Caterpillar On-Highway Engine C-11 C-13 Specification SENR9702-05
Brand: Caterpillar
Type of Machine: On-Highway Engine
Type of Manual: Specification
Model: Caterpillar C-11 C-13 On-Highway Engine
Serial Number: KCA1-Up ; KCB1-Up ; JAM1-Up
Part Number: SENR9702-05
Publication Date: 2005
Number of Pages: 48 Pages
Specifications Section
Engine Design
Fuel Transfer Pump
Electronic Unit Injector
Electronic Unit Injector Mechanism
Electronic Unit Injector Rocker Arm
Electronic Unit Injector Wiring
Lifter Group
RockerShaft
Valve Mechanism
Cylinder Head Valves
CAT Compression Brake
Turbocharger
Air Lines
Exhaust Manifold
Camshaft
Engine Oil Filter Base
Engine Oil Cooler
Engine Oil Pump
Engine Oil Pan
Precooler
Water Temperature Regulator Housing
Cylinder Liner
Cylinder Liner Projection
CrankshaftSeals
Connecting Rod Bearing Journal
Main Bearing Journal
Connecting Rod
Piston and Rings
Piston Cooling Jet
Housing (Front)
Gear Group (Front)
Gear Group (Rear)
Flywheel Housing
Engine to Transmission Adapter
Belt Tensioner
Electric Starting Motor
Coolant Temperature Sensor
Fuel Temperature Sensor
Engine Oil Pressure Sensor
Boost Pressure Sensor
Atmospheric Pressure Sensor
Inlet Manifold Temperature Sensor
Speed/Timing Sensor
Index Section
Index
Brand: Caterpillar
Engine Design
Fuel Transfer Pump
Lifter Group
RockerShaft
Valve Mechanism
Turbocharger
Air Lines
Exhaust Manifold
Camshaft
Engine Oil Cooler
Engine Oil Pump
Engine Oil Pan
Precooler
Cylinder Liner
CrankshaftSeals
Connecting Rod
Piston and Rings
Piston Cooling Jet
Housing (Front)
Gear Group (Front)
Gear Group (Rear)
Flywheel Housing
Belt Tensioner
Speed/Timing Sensor
Index Section
Index
- CAT 416D Parts Manual
- CAT 420D Parts Manual
