Challenger 7460 7660 Sprayer Chassis Parts Catalog 548769D1
Brand: Challenge
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenger 7460, 7660 Sprayer Chassis (2011 - 2013)
Serial Number: ..WXX1001 - ..DXX9999
Part Number: 548769D1
Number of Pages: 316 Pages
Publication Information
Engine, Fuel, And Exhaust System
Engine Install
Engine-Cat C6.6,174hp T3
Filter Assembly-Fuel Water Separator
Compressor-A C,R134a,2 Groove
Pump-Assembly,Hydraulic,Chassis
Pump-Hydraulic,Gear,2.75 Cid
Adapter Straight 0.75mo-R X 1.00mjic
Adapter Straight .50mo-R X 0.50 Mjic
Engine-Perkins 1106d,174hp T3
Timing Cover Assembly
Timing Case
Auxiliaries Miscellaneous
Engine Control Module Assembly
Sensors Assembly
Cylinder Block And Liners Assembly
Rear Oil Seal Assembly
Crankshaft Main And Big Bearing
Pistons And Rings Assembly
Connecting Rods Assembly
Cylinder Head Assembly
Rocker Shaft Assembly
Timing Gear Chamshaft Assembly
High Pressure Fuel Pump Assembly
Fuel Rail Assembly
High Pressure Fuel Pipes Assembly
Pipework Assembly
Fan Drive Assembly
Cylinder Head Cover Base Assembly
Breather Assembly
Blanking Plates Assembly
Oil Cooler Assembly
Oil Filter
Front Drive Output
Water Pump Assembly
Pipes Assembly
Water Outlet Housing Assembly
Timing Case Assembly
Oil Pump Delivery Housing Assembly
Turbocharger Assembly
Pipework Connections Assembly
Induction Manifold Assembly
Pipework Connection Assembly
Heater Plugs Assembly
Engine Lifting Eyes Assembly
Oil Sump Drain Pump Assembly
Oil Pressure Switch Gauge Assembly
Wiring Looms Assembly
Water Trap Assembly
Assembly, Alternator Mounting
Atomisers
Flywheel Housing
Ring Flywheel And Starter
Sump
Tube Dipstick And Filler
Oil Strainer
Cover Cylinder Head
Blanking Plates
Drive Input Front End
Feed Pipes
Pipes Leak-Off
Exhaust Manifold
Wastegate Sensor
Pipes Low Pressure Fuel
Pipe Fuel Leak-Off
Filter Fuel
Cooling Package
Cooling Package,Tier 3
Elbow 90d -12mjic X -12mstor
Switch Assembly-A C,High Pressure
Tank-Dearation
Fan Guard Install
Air Intake
Air Filter Assembly,12.00in
Exhaust System
