Challenger Combine 644 Parts Catalog 3906040
Brand: Challenger
Type of Machine: Combine
Model: Challenger 644 Combine
Serial Number: 551510001-999
Part Number: 3906040
Number of Pages: 1015 Pages
Engine Installation
Engine Installation - Fan
Engine Installation - Belt Tensioner
Engine Installation - Engine Brackets
Engine - Cylinder Block
Engine - Cylinder-Block
Engine - Timing Gears And Housing
Engine - Flywheel Housing
Engine - Flywheel
Engine - Valve Rocker Cover
Engine - Crankshaft And Pistons
Engine - Camshaft
Engine - Intake Valve, Exhaust Valve & Camshaft
Engine - Cylinder Head
Engine - Intake Manifold
Engine - Exhaust Manifold
Engine - Turbocharger
Engine - Lube Oil Lines
Engine - Oil Sump
Engine - Oil Pump
Engine - Oil Filter
Engine - Oil Dipstick
Engine - Water Pump
Engine - Water Lines
Engine - Injection Pump
Engine - Injector
Engine - Fuel Filter
Engine - Fuel Pipe
Engine - Supercharging Lines
Engine - Breather
Engine - Accumulator Hydraulic
Engine - Thermostat
Engine - V-Belt
Engine - Suspension
Engine - Electronic Engine Management
Engine - Starter Motor
Engine - Alternator
Cooling System - Radiator & Attachments
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Compartment - Service Hatch
Engine Air Filter
Exhaust System
Fuel System - Fuel Tank & Attachments
Fuel System - Fuel Tank Bracket
Drive System
Hydrostatic Pump - Drive
Rotary Filter And Dust Aspiration - Drive
Power Take-Off - Drive
Crop Elevator - Drive
Crop Elevator - Reverse Drive
Air Conditioning - Drive
Cylinder Variator
Threshing Mechanism - Drive
Straw Walker - Drive
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Tank Unloading - Drive
Straw Chopper - Drive
Rear Axle Support
Rear Axle - 2 Wheels Drive
Rear Axle - 2 Wheels Drive - Weight
Rear Axle - 2 Wheels Drive - Weight Support
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - Final Drive
Rear Axle - 4 Wheels Drive - Weight
Towing Hook
Frame And Suspension
Frame
Beater - Body
Steering Column
Steering - Hydraulic Lines
Steering - Rear Axle - 2 Wheels Drive
Steering - Rear Axle - 4 Wheels Drive
Front Axle
Reduction Gear - (Components)
Gearbox - Gear Lever
Front Axle Spacer (122 Mm)
Front Axle Spacer (250 Mm)
Gearbox
Brake System - (Components)
Brake Pedal
Brake Master Cylinder & Brake Control Valve - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydrostatic Pump
Hydrostatic Pump - (Components)
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Pump - Control Lever
Hydrostatic Pump - Safety Device
Hydrostatic Motor
Hydrostatic Motor - (Components)
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Cutting Header
Cutting Header - Tilt
Cutting Header - Lifting
Cutting Table Flotation
Control Valve
Control Valve (Header) - (Components)
Pipes Reel
Lateral Header Flotation Control Valve
Straw Chopper Clutch
Header Additional Lifting Ram
Pipe Union
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Rotary Beacon
Auxiliary Headlight
Work Lights - For Folding Cutter Bar
Battery & Main Switch
Battery Box & Battery Cable
Harness - Cab - Operator Platform.
Harness - Cab - Roof
Harness - Control Console
Harness - Fuse Carrier
Harness - Grain Tank
Harness - Engine
Harness - Control Valve
Harness - Multifunction Lever
Harness - Digital Instrumentation
Harness - Agritronicplus
Harness - Straw Walker Loss
Harness - Straw Chopper
Harness - Sheet Metal
Harness Shield
Return Auger - Sensors
Cab Support Frame
Seat Holder
Access Ladder
Access Ladder - Extension
Footstep - Left Side
Footstep - Right Side
Cab - Front Glass & Rear Glass
Cab - Roof & Windscreen Wiper
Cab - Right Door
Cab - Left Door
Cab - Cladding
Control Console
Multifunction Lever
Rear View Mirror
Concave - Control System
Air Conditioning
Front Guard - Right Side
Front Guard - Left Side
Engine Compartment - Access Ladder
Sheet Metal - Right Side
Sheet Metal - Hand Rail
Sheet Metal - Left Side
Sheet Metal - Rear
Rear Sheet Metal - Weight
Decals - Safety - Front
Decals - Safety - Rear
Decals - Safety - Right Side
Decals - Safety - Left Side
Tracks (6 Rollers)
Rollers Elements & Idler Wheels - (Components)
Chain Elements
Front Wheels
Rear Wheels - Weight
Wheels Wedges
Feeding System
Crop Elevator - Tools
Crop Elevator - Shield Plate
Crop Elevator - Frame
Crop Elevator - Drive Pulley
Crop Elevator - Upper Shaft
Crop Elevator - Lower Shaft
Crop Elevator - Feeder Chain
Crop Elevator - Lower Roller
Crop Elevator - Control Lever
Crop Elevator - Overhang
Crop Elevator - Lifting
Threshing System
Thresher Concave - Heavy Grain
Thresher Concave - Maize, Cob & Mixed Crop
Thresher Concave - Rice
Drum Bar Plates
Rear Beater
Concave
Concave - Maize & Mixed Crop
Concave - Maize & Sunflower
Concave - Grain & Maize
Concave - Rice
Concave - Deflector Plate
Concave - Without M.C.S. (Multi Crop Separator)
Straw Walker - Body
Straw Walker
Straw Walker - Maize & Sunflower
Straw Walker - Straw-Lifter Rider
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Shaker Shoe - Shield
Cleaning Fan
Stratification Pan
Chaffer Frame
Sieve Frame
Discharge Extension
Chaffer Frame - Control System
Variable Speed Fan Drive - Electrical Control
Sieve
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Tank
Grain Tank - Extension
Grain Tank - Filling Auger
Connecting Box - (Components)
Grain Tank Unloading - Drain Pipe
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Tank Unloading - Swivel Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Bracket - Right Side
Chaff Spreader - Bracket - Left Side
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield
Number Plate
Tool Box
Tool Box - Tools
Tool Box - Bracket
Additional Fire Extinguisher
Fire Extinguisher - Bracket
Air Compressor
Equipment - Official Approval
Accessories - Additional Fuel Filter
Accessories - Rear Axle 2 Wd - Weight
Accessories - Rear Axle 4 Wd
Accessories - Rear Axle 4 Wd - Weight
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - Straw Chopper Deflector
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Auxiliary Headlights
Accessories - Header Additional Lifting Ram
Accessories - Header Floatation
Accessories - Autolevel Gsa (Ground Self Alignment)
Accessories - Front Elevator Support Kit
Parts For Sandy Soils
Muddy Soil Guards
Spike Tooth Concave With 2 Complete Threshing Section
Conversion Kit - Wheat To Rice
Conversion Kit - Wheat To Maize
Conversion Kit - Belt To Chain
