals And Gearshift
Electrical Multifunction Lever
Instrument Panel & Control Box
Operator Seat
Glass
Frontpanel, Side Members And Datavision
Cab Roof And Air-Conditioning
Air Conditioner
Platform And Ladder
Steering Wheel And Column
Hydraulic
Hydraulic Symbols
Hydraulics - Reel Up Down
Hydraulic - Reel Fore Aft.
Hydraulics - Cylindervariator
Auto Level Combine - Table
Hydraulics - Reel Speed
Propulsion Hydraulic
Hydraulics - Gearshift
Hydraulics - Pump And Main Valve
Hydraulics - Table Up Down
Hydraulics - Steering Gear
Hydraulics - Unloading Auger Out In
Hydraulics - Chaff Spreader - Rekord
Auto Level Combine
Pipe Support
Machine Housing - Guards
Bottom Rh Guard And Ladder
Bottom Lh Guard
Straw Hood Top
Side Member & Straw Guide
Straw Hood Bottom - From 58450
Tools & Electrical System
Tools - Paint
Electric Box Standard And Auto Level Combine
Electrical Parts
Electrical Components For Electric Box
Electrical Wiring - Computer Harness
Electrical Wiring - Cab Harness
Electrical Wiring - Cab Harness - Multi-Fonction Lever
Electrical Wiring - Lighting
Electrical Wiring - Engine Harness - Engine Stage Iii
Electrical Wiring - Machine Harness
Electrical Wiring - Fuse Box Harness
Wiring Harness Fuse Box - From Serial No 62018
Electrical Wiring - Cutting Table Harness
Wiring Harness - Cutting Table - From Serial No 943265
Electrical Wiring - Equipment Harness
Electrical Wiring - Equipment Harness - Yield Meter
Mobil Gps Receiver Antenna
Mobil Landstar Dgps
Mobil Rds Dgps
Straw Chopper
Straw Chopper - Rekord - Rekord M401 - M801
Straw Chopper - Rekord - Rekord M400 - M800
Straw Chopper - Rekord - Rekord M97
Deflector Plate - Rekord M401 - M801
Straw Deflector And El.Adjustment - Rekord M97 M400 - M800 M401 - M801
Counter Drive - Straw Chopper - Rekord M401 - M801
Counter Drive - Straw Chopper - Rekord M97 M400 - M800
Straw Chopper Maize Equipment - Rekord M97 M400 - M800 M401 - M801
Straw Chopper Clutch - Rekord - Rekord M401 - M801
Decal, Front And Right Side
Decal, Rear And Left Side
Security Decal
Dealer Stocking List
Dealer Stocking List - Quantity By Combine
