Challenger Combine 642 Parts Catalog C064201
Brand: Challenger
Type of Machine: Combine
Model: Challenger 642 Combine (BR)
Part Number: C064201
Number of Pages: 725 Pages
Engine Silencer
Support Engine
Engine And Propulsion Pump
Main Valve Hydraulic System
Pistons And Connecting Rods
Valves Cover
Rocker Arm
Hydraulic Transport Shock Absorber
Filter Of The Oil Is Cooling
Lubricating Oil Sump
Lubrificating Oil Pump
Lubrificating Oil Dipstick
Engine Breather
Flwheel Housing
Distribution Cover
Protector
Camshaft
Valve Tappet
Cover
Fuel Pipings
Fuel System Accessories
Coupling
Valve
Filter
Alternator Positioner
Tightener
Fixatión - Starter Motor
Starter Motor
Fanning Drive
Thermostato And Housing
Thermostart Kit
Pulley
Water Inlet Connection
Connection
Plumbing
Turbocharger Compressor
Turbocharger Installation
Turbocharger Compressor Pipes And Heat Shields Cont'd
Gasket
Exhaust Manifold
Flywheel
Support
Drive
Cooling System Radiator
Air Cleaner
Pre Filter Extension
Rotary Screen
Radiator Air Intake
Power Take-Off Shaft And Pulley
Fan Housing
Fuel Tank 600 L
Power Take- Off Eletronic Actuator
Final Reduction
Driving Weels Final Reduced
Front Axle Shaft And Acumulators
Rear Axle
Rear Weel
Hydraulic Cylinder Steering
Rear Alxe 4x4
Gearbox
Front Axle Gear Box And Brake
Suction Channel And Hydraulic Cooler
Hydraulic Container Engine
Hydrostatic Pump Engine
Table Lift Cylinder
Hydraulic Cylinder Table Lift
Hydraulic Cylinder Unloading Pipe
Rotation Speed Hydraulic System
Propulsion Hydraulic Hydraulic System
Pump And Main Valve Hydraulic System
Triple Install Pump Assy Hydraulic System
Table Lift Hydraulic System
Hydraulic System Steering Gear
Hydraulics - Unloading Auger Hydraulic System
Reel Horizontal Displacement Hydraulic System
Check Valve
Lift Hydraulic Reel Hydraulic System
Chaff Spreader Hydraulic System
Auto-Level Combine Table
Hydraulic Cylinder Auto-Level Combine Table
Pipe Support
Cylinder Hydraulic Drive Hydraulic System
Flood Divider Set
Combined Flow Valve
Datavision Cab
Electric Box
Electrical Parts
Battery
Chain
Engine Harness Cummins
Drive Harness
Grain Tank Harness
Lights Harness
Rethreshing Sensor Harness
Vibrations Sensor - Straw Chopper Harness
Loss Sensor Harness
Shaft Sensor Harness
Table - Combine Union Harness
Adaptor To Gleaner Table Harness
148_4x4 Wd Junction Harness
Actuador Harness
Air Conditioner Harness
Chaff Spreader Harness
Warning Light
Platform
Cab Rear Part
Cab Bow And Lateral
Cab Roof
Gearshift Component
Brake Pedal
Steering Arrangement
Object Holder
Windows
Raised Cab And Air Conditioning
Cab Air Conditioner
Plat Form And Lights Platform
Ladder Platform
Instrument Panel
Multi-Function Handle
Shift Levers
Upper Panel Cab
Side Member Cab
Ladder
Engine Closing Assembly Left Hand
Stopping Lower
Shield
Straw Nose
Straw Nose Rear Cover
Straw Nose Lower Stopping
Straw Nose Right Hand
Straw Nose Left Hand
Guarding - Engine Upper
Rear Cover
Rear Axle Side Roll-Over
Decal
Warning Decal Kit
Feeding System
Transmission Table Elevator
Adaptor
Table Elevator Feeder Shaft Lower
Reversing Device
Turnbuckle
Feeder Chain Protective Plate
Tightener Gear Assy
Feeder Shaft Upper And Suspension
Bearing
Table Clutch
Clutch
Tightener And Shield Table Elevator
Threshing System
Concave
Concave Spacement 14mm
Concave Setting
Threshing Cylinder
Threshing Cylinder 600mm = Dia
Drum Cover And Stone Trap
Cylinder Transmission
Main Shaft
Main Shaft Pulley
Threshing Cylinder Rice
Concave Rice
Rear Beater
Check Flaps
Cleaning System
Eccentric Drive
Lower Shaker
Extension
Lever Assembly Sieves
Lower Shaker Shoe And Suspension
Grain Pan Box Lower
Arm Oscillating
Upper Sieves
Extension Set
Upper Shaker Shoe And Suspension
Grain Pan Box Upper
Grain Pan
Feeder Structure
Return Pan
Straw Walkers
Furrowers Straw Walkers
Crankshaft Rear
Crankshaft Front
Fan Housing, Mantle And Rotary Air Intak
Ventilator Housing
Protector Fan
Main Fain Blade And Bottom Auger
Propeller Blade
Fanning Mill Variator
Couter Drive
Straw Spreader
Couter Drive Straw Chopper
Straw Chopper
Straw Chopper Spreader
Straw Chopper Clutch
Impeller Straw Chopper
Straw Spreader Straw Chopper
Turnbuckle Straw Chopper
Grain Bin And Elevator System
Turbocharger Feeder
Turbocharger Feeder Drive
Nivel Transmission
Discharge Auger Swivel Part
Transmission Discharge Auger
Grain Tank Guards And Covers
Protection - Sides And Rear Grain Tank
Botton Grain Tank
Discharge Auger Pipe
Coupling Unloading Pipe
Discharge Auger Fixeds Part
Upper Cylinder Head Grain Elevator
Filler Grain Elevator
Angular Transmission
Return Elevator Upper Cylinder Head
Return Elevator Body And Lower Cylinder Head
Returns Thresher Upper Cylinder Head
Returns Thresher Transmission And Cylinder
Agriculture Precision System Trimble
Agriculture Precision System Garmin
Yiedlmeter Microtrack
Yiedlmeter 3 Staffs
Corn Table Kit
Speed Control
Kit 3 Threshing Cylinder
Kit To Inclined Ground
Corn Cylinder 60mm = Dia
Kit Belt - Extra
Cylinder
Bean Kit Elevator's Grain Bucket
Bean Kit Concave Wires
Bean Kit Cylinder Bar
Bean Kit Rangebox
Bean Kit Reduction Threshing Cylinder
Bean Kit Stopping
Hearing Protector
Heater
Guard Plate Bottom Grain Tank
Wheat Concave Kit
Tools
Brand: Challenger
Engine Silencer
Support Engine
Valves Cover
Rocker Arm
Engine Breather
Flwheel Housing
Distribution Cover
Protector
Camshaft
Valve Tappet
Cover
Fuel Pipings
Coupling
Valve
Filter
Tightener
Starter Motor
Fanning Drive
Thermostart Kit
Pulley
Connection
Plumbing
Gasket
Exhaust Manifold
Flywheel
Support
Drive
Air Cleaner
Rotary Screen
Radiator Air Intake
Fan Housing
Fuel Tank 600 L
Final Reduction
Rear Axle
Rear Weel
Rear Alxe 4x4
Gearbox
Table Lift Cylinder
Check Valve
Pipe Support
Flood Divider Set
Combined Flow Valve
Datavision Cab
Electric Box
Electrical Parts
Battery
Chain
Drive Harness
Grain Tank Harness
Lights Harness
Loss Sensor Harness
Actuador Harness
Warning Light
Platform
Cab Rear Part
Cab Bow And Lateral
Cab Roof
Gearshift Component
Brake Pedal
Object Holder
Windows
Cab Air Conditioner
Ladder Platform
Instrument Panel
Shift Levers
Upper Panel Cab
Side Member Cab
Ladder
Stopping Lower
Shield
Straw Nose
Rear Cover
Decal
Warning Decal Kit
Feeding System
Adaptor
Reversing Device
Turnbuckle
Tightener Gear Assy
Bearing
Table Clutch
Clutch
Threshing System
Concave
Concave Setting
Threshing Cylinder
Main Shaft
Main Shaft Pulley
Concave Rice
Rear Beater
Check Flaps
Cleaning System
Eccentric Drive
Lower Shaker
Extension
Grain Pan Box Lower
Arm Oscillating
Upper Sieves
Extension Set
Grain Pan Box Upper
Grain Pan
Feeder Structure
Return Pan
Straw Walkers
Crankshaft Rear
Crankshaft Front
Ventilator Housing
Protector Fan
Propeller Blade
Couter Drive
Straw Spreader
Straw Chopper
Turbocharger Feeder
Nivel Transmission
Botton Grain Tank
Yiedlmeter 3 Staffs
Corn Table Kit
Speed Control
Kit Belt - Extra
Cylinder
Bean Kit Rangebox
Bean Kit Stopping
Hearing Protector
Heater
Wheat Concave Kit
Tools
