Challenger 4650 Sprayer Parts Catalog 503986D1
Brand: Challenge
Type of Machine: Applicators
Model: Challenger 4650 Sprayer (Man Trans) 2006
Part Number: 503986D1
Number of Pages: 1348 Pages
Publication Information
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Engine Install-Cat 122hp
Package-Parts,Ford
Motor-Starter
Engine-Cat,122hp
Engine Support Group
Arm Assembly-Pulley
Exhaust Group
Cooling Group
Air Cleaner Group
Filter-Air
4000 Series
Install Throttle
Throttle Assembly-Hand
Driveline Group
4000 Mt
Transmission Assembly
Differential Assembly
Shaft-Drive,T-5 Manual
Chaincase Group-4650
Case-Chain,Final Drive,Lh,Assembly
Hub Assembly-Wheel
Case-Chain,Final Drive,Rh,Assembly
Cylinder Assembly-Brake
Brake Install-4650
Pedal Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Shaft Drive T-S,Manual R B 523030d1
Clutch Assembly
Frame And Suspension Group
4000m8
Frame-Adjust Rear 46xx Series 80 Inch
Channel Assembly 80 Inch
Frame Assembly 80 Inch Wide Front
Footboard Group
Footboard Group-W O Boomrest,4650mt
Hitch-Install
F A-Front Extension,Sc
Belly Pan Install-Wf
Axle And Steering Group
Extension Install-Front
Wide Front Group-Sc
Steering Group-Wide Front,80 In
Tie Rod Assembly-340-80
Steering Column
Steering Assembly-Arm
Steer Install-No Tow,4650 80in
Hydraulic Group
Tube Assembly
Hydraulic Install-Kit No H Frame
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
Assembly Valve-Hydraulic,H Frame
Valve-Hydraulic,Boom,6 Bank
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Cylinder-Hydraulic,
Tank Assembly
Hydraulic Install-4000 Chassis
Valve Assembly-Control
Tank Assembly-Hydraulic
Valve-Charge
Grip Assembly-Handle
Valve-Float,2 Position
Cylinder-Hydraulic,1.75x16.84x1.00
Pump Hydraulic R B 531603d1
Elbow 90d 0.50mo-R X 0.50mjic
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adjust, 4000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-H Frame
Assembly-Valve,Relief,Boom Tip
Valve Relief-Boom Tip
Valve-Cartridge,Check-08 (4 Psi )
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.75x16.84x1.25
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Hydraulic Install-4x50mt Chassis,Sc6080
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
Tube Install-Hydraulic,H Frame
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Hose Install-Hydraulic,H Frame,4x50
Hose Install-Hydraulic,Boom Lift,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Assembly Valve-Hydraulic H Frame
Hydraulic Install-Chassis,4000m
Assembly Valve-2 Position,Float
Assembly Pump-Hydraulic 4000,Chassis
Assembly-Valve Charge
Assembly Filter-Hydraulic,4000,Chassis
Assembly-Switch Pressure
Assembly Valve-Hydraulic,4000,Chassis
Valve-Hydraulic,Boom Lift Track Adjust,3 Bank
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Hydraulic Install-Chassis,4000m,Sc6080
Cab Group
Valve-Modulating
Cab Install Chal
Cab Top Assembly-Chal
Kit-Radio,Sc
Seat Install
Seat-Suspension
Shift Install-Mt
Clutch Pedal Install
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Electrical Install-3 Valve
Electrical Install-5 Valve
Kit-Overspray
Battery Install
Electrical Install-Chassis,4000m
Light Assembly
Alternator,140 Amp-2 Groove
Electrical Install-Cab
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Light-Flood,Med
F A-Floodlight Kit
Electrical Install-Relief Valve
Appearance Group
Hood Install-Chal
Hood Assembly-Chal
Tire And Wheel Group
Tire Install-320 9,Gray
Tire Assembly-320 85r24,Lh,Gray
Tire Assembly-320 85r24,Rh,Gray
Tire Assembly-9.00x24,Gray
Tire Install-320 9 Gray W Fluid
Tire Assembly-9.00x24 Gray W Fluid
Decal Group
Decal Install-Chal,4650
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-A And M
Tank Assembly,Spray
Spray Install-4000 Chassis
Valve Ball 0.75 Poly Full Flow
Pump Assembly- Spray W Clutch
Pump-Spray
Valve 3-Way 2.00 Bottom Load
Valve Assembly-Inlet
Valve-Ball,2in Full Port,W Cam
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Flowmeter Kit-2.00sp Flange,Rfm60p
Flowmeter-2.00sp Flange,Rfm60p,Cnxl
Spray Install-60 Ft Manifold
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly Double
Nozzle Assembly-Double
Spray System Install-H Frame
Valve-Control,1.00npt 2.00sp Flange
3-Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flange X O-Ring
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray Install-Center Manifold
Spray Install-80 Ft Manifold
5-Section Valve-Boom Shut Off
Valve Assembly-Kz,5 Section
Spray Install-Loose Parts Kit
Valve-Pressure,Control
Manifold Install-Center,Sc6080,4x50
Valve Assembly-Shutoff,Boom Sect,5
Valve Teejet
Flowmeter-2.00sp Flange,Rfm60p,12v
Option-Pp Plumbing,Sc6080x5x20,Off
Pipe Assembly-90d W .75hb,6x20.Pp
Bracket Assembly-L,.75 Stauff,Std
Bracket Assembly-Z,Sh,.75ips,Std
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,3x20,Pp
Pipe Assembly-90d W 1.00hb,2x20,Pp
Pipe Assembly-90d W .75hb,6x20,Pp
Mender Assembly-Hose,.75x1.00,Pp
Bracket Assembly-L Lg Str,.75pp,2pclp
Bracket Assembly-L,.75 Stauff,Pclp,Std
Bracket Assembly-Z,Lg,.75 1.00ips,Pclp
Bracket Assembly-L,.75 Stauff,Rev Pclp
Bracket Assembly-Z,Lg,.75 1.00ips,1.0u
Bracket Assembly-Z,Sh,.75ips,1.00u
Bracket Assembly-L,.75 Stauff,1.00u
Option-Pp Plumbing,Sc6080x5x10,On
Pipe Assembly-90d W .75hb,11x10,Pp
Pipe Assembly-T W 2 1.00hb,10x10,Pp
Pipe Assembly-T W 2 1.00hb, 6x10,Pp
Pipe Assembly-90d W 1.00hb, 5x10,Pp
Option-Nozzle,3way,Rotary,80x10,0n
Body-Nozzle,3 Way,Rotary,.75
Option-Nozzle,3way,Rotary,80x20,Off
Boom Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Bar Install-Mounting,Plumbing,Center,Sc6080
Lift Install-Boom,Par Link,4x50
Boomrest Install-Sc6080,4x50
Bag-Parts
Kit-Loose Parts,Boom Hinge
Block Install-Boomrest,4x50
Controller Group
Controller Install-Raven 460,Wf
Foam Marker Group
F A-Marker,Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Control Module Assembly
Options Group
Fresh Water Install
Overspray Install
F A Crop Deflector,3600,4600
F A-Driveshaft Extension Kit
Recommended Dealer Stock
Brand: Challenge
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Package-Parts,Ford
Motor-Starter
Engine-Cat,122hp
Arm Assembly-Pulley
Exhaust Group
Cooling Group
Air Cleaner Group
Filter-Air
4000 Series
Install Throttle
Driveline Group
4000 Mt
Hub Assembly-Wheel
Brake Install-4650
Brake Assembly,Lh
Brake Assembly,Rh
Clutch Assembly
4000m8
Footboard Group
Hitch-Install
Wide Front Group-Sc
Steering Column
Hydraulic Group
Tube Assembly
H Frame
Cylinder-Hydraulic,
Tank Assembly
Valve-Charge
Pump-Gear,19cc,P5t
Cab Group
Valve-Modulating
Cab Install Chal
Kit-Radio,Sc
Seat Install
Seat-Suspension
Shift Install-Mt
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Kit-Overspray
Battery Install
Light Assembly
Gauge-Fuel,12v
Gauge-Oil Pressure
Light-Flood,Med
F A-Floodlight Kit
Appearance Group
Hood Install-Chal
Hood Assembly-Chal
Decal Group
Tank Assembly-Spray
Cover-Hinged
Agitator-A And M
Tank Assembly,Spray
Pump-Spray
Strainer-Manifold
Valve R B 056871
Insert-Seat,Qc3
Valve Teejet
Boom Group
Tilt Rack Assembly
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Option-Boom 60 80
Boom Assembly-60 80
Bag-Parts
Controller Group
Foam Marker Group
F A-Marker,Rsc 2130
Options Group
Fresh Water Install
Overspray Install
