Challenger Combine 652 Parts Catalog 3906044
Brand: Challenger
Type of Machine: Combine
Model: Challenger 652 Combine
Serial Number: 563010001-999, 563410001-999 AL
Part Number: 3906044
Number of Pages: 1241 Pages
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Intake & Exhaust Manifold
Turbocharger
Oil Pump And Sump
Oil Cooler And Filter
Centrifugal Oil Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management
Fan Drive
Starter Motor
Engine Gasket Kits
Engine Overhaul Parts
Engine Installation
Engine Brackets
Cooling System - Cooler Hoses
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Fuel Tank Bracket
Fuel Lines
Air Compressor
Drive System
Hydrostatic Pump & Power Take-Off - Drive
Rotary Filter & Dust Aspirator - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Air Conditioning - Drive
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Cylinder Variator
Cylinder Variator - (Components)
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Front Axle
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive - (Components)
Rear Axle - 4 Wheels Drive - Weight
Tow Hook
Steering Column
Steering - Hydraulic Lines
Final Drive (Components)
Gearbox (Components)
Gear Lever System
Brake Pedals
Brake Master Cylinder & Brake Control Valve - (Components)
Brake Caliper - (Components)
Parking Brake - Pedal
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydrostatic Pump - (Components)
Hydraulic Propel - Hydrostatic Motor
Hydrostatic Motor - (Components)
Cutting Header - Lifting
Cutting Header
Cutting Header - Tilt
Cutting Table Flotation
Reel Speed Control
Rear Axle - 4 Wheels Drive - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Control Valve (Header + Grain Tank Unloading)
Control Valve (Header + Grain Tank Unloading) - (Components)
Grain Bin Unloading
Pipes Reel
Electrohydraulic Engagement Control Valve
Hydraulic Levelling - Pump
Hydraulic Levelling - Hydraulic Lines
Hydraulic Levelling - Distributor
Hydraulic Levelling - Distributor (Components)
Hydraulic Levelling - Front Lift
Header Additional Lifting Ram
Pipe Union
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Additional Work Lights
Flip-Up Header Light
Battery & Cables
Battery & Cables - Main Switch
Electronic Box - (Components)
Power Distributor Center Electrical
Harness - Front Axle
Harness - Cab
Harness - Digital Instrumentation
Harness - Engine
Harness - Hydraulic Oil Tank & Hydrostatic Pump
Harness - Control Valve
Harness - Multi Crop Separator
Harness - Grain Bin
Harness - Hydraulic Levelling
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Return Auger - Sensors
Cab Support Frame
Cab Substructure
Cab - Roof
Cab - Push Buttons
Cab - Rear Glass
Cab - Front Glass & Windscreen Wiper
Cab - Right Door
Cab - Left Door
Cab - Cladding
Seat Holder
Control Console
Control Console - Switches
Agritronic Plus
Feeder Reverser - Lever
Rear View Mirror
Platform - Right Side
Platform - Left Side
Access Ladder
Air Conditioning
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Straw Walker
Tool Box - Tools
Tool Box
Stone Trap
Front Guards - Right Side
Front Guards - Left Side
Front Guards - Shaker Shoe
Rear Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Additional Fire Extinguisher
Engine Cover
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Sheet Metal - Straw Hood
Rear Ballast (300 Kg)
Number Plate
Signaling Panels
Decals - Standard
Decals - Autolevel
Decals - Safety & Warning
Tracks (6 Rollers)
Tracks (7 Rollers)
Rollers Elements & Idler Wheels - (Components)
Chain Elements - (Components)
Front Wheels
Rear Wheels - Weight
Wheels Wedges
Feeding System
Tools
Shield Plate
Tilt Frame
Tilt Frame - Control Lever
Feeder Frame
Upper Shaft - Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum
Collector Drum - Link Belt
Shields
Lifting
Threshing System
Thresher Concave
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Maize & Mixed Crop
Thresher Concave - Rice
Thresher Concave - Drum Bar Plates
Rear Beater
Concave - Control System
Concave - Normal & Mixed Brushing
Concave - Grain & Maize
Concave - Maize & Sunflower
Concave - Maize, Cob & Mixed Crop
Concave - Rice
Multi Crop Separator - Right Side
Multi Crop Separator - Left Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Bin
Grain Bin - Access Ladder
Grain Bin - Extension
Grain Bin - Unloader Gate
Grain Bin Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Swivel Auger
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator - Filling Auger
Connecting Box - (Components)
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Bracket - Right Side
Chaff Spreader - Bracket - Left Side
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield
Accessories - Additional Fuel Filter
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Tracks (7 Rollers)
Accessories - Chaff Spreader
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Flip-Up Header Light
Accessories - Front Elevator Support Kit
Accessories - Straw Chopper Deflector
Accessories - Header Additional Lifting Ram
Spike Tooth Concave With 2 Complete Threshing Section
Speed Reduction
Muddy Soil Guards
Chain Drive For Drum
Conversion Kit - Wheat To Rice
Conversion Kit - Wheat To Maize
Conversion Kit - Rice To Wheat
Conversion Kit - Rice To Maize
