Caterpillar Forklift V155C Chassis Mast Engine 4.236 Diesel Europe Parts Catalog SEBN2669
Brand: Caterpillar
Type of Machine: Forklift
Type of Manual: Parts Manual
Model: Caterpillar V155C Chassis Mast Engine 4.236 Diesel Forklift
Region: Europe
Part Number: SEBN2669
Number of Pages: 488 Pages
001_ENGINE AR
002_ENGINE AR_1
003_CYLINDER BLOCK GP 9Y2630-PAGE 5
004_CYLINDER BLOCK GP FIELD REPLACEMENT FOR 7E3710 ENGINE AR
005_CYLINDER BLOCK GP PART OF 9Y5018 CYLINDER BLOCK
006_CYLINDER BLOCK AS-PART 1 OF 2 PART OF 7N3472 CYLINDER BLOCK
007_CYLINDER BLOCK AS-PART 2 OF 2 PART OF 7N3472 CYLINDER BLOCK
008_CRANKSHAFT GP
009_HOUSING GP-FLYWHEEL
010_FLYWHEEL GP
011_PISTON AND ROD GP
012_CAMSHAFT GP
013_CYLINDER HEAD GP 7C3188-PAGE 15
014_CYLINDER HEAD GP PART OF 7C6480 CYLINDER HEAD
015_VALVE MECHANISM GP
016_COVER GP-VALVE MECHANISM
017_GEAR GP-FRONT IDLER
018_HOUSING GP-FRONT
019_PULLEY GP-CRANKSHAFT
020_PAN GP-OIL
021_LIFTING GP
022_MOUNTING GP-ENGINE
023_FUMES DISPOSAL GP
024_GAUGE GP-OIL LEVEL (DIPSTICK)
025_PUMP GP-ENGINE OIL
026_FILTER GP-ENGINE OIL
027_LINES GP-ENGINE OIL
028_RADIATOR GP
029_FAN GP-BLOWER
030_PUMP GP-WATER GROUP 1W2222
031_LINES GP-WATER
032_MANIFOLD GP-EXHAUST
033_MANIFOLD GP-INLET
034_PIPING GP-EXHAUST 537991-PAGE 36
035_MUFFLER GP PART OF 6R6692 PIPING-EXHAUST
036_AIR CLEANER GP
037_PUMP GP-FUEL INJECTION
038_PUMP GP-FUEL
039_LINES GP-FUEL INJECTION
040_LINES GP-FUEL
041_LINES GP-FUEL FILTER
042_FILTER GP-FUEL
043_SEPARATOR GP-WATER
044_TANK GP-FUEL
045_STARTING AID GP
046_PEDAL GP-ACCELERATOR 2V4281-PAGE 49
047_PEDAL GP-GOVERNOR PART OF 6R6693 PEDAL-ACCELERATOR
048_BATTERY AND WIRING GP-PART 1 OF 2
049_BATTERY AND WIRING GP-PART 2 OF 2
050_PANEL GP-INSTRUMENT 9W1490-PAGE 55
051_KIT-METER SERVICE PART OF 6R6726 WIRING
052_METER-SERVICE PART OF 9W1490 METER SERVICE FOR USE WITH 12 OR 24 VOLT ELECT
053_ALTERNATOR GP-CHARGING 8C5510-PAGE 57
054_ALTERNATOR GP-CHARGING PART OF 551757 ALTERNATOR
055_MOUNTING GP-ALTERNATOR
056_STARTING MOTOR GP-ELECTRIC 7C2264-PAGE 60
057_STARTING MOTOR GP-ELECTRIC PART OF 7W2805 STARTING MOTOR-ELECTRIC
058_STARTING MOTOR GP-ELECTRIC PART OF 7C2264 STARTING MOTOR-ELECTRIC
059_STARTING MOTOR GP-ELECTRIC PART OF 7C2264 STARTING MOTOR-ELECTRIC_1
060_HORN GP-ELECTRIC
061_ACCESSORY AR-WARNING LIGHT ROTATING-AMBER AN ATTACHMENT
062_ACCESSORY AR-WARNING LIGHT ROTATING-AMBER-REAR HEADGUARD MOUNTED 9R8250-PAGE 70 AN ATTACHMENT
063_ACCESSORY AR-BACK-UP ALARM AN ATTACHMENT
064_ACCESSORY AR TRAVEL LIGHTS AN ATTACHMENT
065_LAMP GP-AMBER-ROTATING WARNING PART OF 834933 ACCESSORY AR AN ATTACHMENT
066_TRANSMISSION AR TRANSMISSION S_N 4FX1-UP
067_7T9403 CASE AND PARTS GP 9W7189-PAGE 74 PART OF 8E9013 TRANSMISSION AR
068_9W7189 VALVE GP-FLOW CONTROL PART OF 7T9403 CASE AND PARTS
069_7T7395 CLUTCH GP-1ST PART OF 8E9013 TRANSMISSION AR
070_7T7396 CLUTCH GP-2ND AND 3RD PART OF 8E9013 TRANSMISSION AR
071_7T9400 CLUTCH GP FORWARD AND REVERSE PART OF 8E9013 TRANSMISSION AR
072_6R6680 CONTROL GP-TRANSMISSION 8C5325-PAGE 81
073_8C5325 CONTROL GP-TRANSMISSION PART OF 6R6680 CONTROL-TRANSMISSION
074_8E9012 CONTROL GP-TRANSMISSION OIL 8E9011-PAGE 83 PART OF 8E9013 TRANSMISSION AR
075_8E9011 VALVE GP 8E8621-PAGE 84, 9U8880-PAGE 85 PART OF 8E9012 CONTROL-TRANSMISSION OIL
076_8E8621 VALVE GP-CONTROL PART OF 8E9011 VALVE
077_9U8880 VALVE GP-CONTROL SELECTOR AND PRESSURE PART OF 8E9011 VALVE
078_8E8657 PUMP GP-CRESCENT 8E8658-PAGE 87 PART OF 8E9013 TRANSMISSION AR
079_8E8658 PUMP GP-CRESCENT PART OF 8E8657 PUMP-CRESCENT
080_6Y9963 FILLER GP-POWER TRAIN OIL PART OF 8E9013 TRANSMISSION AR
081_7T8782 LINES GP-POWER TRAIN OIL 6Y3560-PAGE 90 PART OF 8E9013 TRANSMISSION AR
082_6Y3560 FILTER GP-TRANSMISSION PART OF 7T8782 LINES-POWER TRAIN OIL
083_9W8214 DRIVE GP-FLEXIBLE COUPLING PART OF 8E9013 TRANSMISSION AR
084_552129 POWER TRANSFER GP
085_979347 POWER TAKE-OFF GP 550735-PAGE 96
086_550735 SLIP JOINT GP PART OF 979347 POWER TAKE-OFF
087_9W9415 MOUNTING GP-TRANSMISSION
088_550731 MOUNTING GP-DRIVE AXLE
089_540951 WHEEL AND TIRE GP-DRIVE AND STEER PNEUMATIC V155C. AN ATTACHMENT
090_549473 WHEEL AND TIRE GP-DRIVE AND STEER BERGOUGNAN SOLID SOFTER RIDE (8.25 X 15) 970545-PAGE 101
091_970545 WHEEL GP PART OF 549473 WHEEL AND TIRE AN ATTACHMENT
092_AXLE GP-STEER 551021-PAGE 104
093_AXLE GP-STEER 694951-PAGE 105 PART OF 684876 AXLE-STEER
094_CYLINDER GP-STEER AXLE PART OF 551021 AXLE-STEER
095_COLUMN GP-ADJUSTABLE STEERING
096_CONTROL GP-STEERING 546646-PAGE 109
097_STEERING GEAR GP PART OF 6R6679 CONTROL-STEERING
098_LINES GP-STEERING
099_CREEPER AND CONTROL GP 6R8296-PAGE 114
100_CYLINDER GP-MASTER PART OF 6R6678 CREEPER AND CONTROL
101_BRAKE GP-SERVICE 977558-PAGE 116, 977559-PAGE 117
102_BRAKE GP-RH 546092-PAGE 118 PART OF 979306 BRAKE-SERVICE
103_BRAKE GP-LH 546092-PAGE 118 PART OF 979306 BRAKE-SERVICE
104_CYLINDER GP-BRAKE PART OF 977558, 977559 BRAKES
105_LINES GP-BRAKE-PART 2 OF 2 551149-PAGE 126
106_BOOSTER AS-BRAKE PART OF 6R6700 LINES-BRAKE
107_PUMP GP-VACUUM
108_DASH GP
109_FIREWALL GP
110_GUARD GP-OVERHEAD
111_HOOD GP
112_PLATFORM GP
113_COUNTERWEIGHT GP FIXED V110C. AN ATTACHMENT
114_COUNTERWEIGHT GP FIXED V135C. AN ATTACHMENT
115_COUNTERWEIGHT GP FIXED V155C. AN ATTACHMENT
116_TREAD GP-NON-SKID
117_SEAT GP-ADJUSTABLE 8R5373-PAGE 142, 6W2519-PAGE 146 AN ATTACHMENT
118_SEAT GP-ADJUSTABLE 8Y3914-PAGE 143, 6W2519-PAGE 146 AN ATTACHMENT
119_SEAT GP 6W8502-PAGE 144 PART OF 834858 SEAT AN ATTACHMENT
120_SEAT GP-SUSPENSION 6W8502-PAGE 144 PART OF 835382 SEAT AN ATTACHMENT
121_SUSPENSION GP-SEAT-PART 1 OF 2 PART OF 8R5373, 8Y3914 SEATS AN ATTACHMENT
122_SUSPENSION GP-SEAT-PART 2 OF 2 6W8505-146 PART OF 8R5373, 8Y3914 SEAT AN AT
123_CUSHION AS-ARM-RH PART OF 834858, 835382 SEATS AN ATTACHMENT
124_ADJUSTER GP-SEAT PART OF 6W8502 SEAT AN ATTACHMENT
125_SEAT GP-STATIC 9V8787-PAGE 148 AN ATTACHMENT
126_SEAT GP PART OF 6R6750 SEAT AN ATTACHMENT
127_CAB GP AN ATTACHMENT
128_OPTION AR-WIPER TOP WINDOW AN ATTACHMENT
129_CAB GP-PART 2 OF 6 PART OF 8Q7201 CAB AN ATTACHMENT
130_CAB GP-PART 3 OF 6 PART OF 8Q7201 CAB AN ATTACHMENT
131_CAB GP-PART 4 OF 6 PART OF 8Q7201 CAB AN ATTACHMENT
132_CAB GP-PART 5 OF 6 PART OF 8Q7201 CAB AN ATTACHMENT
133_CAB GP-PART 6 OF 6 PART OF 8Q7201 CAB AN ATTACHMENT
134_MOUNTING GP-CAB PART OF 8Q7201 CAB AN ATTACHMENT
135_MIRROR GP AN ATTACHMENT
136_LINES GP-CAB PART OF 8Q7201 CAB AN ATTACHMENT
137_WIRING GP-CAB PART OF 8Q7201 CAB AN ATTACHMENT
138_CONTROL GP-MAST OPERATING VALVE-2 WAY 8Q2982-PAGE 168 AN ATTACHMENT
139_CONTROL GP-MAST OPERATING VALVE-3 WAY 8Q2983-PAGE 168 AN ATTACHMENT
140_CONTROL GP-MAST OPERATING VALVE-4 WAY 8Q2984-PAGE 169 AN ATTACHMENT
141_CONTROL GP-MAST OPERATING VALVE-5 WAY 8Q2985-PAGE 169 AN ATTACHMENT
142_CONTROL GP-HYDRAULIC-2 WAY 8Q2981-PAGE 170 PART OF 8Q6542 CONTROL AN ATTACHMENT
143_CONTROL GP-HYDRAULIC-3 WAY 8Q2981-PAGE 170 PART OF 8Q6543 CONTROL AN ATTACHMENT
144_CONTROL GP-HYDRAULIC-4 WAY 8Q2981-PAGE 170 PART OF 8Q6544 CONTROL AN ATTACHMENT
145_CONTROL GP-HYDRAULIC-5 WAY 8Q2981-PAGE 170 PART OF 8Q6545 CONTROL AN ATTACH
146_VALVE GP PART OF 8Q2982, 8Q2983, 8Q2984 8Q2985 CONTROLS AN ATTACHMENT
147_VALVE GP-CONTROL-2 WAY AN ATTACHMENT
148_VALVE GP-CONTROL-3 WAY AN ATTACHMENT
149_VALVE GP-CONTROL-4 WAY AN ATTACHMENT
150_VALVE GP-CONTROL-5 WAY AN ATTACHMENT
151_PUMP AND MOUNTING GP-HYDRAULIC 6R6671-PAGE 176
152_PUMP GP-VANE 3G2195, 8Q5429-PAGE 177 PART OF 6R6694 PUMP AND MOUNTING-HYDRAULIC
153_CARTRIDGE GP-FRONT PART OF 6R6671 PUMP-VANE
154_CARTRIDGE GP-REAR PART OF 6R6671 PUMP-VANE
155_FILTER GP-HYDRAULIC OIL PART OF 6R6684 LINES-HYDRAULIC OIL
156_TANK GP-HYDRAULIC
157_ACCUMULATOR GP AN ATTACHMENT
158_CYLINDER AND MOUNTING GP-TILT 15 DEGREES FORWARD, 10 DEGREES BACKWARD 551471-
159_CYLINDER AND MOUNTING GP-TILT 6 DEGREES FORWARD, 10 DEGREES BACKWARD 3C8042-P
160_CYLINDER AND MOUNTING GP-TILT 5 DEGREES FORWARD, 5 DEGREES BACKWARD 547540-PA
161_CYLINDER GP-TILT-2 REQUIRED 551191-PAGE 191 PART OF 552177 CYLINDER AND MOUNT
162_CYLINDER GP-TILT-2 REQUIRED 3C8043-PAGE 192 PART OF 3C8041 CYLINDER AND MOUNT
163_CYLINDER GP-TILT-(CHG 01)-2 REQUIRED 115MM (4.5 IN) BORE X 107MM (4.2 IN) S
164_CYLINDER GP-TILT-(CHG 00)-2 REQUIRED 115MM (4.5 IN) BORE X 256MM (10.4 IN)
165_CYLINDER GP-TILT-(CHG 00)-2 REQUIRED 115MM (4.6 IN) BORE X 265MM (10.5 IN)
166_LINES GP-ATTACHMENT-2 WAY AN ATTACHMENT
167_LINES GP-ATTACHMENT-3 WAY AN ATTACHMENT
168_LINES GP-ATTACHMENT-3 WAY AN ATTACHMENT_1
169_LINES GP-ATTACHMENT-4 WAY-LH AN ATTACHMENT
170_LINES GP-ATTACHMENT-4 WAY AN ATTACHMENT
171_LINES GP-ATTACHMENT-5 WAY-STD LIFT AN ATTACHMENT
172_LINES GP-ATTACHMENT-5 WAY AN ATTACHMENT
173_COUPLING GP FOR USE WITH 3-WAY AND 4-WAY HYDRAULICS 2 REQUIRED FOR 4-WAY HY
174_MAST AR-STANDARD LIFT MFH 3100 MM (122 IN) AN ATTACHMENT
175_MAST AR-STANDARD LIFT MFH 3710MM (146 IN) AN ATTACHMENT
176_MAST AR-STANDARD LIFT MFH 4320MM (170 IN) AN ATTACHMENT
177_MAST AR-STANDARD LIFT MFH 4930MM (194 IN) AN ATTACHMENT
178_MAST AR-STANDARD LIFT MFH 5540MM (218 IN) AN ATTACHMENT
179_MAST AS-OUTER PART OF 844391, 844392, 844393, 844394, 844395 MASTS AN ATTACHMENT
180_MAST AS-INNER PART OF 551134, 551298, 551299, 551133, 551043 MASTS AN ATTACHMENT
181_MOUNTING GP-MAST-PART 1 OF 2 551194, 551195-PAGE 208 PART OF 844386, 844387
182_MOUNTING GP-MAST-PART 2 OF 2 PART OF 844386, 844387, 844388, 844389, 844390
183_PLATE GP-LOAD-RH PART OF 836357 MOUNTING-MAST AN ATTACHMENT
184_PLATE GP-LOAD-LH PART OF 836357 MOUNTING-MAST AN ATTACHMENT
185_LIFT GP PART OF 844390 MAST AR AN ATTACHMENT
186_LIFT GP PART OF 844386 MAST AR AN ATTACHMENT
187_LIFT GP PART OF 844387 MAST AR AN ATTACHMENT
188_LIFT GP PART OF 844388 MAST AR AN ATTACHMENT
189_LIFT GP PART OF 844389 MAST AR AN ATTACHMENT
190_LIFT GP PART OF 837379, 837380, 837381, 837382, 837383 LIFTS AN ATTACHMENT
191_CHAIN GP-LIFTING PART OF 844386 MAST AR AN ATTACHMENT
192_CHAIN GP-LIFTING PART OF 844387 MAST AR AN ATTACHMENT
193_CHAIN GP-LIFTING PART OF 844388 MAST AR AN ATTACHMENT
194_CHAIN GP-LIFTING PART OF 844389 MAST AR AN ATTACHMENT
195_CHAIN GP-LIFTING PART OF 844390 MAST AR AN ATTACHMENT
196_CARRIAGE AR-SHAFT TYPE-PALLET CARRIAGE WIDTH 1752MM (69 IN) AN ATTACHMENT
197_CARRIAGE AR-HOOK TYPE CARRIAGE WIDTH 2032MM (80 IN) AN ATTACHMENT
198_CARRIAGE AR-SIDESHIFTER-SHAFT TYPE CARRIAGE WIDTH 1676MM (66 IN) AN ATTACHMENT
199_CARRIAGE AR-SHAFT TYPE-PALLET CARRIAGE WIDTH 2108MM (83 IN) AN ATTACHMENT
200_CARRIAGE AR-SIDESHIFTER-SHAFT TYPE CARRIAGE WIDTH 2032MM (80 IN) AN ATTACHMENT
201_CARRIAGE AR-SIDESHIFTER-HOOK TYPE CARRIAGE WIDTH 2032MM (80 IN.) AN ATTACHMENT
202_CARRIAGE AR-SHAFT TYPE CARRIAGE WIDTH 1676MM (50 IN.) AN ATTACHMENT
203_CARRIAGE AR-SHAFT TYPE CARRIAGE WIDTH 2032MM (80 IN) AN ATTACHMENT
204_ATTACHMENT AR-BLOCK HANDLING CARRIAGE WIDTH 2438MM (96 IN) AN ATTACHMENT
205_CARRIAGE AS PART OF 836380 CARRIAGE AR-SIDESHIFTER AN ATTACHMENT
206_CARRIAGE AS PART OF 836382 CARRIAGE AR-SIDESHIFTER AN ATTACHMENT
207_CARRIAGE AS PART OF 836383 CARRIAGE AR AN ATTACHMENT
208_CARRIAGE AS PART OF 836376 CARRIAGE AR AN ATTACHMENT
209_CARRIAGE AS PART OF 836378 CARRIAGE AR AN ATTACHMENT
210_CARRIAGE AS PART OF 976681 CARRIAGE AR AN ATTACHMENT
211_CARRIAGE AS PART OF 976693 CARRIAGE AR AN ATTACHMENT
212_CARRIAGE AS-SIDESHIFTER PART OF 3C8303 CARRIAGE AR AN ATTACHMENT
213_MOUNTING GP-CARRIAGE PART OF 836376, 836378 CARRIAGE ARS AN ATTACHMENT
214_MOUNTING GP-CARRIAGE PART OF 836383 CARRIAGE AR AN ATTACHMENT
215_MOUNTING GP-CARRIAGE PART OF 836380 CARRIAGE AR AN ATTACHMENT
216_MOUNTING GP-CARRIAGE PART OF 836382 CARRIAGE AR AN ATTACHMENT
217_MOUNTING GP-CARRIAGE PART OF 836385 ATTACHMENT AR AN ATTACHMENT
218_MOUNTING GP-CARRIAGE PART OF 3C8303 CARRIAGE AR AN ATTACHMENT
219_MOUNTING GP-CARRIAGE PART OF 976681, 976693, CARRIAGE ARS AN ATTACHMENT
220_MOUNTING GP-ATTACHMENT 545550-PAGE 236 PART OF 836380, 836382 CARRIAGE ARS
221_MOUNTING GP-ATTACHMENT 545550-PAGE 236 PART OF 3C8303 CARRIAGE AR AN ATTACH
222_CYLINDER GP-SIDESHIFT (CHG 00-01) 90MM (3
223_BRACKET AS-ROLLER PART OF 836380, 836382 CARRIAGE ARS AN ATTACHMENT
224_BRACKET AS-ROLLER PART OF 3C8303 CARRIAGE AR AN ATTACHMENT
225_ATTACHMENT GP-BLOCK HANDLER 836387-PAGE 240, 538410-PAGE 241 PART OF 836385
226_CARRIAGE AS-BLOCK HANDLER PART OF 836386 ATTACHMENT-BLOCK HANDLING AN ATTACHMENT
227_CYLINDER GP-CARRIAGE PART OF 836386 ATTACHMENT-BLOCK HANDLER AN ATTACHMENT
228_MOUNTING GP-FORK PART OF 836385 ATTACHMENT AR AN ATTACHMENT
229_FORK GP-HOOK TYPE-2 REQUIRED 130MM (5 IN) WIDE, 60MM (2.5 IN) THICK, 1220MM
230_FORK GP-HOOK TYPE-2 REQUIRED 150MM (6 IN) WIDE, 60MM (2.5 IN) THICK, 1220MM
231_FORK AS-SHAFT TYPE-PALLET-2 REQUIRED 130MM (5 IN) WIDE, 60MM (2.5 IN) THICK
232_FORK AS-SHAFT TYPE-PALLET-2 REQUIRED 150MM (6 IN) WIDE, 60MM (2.5 IN) THICK
233_FORK AS-SHAFT TYPE-PALLET-2 REQUIRED 150MM (5 IN) WIDE, 60MM (2.5 IN) THICK
234_FORK AS-SHAFT TYPE-LUMBER-2 REQUIRED 180MM (7 IN) WIDE, 50MM (2.0 IN) THICK
235_FORK AS-BLOCK HANDLING-SHAFT TYPE-2 REQUIRED 50MM (2 IN) WIDE, 38MM (1.5 IN
236_POSITIONER GP-FORK PART OF 3C7270, 3C7279 FORKS-HOOK TYPE AN ATTACHMENT
237_PAINT AND LUBRICANT GP AN ATTACHMENT
238_PAINT AND LUBRICANT GP-FRENCH (NAME PLATES AND FILMS) AN ATTACHMENT
