Challenger 7460 7660 Sprayer System Parts Catalog 523710D1
Brand: Challenge
Type of Machine: Applicators
Model: Challenger 7460, 7660 Sprayer System (2009 - 2013)
Serial Number: ..UXX1001 - ..DXXX9999
Part Number: 523710D1
Number of Pages: 1769 Pages
Hydraulic Installation, H Frame, 60 80
Hydraulic Hose Installation, H Frame 7x50
Hydraulic Valve Installation, Boom, 6 Bank
Hydraulic Boom Valve Installation, 6 Section
Hydraulic Boom Valve, 6 Bank
Straight Adapter, 0.37mo-R X 0.37mjic
Plug, 037mo-R Hex
Tube Installation, Hydraulic, H Frame
Hydraulic Installation, H Frame, Sc6080 80 90
Hydraulic Valve Assembly, 6 Bank, Boom
Hydraulic Hose Installation, Boom Lift, Parallel Link
Tube Installation, Hydraulic, Product Pump, 7x50
Hose Installation, Boom Tilt, 6080, 7x50
Hose Installation, Boom Tip, 6080, 7x50
Hose Installation, Boom Tip 60 80
Boom Swing Cylinder Assembly, Sc6080, Right And Left Hand
Hydraulic Cylinder, 2.75 X 11 X 1.38
Left Hand
Hydraulic Cylinder, 2.50 X 12.00 X 1.12
Straight Adapter, 0.50mo-R X 50mo-R
Right Hand
80, 90, 100 Foot
Hydraulic Cylinder, 2.25 X 1.00 X .65
Hydraulic Cylinder, 1.75 X 16.84 X 1.25
Boom Tip Fold Cylinder Assembly
Accumulator Installation, Parallel Links
Check Valve
Orifice Check Valve Assembly, -12 Male O-Ring
System Electrical Installation, Raven
Boom And Speed Node, Raven
Flowmeter, 2.00 Inch, Sp Flange, Rfm60p, 12 Volt
System Electrical Installation, Raven, Pwm, 2010
System Electrical Installation, Global Technologies By Agco
System Electrical Installation, Raven, Servo
Butterfly Valve, 1.50, 90d
System Electrical Installation, Raven, Servo, 2010
Global Technologies By Agco (Gta)
Electrical Installation, Boom, 7x50
Module Assembly, Input Output, Can
Taillight Installation, Without Tilt Rack
Taillight Harness Installation, 7x50
Lamp Cluster, Rear, Right Hand
Lamp Cluster, Rear, Left Hand
Taillight Installation, 7x50
End Row Switch Installation
Panel Assembly, Switch, Console
End Row Switch Installation, Cab
Taillight Harness Installation, No Worklight
Light Installation, Hid, System
Worklight, Hid
Worklight Installation, System
Worklight
Worklight, Liquid System
Hid Light, Liquid System
Decal Installation, 725 Gallon, North America
Decal Installation, 725 Gallon, International
Decal Installation, 2498 Liter, Ss, North America
Decal Installation, 2498 Liter, Ss, International
Decal Installation, 660 Gallon, North America
Decal Installation, 660 Gallon, International
Sign Slow Moving Vehicle Sign Installation
Speed Indicator Symbol Installation, 30 Mph
Speed Indicator Symbol Installation, 50 Kph
Controller System
Flowmeter, 2.00 Inch, Sp Flange, Rfm60, 12 Volt
Product Containment
Tank And Saddle Assembly, 660 Gallon, Ss
Tank Assembly, 660 Gallon, Ss
Stubby Valve, 2.00 Inch Port, Male X Female
Tank And Saddle Assembly, 725 Gallon, Poly
Tank Assembly, 725 Gallon, Poly
Tank Flange, Bottom Drain, 2.00 Inch, Full Port
Lid Assembly, 10 Inch
Gasket Kit, 10 Inch
Hinged Cover
Screen Installation, Product Tank, 725 Gallon
Manifold
Tiedown Installation, 7x50
Tiedown Installation, 725 Gallon, Poly
Primary Product Distribution
Liquid System Plumbing Installation, 660 Gallon Tank, Ss
Plumbing Assembly, Pump And Reload, 1.50 X 1.25
Centrifugal Pump, 1.50 X 1.25, 9303chm1
Ball Valve, Union, Poly, 1.00npt
Pressure Plumbing Assembly, Manifold, 660 Gallon Ss
Manifold Assembly, Strainer And Rinse Valve, 1.50
Ball Valve, 1.00 Inch Full Port Flange X Npt, Electrical
Pressure Plumbing Installation, 660 Gallon Ss, 7 X 50
Valve Assembly, Low Rate Kit, 7x50
Valve Assembly, Regulating, Pressure
Ball Valve, 1.50 Inch Poly, Full Flow
Liquid System Plumbing Installation, 725 Gallon Tank, Poly
Pressure Plumbing Installation, 725 Gallon, 7 X 50
Valve Assembly, Low Rate, Poly, 7x50
Pressure Plumbing Assembly, Manifold, 725 Gallon, Poly
Y Manifold Assembly, 1.00 Full Port Flange, Electrical
Manifold Installation, Ball Valve, Standard
Boom Manifold Assembly, With Ball Valve, Standard
Strainer Body Assembly, 1.00 Inch
Valve, 2.00 Inch, Flange X 1.50npt, T Handle
Strainer, Line, 1.50fnpt, 32 Mesh
Chemical Eductor Plumbing Assembly, Ss, 7x50
Chemical Eductor Assembly, Clean Load, Poly
Chemical Eductor, Clean Load, Poly
Nozzle Valve
Plumbing Assembly, Eductor Return, 7x50
Chemical Eductor, Poly, 660 Gallon Ss Tank
Chemical Eductor, Poly, 725 Gallon Poly Tank
Chemical Eductor, Poly, 660 Gallon Ss Tank, 2010
Chemical Eductor Plumbing Assembly, Poly, 4.5 Gallon, 2010
Chemical Eductor Assembly, Poly, Sm 2010
Chemical Eductor, Clean Load Ii, Poly, 4.5 Gallon
Ball Valve, 32 Fp X 32 Mp, Poly
Chemical Eductor, Poly, 725 Gallon Poly Tank, 2010
Chemical Eductor, Ss, 660 Gallon, 7 X 50
Chemical Eductor, Ss, 725 Gallon, Poly
No Chemical Eductor Option, 7 X 50
Chemical Eductor Option, Poly, 660 Gallon, Ss 2010
Chemical Eductor Option, Poly, 725 Gallon, 2010
Secondary Product Distribution
Plumbing System Installation, Sc60180 X 5, Electrical
System Plumbing Installation, Servo, Poly Tank
Pressure Plumbing Installation, Servo, Poly Tank
Product Control Valve Assembly, 1.50, Raven
System Plumbing Installation, Servo, Ss Tank
Pressure Plumbing Installation, Servo, Ss Tank
L Bracket Assembly And Long Straight, Poly Pipe Clip
Bracket Assembly, Straight, Long, 2ips Clip, 1.00 U
Bracket Assembly, Straight, Long, 2ips, P Clip
Bracket Assembly, Straight, Short, So, Ips, P Clip
L Bracket Assembly, So, Stauff, Reversed P Clamp
Bracket Assembly, Straight, Long, So, 2 Ips, P Clip
Bracket Assembly, Straight, Long, P Clip, 1.00 U
Bracket Assembly, Straight, Long, 3 Clips
Fence Row Nozzle Assembly 60 80 Boom
Endrow Pipe Assembly, 5 X 20, Poly
Bracket Assembly, Straight, Short, Ips Clip, 1.00 U
Fence Row Nozzle, 60 80 90
X Pipe Assembly, With Three 1.00 Hose Barb, 11x10, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 9x10, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 11x10, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 9 X 10, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 5x10, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 8x10, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 6x10, Poly
Triple Nozzle Assembly Option 10 X 90
Triple Nozzle Holder, 1.00 Ips
Pipe Assembly, 90d With 1.00 Hose Barb, 11x10, Poly
Triple Nozzle Assembly Option 10 X 80
Bracket Assembly, Straight, Long, 3ips Clip
Bracket Assembly, Straight, Short, Ips Clip, P Clip
L Bracket Assembly, Poly Stauff
Bracket Assembly, Straight, Short, 1.00 Ips Clip
L Bracket Assembly, Poly Stauff, Reversed P Clamp
L Bracket Assembly, Poly Stauff, Center P Clip
X Pipe Assembly, With Three 1.00 Hose Barb, 6 X 20, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 6 X 20, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 5 X 20, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 5 X 20, Poly
Tee Pipe Assembly, With Two 1.00 Hose Barb, 3 X 20, Poly
Pipe Assembly, 90d With 1.00 Hose Barb, 3 X 20, Poly
L Bracket Assembly, Poly Stauff, 1.00 U
Reload Installation, 2.00, 7x50
Valve, 2 Inch Male Npt X 2 Inch Male Adapter
Reload Installation, 3.00, 7x50
Valve, 3.00 Inch, Female Npt X 3.00 Male Adapter
Triple Nozzle Assembly Option, 20 X 80
Spray Nozzle, Varitarget, 15gpm
Nozzle Kit, Varitarget, Clr, 25
Spray Nozzle Kit, Varitarget, Clr, 5
Nozzle Kit, Xrc11003vp, 50
Nozzle Kit, Xrc11003vp, 60
Nozzle Kit, Xrc11003vp, 75
Poly Plumbing Option, Sc6080 X 80 X 5 X 20, Off
Poly Plumbing Option, Sc6080 X 5 X 10, On
Poly Plumbing Option, Sc6090 X 5 X 10, On
Poly Plumbing Option, Sc6090 X 5 X 20, Off
Nozzle Varitarget, Clear, 80x20
Nozzle Varitarget, Clear, 90x20
Booms
Boom Installation, Center, H Frame, With Tilt Rack, 2011
Boom Tilt Rack Installation, 60 80
Boom Tilt Rack Assembly, 60 80
Boom H Frame Installation, Rear, 60 80
Boom H Frame Assembly, Rear, 60 80
Boom Lift Installation, Parallel Link
Boom Assembly, 60 80, Left Hand
Boom Assembly, 60 80, Right Hand
Breakaway Cam Assembly, 60 80
Boom Assembly, 60 90, Right Hand
Boom Assembly, 60 90, Left And Right Hand
Boom Breakaway Cam Assembly
Boom Installation, Center, H Frame, Without Tilt Rack
H-Frame Installation, Without Tilt Rack
Boom Assembly, Sc6090, Left Hand
Boom Assembly, Sc6090, Left And Right Hand
Boom Assembly, Sc6090, Right Hand
Tube Assembly, Rack Tilt
Hinge Assembly, 60 80 90, Right Hand
Hinge Assembly, 60 80 90, Left Hand
Hinge Assembly, 60 80, Right Hand
Hinge Assembly, 60 80, Left Hand
Hydraulic Block Installation, Boom Rest, 7x50
Boom Rest Block Assembly
Cap Installation, Without H Frame
Cap Installation, H Frame, B6633 Without Boom
Boom Assembly, Sc6080, Left And Right Hand
Hose Installation, Boom Tilt, 60 80 90
Boom Mounting Hardware, Sc6080 Sc6090
Boom Assembly, 60 90, Left Hand
Boom, 60 80
Boom, 90 Foot, Spra Coupe
Boom Option, 60 90
Hinge, Boom, 60 80 Foot
Boom Hinge Option, 60 80 90
Boom Option, 60 80
Foam Marker
Foam Marker Installation, Boom Parts, Sc6080
Mounting Bracket Assembly, Foam Marker Mixing Chamber
Foam Marker Mixing Chamber, Richway
Bracket Assembly, Drop Hose, Foam Marker, Right Hand
Bracket Assembly, Drop Hose, Foam Marker, Left Hand
Foam Marker Tank And Pump Installation, 25 Gallon, 7x50
Tank And Pump Assembly, Foam Marker, 25 Gallon, Richway
Manifold Assembly, With Actuators
Airline Installation, Foam Marker, 7x50
Pressure Washer And Rinse System
Rinse Tank Installation, 65 Gallon, 7 X 50
Rinse Tank Assembly, 65 Gallon, 7 X 50
65 Gallon Tank, Right Hand, Poly
