Caterpillar Skid Steer Loader 216B 226B 232B 242B Parts Manual SEBP3770-14 2006
Brand: Caterpillar
Type of Machine: Skid Steer Loader
Model: Caterpillar 216B, 226B, 232B, 242B Skid Steer Loader
Serial Number:
BXM1-Up (Machine)
MJH1-Up (Machine)
RLL1-Up (Machine)
SCH1-Up (Machine)
CSD1-Up (Engine)
GGA1-Up (Engine)
Engine: 3024C
Part Number: SEBP3770-14
Publication Date: 2006
Number of Pages: 960 Pages
Machine Arrangement
Chassis Ar
Common Ar
Conversion Ar-Machine
Engine Arrangement
Engine Ar
Engine Ar- Primary
Installation Ar- Engine
Basic Engine
Camshaft Gp
Cover Gp- Valve Mechanism
Crankshaft Gp
Cylinder Block Gp
Cylinder Head Gp
Drain Gp- Engine Oil
Flywheel Gp
Guard Gp- Belt
Housing Gp- Flywheel
Housing Gp- Front
Lifting Gp- Engine
Mounting Gp- Engine
Mounting Gp- Fan
Pan Gp- Oil
Piston & Rod Gp
Pulley Gp- Crankshaft
Pulley Gp- Water Pump
Valve Mechanism Gp
Lubrication System
Filter Gp- Engine Oil
Cooler Gp- Fltr Base & Eng Oil
Mounting Gp- Rad & Oil Cooler
Pump Gp- Water
Radiator & Hyd Oil Cooler Gp
Radiator & Oil Cooler Mtg Gp
Air Inlet And Exhaust System
Air Cleaner Gp
Lines Gp- Air
Manifold Gp- Exhaust
Muffler & Mounting Gp
Muffler Gp
Turbocharger Gp
Fuel System
Cable Gp- Governor Control
Control Gp- Governor
Filter Gp- Water Sep & Fuel
Governor Gp
Lines Gp- Fuel Prm & Filter
Pump & Mtg Gp- Fuel Transfer
Pump Gp- Fuel Injection
Pump Gp- Fuel Prm & Prim Filter
Electrical And Starting System
Alternator Gp- Charging
Battery Gp
Connection Gp- Electrical
Control Gp- Interlock
Conversion Ar- Non- Roading
Cover Gp- Fuse Panel
Electronics Gp- Implement
Fastener Gp- Wiring Harness
Glow Plug Gp
Heater Gp- Jacket Water
Installation Gp- Security
Kit-Work Tool Wiring
Lamp Gp- Flood
Lamp Gp- Head & Signal
Lamp Gp- Stop & Tail
Lighting Gp- Flood
Lighting Gp- Roading
Lighting Gp- Stop & Tail
Lighting Gp- Warning Beacon
Sensor Gp- Temp & Press
Service Gp- Machine
Starting Motor Gp- Electric
Switch Gp- Pressure
Warning Gp- Backup
Wiring Gp- Air Conditioner
Wiring Gp- Chassis
Wiring Gp- Engine
Wiring Gp- Horn
Wiring Gp- Machine
Wiring Gp- Rear Lighting
Wiring Gp- Work Tool
Power Train
Axle Gp
Control Gp- Parking Brake
Drive Gp- Tandem
Filter & Lines Gp- Hydraulic
Filter Gp- Oil
Lines Gp- Hydrostatic
Manifold Gp- Return
Motor & Mtg Gp- Hydrostatic
Motor Gp- Piston
Mounting Gp- Pump
Power Train Ar
Pump & Mtg Gp- Hydrostatic
Pump Gp- Piston
Tire & Rim Gp
Valve & Mtg Gp- Solenoid
Valve Gp- Solenoid
Wheel & Tire Ar
Frame And Body
Bumper Gp
Conversion Ar- Roading
Conversion Gp- Roading
Counterweight Gp
Enclosure Gp- Engine
Frame & Mtg Gp- Machine
Frame Gp- Blade
Guide Gp- Lines
Kit- Roading Conversion
Lifting Gp- Machine
Mirror & Mtg Gp- Rear View
Mounting Gp- Registration
Mounting Gp- Roading Lights
Suppression Gp- Sound
Accumulator & Mtg Gp- Hydraulic
Adapter Gp- Oil Line
Control Gp- Handle
Control Gp- Pilot Operated Hyd
Cylinder & Mtg Gp- Angle Blade
Cylinder & Mtg Gp- Lift Arm
Cylinder Gp- Bucket
Cylinder Gp- Coupler
Cylinder Gp- Grapple
Cylinder Gp- Hydraulic
Cylinder Gp- Lift
Cylinder Gp- Tilt
Fitting Gp- Hydraulic
Handle Gp- Modular
Hydraulic Ar
Kit-High Flow Conversion
Kit-Quick Coupler Conversion
Lines Gp- Bucket
Lines Gp- Connecting
Lines Gp- Grapple
Lines Gp- Hydraulic Fan
Lines Gp- Hydraulic Oil Cooler
Lines Gp- Lift Cylinder
Lines Gp- Load Control Valve
Lines Gp- Pilot
Lines Gp- Pump
Lines Gp- Tilt Cylinder
Lines Gp- Work Tool
Manifold & Mtg Gp- Control
Manifold Gp- Control
Motor & Mtg Gp- Hydraulic Fan
Motor Gp- Gear
Mounting Gp- Cylinder
Plug Gp- Pilot Valve
Pump & Mtg Gp- Work Tool
Pump Gp- Gear
Tank & Mtg Gp- Hydraulic
Tank Gp- Hydraulic
Valve & Lines Gp- Coupler
Valve & Mtg Gp- Control
Valve & Mtg Gp- Diverter
Valve Gp- Control
Valve Gp- Diverter
Valve Gp- Pilot
Valve Gp- Relief
Valve Gp- Solenoid
Work Tools
Arm Gp- Material Handling
Blade Ar
Blade Gp- Angling
Bucket Ar- Grapple
Bucket Ar-Multipurpose
Bucket Gp- Dirt
Bucket Gp- General Purpose
Bucket Gp- Grapple
Bucket Gp- Light Material
Bucket Gp- Multipurpose
Bucket Gp- Utility
Carriage & Fork Ar
Conversion Ar- Quick Coupler
Conversion Gp- Work Tool
Coupler Ar- Quick
Coupler Gp- Quick
Cover Gp- Lines
Cylinder & Link Gp- Coupler
Edge Gp- Bit & Cutting
Edge Gp- Cutting
Fork Ar- Grapple
Fork Gp- Grapple
Fork Gp- Pallet
Fork Gp- Utility
Grapple & Cylinder Gp- Utility
Grapple Gp- Utility
Handle & Pin Gp- Coupler
Handle Gp- Coupler
Kit- Roading Plate & Mounting
Link Gp- Coupler
Lock Gp- Quick Coupler
Plate Gp- Roading
Pump Gp- Diaphragm
Spring Gp- Blade
Step Gp- Material Handling Arm
Strainer Gp- Water
Tank & Mtg Gp- Water
Tank Gp- Water
Tooth Gp- Uni
Operator Station
Accumulator Gp- Refrigerant
Air Conditioner & Mounting Gp
Air Conditioner Ar
Air Conditioner Gp
Armrest & Mounting Gp
Armrest Gp
Box Gp- Storage
Cab Ar- Enclosed Rops
Cab Gp- Enclosed Rops
Compressor & Motor Gp- Refrig
Compressor & Mtg Gp- Refrig
Condenser & Mtg Gp- Refrigerant
Coupling Gp- Drive
Cover Gp- Console
Cover Gp- Instrument Panel
Door & Mtg Gp- Cab
Door Gp- Cab
Duct & Control Gp
Frame Gp- Window
Gauge & Warning Gp
Guard Gp- Rops/ Fops
Handhold Gp
Heater & Mtg Gp- Cab
Heater Ar- Cab
Heater Gp- Cab
Housing As- Side
Installation Ar
Installation Gp
Kit- Cab Door & Mounting
Kit-Cab Seal
Lever Gp- Governor
Liner Gp- Cab
Liner- Cab
Lines Gp- Air Conditioner
Lines Gp- Heater
Literature Gp
Mirror Gp- Rear View
Module Gp- Warning Indicator
Mounting Gp- Rops
Panel Ar- Instrument
Panel Gp- Instrument
Panel Gp- Side
Pedal Gp- Governor
Platform Gp- Operator
Seal Gp- Cab
Spring Gp- Gas
Suspension Gp- Seat
Visor Gp- Cab
Window Gp- Cab
Service Equipment And Supplies
Film Gp
Plate & Film Gp
Part Number Index
Brand: Caterpillar
Serial Number:
BXM1-Up (Machine)
MJH1-Up (Machine)
RLL1-Up (Machine)
SCH1-Up (Machine)
CSD1-Up (Engine)
GGA1-Up (Engine)
Engine: 3024C
Machine Arrangement
Chassis Ar
Common Ar
Engine Arrangement
Engine Ar
Engine Ar- Primary
Basic Engine
Camshaft Gp
Crankshaft Gp
Cylinder Block Gp
Cylinder Head Gp
Flywheel Gp
Guard Gp- Belt
Housing Gp- Front
Lifting Gp- Engine
Mounting Gp- Engine
Mounting Gp- Fan
Pan Gp- Oil
Piston & Rod Gp
Valve Mechanism Gp
Lubrication System
Pump Gp- Water
Air Cleaner Gp
Lines Gp- Air
Muffler Gp
Turbocharger Gp
Fuel System
Governor Gp
Battery Gp
Glow Plug Gp
Lamp Gp- Flood
Lighting Gp- Flood
Service Gp- Machine
Switch Gp- Pressure
Warning Gp- Backup
Wiring Gp- Chassis
Wiring Gp- Engine
Wiring Gp- Horn
Wiring Gp- Machine
Power Train
Axle Gp
Drive Gp- Tandem
Filter Gp- Oil
Manifold Gp- Return
Motor Gp- Piston
Mounting Gp- Pump
Power Train Ar
Pump Gp- Piston
Tire & Rim Gp
Valve Gp- Solenoid
Wheel & Tire Ar
Frame And Body
Bumper Gp
Counterweight Gp
Frame Gp- Blade
Guide Gp- Lines
Lifting Gp- Machine
Control Gp- Handle
Cylinder Gp- Bucket
Cylinder Gp- Lift
Cylinder Gp- Tilt
Handle Gp- Modular
Hydraulic Ar
Lines Gp- Bucket
Lines Gp- Grapple
Lines Gp- Pilot
Lines Gp- Pump
Lines Gp- Work Tool
Motor Gp- Gear
Pump Gp- Gear
Tank Gp- Hydraulic
Valve Gp- Control
Valve Gp- Diverter
Valve Gp- Pilot
Valve Gp- Relief
Valve Gp- Solenoid
Work Tools
Blade Ar
Blade Gp- Angling
Bucket Ar- Grapple
Bucket Gp- Dirt
Bucket Gp- Grapple
Bucket Gp- Utility
Carriage & Fork Ar
Coupler Ar- Quick
Coupler Gp- Quick
Cover Gp- Lines
Edge Gp- Cutting
Fork Ar- Grapple
Fork Gp- Grapple
Fork Gp- Pallet
Fork Gp- Utility
Grapple Gp- Utility
Handle Gp- Coupler
Link Gp- Coupler
Plate Gp- Roading
Pump Gp- Diaphragm
Spring Gp- Blade
Strainer Gp- Water
Tank Gp- Water
Tooth Gp- Uni
Operator Station
Air Conditioner Ar
Air Conditioner Gp
Armrest Gp
Box Gp- Storage
Coupling Gp- Drive
Cover Gp- Console
Door & Mtg Gp- Cab
Door Gp- Cab
Duct & Control Gp
Frame Gp- Window
Gauge & Warning Gp
Handhold Gp
Heater Ar- Cab
Heater Gp- Cab
Housing As- Side
Installation Ar
Installation Gp
Kit-Cab Seal
Lever Gp- Governor
Liner Gp- Cab
Liner- Cab
Lines Gp- Heater
Literature Gp
Mounting Gp- Rops
Panel Gp- Side
Pedal Gp- Governor
Seal Gp- Cab
Spring Gp- Gas
Suspension Gp- Seat
Visor Gp- Cab
Window Gp- Cab
Film Gp
Plate & Film Gp
Part Number Index
- CAT 416D Parts Manual
- CAT 420D Parts Manual
