Hyundai
86
176,834
Caterpillar Wheeled Excavator M315 D2 Parts Manual SEBP6840-02 2014
Brand: Caterpillar
Type of Machine: Wheeled Excavator
Model: Caterpillar M315 D2 Wheeled Excavator
Engine: C4.4 Engine
Serial Number: CH31-Up (Machine), C4E1-Up (Engine)
Part Number: SEBP6840-02
Publication Date: 2014
Number of Pages: 865 Pages
Repair Alternatives
Supplemental Coolant Additives
Maintenance Parts
Index
Machine Arrangement
Chassis Ar​
Common Ar​
Roading Ar​
Engine Arrangement
Engine Ar-Complete​
Engine Ar-Primary​
Installation Ar-Engine​
Basic Engine
Adapter GP-Auxiliary Drive​
Camshaft GP​
Cover GP-Cylinder Head​
Crankshaft GP​
Cylinder Block GP​
Cylinder Head As​
Cylinder Head GP​
Drain GP-Engine Oil​
Drive GP-Auxiliary​
Drive GP-Fan​
Flywheel GP​
Housing GP-Flywheel​
Housing GP-Front​
Lifting GP-Engine​
Mounting GP-Engine Flexible​
Mounting GP-Fan​
Pan GP-Oil​
Piston - Rod GP​
Plug GP-Cylinder Head​
Plug GP-Engine​
Plug GP-Flywheel Housing​
Pulley GP-Crankshaft​
Rocker Arm GP​
Lubrication System
Breather GP​
Filler GP-Engine Oil​
Filter GP-Engine Oil​
Pump GP-Engine Oil​
Connection GP-Water​
Cooler GP-Engine Oil​
Cooling Ar​
Fan GP-Suction​
Guard GP-Fan​
Lines GP-Coolant​
Pump GP-Water​
Radiator - Mounting GP​
Tank GP-Coolant​
Air Inlet And Exhaust System
Aftercooler GP-Air​
Air Cleaner GP​
Connection GP-Inlet​
Fastener GP-Turbocharger​
Lines GP-Air​
Muffler GP​
Turbocharger GP​
Fuel System
Filter GP-Fuel​
Filter GP-Water Sep - Fuel​
Hose GP-Refueling​
Injector GP-Fuel​
Lines GP-Fuel​
Pump GP-Fuel Injection​
Pump GP-Fuel Transfer​
Tank - Mtg GP-Fuel​
Tank GP-Fuel​
Electrical And Starting System
Alarm GP-Travel​
Alternator GP-Charging​
Battery - Wiring GP​
Battery GP​
Control - Mtg GP-Machine​
Control Ar-Machine​
Control GP-Communication​
Control GP-Engine Electronic​
Control GP-Unprogrammed​
Electrical Ar​
Electronics GP-Machine​
Glow Plug GP​
Guard GP-Alternator​
Harness As-Cab​
Harness As-Chassis​
Harness As-Control​
Harness As-Lighting​
Harness As-Power​
Harness As-Sensor​
Harness As-Solenoid​
Installation Ar-Security​
Installation GP-Security​
Key GP-Electronic​
Lamp GP-Flood​
Lamp GP-Head - Signal​
Lamp GP-Registration Plate​
Lamp GP-Warning Beacon​
Lighting GP-Flood​
Lighting GP-Roading​
Monitor - Mounting GP​
Radio GP-Communication​
Reflector GP​
Sensor - Mtg GP-Liquid Level​
Starting Motor GP-Electric​
Switch GP-Disconnect​
Switch GP-Magnetic​
Switch GP-Pressure​
Switch GP-Shutdown​
Swivel GP-Electric​
Wiring GP-Cab​
Wiring GP-Camera​
Wiring GP-Chassis​
Wiring GP-Console​
Wiring GP-Electronic Control​
Wiring GP-Engine​
Wiring GP-Fan​
Wiring GP-Monitor​
Wiring GP-Ride Control​
Wiring GP-Stabilizer​
Wiring GP-Transmission Control​
Wiring GP-Work Tool​
Power Train
Axle - Mtg Ar-Front​
Axle - Mtg Ar-Rear​
Axle - Transmission Ar​
Axle GP-Steering​
Power Train Ar​
Ring GP-Tire​
Shaft GP-Drive​
Tire - Rim Ar​
Tire - Rim GP​
Transmission GP​
Universal Joint GP​
Frame And Body
Counterweight GP​
Cover GP-Access​
Door GP-Access​
Enclosure GP-Engine​
Enclosure GP-Fuel Tank​
Enclosure GP-Radiator​
Frame GP-Upper​
Gear - Bearing GP-Swing​
Guard GP-Bottom​
Hood Ar​
Insulation GP-Sound Suppr​
Lines GP-Grease​
Lines GP-Lubrication​
Lock GP-Transport​
Mounting GP-Registration​
Mounting GP-Step - Tool Box​
Panel GP-Enclosure​
Step GP-Tool Box​
Striker GP-Latch​
Support GP-Hood​
Walkway GP​
Undercarriage
Frame GP-Undercarriage​
Undercarriage Ar​
Undercarriage Frame - Lines Ar​
Accumulator GP​
Accumulator GP-Hydraulic​
Actuator GP-Hydraulic​
Actuator GP-Pump​
Barrel GP-Motor​
Barrel GP-Pump​
Control GP-Brake​
Coupling GP-Flexible​
Cover GP-Lines​
Cylinder - Mtg GP-Axle Lock​
Cylinder - Seal GP-Boom​
Cylinder GP-Axle Osc Lock​
Cylinder GP-Blade​
Cylinder GP-Boom​
Cylinder GP-Bucket​
Cylinder GP-Stabilizer​
Cylinder GP-Steering​
Cylinder GP-Stick​
Drive GP-Pump​
Drive GP-Swing​
Filter - Mtg GP-Oil​
Filter GP-Oil​
Fitting GP-Hydraulic​
Gauge GP-Sight​
Head GP-Motor​
Head GP-Pump​
Hydraulic Ar​
Hydraulic Ar-Lower​
Hydraulic Ar-Upper​
Lines Ar-Auxiliary Hydraulic​
Lines GP-Auxiliary Hydraulic​
Lines GP-Blade Cylinder​
Lines GP-Boom​
Lines GP-Boom Cylinder​
Lines GP-Check Valve​
Lines GP-Cylinder​
Lines GP-Front​
Lines GP-Hydraulic​
Lines GP-Hydraulic Control​
Lines GP-Hydraulic Fan​
Lines GP-Load Control Valve​
Lines GP-Pilot​
Lines GP-Pressure Test​
Lines GP-Pump​
Lines GP-Return​
Lines GP-Ride Control​
Lines GP-Stabilizer​
Lines GP-Steering​
Lines GP-Stick​
Lines GP-Stick Cylinder​
Lines GP-Swing Motor​
Lines GP-Swivel - Steering​
Motor - Mtg GP-Travel​
Motor GP-Gear​
Motor GP-Piston​
Motor GP-Swing​
Plug GP​
Pump - Mtg GP-Hydraulic​
Pump - Mtg GP-Pilot​
Pump - Mtg GP-Piston​
Pump GP-Gear​
Pump GP-Gerotor​
Pump GP-Piston​
Rotating GP-Motor​
Rotating GP-Pump​
Shaft GP-Hydraulic Motor​
Stabilizer Ar​
Steering GP-Hydraulic​
Swivel - Mounting GP​
Swivel GP​
Tank - Mtg GP-Hydraulic​
Tank GP-Hydraulic​
Valve - Lines Ar​
Valve - Lines Ar-Auxiliary​
Valve - Lines GP​
Valve - Lines GP-Auxiliary​
Valve - Lines GP-Boom​
Valve - Lines GP-Control​
Valve - Lines GP-Diverter​
Valve - Lines GP-Travel Cont​
Valve - Mtg GP-Implement Cont​
Valve - Mtg GP-Main Control​
Valve GP-Brake Control​
Valve GP-Check​
Valve GP-Combination​
Valve GP-Control​
Valve GP-Diverter​
Valve GP-Flow Control​
Valve GP-Load Control​
Valve GP-Main Control​
Valve GP-Manual​
Valve GP-Motor Control​
Valve GP-Pilot​
Valve GP-Pump Control​
Valve GP-Relief​
Valve GP-Shuttle​
Valve GP-Solenoid​
Valve GP-Solenoid - Press Redc​
Implements
Boom Ar​
Boom Ar-1 Piece Short​
Boom GP​
Boom GP-Fore​
Boom GP-Stub​
Indicator GP-Position​
Lines GP-Grease​
Linkage GP-Bucket​
Stabilizer GP​
Stick Ar​
Stick Ar-Hoe​
Stick GP-Hoe​
Valve GP-Lube Distribution​
Work Tools
Adjuster GP-Bucket​
Blade - Mounting GP​
Blade Ar-Straight​
Blade GP​
Bucket - Adjuster GP​
Bucket Ar-General Purpose​
Bucket As-Excavation​
Bucket As-General Purpose​
Bucket As-Heavy Duty​
Bucket GP-General Purpose​
Bucket GP-Hoe​
Coupler Ar-Quick​
Coupler GP-Quick​
Hook GP-Lifting​
Lines GP-Grease​
Lock GP-Quick Coupler​
Pin GP-Bucket​
Sidecutter GP​
Tip GP-Long​
Tip GP-Penetration​
Operator Station
Air Conditioner - Mounting GP​
Air Conditioner Ar​
Air Conditioner GP​
Armrest GP​
Bracket GP-Mounting​
Cab Ar​
Cab GP​
Coil GP-Evaporator​
Compressor GP-Refrigerant​
Condenser - Mtg GP-Refrigerant​
Console GP-Operator​
Control - Mtg GP-Pedal​
Control Ar-Handle​
Control GP-Handle​
Control GP-Heat - Air Cond​
Control GP-Hydraulic Hand​
Control GP-Hydraulic Pedal​
Control GP-Joystick​
Control GP-Pedal​
Control GP-Pilot Operated Hyd​
Control Pedal - Seat Ar​
Cover GP-Access​
Cover GP-Platform​
Door - Mtg GP-Cab​
Door GP-Cab​
Duct GP-Cab Air​
Guard Ar-Fog Lights​
Guard GP-Overhead​
Guard GP-Vandalism​
Guard GP-Window​
Horn GP-Electric​
Installation GP-Radio​
Lever GP-Cab Door​
Lines GP-Air Conditioner​
Lines GP-Heater​
Literature GP​
Mirror GP-Rear View​
Mounting GP-Cab​
Mounting GP-Platform​
Operator Ar​
Pedal GP​
Pedal GP-Brake​
Platform GP-Operator​
Screen GP-Sun​
Seat Belt GP​
Seat GP-Suspension​
Steering Column GP-Adjustable​
Support GP-Seat​
Suspension GP-Seat​
Tank GP-Window Washer​
Trim GP-Cab​
Visor GP-Cab​
Window GP-Cab​
Window GP-Door​
Wiper GP-Window​
Service Equipment And Supplies
Box GP-Tool​
Film GP​
Plate - Film GP​
Tool GP​
Part Number Index
