Challenger Combine 645 Parts Catalog 3906041
Brand: Challenger
Type of Machine: Combine
Model: Challenger 645 Combine
Serial Number: 551710001-999
Part Number: 3906041
Number of Pages: 1011 Pages
Engine Installation
Engine Installation - Fan
Engine Installation - Belt Tensioner
Engine Installation - Engine Brackets
Engine - Cylinder Block
Engine - Cylinder-Block
Engine - Timing Gears And Housing
Engine - Flywheel Housing
Engine - Flywheel
Engine - Valve Rocker Cover
Engine - Crankshaft And Pistons
Engine - Camshaft
Engine - Intake Valve, Exhaust Valve & Camshaft
Engine - Cylinder Head
Engine - Intake Manifold
Engine - Exhaust Manifold
Engine - Turbocharger
Engine - Lube Oil Lines
Engine - Oil Sump
Engine - Oil Pump
Engine - Oil Filter
Engine - Oil Dipstick
Engine - Water Pump
Engine - Water Lines
Engine - Injection Pump
Engine - Injector
Engine - Fuel Filter
Engine - Fuel Pipe
Engine - Supercharging Lines
Engine - Breather
Engine - Accumulator Hydraulic
Engine - Thermostat
Engine - V-Belt
Engine - Suspension
Engine - Electronic Engine Management
Engine - Starter Motor
Engine - Alternator
Cooling System - Radiator & Attachments
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Fuel System - Fuel Tank & Attachments
Fuel System - Fuel Tank Bracket
Drive System
Hydrostatic Pump - Drive
Rotary Filter And Dust Aspiration - Drive
Power Take-Off - Drive
Crop Elevator - Drive
Crop Elevator - Reverse Drive
Air Conditioning - Drive
Cylinder Variator
Threshing Mechanism - Drive
Straw Walker - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Tank Unloading - Drive
Straw Chopper - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Final Drive
Rear Axle - 4 Wheels Drive - Weight
Towing Hook
Frame And Suspension
Frame
Beater - Body
Steering Column
Front Axle
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Reduction Gear - (Components)
Gearbox - Gear Lever
Gearbox
Brake System - (Components)
Brake Pedal
Brake Master Cylinder & Brake Control Valve - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Cutting Header
Cutting Header - Tilt
Cutting Header - Lifting
Cutting Table Flotation
Steering - Hydraulic Lines
Steering - Rear Axle - 2 Wheels Drive
Steering - Rear Axle - 4 Wheels Drive
Control Valve
Control Valve (Header) - (Components)
Pipes Reel
Lateral Header Flotation Control Valve
Straw Chopper Clutch
Header Additional Lifting Ram
Hydrostatic Pump
Hydrostatic Pump - (Components)
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Pump - Control Lever
Hydrostatic Pump - Safety Device
Hydrostatic Motor
Hydrostatic Motor - (Components)
Pipe Union
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Auxiliary Headlight
Work Lights - For Folding Cutter Bar
Battery & Main Switch
Battery Box & Battery Cable
Harness - Cab - Operator Platform.
Harness - Cab - Roof
Harness - Control Console
Harness - Fuse Carrier
Harness - Grain Tank
Harness - Engine
Harness - Control Valve
Harness - Multifunction Lever
Harness - Digital Instrumentation
Harness - Agritronicplus
Harness - Straw Walker Loss
Harness - Straw Chopper
Harness - Sheet Metal
Harness Shield
Return Auger - Sensors
Cab Support Frame
Seat Holder
Access Ladder
Access Ladder - Extension
Footstep - Left Side
Footstep - Right Side
Cab - Front Glass & Rear Glass
Cab - Roof & Windscreen Wiper
Cab - Right Door
Cab - Left Door
Cab - Cladding
Control Console
Multifunction Lever
Rear View Mirror
Concave - Control System
Air Conditioning
Front Guard - Right Side
Front Guard - Left Side
Engine Compartment - Service Hatch
Engine Compartment - Access Ladder
Sheet Metal - Right Side
Sheet Metal - Hand Rail
Sheet Metal - Left Side
Sheet Metal - Rear
Rear Sheet Metal - Weight
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Tracks (6 Rollers)
Rollers Elements & Idler Wheels - (Components)
Chain Elements
Front Wheels
Rear Wheels - Weight
Wheels Wedges
Feeding System
Crop Elevator - Tools
Crop Elevator - Shield Plate
Crop Elevator - Frame
Crop Elevator - Drive Pulley
Crop Elevator - Upper Shaft
Crop Elevator - Lower Shaft
Crop Elevator - Feeder Chain
Crop Elevator - Lower Roller
Crop Elevator - Control Lever
Crop Elevator - Overhang
Crop Elevator - Lifting
Threshing System
Thresher Concave - Heavy Grain
Thresher Concave - Maize, Cob & Mixed Crop
Thresher Concave - Rice
Drum Bar Plates
Rear Beater
Concave
Concave - Maize & Mixed Crop
Concave - Maize & Sunflower
Concave - Grain & Maize
Concave - Rice
Concave - Deflector Plate
Concave - Without M.C.S. (Multi Crop Separator)
Straw Walker - Body
Straw Walker
Straw Walker - Maize & Sunflower
Straw Walker - Straw-Lifter Rider
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Shaker Shoe - Shield
Cleaning Fan
Stratification Pan
Chaffer Frame
Sieve Frame
Discharge Extension
Chaffer Frame - Control System
Variable Speed Fan Drive - Electrical Control
Sieve
Grain Bin And Elevator System
Grain Elevator - Standard
Tailings Elevator - Standard
Tailings Elevator - Scraper
Grain Elevator - Anti-Wear Rice
Tailings Elevator - Anti-Wear Rice
Grain Tank
Grain Tank - Extension
Grain Tank - Filling Auger
Connecting Box - (Components)
Grain Tank Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Tank Unloading - Swivel Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Bracket - Right Side
Chaff Spreader - Bracket - Left Side
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield
Number Plate
Tool Box
Tool Box - Tools
Tool Box - Bracket
Additional Fire Extinguisher
Fire Extinguisher - Bracket
Air Compressor
Equipment - Official Approval
Accessories - Additional Fuel Filter
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Header Additional Lifting Ram
Accessories - Header Floatation
Accessories - Autolevel Gsa (Ground Self Alignment)
Accessories - Front Elevator Support Kit
Parts For Sandy Soils
Muddy Soil Guards
Spike Tooth Concave With 2 Complete Threshing Section
Conversion Kit - Wheat To Rice
Conversion Kit - Wheat To Maize
Conversion Kit - Belt To Chain
Brand: Challenger
Engine Installation
Engine - Flywheel
Engine - Camshaft
Engine - Oil Sump
Engine - Oil Pump
Engine - Oil Filter
Engine - Water Pump
Engine - Injector
Engine - Fuel Pipe
Engine - Breather
Engine - Thermostat
Engine - V-Belt
Engine - Suspension
Engine - Alternator
Dust Aspirator
Engine Air Filter
Exhaust System
Drive System
Cylinder Variator
Shaker Shoe - Drive
Rear Axle Support
Towing Hook
Frame
Beater - Body
Steering Column
Front Axle
Gearbox
Brake Pedal
Hydraulic Oil Tank
Cutting Header
Control Valve
Pipes Reel
Hydrostatic Pump
Hydrostatic Motor
Pipe Union
Front Lighting
Rear Lighting
Rotary Beacon
Auxiliary Headlight
Harness - Engine
Harness Shield
Cab Support Frame
Seat Holder
Access Ladder
Cab - Right Door
Cab - Left Door
Cab - Cladding
Control Console
Multifunction Lever
Rear View Mirror
Air Conditioning
Sheet Metal - Rear
Tracks (6 Rollers)
Chain Elements
Front Wheels
Wheels Wedges
Feeding System
Threshing System
Drum Bar Plates
Rear Beater
Concave
Concave - Rice
Straw Walker - Body
Straw Walker
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Cleaning Fan
Stratification Pan
Chaffer Frame
Sieve Frame
Discharge Extension
Sieve
Grain Tank
Discharge System
Straw Deflector
Number Plate
Tool Box
Tool Box - Tools
Tool Box - Bracket
Air Compressor
Muddy Soil Guards
