Caterpillar Load Haul Dump R1600H Parts Manual CCRC6406-11
Brand: Caterpillar
Type of Machine: Load Haul Dump
Model: Caterpillar R1600H Load Haul Dump
9SD1-Up (Machine)
TXE1-Up (Engine)
KSS1-Up (Transmission)
6KT1-Up (Torque Converter)
Part Number: CCRC6406-11
Publication Date: 2015
Number of Pages: 828 Pages
GENERAL INFORMATION
REPAIR ALTERNATIVES
SUPPLEMENTAL COOLANT ADDITIVES
MAINTENANCE PARTS
INDEX
MACHINE ARRANGEMENT
Brand: Caterpillar
9SD1-Up (Machine)
TXE1-Up (Engine)
GENERAL INFORMATION
REPAIR ALTERNATIVES
MAINTENANCE PARTS
INDEX
MACHINE ARRANGEMENT
CHASSIS AR
COMMON AR
ENGINE ARRANGEMENTENGINE AR
ENGINE AR-COMPLETE
ENGINE AR-CORE
INSTALLATION AR-ENGINE
BASIC ENGINEBASE GP-VALVE COVER
CAMSHAFT GP
COVER GP-FLYWHEEL HOUSING
COVER GP-FRONT HOUSING
COVER GP-VALVE MECHANISM
CRANKSHAFT GP
CYLINDER BLOCK AS
CYLINDER BLOCK GP
CYLINDER HEAD AS
CYLINDER HEAD GP
DAMPER GP
DRIVE GP-FAN
FASTENER GP-CYLINDER HEAD
FASTENER GP-DAMPER & PULLEY
FASTENER GP-FLYWHEEL
FLYWHEEL GP
GEAR GP-FRONT
HOUSING GP-FLYWHEEL
HOUSING GP-FRONT
KIT-FRONT COVER GASKET
LIFTER GP-VALVE
LIFTING GP-ENGINE
MOUNTING GP-ALTERNATOR
MOUNTING GP-ENGINE
MOUNTING GP-FAN DRIVE
MOUNTING GP-VALVE MECHANISM
PAN GP-OIL
PISTON & ROD GP
PLUG GP-CYLINDER BLOCK
PLUG GP-ENGINE
PULLEY GP-CRANKSHAFT
PULLEY GP-FAN & ALT DRIVE
ROCKER ARM GP
SEAL GP-CRANKSHAFT
SUPPORT GP-ENGINE
VALVE MECHANISM GP
LUBRICATION SYSTEMBASE GP-OIL FILTER
BREATHER GP
DRAIN GP-HIGH SPEED FLUID
FILLER GP-ENGINE OIL
FILTER GP-ENGINE OIL
FUMES DISPOSAL GP
GAUGE GP-OIL LEVEL (DIPSTICK)
LINES GP-ENGINE OIL DRAIN
LINES GP-TURBOCHARGER OIL
PUMP GP-ENGINE OIL
COOLING SYSTEMCOOLER GP-ENGINE OIL
FAN & GUARD GP-BLOWER
HOUSING & REGULATOR GP
LINES GP-OIL COOLER
LINES GP-TURBOCHARGER WATER
LINES GP-WATER
PLUG GP-WATER LINES
PUMP GP-WATER
RADIATOR & AFTERCOOLER GP
RADIATOR & MOUNTING GP
RADIATOR GP
AIR INLET AND EXHAUST SYSTEMAFTERCOOLER GP-AIR
AIR CLEANER GP
EXHAUST GP-PURIFIER
FILTER & MTG GP-DPF
KIT-AIR CLEANER
LINES GP-AIR
MANIFOLD GP-EXHAUST
MANIFOLD GP-INLET
TURBOCHARGER GP
FUEL SYSTEMADAPTER GP-FAST FILL FUEL
ADAPTER GP-FUEL FILL
BOWL GP-WATER COLLECTION
CONTROL GP-GOVERNOR
COOLER GP-FUEL
FILTER GP-SECONDARY FUEL
FITTING GP-QUICK DISCONNECT
INJECTOR GP-FUEL
KIT-INJECTOR
LINES GP-FUEL
MOUNTING GP-FILTER
PUMP GP-FUEL INJECTION
PUMP GP-FUEL PRIMING
PUMP GP-FUEL PRM & PRIM FILTER
PUMP GP-FUEL TRANSFER
SHUTOFF GP-MANUAL
VALVE GP-CHECK
ELECTRICAL AND STARTING SYSTEMALARM GP
ALTERNATOR GP-CHARGING
BATTERY & WIRING GP
BOX GP-CONTROL
CONTROL & MTG GP-ENGINE ELEK
CONTROL AR-COMMUNICATION
CONTROL GP-COMMUNICATION
ELECTRICAL AR
ELECTRONICS GP-MACHINE
ELECTRONICS GP-MONITOR
ELECTRONICS GP-POWER TRAIN
FUSE GP
GUARD GP-ALTERNATOR
HARNESS AS-CAB
HARNESS AS-CONTROL
HARNESS AS-ENGINE
HARNESS AS-FRONT
HARNESS AS-HEATER & AIR COND
HARNESS AS-LIGHTING
HARNESS AS-MONITOR
HARNESS AS-MOTOR
HARNESS AS-PANEL
HARNESS AS-REAR
HARNESS AS-SENSOR
HARNESS AS-SOLENOID
HARNESS AS-SWITCH
HARNESS AS-TRANSMISSION
HARNESS AS-WIRING
LAMP GP-DOME
LAMP GP-FLOOD
LAMP GP-HEAD
LAMP GP-SIGNAL
LIGHTING AR
LIGHTING GP-CAB
LIGHTING GP-FLOOD
LIGHTING GP-FRONT
LIGHTING GP-REAR
LIGHTING GP-STOP
MOTOR GP-ELECTRIC
PLATE AS-BRUSH
SENSOR & MOUNTING GP
SENSOR & MTG GP-PRESSURE
SENSOR GP-ENGINE
SENSOR GP-LIQUID LEVEL
SENSOR GP-POSITION
SENSOR GP-PRESSURE
SENSOR GP-SPEED
SENSOR GP-TEMPERATURE
STARTING MOTOR GP-ELECTRIC
SUPPRESSOR AS-ARC
SWITCH GP-DISCONNECT
SWITCH GP-MAGNETIC
SWITCH GP-PRESSURE
SWITCH GP-PUSH BUTTON
SWITCH GP-ROTARY
SWITCH GP-SHUTDOWN
SWITCH GP-TRANSMISSION
WARNING GP-BACKUP
WIRING GP-CAB
WIRING GP-COMMUNICATION
WIRING GP-ELECTRONIC CONTROL
WIRING GP-ENGINE
WIRING GP-FRONT
WIRING GP-PANEL
WIRING GP-REAR
WIRING GP-STEERING
WIRING GP-TORQUE CONVERTER
WIRING GP-TRANSMISSION
WIRING GP-UNIT INJECTOR
POWER TRAINAXLE AR-FIXED
AXLE AR-OSCILLATING
AXLE GP-FIXED
AXLE GP-OSCILLATING
CASE & PARTS GP-PLANETARY
COOLER AR-AXLE OIL
COOLER GP-TRANSMISSION OIL
CORE GP-OIL COOLER
COVER GP-SHIPPING
DIFFERENTIAL & BEVEL GEAR GP
DIFFERENTIAL GP
DIFFERENTIAL GP-NOSPIN
DRAIN GP-ECOLOGY
FILLER GP-POWER TRAIN OIL
FILTER & LINES GP-TRANSMISSION
FILTER GP-OIL
GEAR & CASE GP-TRANSFER
GEAR GP-BEVEL & PINION
HOUSING GP-AXLE
HOUSING GP-TORQUE CONVERTER
LINES GP-AXLE OIL COOLER
LINES GP-AXLE VENT
LINES GP-TORQUE CONVERTER
LINES GP-TRANSMISSION OIL
MOUNTING GP-AXLE
PLANETARY GP-TRANSMISSION
POWER TRAIN AR
PUMP & MTG GP-TRANSMISSION
PUMP GP-GEAR
PUMP GP-TRANSMISSION
RETAINER GP-WHEEL RIM
RIM AR
RIM GP-DEMOUNTABLE
SHAFT GP-DRIVE
SLIP JOINT GP
SUPPORT GP-TRANSMISSION
TIRE GP
TORQUE CONVERTER & HOUSING GP
TORQUE CONVERTER & UPDRIVE AR
TORQUE CONVERTER GP
TRANSMISSION AR
TRANSMISSION AR-COMPLETE
UNIVERSAL JOINT GP
VALVE GP-BYPASS
VALVE GP-DRAIN
VALVE GP-LOCKUP CLUTCH & SOL
VALVE GP-RELIEF
VALVE GP-SELECTOR
VALVE GP-SELECTOR & PRESS CONT
VALVE GP-SOLENOID
VALVE GP-TRANSMISSION CONTROL
WHEEL & FINAL DRIVE GP
FRAME AND BODYBAR GP-WEAR
COVER GP-ACCESS
COVER GP-DECK
COVER GP-RADIATOR
DRAWBAR GP
FENDER GP-FRONT
FENDER GP-REAR
FILTER GP-GREASE
FIREWALL GP
FRAME GP-FRONT
FRAME GP-REAR
GRILL GP-RADIATOR
GUARD GP-CRANKCASE
GUARD GP-DRIVE SHAFT
GUARD GP-LIGHTING
HANDRAIL GP
HITCH GP-ARTICULATING
HOOD GP
LINES GP-CENTRAL LUBRICATION
LINES GP-FIRE SUPPRESSION
LINES GP-GREASE
LINES GP-LUBRICATION
LINK GP-STEERING FRAME LOCK
LUBRICATION AR-AUTOMATIC
LUBRICATION AR-CENTRAL
LUBRICATION AR-MANUAL
PIN GP-DRAWBAR
PUMP GP-LUBRICATION
TREAD GP-NON-SKID
VALVE GP-LUBE DISTRIBUTION
BRAKING SYSTEMACCUMULATOR GP-BRAKE
ACCUMULATOR GP-HYDRAULIC
BRAKE AR
BRAKE GP
BRAKE GP-SERVICE & PARKING
BRAKE RELEASE AR
CONTROL GP-FOOT BRAKE
CYLINDER GP-BRAKE RELEASE
LINES GP-BRAKE
LINES GP-BRAKE RELEASE
LINES GP-PARKING BRAKE
LINES GP-SERVICE BRAKE
VALVE GP-PARKING BRAKE
VALVE GP-PRESSURE REDUCING
STEERING SYSTEMCONTROL GP-STEERING
CYLINDER & MTG GP-STEERING
CYLINDER & SEAL GP-STEERING
CYLINDER GP-STEERING
LINES GP-SECONDARY STEERING
LINES GP-STEERING
LINES GP-STEERING NEUTRALIZER
PUMP & MOTOR GP
PUMP & MTG GP-SECONDARY STEER
PUMP GP-GEAR
STEERING AR
VALVE & MTG GP-STEERING
VALVE GP-DIVERTER
VALVE GP-PILOT
VALVE GP-RELIEF
VALVE GP-STEERING NEUTRALIZER
HYDRAULIC SYSTEMACCUMULATOR GP-RIDE CONTROL
BLOCK GP-HYDRAULIC
CARTRIDGE GP-VANE PUMP
COOLER GP-HYDRAULIC OIL
CYLINDER & SEAL GP-EJECTOR
CYLINDER GP-EJECTOR
CYLINDER GP-LIFT
CYLINDER GP-TILT
GAUGE GP-SIGHT
HYDRAULIC AR
HYDRAULIC AR-2 VALVE
HYDRAULIC AR-3 VALVE
LINES GP-BUCKET
LINES GP-HYDRAULIC
LINES GP-IMPLEMENT
LINES GP-LIFT CYLINDER
LINES GP-PILOT
LINES GP-RIDE CONTROL
LINES GP-TILT CYLINDER
MOUNTING GP-HYDRAULIC TANK
PUMP & MTG GP-IMPLEMENT
PUMP GP-VANE
TANK & FILTER GP-HYDRAULIC
TANK GP-HYDRAULIC
VALVE & MTG GP-CONTROL
VALVE GP-AUXILIARY
VALVE GP-BANK 1
VALVE GP-CONTROL
VALVE GP-PILOT
VALVE GP-RELIEF
VALVE GP-SHUTTLE
VALVE GP-SOLENOID
IMPLEMENTSARM GP-LIFT
BRACE GP
CONTROL GP-BUCKET
WORK TOOLSBUCKET & VALVE AR-EJECTOR
BUCKET AR-EJECTOR
BUCKET AS
BUCKET AS-EJECTOR
BUCKET GP-EJECTOR
EDGE GP-CUTTING
PLATE GP-WEAR
PROTECTOR GP-WEAR
OPERATOR STATIONAIR CONDITIONER & MOUNTING GP
AIR CONDITIONER AR
AIR CONDITIONER GP
ARMREST GP
CAB AR
CAB AR-ENCLOSED ROPS
CAB GP
CAB GP-ENCLOSED ROPS
COMPARTMENT GP-LITERATURE
COMPRESSOR GP-REFRIGERANT
CONDENSER GP-REFRIGERANT
CONTROL GP-HANDLE
CONTROL GP-MONITOR
CONTROL GP-PILOT OPERATED HYD
CONTROL GP-STEERING & XMSN
CONTROL GP-TRANSMISSION
COVER GP-OPERATOR MODULE
COVER GP-SEAT
DOOR GP-CAB
DUCT GP-CAB AIR
FAN GP
FOOTREST GP
GUARD GP-WINDOW
HANDHOLD GP
LATCH GP
LATCH GP-CAB DOOR
LINER GP-CAB
LINES GP-AIR CONDITIONER
LINES GP-HEATER
LINES GP-WINDOW WASHER
MONITOR & MOUNTING GP
MONITOR AR-PAYLOAD
MONITOR GP-PAYLOAD
MOTOR GP-WINDOW WIPER
MOUNTING GP-PLATFORM
MOUNTING GP-ROPS
OPERATOR AR
OPERATOR AR-ENCLOSED ROPS
PANEL GP-INSTRUMENT
PEDAL GP-BRAKE
PEDAL GP-GOVERNOR
PEDAL GP-THROTTLE
PRESSURIZER & MOUNTING GP
PRESSURIZER GP-CAB
SEAT & MOUNTING GP
SEAT BELT GP
SEAT GP-SUSPENSION
TANK GP-WINDOW WASHER
TOOL GP-ELECTRONIC
WINDOW GP-CAB
WIPER GP-WINDOW
REMOTE CONTROL SYSTEMCONTROL AR-REMOTE
INTERFACE & MOUNTING GP
INTERFACE AR-REMOTE CONTROL
LIGHTING GP-WARNING
MANIFOLD & VALVE GP
MOUNTING GP-RECEIVER
WIRING GP-REMOTE CONTROL
SERVICE EQUIPMENT AND SUPPLIESCONVERSION AR-MINE TRANSFER
FILM GP
FILM GP-INTERNATIONAL
FILM GP-U.S.
HOOK GP-RECOVERY
LIFTING GP
PLATE & FILM GP
PUMP GP-ELECTRIC DRIVE
SERVICE GP-FILTER
TOOL GP
TOOL GP-DIAGNOSTIC
VALVE GP-FLUID SAMPLING
PART NUMBER INDEX
- CAT 416D Parts Manual
- CAT 420D Parts Manual
