Caterpillar Wheel Loader 962H Parts Manual SEBP4283-01 2005
Brand: Caterpillar
Type of Machine: Wheel Loader
Model: Caterpillar 962H Wheel Loader
Serial Number:
M3G1-Up (Machine)
KHX1-Up (Engine)
FAK1-Up (Transmission)
CJF1-Up (Torque Converter)
Engine: Caterpillar C7 Engine
Part Number: SEBP4283-01
Publication Date: 2005
Number of Pages: 966 Pages
Repair Alternatives
Supplemental Coolant
Additives
English-Portuguese Parts
Nomenclature
Maintenance Parts
Index
Machine Arrangement
Chassis Ar
General Ar
Machine Ar
Waste Handling Ar
Engine Arrangement
Engine Ar-Complete
Engine Ar-Core
Installation Ar-Engine
Basic Engine
Camshaft Gp
Carrier Gp-Seal
Cover Gp-Cylinder Block
Cover Gp-Front Housing
Cover Gp-Valve Mechanism
Crankshaft Gp
Cylinder Block Gp
Cylinder Head As
Cylinder Head Gp
Damper & Pulley Gp
Drain Gp-Engine Oil
Fastener Gp-Damper & Pulley
Fastener Gp-Front Housing
Fastener Gp-Valve Cover
Fastener Gp-Valve Mechanism
Flywheel Gp
Gear Gp-Front
Housing Gp-Flywheel
Housing Gp-Front
Idler Gp-Belt
Lifter Gp-Valve
Lifting Gp-Engine
Mounting Gp-Alternator
Mounting Gp-Engine & Tmsn
Pan Gp-Oil
Piston & Rod Gp
Plug Gp-Cylinder Block
Plug Gp-Engine
Pulley Gp-Idler
Seal Gp-Crankshaft
Seal Gp-Flywheel Housing
Valve Mechanism Gp
Lubrication System
Adapter Gp-Oil Line
Breather Gp
Filler Gp-Engine Oil
Filter Gp-Engine Oil
Fumes Disposal Gp
Gauge Gp-Oil Level (Dipstick)
Lines Gp-Engine Oil
Lines Gp-Engine Oil Drain
Lines Gp-Turbocharger Oil
Pump Gp-Engine Oil
Cooler Gp-Engine Oil
Cooling Ar-High Ambient Temp
Elbow Gp-Water
Lines Gp-Water
Pump Gp-Water
Radiator & Fan Gp
Tank Gp-Radiator Top
Air Inlet And Exhaust System
Air Cleaner Gp
Cover Gp-Air Inlet
Elbow Gp-Air Inlet
Lines Gp-Aftercooler Air
Lines Gp-Air
Manifold Gp-Exhaust
Muffler Gp
Pipe Gp-Exhaust
Precleaner Gp
Turbocharger Gp
Fuel System
Filter & Lines Gp-Fuel
Filter Gp-Water Sep & Fuel
Injector Gp-Fuel
Lines Gp-Fuel
Lines Gp-Fuel Drain
Lines Gp-Injector Hyd Pump
Pump & Mtg Gp-Unit Inj Hyd
Pump Gp-Fuel Injection
Pump Gp-Fuel Prm & Prim Filter
Pump Gp-Unit Injector Hyd
Regulator Gp-Fuel Pressure
Tank Gp-Fuel
Water Sep & Fuel Prm Pump Gp
Electrical And Starting System
Alarm Gp
Alternator Gp-Charging
Battery & Wiring Gp
Control & Mtg Gpcommunication
Control & Mtg Gp-Engine Elek
Control Ar-Autodig
Control Gp-Autodig
Control Gp-Unprogrammed
Electrical Ar
Electronics Gpcommunication
Electronics Gp-Implement
Electronics Gp-Monitor
Electronics Gp-Power Train
Heater Gp-Jacket Water
Installation Arcommunication
Installation Ar-Security
Installation Gp-Security
Lamp Gp-Dome
Lamp Gp-Flood
Lamp Gp-Head & Signal
Lamp Gp-Signal
Lamp Gp-Stop & Tail
Lamp Gp-Warning Beacon
Lighting Ar-Roading
Lighting Ar-Signal
Lighting Gp-Flood
Lighting Gp-Flood & Signal
Lighting Gp-Roading
Lighting Gp-Warning Beacon
Plug Gp-Connector
Receptacle Gp-Auxiliary Start
Sensor & Mtg Gp-Lift Position
Sensor & Mtg Gp-Pressure
Sensor & Mtg Gp-Tilt Position
Sensor Gp-Engine
Sensor Gp-Position
Sensor Gp-Pressure
Sensor Gp-Speed
Sensor Gp-Temperature
Starting Aid Ar-Ether
Starting Aid Gp
Starting Aid Gp-Ether
Starting Motor Gp-Electric
Switch Gp-Bypass
Switch Gp-Dimmer
Switch Gp-Disconnect
Switch Gp-Magnetic
Switch Gp-Pressure
Switch Gp-Reversing Fan
Switch Gp-Ride Control
Switch Gp-Rocker
Switch Gp-Rotary
Switch Gp-Secondary
Steering
Switch Gp-Signal
Switch Gp-Toggle
Switch Gp-Transmission
Valve Gp-Ether Starting
Wiring Gp-Air Conditioner
Wiring Gp-Axle Monitoring
Wiring Gp-Cab
Wiring Gp-Chassis
Wiring Gp-Coupler
Wiring Gp-Electric Clutch
Wiring Gp-Engine
Wiring Gp-Ether Starting Aid
Wiring Gp-Front
Wiring Gp-Lighting
Wiring Gp-Open Rops
Wiring Gp-Secondary Steering
Wiring Gp-Sensor
Wiring Gp-Waste Handler
Power Train
Axle Ar-Fixed
Axle Ar-Oscillating
Brake & Planetary Gp
Control Gp-Transmission
Control Gp-Transmission Hyd
Cooler & Mtg Gp-Transmission
Cooler Ar-Axle Oil
Differential Gp
Differential Gp-Limited Slip
Differential Gp-Nospin
Drain Gp-Ecology
Filler Gp-Power Train Oil
Filter & Lines Gp-Transmission
Filter Gp-Oil
Gear Gp-Bevel & Pinion
Gear Gp-Output Transfer
Housing Gp-Fixed Axle
Housing Gp-Oscillating Axle
Lines Gp-Axle Oil Cooler
Lines Gp-Torque Conv Cooler
Mounting Gp-Axle
Mounting Gp-Axle Oil Cooler
Mounting Gp-Rim
Planetary Gp-Transmission
Power Train Ar
Pump & Mtg Gp-Axle Oil Cooler
Pump Gp-Transmission
Rim Ar
Rim Gp-Demountable
Shaft Gp-Drive
Slip Joint Gp
Spider & Bearing Gp
Tire & Rim Ar
Torque Converter & Housing
Gp
Torque Converter Gp
Transmission Ar
Universal Joint Gp
Valve Gp-Modulating
Valve Gp-Relief
Frame And Body
Actuator Gp-Hood Tilt
Actuator Gp-Power
Actuator Gp-Power Guard
Baffle Gp
Block Gp-Axle Osc Limiter
Box Gp-Battery
Counterweight Gp
Cover Gp-Bumper
Door Gp-Access
Fender Ar-Roading
Fender Gp
Fender Gp-Front
Fender Gp-Roading
Frame As-Loader
Frame As-Rear
Grill Gp-Radiator
Guard Gp-Articulation
Guard Gp-Axle Oil Cooler
Guard Gp-Axle Seal
Guard Gp-Drive Shaft
Guard Gp-Front
Guard Gp-Lighting
Guard Gp-Power Train
Hardware Gp-Loader Frame
Hardware Gp-Mounting
Hardware Gp-Rear Frame
Hitch Gp-Articulating
Hood & Guard Gp
Ladder Gp
Lines Gp-Grease
Link Gp-Steering Frame Lock
Panel Gp-Hood
Panel Gp-Side
Shield Gp-Engine Compartment
Step Gp
Support Gp-Air Inlet
Support Gp-Valve & Filter
Suppression Ar-Sound
Suppression Gp-Sound
Tilt Gp-Hood
Braking System
Accumulator Gp-Brake
Actuator Gp-Parking Brake
Base Gp-Foot Brake
Brake Gp-Parking
Control Gp-Foot Brake
Control Gp-Parking Brake
Control Gp-Service Brake
Valve Gp-Brake Control
Control Gp-Steering
Cylinder & Mtg Gp-Steering
Cylinder Gp-Hydraulic
Lines Gp-Secondary Steering
Lines Gp-Steering
Pump & Motor Gp-Sec Steering
Pump & Mtg Gp-Secondary
Steer
Pump Gp-Piston
Rotating Gp-Pump
Steering Ar-Secondary
Valve Gp-Pump Control
Valve Gp-Relief
Valve Gp-Secondary Steering
Valve Gp-Steering
Valve Gp-Steering Neutralizer
Accumulator Gp-Pilot Oil
Accumulator Gp-Ride Control
Control & Lines Gp-Fan
Control & Lines Gp-Ride
Control Ar-Fan
Control Ar-Ride
Control Gp-Electrohydraulic
Control Gp-Handle
Control Gp-Joystick
Cylinder & Seal Gp-Lift
Cylinder & Seal Gp-Tilt
Cylinder Gp-Coupler
Cylinder Gp-Lift
Cylinder Gp-Tilt
Filter Gp-Oil
Guard Gp-Lift Cylinder
Hydraulic Ar-2 Valve
Hydraulic Ar-3 Valve
Lines Gp-Coupler
Lines Gp-Front
Lines Gp-Hydraulic
Lines Gp-Hydraulic Oil Cooler
Lines Gp-Lift Cylinder
Lines Gp-Tilt Cylinder
Manifold Gp-Control
Manifold Gp-Valve
Motor Gp-Gear
Motor Gp-Piston
Mounting Gp-Hydraulic Tank
Pump & Mtg Gp-Brake & Hyd Fan
Pump & Mtg Gp-Hydraulic
Pump Gp-Piston
Rotating Gp-Motor
Rotating Gp-Pump
Tank Gp-Hydraulic
Valve & Mtg Gp-Main Control
Valve Gp-Check
Valve Gp-Check & Relief
Valve Gp-Control
Valve Gp-Diverter
Valve Gp-Drain
Valve Gp-Lowering Control
Valve Gp-Main Control
Valve Gp-Manual
Valve Gp-Pressure Reducing
Valve Gp-Relief
Valve Gp-Ride Control
Valve Gp-Shuttle
Valve Gp-Solenoid
Implements
Arm As-Lift
Control Gp-Bucket
Lift Ar
Work Tools
Adapter Gp-Tip
Arm Gp-Material Handling
Bucket As-General Purpose
Bucket As-Material Handling
Bucket As-Rock
Bucket Gp-General Purpose
Bucket Gp-Material Handling
Bucket Gp-Rock
Carriage Gp-Fork
Control Ar-Quick Coupler
Coupler Gp-Quick
Edge Gp-Cutting
Edge Gp-Segment
Frame Gp-Quick Coupler
Tip Gp-Extra Duty
Tip Gp-General Purpose
Tip Gp-Long
Tip Gp-Penetration
Tip Gp-Short
Operator Station
Adjuster Gp-Seat
Air Conditioner Ar
Air Conditioner Gp
Arm Gp-Window Wiper
Armrest Gp
Cab Ar-Enclosed Rops
Canopy Ar-Open Rops
Compressor Gp-Refrigerant
Condenser & Mtg Gprefrigerant
Control Gp-Monitor
Control Gp-Unprgmed
Monitor
Door Gp-Cab
Duct & Filter Gp-Air
Duct Gp-Air
Floor Gp-Sound Suppression
Guard Gp-Vandalism
Guard Gp-Window
Heater Gp-Cab
Horn Gp-Electric
Installation Gp-Controls
Installation Gp-Radio
Liner Gp-Cab
Lines Gp-Air Conditioner
Lines Gp-Cab Heater
Mirror Gp-Rear View
Module Gp-Quad Gauge
Module Gp-Speedometer &
Tach
Monitor Ar-Payload
Monitor Gp-Payload
Motor Gp-Window Wiper
Mounting Gp-Cab
Operator Ar-Enclosed Rops
Operator Ar-Open Rops
Pan Gp-Backrest
Panel Gp-Instrument
Pedal Gp-Governor
Radio Gp
Recliner Gp-Seat
Rops Gp-Enclosed
Rops Gp-Open
Seat Belt Gp
Seat Gp
Seat Gp-Suspension
Support Gp-Hydraulic
Control
Suppression Gp-Cab Sound
Suspension Gp-Seat
Visor Gp-Cab
Washer Gp-Window
Window Gp-Door
Wiper Gp-Window
Service Equipment And Supplies
Box Gp-Tool
Film Gp
Lines Gp-Diagnostic
Plate & Film Gp
Plate Gp-Axle Identification
Part Number Index
Brand: Caterpillar
Serial Number:
M3G1-Up (Machine)
KHX1-Up (Engine)
Repair Alternatives
Additives
Nomenclature
Maintenance Parts
Index
Machine Arrangement
Chassis Ar
General Ar
Machine Ar
Waste Handling Ar
Engine Arrangement
Engine Ar-Complete
Engine Ar-Core
Basic Engine
Camshaft Gp
Carrier Gp-Seal
Crankshaft Gp
Cylinder Block Gp
Cylinder Head As
Cylinder Head Gp
Damper & Pulley Gp
Drain Gp-Engine Oil
Flywheel Gp
Gear Gp-Front
Housing Gp-Flywheel
Housing Gp-Front
Idler Gp-Belt
Lifter Gp-Valve
Lifting Gp-Engine
Pan Gp-Oil
Piston & Rod Gp
Plug Gp-Engine
Pulley Gp-Idler
Seal Gp-Crankshaft
Valve Mechanism Gp
Lubrication System
Adapter Gp-Oil Line
Breather Gp
Fumes Disposal Gp
Lines Gp-Engine Oil
Pump Gp-Engine Oil
Elbow Gp-Water
Lines Gp-Water
Pump Gp-Water
Radiator & Fan Gp
Air Cleaner Gp
Cover Gp-Air Inlet
Elbow Gp-Air Inlet
Lines Gp-Air
Manifold Gp-Exhaust
Muffler Gp
Pipe Gp-Exhaust
Precleaner Gp
Turbocharger Gp
Fuel System
Injector Gp-Fuel
Lines Gp-Fuel
Lines Gp-Fuel Drain
Tank Gp-Fuel
Alarm Gp
Battery & Wiring Gp
Control Ar-Autodig
Control Gp-Autodig
Electrical Ar
Lamp Gp-Dome
Lamp Gp-Flood
Lamp Gp-Signal
Lamp Gp-Stop & Tail
Lighting Ar-Roading
Lighting Ar-Signal
Lighting Gp-Flood
Lighting Gp-Roading
Plug Gp-Connector
Sensor Gp-Engine
Sensor Gp-Position
Sensor Gp-Pressure
Sensor Gp-Speed
Starting Aid Gp
Switch Gp-Bypass
Switch Gp-Dimmer
Switch Gp-Magnetic
Switch Gp-Pressure
Switch Gp-Rocker
Switch Gp-Rotary
Switch Gp-Secondary
Steering
Switch Gp-Signal
Switch Gp-Toggle
Wiring Gp-Cab
Wiring Gp-Chassis
Wiring Gp-Coupler
Wiring Gp-Engine
Wiring Gp-Front
Wiring Gp-Lighting
Wiring Gp-Open Rops
Wiring Gp-Sensor
Power Train
Axle Ar-Fixed
Axle Ar-Oscillating
Cooler Ar-Axle Oil
Differential Gp
Drain Gp-Ecology
Filter Gp-Oil
Mounting Gp-Axle
Mounting Gp-Rim
Power Train Ar
Rim Ar
Rim Gp-Demountable
Shaft Gp-Drive
Slip Joint Gp
Spider & Bearing Gp
Tire & Rim Ar
Gp
Torque Converter Gp
Transmission Ar
Universal Joint Gp
Valve Gp-Modulating
Valve Gp-Relief
Frame And Body
Actuator Gp-Power
Baffle Gp
Box Gp-Battery
Counterweight Gp
Cover Gp-Bumper
Door Gp-Access
Fender Ar-Roading
Fender Gp
Fender Gp-Front
Fender Gp-Roading
Frame As-Loader
Frame As-Rear
Grill Gp-Radiator
Guard Gp-Axle Seal
Guard Gp-Front
Guard Gp-Lighting
Hood & Guard Gp
Ladder Gp
Lines Gp-Grease
Panel Gp-Hood
Panel Gp-Side
Step Gp
Tilt Gp-Hood
Braking System
Base Gp-Foot Brake
Brake Gp-Parking
Control Gp-Steering
Lines Gp-Steering
Steer
Pump Gp-Piston
Rotating Gp-Pump
Valve Gp-Relief
Valve Gp-Steering
Control Ar-Fan
Control Ar-Ride
Control Gp-Handle
Control Gp-Joystick
Cylinder Gp-Coupler
Cylinder Gp-Lift
Cylinder Gp-Tilt
Filter Gp-Oil
Lines Gp-Coupler
Lines Gp-Front
Lines Gp-Hydraulic
Manifold Gp-Control
Manifold Gp-Valve
Motor Gp-Gear
Motor Gp-Piston
Pump Gp-Piston
Rotating Gp-Motor
Rotating Gp-Pump
Tank Gp-Hydraulic
Valve Gp-Check
Valve Gp-Control
Valve Gp-Diverter
Valve Gp-Drain
Valve Gp-Manual
Valve Gp-Relief
Valve Gp-Shuttle
Valve Gp-Solenoid
Implements
Arm As-Lift
Control Gp-Bucket
Lift Ar
Work Tools
Adapter Gp-Tip
Bucket As-Rock
Bucket Gp-Rock
Carriage Gp-Fork
Coupler Gp-Quick
Edge Gp-Cutting
Edge Gp-Segment
Tip Gp-Extra Duty
Tip Gp-Long
Tip Gp-Penetration
Tip Gp-Short
Operator Station
Adjuster Gp-Seat
Air Conditioner Ar
Air Conditioner Gp
Arm Gp-Window Wiper
Armrest Gp
Canopy Ar-Open Rops
Control Gp-Monitor
Control Gp-Unprgmed
Monitor
Door Gp-Cab
Duct Gp-Air
Guard Gp-Vandalism
Guard Gp-Window
Heater Gp-Cab
Horn Gp-Electric
Liner Gp-Cab
Lines Gp-Cab Heater
Mirror Gp-Rear View
Tach
Monitor Ar-Payload
Monitor Gp-Payload
Mounting Gp-Cab
Pan Gp-Backrest
Panel Gp-Instrument
Pedal Gp-Governor
Radio Gp
Recliner Gp-Seat
Rops Gp-Enclosed
Rops Gp-Open
Seat Belt Gp
Seat Gp
Seat Gp-Suspension
Control
Suspension Gp-Seat
Visor Gp-Cab
Washer Gp-Window
Window Gp-Door
Wiper Gp-Window
Box Gp-Tool
Film Gp
Lines Gp-Diagnostic
Plate & Film Gp
Part Number Index
- CAT 416D Parts Manual
- CAT 420D Parts Manual
