Caterpillar Forklift V300C Chassis Mast Engine 3208 Europe Parts Catalog SEBN2672
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar V300C Chassis Mast Engine 3208 Forklift
Region: Europe
Part Number: SEBN2672
Number of Pages: 601 Pages
001_ENGINE AR-PART 1 OF 3
002_ENGINE AR-PART 2 OF 3 1W6926-PAGE 2, 2N9305-PAGE 81, 8C5908-PAGE 80
003_ENGINE AR-PART 3 OF 3 7N6771-PAGE 29
004_CYLINDER BLOCK GP FOR FIELD REPLACEMENT ORDER 9N3763-PAGE 8
005_SERVICE GP-CYLINDER BLOCK FIELD REPLACEMENT FOR 9N3761-PAGE 7
006_COVER GP-CYLINDER BLOCK
007_CRANKSHAFT GP FOR FIELD REPLACEMENT OF 9N6221 CRANKSHAFT ORDER 2W0085-PAGE 10
008_CRANKSHAFT GP_R FIELD REPLACEMENT FOR 9N6221-PAGE 9 (PART OF 9N6222)
009_SEAL GP-CRANKSHAFT
010_HOUSING GP-FLYWHEEL
011_FLYWHEEL GP
012_COVER GP-FLYWHEEL HOUSING
013_PISTON AND ROD GP 7W3900-PAGE 14
014_PISTON GP PART OF 7W3901 PISTON AND ROD
015_CAMSHAFT GP-SINGLE
016_CYLINDER HEAD GP 1W4241-PAGE 17
017_CYLINDER HEAD AS FOR FIELD REPLACEMENT ORDER 7C3807-PAGE 19 PART OF 1W4241, 7C3807 CYLINDER HEADS
018_CYLINDER HEAD AS 7C2296-PAGE 18 FIELD REPLACEMENT FOR 7C2296-PAGE 18
019_PANEL GP-CYLINDER BLOCK FOR FIELD REPLACEMENT ORDER 9N6434-PAGE 21
020_PANEL GP-SOUND SUPPRESSION (CYLINDER BLOCK) FIELD REPLACEMENT FOR 9L6560-PA
021_VALVE MECHANISM GP
022_COVER GP-VALVE MECHANISM 4W6974-PAGE 24, 4W7066-PAGE 24
023_COVER GP-VALVE MECHANISM PART OF 9L6978 COVER-VALVE MECHANISM
024_COVER GP-VALVE MECHANISM 7C6353-PAGE 49 PART OF 9L6978 COVER-VALVE MECHANISM
025_HOUSING GP-FRONT
026_COVER GP-FRONT HOUSING
027_DAMPER AND PULLEY GP
028_PAN GP-OIL
029_LIFTING GP
030_PAINT AND LUBRICANT GP
031_AIR COMPRESSOR GP PART OF 372110 ENGINE AR
032_GAUGE GP-OIL LEVEL (DIPSTICK) (REAR SUMP)
033_LINES GP-ENGINE OIL-REAR SUMP
034_RADIATOR GP-PART 1 OF 2
035_RADIATOR GP-PART 2 OF 2
036_BAFFLE GP AN ATTACHMENT
037_BAFFLE GP 989001-PAGE 38 AN ATTACHMENT
038_BAFFLE AS PART OF 835345 BAFFLE AN ATTACHMENT
039_PUMP GP-WATER
040_LINES GP-WATER
041_COOLER GP-ENGINE OIL 1W7526-PAGE 41
042_OIL COOLER AND FILTER BASE GP PART OF 1W7526 OIL COOLER AND FILTER BASE
043_CHASSIS OPTION AR (HEAVY DUTY COOLING) AN ATTACHMENT
044_MANIFOLD GP-EXHAUST
045_MANIFOLD GP-INLET
046_ELBOW GP-EXHAUST
047_PIPING GP-EXHAUST
048_AIR CLEANER GP 835275-PAGE 47, 4M0310-PAGE 48
049_AIR CLEANER GP PART OF 834916 AIR CLEANER
050_PRECLEANER AS PART OF 834916 AIR CLEANER
051_LINES GP-PCV
052_VALVE AS-PCV (CRANKCASE VENTILATION) PART OF 4W7066 COVER-VALVE MECHANISM
053_GOVERNOR AND FUEL INJECTION PUMP GP 9Y0500-PAGE 53, 9N0683-PAGE 59, 6N0509-PAGE 61FOR FIELD REPLACEMENT _ORDER 9Y0511-PA
054_GOVERNOR AND FUEL INJECTION PUMP GP FIELD REPLACEMENT FOR 9Y10499-PAGE 51
055_GOVERNOR AND FUEL INJECTION PUMP GP 9Y0509-PAGE 54, 6N0509-PAGE 61 PART OF 9Y0511 GOVERNOR AND FUEL INJECTION _PUMP FIEL
056_GOVERNOR AND FUEL INJECTION PUMP GP 9Y0509-PAGE 54 PART OF 9Y0499 GOVERNOR AND FUEL INJECTION PUMP
057_GOVERNOR AND FUEL INJECTION PUMP GP-PART 1 OF 5 PART OF 9Y0500, 9Y5012 GOVERNOR AND FUEL INJECTION PUMPS
058_GOVERNOR AND FUEL INJECTION PUMP GP-PART 2 OF 5 PART OF 9Y0500, 9Y0512 GOVERN
059_GOVERNOR AND FUEL INJECTION PUMP GP-PART 3 OF 5 PART OF 9Y0500, 9Y0512 GOVERN
060_GOVERNOR AND FUEL INJECTION PUMP GP-PART 4 OF 5 PART OF 9Y0500, 9Y0512 GOVERN
061_GOVERNOR AND FUEL INJECTION PUMP GP-PART 5 OF 5 PART OF 9Y0500, 9Y0512 GOVERN
062_SHUT-OFF GP-ELECTRICAL (12 VOLT) 6N9988-PAGE 59 PART OF 9Y0499 GOVERNOR AND FUEL INJECTION PUMP
063_SOLENOID GP-SHUT-OFF (12 VOLT) PART OF 9N0683 SHUT-OFF-ELECTRICAL
064_SOLENOID AS-SHUT-OFF (12 VOLT) PART OF 6N9988 SOLENOID-SHUT-OFF
065_SOLENOID AS-SHUT-OFF (12 VOLT) PART OF 6N9988 SOLENOID-SHUT-OFF_1
066_TORQUE CONTROL GP PART OF 9Y0499, 9Y0512 GOVERNOR AND FUEL INJECTION PUMPS
067_FASTENER GP-FUEL PUMP HOUSING
068_CONTROL GP-GOVERNOR
069_DRIVE GP-GOVERNOR AND FUEL PUMP
070_PUMP GP-FUEL PRIMING
071_LINES GP-FUEL INJECTION 9Y0300-PAGE 65, 9Y0301-PAGE 66
072_LINES GP-FUEL INJECTION PART OF 7W1998 LINES-FUEL INJECTION
073_LINES GP-FUEL INJECTION PART OF 7W1998 LINES-FUEL INJECTION_1
074_LINES GP-FUEL
075_TANK GP-FUEL
076_LINES GP-FUEL FILTER
077_FILTER GP-FUEL
078_PEDAL GP-GOVERNOR
079_SEPARATOR GP-WATER 4P0632-PAGE 73
080_SEPARATOR GP-WATER PART OF 9Y6062 SEPARATOR-WATER
081_BATTERY AND WIRING GP-PART 1 OF 2
082_BATTERY AND WIRING GP-PART 2 OF 2
083_PANEL GP-INSTRUMENT 9W1490-PAGE 79
084_KIT-METER SERVICE PART OF 834838 PANEL-INSTRUMENT
085_METER-SERVICE PART OF 9W1490 KIT-METER SERVICE
086_ALTERNATOR GP PART OF 372110 ENGINE AR
087_STARTING MOTOR GP-ELECTRIC (12 VOLT) 3T2655-PAGE 82 PART OF 372110 ENGINE AR
088_STARTING MOTOR GP-ELECTRIC_R (12 VOLT) PART OF 2N9305 STARTING MOTOR-ELECTRIC
089_STARTING MOTOR GP-ELECTRIC (12 VOLT) PART OF 3T2655 STARTING MOTOR-ELECTRIC
090_STARTING MOTOR GP-ELECTRIC (12 VOLT) PART OF 3T2655 STARTING MOTOR-ELECTRIC_1
091_HORN GP-ELECTRIC
092_ACCESSORY AR-WARNING LIGHT (ROTATING AMBER) AN ATTACHMENT
093_ACCESSORY AR-WARNING LIGHT (ROTATING AMBER) 9R8250-PAGE 89 AN ATTACHMENT
094_LAMP GP-WARNING (ROTATING AMBER) PART OF 834933 ACCESSORY AR-WARNING LIGHT
095_ACCESSORY AR-TRAVEL LIGHTS-COSA AN ATTACHMENT
096_ACCESSORY AR-BACK UP ALARM AN ATTACHMENT
097_TRANSMISSION GP-TORQUE CONVERTER 9J1212-PAGE 114, 8E9463-PAGE 94
098_TRANSMISSION GP-TORQUE CONVERTER-PART 1 OF 5 8E9700-PAGE 109, 6Y8854- PAGE
099_TRANSMISSION GP-TORQUE CONVERTER-PART 2 OF 5 6Y5200-PAGE 112 835402-TRANSMI
100_TRANSMISSION GP-TORQUE CONVERTER-PART 3 OF 5 534373-PAGE 117 835402-TRANSMI
101_TRANSMISSION GP-TORQUE CONVERTER-PART 4 OF 5 835402-TRANSMISSION FIELD KIT
102_TRANSMISSION GP-TORQUE CONVERTER-PART 5 OF 5 8E1093-PAGE 144 835402-TRANSMI
103_TRANSMISSION GP-TORQUE COVERTER-PART 1 OF 5 8E9700-PAGE 109, 6Y8854-PAGE
104_TRANSMISSION GP-TORQUE CONVERTER-PART 2 OF 5 6Y5200-PAGE 112 FIELD REPLACEMENT
105_TRANSMISSION GP-TORQUE CONVERTER-PART 3 OF 5 534373-PAGE 117 FIELD REPLACEMENT
106_TRANSMISSION GP-TORQUE CONVERTER-PART 4 OF 5 FIELD REPLACEMENT FOR 8E9463-P
107_TRANSMISSION GP-TORQUE CONVERTER-PART 5 OF 5 8E 1093-PAGE 144 FIELD REPLACE
108_TRANSMISSION GP-TORQUE CONVERTER-PART 1 OF 5 8E9700-PAGE 109, 6Y8854-PAGE 1
109_TRANSMISSION GP-TORQUE CONVERTER-PART 2 OF 5 8E9602-PAGE 113 PART OF 6R8246
110_TRANSMISSION GP-TORQUE CONVERTER-PART 3 OF 5 534373-PAGE 117 PART OF 6R8246
111_TRANSMISSION GP-TORQUE CONVERTER-PART 4 OF 5 PART OF 6R8246 CHASSIS OPTION
112_TRANSMISSION GP-TORQUE CONVERTER-PART 5 OF 5 8E1093-PAGE 144 PART OF 6R8246
113_VALVE GP-CONTROL PART OF 8E9463, 8E9701, 6I9101 TRANSMISSIONS
114_PUMP GP-CHARGE PART OF 8E9463, 8E9701, 6I9101 TRANSMISSIONS
115_ADAPTER AS-PUMP PART OF 8E9463, 6I9101 TRANSMISSIONS
116_TORQUE CONVERTER GP PART OF 8E9463, 8E9701 TRANSMISSIONS
117_TORQUE CONVERTER GP PART OF 6I9101 TRANSMISSION
118_FILTER GP-OIL PART OF 834900 TRANSMISSION
119_CONTROL GP-TRANSMISSION
120_INSTALLATION GP-CONTROLS (TRANSMISSION)
121_SERVICE GP-CLUTCH CUT OFF PART OF 8E9463, 8E9701, 6I9101 TRANSMISSIONS
122_AXLE GP-DRIVE 839361-PAGE 120, 685539-PAGE 124
123_AXLE GP-DRIVE-PART 1 OF 2 AXLE RATIO 19.03_1 695055-PAGE 122 PART OF 839359
124_AXLE GP-DRIVE-PART 2 OF 2 AXLE RATIO 19.03_1 839364-PAGE 141 PART OF 839359
125_CARRIER GP-DIFFERENTIAL PART OF 839361 AXLE-DRIVE
126_UNIVERSAL JOINT GP PART OF 839359 AXLE-DRIVE
127_UNIVERSAL JOINT GP PART OF 685539 UNIVERSAL JOINT
128_UNIVERSAL JOINT GP PART OF 685539 UNIVERSAL JOINT_1
129_WHEEL AND TIRE GP-DRIVE AND STEER AN ATTACHMENT
130_WHEEL AND TIRE GP-DRIVE AND STEER V300C, V330C AN ATTACHMENT
131_WHEEL AND TIRE GP-DRIVE 7 STEER BERGOUGNAN SOLID TIRE-SOFTER RIDE AN ATTACHMENT
132_AXLE GP-STEER 550865-PAGE 132
133_AXLE GP-STEER 6R5263-PAGE 133 PART OF 549359 AXLE STEER
134_CYLINDER GP-STEER PART OF 550865 AXLE-DRIVE
135_CONTROL GP-STEERING 546045-PAGE 135
136_STEERING GEAR GP PART OF 835375 CONTROL-STEERING
137_COLUMN GP-ADJUSTABLE STEERING-PART 1 OF 2
138_COLUMN GP-ADJUSTABLE STEERING-PART 2 OF 2
139_CREEPER AND CONTROL GP 697611-PAGE 140
140_VALVE GP-BRAKE PART OF 834928 CREEPER AND CONTROL
141_BRAKE GP-2 REQUIRED PART OF 839361 AXLE-DRIVE
142_CONTROL GP-BRAKE PARKING
143_BRAKE AS-PARKING PART OF 8E9463, 8E9701, 6I9101 TRANSMISSION
144_LINES GP-SERVICE BRAKE (FRENCH AIR TANKS) AN ATTACHMENT
145_LINES GP-AIR
146_HOOD GP
147_DASH GP
148_FIREWALL GP
149_PLATFORM GP
150_GUARD GP-OVERHEAD
151_COUNTERWEIGHT GP V265C AN ATTACHMENT
152_COUNTERWEIGHT GP V300C AN ATTACHMENT
153_COUNTERWEIGHT GP V330C AN ATTACHMENT
154_MIRROR GP AN ATTACHMENT
155_TREAD GP-NON-SKID
156_FRAME AS-MAIN
157_SEAT GP-ADJUSTABLE 8R5373-PAGE 162, 6W2519-PAGE 168 AN ATTACHMENT
158_SEAT GP-SUSPENSION (FABRIC) 6W8502-PAGE 166 PART OF 834858 SEAT-ADJUSTABLE
159_SEAT GP-ADJUSTABLE (VINYL) 8Y3914-PAGE 164, 6W25-19-PAGE 168 AN ATTACHMENT
160_SEAT GP-SUSPENSION 6W8502-PAGE 166 PART OF 835382 SEAT-ADJUSTABLE AN ATTACH
161_SUSPENSION GP-SEAT-PART 1 OF 2 PART OF 8R5373, 8Y3914 SEATS-SUSPENSION AN A
162_SUSPENSION GP-SEAT-PART 2 OF 2 6W8505-PAGE 168 PART OF 8R5373, 8Y3914 SEATS
163_ADJUSTER GP-SEAT PART OF 6W8502 SEAT-SUSPENSION AN ATTACHMENT
164_CUSHION AS-ARM PART OF 834858, 835382 SEATS-ADJUSTABLE AN ATTACHMENT
165_CAB GP AN ATTACHMENT
166_CAB GP-PART 1 OF 6 PART OF 835326 CAB AN ATTACHMENT
167_CAB GP-PART 2 OF 6 PART OF 835326 CAB AN ATTACHMENT
168_CAB GP-PART 3 OF 6 PART OF 835326 CAB AN ATTACHMENT
169_CAB GP-PART 4 OF 6 PART OF 835326 CAB AN ATTACHMENT
170_CAB GP-PART 5 OF 6 PART OF 835326 CAB AN ATTACHMENT
171_CAB GP-PART 6 OF 6 PART OF 835326 CAB AN ATTACHMENT
172_OPTION AR-WIPER (TOP WINDOW) AN ATTACHMENT
173_CONTROL GP-MAST OPERATING-2 SECTION 8Q2982-PAGE 187 AN ATTACHMENT
174_CONTROL GP-HYDRAULIC-2 WAY 8Q2981-PAGE 204 PART OF 8Q6542 CONTROL-MAST OPERATING AND ATTACHMENT
175_CONTROL GP-MAST OPERATING-3 SECTION 8Q2983-PAGE 188 AN ATTACHMENT
176_CONTROL GP-HYDRAULIC-3 WAY 8Q2981-PAGE 204 PART OF 8Q6543 CONTROL-MAST OPERATING AND ATTACHMENT
177_CONTROL GP-MAST OPERATING-4 SECTION 8Q2984-PAGE 189 AN ATTACHMENT
178_CONTROL GP-HYDRAULIC-4 WAY 8Q2981-PAGE 204 PART OF 8Q6544 CONTROL-MAST OPERATING AND ATTACHMENT
179_CONTROL GP-MAST OPERATING-5 SECTION 8Q2985-PAGE 190 AN ATTACHMENT
180_CONTROL GP-HYDRAULIC-5 WAY 8Q2981-PAGE 204 PART OF 8Q6545 CONTROL-MAST OPERATING AND ATTACHMENT
181_VALVE GP-CONTROL-2 SECTION 834892-PAGE 192 FOR COSA USAGE AN ATTACHMENT
182_VALVE GP-CONTROL-2 834907-PAGE 199, 834911-PAGE 203 PART OF 834853 VALVE-CONTROL AND ATTACHMENT
183_VALVE GP-CONTROL-3 SECTION 834893-PAGE 194 AN ATTACHMENT
184_VALVE GP-3 834908-PAGE 200, 834909-PAGE 201, 834911-PAGE 203 PART OF 834854 VALVE-CONTROL AN ATTACHMENT
185_VALVE GP-CONTROL-4 SECTION 834894-PAGE 196 AN ATTACHMENT
186_VALVE GP-4 WAY 834908-PAGE 200, 834909-PAGE 201, 834910-PAGE 202, 834911-PAGE 203 PART OF 834855 VALVE-CONTROL AN A
187_VALVE GP-CONTROL-5 SECTION 834895-PAGE 198 AN ATTACHMENT
188_VALVE GP-CONTROL-5 WAY 834908-PAGE 200, 834909-PAGE 201, 834910-202, 834911-PAGE203 PART OF 834856 VALVE-CONTROL _AN ATT
189_SECTION GP-VALVE-OUTLET PART OF 834892 VALVE-CONTROL AN ATTACHMENT
190_SECTION GP-VALVE-OUTLET PART OF 834893, 834894, 834895 VALVES AN ATTACHMENT
191_SECTION GP-VALVE-CENTER PART OF 834893, 834894, 834895 VALVES AN ATTACHMENT
192_SECTION GP-VALVE-CENTER PART OF 834894, 834895 VALVES AN ATTACHMENT
193_SECTION GP-VALVE-INLET PART OF 834892, 834893, 834894, 834895 VALVES AN ATTACHMENT
194_VALVE GP PART OF 8Q2982, 8Q2983, 8Q2984, 8Q2985 CONTROLS-MAST OPERATING AN
195_LINES GP-HYDRAULIC OIL-PART 2 OF 2
196_FILTER GP-OIL PART OF 834851 LINES-HYDRAULIC OIL
197_TANK GP-HYDRAULIC
198_PUMP AND MOUNTING GP 6R8116-PAGE 212
199_PUMP GP-VANE 3G2751-PAGE 213, 1U2669-PAGE 214 PART OF 834913 PUMP AND MOUNTING
200_CARTRIDGE GP-REAR_R PART OF 6R8116 PUMP-VANE
201_TILT GP 15 DEGREES FORWARD, 12 DEGREES BACKWARD 835474-PAGE 219 AN ATTACHMENT
202_TILT GP 15 DEGREES FORWARD, 12 DEGREES BACKWARD 8Q5251-PAGE 220 AN ATTACHMENT
203_TILT GP 6 DEGREES FORWARD, 12 DEGREES BACKWARD 834935-PAGE 220 AN ATTACHMENT
204_CYLINDER GP-TILT-(CHG 00)-2 REQUIRED 152MM (6 IN) BORE X 230MM (9 IN) STROKE 6 DEGREES FORWARD, 12 DEGREES _BACKWARD PAR
205_CYLINDER GP-TILT-(CHG 00)-2 REQUIRED 152MM (6 IN) BORE X 341MM (13
206_CYLINDER AND MOUNTING GP-2 REQUIRED PART OF 834575 TILT AN ATTACHMENT
207_CYLINDER AND MOUNTING GP-2 REQUIRED PART OF 8Q5249 TILT
208_LINES GP-ATTACHMENT-2 WAY HYDRAULICS AN ATTACHMENT
209_LINES GP-ATTACHMENT-3 WAY HYDRAULICS AN ATTACHMENT
210_LINES GP-ATTACHMENT-4 WAY HYDRAULICS AN ATTACHMENT
211_LINES GP-ATTACHMENT-5 WAY HYDRAULICS AN ATTACHMENT
212_LINES GP-ATTACHMENT-3 WAY HYDRAULICS AN ATTACHMENT_1
213_LINES GP-ATTACHMENT-4 WAY HYDRAULICS AN ATTACHMENT_1
214_LINES GP-ATTACHMENT-5 WAY HYDRAULICS AN ATTACHMENT_1
215_ACCUMULATOR AND MOUNTING GP AN ATTACHMENT
216_COUPLING GP FOR USE WITH 3 WAY AND 4 WAY HYDRAULICS 2 GROUPS REQUIRED FOR 4 WAY HYDRAULICS AN ATTACHMENT
217_MAST AR-STD LIFT MFH 3710MM (146 IN) V265C, V300C AN ATTACHMENT
218_MAST AR-STD LIFT MFH 4320MM (170 IN) V265C, V300C AN ATTACHMENT
219_MAST AR-STD LIFT MFH 4930MM (194 IN) V265C, V300C AN ATTACHMENT
220_MAST AR-STD LIFT MFH 5540MM (218 IN) V265C, V300C AN ATTACHMENT
221_MAST AR-STD LIFT MFH 6100MM (290 IN) V265C, V300C AN ATTACHMENT
222_MAST AR-STD LIFT MFH 3400MM (134 IN) V330C AN ATTACHMENT
223_MAST AR-STD LIFT MFH 4620MM (182 IN) V330C AN ATTACHMENT
224_MAST AR-STD LIFT MFH 5230MM (206 IN) V330C AN ATTACHMENT
225_MAST AR-STD LIFT MFH 5790MM (228 IN) V330C AN ATTACHMENT
226_MAST GP PART OF 5I0856, 5I0861 MAST ARS AN ATTACHMENT
227_MAST GP PART OF 5I0857 MAST AR AN ATTACHMENT
228_MAST GP PART OF 5I0858, 5I0862 MAST ARS AN ATTACHMENT
229_MAST GP PART OF 5I0860, 5I0863 MAST ARS AN ATTACHMENT
230_MAST GP PART OF 5I0859, 5I0864 MAST ARS AN ATTACHMENT
231_MAST GP 988476-PAGE 242, 988477-PAGE 242 PART OF 5I0865, 5I0866, 5I0867, 5I0869 MASTS AN ATTACHMENT
232_PLATE GP-RH PART OF 988247 MAST AN ATTACHMENT
233_PLATE GP-LH PART OF 988247 MAST AN ATTACHMENT
234_UPRIGHT AS-STATIONARY PART OF 6R9857, 6R9858, 6R9859, 6R9860, 6R9861 UPRIGHTS-STATIONARY AN ATTACHMENT
235_UPRIGHT AS-INNER PART OF 6R9870, 6R9871, 6R9872, 6R9873, 6R9874, UPRIGHTS-INNER AN ATTACHMENT
236_MOUNTING GP-MAST PART OF 5I0856, 5I0857, 5I0858, 5I0859, 5I0860, 5I0861, 5I0862,5I0863, 5I0864 MAST ARS AN ATTACHMENT
237_LIFT GP-CYLINDER-(CHG 00)-2 REQUIRED 127MM (5 IN) BORE X 1855MM (73 IN) STROKE PART OF 5I0856 MAST AR AN _ATTACHMENT
238_LIFT GP-CYLINDER-(CHG 00) -2 REQUIRED 127MM (5 IN) BORE X 2160MM (85 IN) STROKE PART OF 5I0857 MAST AR AN _ATTACHMENT
239_LIFT GP-CYLINDER-(CHG 00)-2 REQUIRED 127MM (5 IN) BORE X 2465MM (97 IN) STR
240_LIFT GP-CYLINDER-(CHG 00)-2 REQUIRED 127MM 5 IN) BORE X 2770MM (109 IN) STR
241_LIFT GP-CYLINDER-(CHG 00)-2 REQUIRED 127MM (5 IN) BORE X 3050MM (120 IN) STROKE PART OF 5I0859 MAST AR AN _ATTACHMENT
242_LIFT GP-CYLINDER-(CHG 00)-2 REQUIRED 127MM (5 IN) BORE X 1700MM (67 IN) STROKE PART OF 5I0861 MAST AR AN _ATTACHMENT
243_LIFT GP-CYLINDER-(CHG 00)-2 REQUIRED 127MM (5 IN) BORE X 2130MM (91 IN) STROKE PART OF 5I0863 MAST AR AN _ATTACHMENT
244_LIFT GP-CYLINDER-(CHG 00)-2 REQUIRED 127MM (5 IN) BORE X 2615MM (103 IN) STROKE PART OF 5I0863 MAST AR AN _ATTACHMENT
245_LIFT GP-CYLINDER-(CHG 00)-2 REQUIRED 127MM (5 IN) BORE X 2895MM (114 IN) STROKE PART OF 5I0864 MAST AR AN _ATTACHMENT
246_LIFT GP PART OF 988558, 988562, 988545, 988570, 988566, 988556, 988557, 988574, 988575 LIFTS AN ATTACHMENT
247_RELAY GP-LIFT 988234-PAGE 253 PART OF 5I0856, 5I0857, 5I0858, 5I0859, 5I0860, 5I08561, 5I0862, 5I0863, 5I0864 MAST
248_SHEAVE GP PART OF 988231 RELAY-LIFT AN ATTACHMENT
249_CARRIAGE AR-SHAFT TYPE FORK RANGE_ 406MM (16 IN) - 2032MM (80 IN) V265C, V300C AN ATTACHMENT
250_CARRIAGE AR-SHAFT TYPE (HYDRAULIC FORK POSITIONER) FORK RANGE_ 406MM (16 IN) - 2032MM (80 IN) V265C, V300C
251_CARRIAGE AR-SIDESHIFT SHAFT FORK RANGE_ 75MM (3 IN) - 2030MM (80 IN) V265C, V300C AN ATTACHMENT
252_CARRIAGE AR-SIDESHIFT SHAFT FORK RANGE_ 76MM (3 IN) - 2286MM (90 IN) V265C, V300C AN ATTACHMENT
253_CARRIAGE AR-SHAFT TYPE FORK RANGE_ 660MM (26 IN) 2286MM (90 IN) V330C AN ATTACHMENT
254_CARRIAGE AR-SHAFT TYPE (HYDRAULIC FORK POSITIONER) FORK RANGE_ 406MM (16 IN) - 2030MM (80 IN) V330C. AN _ATTACHMENT
255_CARRIAGE AR-SIDESHIFT SHAFT FORK RANGE_ 75MM (3 IN) - 2290MM (90 IN) V330C AN ATTACHMENT
256_CARRIAGE AS 2112MM (83 IN) CARRIAGE WIDTH PART OF 988379 CARRIAGE AR AN ATTACHMENT
257_CARRIAGE AS 2112MM (83 IN) CARRIAGE WIDTH PART OF 988389 CARRIAGE AR AN ATTACHMENT
258_CARRIAGE AS 2112MM (83 IN) CARRIAGE WIDTH PART OF 988297 CARRIAGE AR AN ATTACHMENT
259_CARRIAGE AS 2366MM (93 IN) CARRIAGE WIDTH PART OF 988383 CARRIAGE AR AN AT
260_CARRIAGE AS 2134MM (84 IN) CARRIAGE WIDTH PART OF 988202 CARRIAGE AR AN ATTACHMENT
261_CARRIAGE AS 2388MM (94 IN) CARRIAGE WIDTH PART OF 988385 CARRIAGE WIDTH PAR
262_CARRIAGE AS 2388MM (94 IN) CARRIAGE WIDTH PART OF 988195 CARRIAGE AR AN ATTACHMENT
263_MOUNTING GP-CARRIAGE PART OF 988385, 988202 CARRIAGE ARS AN ATTACHMENT
264_MOUNTING GP-CARRIAGE PART OF 988379, 988389 CARRIAGE ARS AN ATTACHMENT
265_MOUNTING GP-CARRIAGE PART OF 988383, 988297 CARRIAGE ARS AN ATTACHMENT
266_MOUNTING GP-CARRIAGE PART OF 988195 CARRIAGE AR AN ATTACHMENT
267_MOUNTING GP-ATTACHMENT 988491-PAGE 274 PART OF 988389 CARRIAGE AR AN ATTACH
268_MOUNTING GP-ATTACHMENT 988491-PAGE 274 PART OF 988297 CARRIAGE AR AN ATTACH
269_MOUNTING GP-ATTACHMENT 545569-PAGE 275 PART OF 988202 CARRIAGE AR AN ATTACH
270_MOUNTING GP-ATTACHMENT 545569-PAGE 275 PART OF 988195 CARRIAGE AR AN ATTACH
271_BRACKET AS-ROLLER PART OF 988202, 988385 CARRIAGE ARS AN ATTACHMENT
272_BRACKET AS-ROLLER PART OF 988195 CARRIAGE AR AN ATTACHMENT
273_ROLLER AR FOR FIELD INSTALLATION OF AUXILIARY EQUIPMENT AN ATTACHMENT
274_CYLINDER GP-FORK ADJUSTMENT-(CHG 00)-2 REQUIRED 63.5MM (2.5 IN) BORE X 647.7MM (25
275_CYLINDER GP-SIDESHIFTER-(CHG 00)-2 REQUIRED 101
276_FORK AS 80MM (3 IN) THK X 180MM (7 IN) WIDE X 2438MM (96 IN) LENGTH V265C AN ATTACHMENT
277_FORK AS 80MM (3 IN) THK X 180MM (7 IN) WIDE X 1829MM (72 IN) LENGTH V265C AN ATTACHMENT
278_FORK AS 80MM (3 IN) THK X 180MM (7 IN) WIDE X 1524MM (60 IN) LENGTH V265C, V300CAN ATTACHMENT
279_FORK AS 90MM (3.5 IN) THK X 180MM (7 IN) WIDE X 1829MM (72 IN) LENGTH V300C AN ATTACHMENT
280_FORK AS 90MM (3.5 IN) THK X 180MM (7 IN) WIDE X 2438MM (96 IN) LENGTH V300C AN ATTACHMENT
281_FORK AS 90MM (3.5 IN) THK X 180MM (7 IN) WIDE X 1524MM (60 IN) LENGTH V330C AN ATTACHMENT
282_FORK AS 90MM (3.5 IN) THK X 180MM (7 IN) WIDE X 1829 MM (72 IN) LENGTH V330C AN ATTACHMENT
283_FORK AS 90MM (3.5 IN) THK X 180MM (7 IN) WIDE X 2438MM (96 IN) LENGTH V330C AN ATTACHMENT
284_PAINT AND LABRICANT GP (NAMEPLATES AND TRANSFERS) AN ATTACHMENT
285_PAINT AND LUBRICANT GP-FRENCH AN ATTACHMENT
286_PAINT AND LUBRICANT GP-SPANISH AN ATTACHMENT
287_PAINT AND LUBRICANT GP-GERMAN AN ATTACHMENT
288_PAINT AND LUBRICANT GP-ITALIAN AN ATTACHMENT
289_PAINT AND LUBRICANT GP-PORTUGUESE AN ATTACHMENT
290_PAINT AND LUBRICANT GP-DANISH AN ATTACHMENT
291_PAINT AND LUBRICANT GP-GREEK AN ATTACHMENT
292_PAINT AND LUBRICANT GP-DUTCH AN ATTACHMENT
