Challenger 4460 4660 Sprayer Parts Catalog 518482D1
Brand: Challenge
Type of Machine: Applicators
Model: Challenger 4460, 4660 Sprayer (Auto Trans) (2008 - 2013)
Serial Number: ..TXX1001 - ..DXX9999
Part Number: 518482D1
Number of Pages: 973 Pages
Publication Information
Engine Supolyort Install-At
Arm Assembly-Pulley
Engine Install-4x60at Perkins
Motor-Starter
Engine-1104d Perkins Tier 3
Rear End Oil Seal Assembly
Dipstick And Filler Tube Assembly
Oil Strainer Assembly
Blanking Plate Assembly
Front End Drive Input Assembly
Fan Assembly
Timing Cover Assembly
Oil Pump And Delivery Housing Assembly
Leak-Off Pipe Assembly
Pipework And Connections Assembly
Temperature Gauge And Sender Assembly
Plug, Blanking Assembly
Engine Assembly-Short
Rods Connecting
Kit Crankshaft
Camshaft Timing Gear
Atomisers
Fuel Rail
Engine Control Module
Flywheel Housing
Rocker Shaft Assembly
Flywheel Starter Ring
Fan Drive
Blanking Plates
Sump
Cylinder Head Cover
Breather
Filler
Oil Filter
Pipes
Water Outlet Housing
Timing Case
Exhaust Manifold
Feed Pipes
Pipework Connections Assembly
Turbocharger Assembly
Pipework Assembly
Wastegate Sensor Assembly
Piston Rings Assembly
Fuel Pump-High Pressure Assembly
Fuel Filter Assembly
Fuel Leak-Off Pipe
Fuel Pipes-Low Pressure
Fuel Pipes-High Pressure
Sensors Assembly
Heater Plugs
Engine Lifting Eyes
Engine Mounts-Blanking Plugs
Lube Oil Pressure Switch Gauge
Wiring Looms
Wiring Looms Assembly
Pump, Fuel Pre-Lift Assembly
Filter Kit-Fuel,Perkins
Water Trap Assembly
Pre-Fuel Filter Assembly
Fuel Filter Bowl
Auxiliaries Miscellaneous
Cooling Install
Cooling Package Assembly
Tank-Dearation
Expansion Tank Install
Alternator,140 Amp-2 Groove
Shift Allison
Shifter Assembly-Allison
Air Cleaner Install
Filter-Air
Tank-Dearating
Exhaust Install-4450at And 4650at
F A-Filling Pump,Sc4xxx
Pump-Install,Filling,Sc4xxx
