Caterpillar Forklift NTR50N2 Chassis Mast Options Internal Hosing Europe Parts Catalog DOC00039432
Brand: Caterpillar
Type of Machine: Forklift
Model: Caterpillar NTR50N2 Chassis Mast Options Internal Hosing Forklift
Region: Europe
Part Number: DOC00039432
Number of Pages: 391 Pages
001_01-01-01 ACCESSORIES
002_01-01-02 ACCESSORY RAIL IN FRONT (NO20N2X, NTR30-50N2)
003_01-01-03 ACCESSORY RACK, 1 PC, C-SIZE, RAM MOUNT (NO20N2X, NTR30-50N2)
004_01-01-04 ACCESSORY RACK, 2 PCS, C-SIZE, RAM MOUNT (NO20N2X, NTR30-50N2)
005_01-01-05 ACCESSORY RACK, 1 PC, D-SIZE, RAM MOUNT (NO20N2X, NTR30-50N2)
006_01-01-06 ACCESSORY RACK, 2 PCS, D-SIZE, RAM MOUNT (NO20N2X, NTR30-50N2)
007_01-01-07 ACCESSORY RACK, 1 PC, D-SIZE, RAM MOUNT ON TRAY (NO20N2XP)
008_01-01-08 ACCESSORY RACK, 2 PCS, D-SIZE, RAM MOUNT ON TRAY (NO20N2XP)
009_01-01-09 BARCODE SCANNER HOLDER (NO20N2X)
010_01-01-10 BARCODE SCANNER HOLDER (NO20N2XP)
011_01-01-11 BATTERY CHANGING DEVICE, 465Ah
012_01-01-12 BATTERY CHANGING DEVICE, 620Ah
013_01-01-13 BRACKET C-SERIES
014_01-01-14 BRACKET D-SERIES
015_01-01-15 BUZZER
016_01-01-16 COUPLING, MANUAL, Ø22 (NTR30-50N2) - OPTION
017_01-01-17 COUPLING, AUTOMATIC (NTR30-50N2) - OPTION
018_01-01-18 COUPLING, AUTOMATIC WITH HANDLE (NTR30-50N2) - OPTION
019_01-01-19 DRIVING SEAT (NEW)
020_01-01-20 DRIVING SEAT (OLD)
021_01-01-21 FIRE EXTINGUISHER ASSEMBLY
022_01-01-22 GAS SPRING
023_01-01-23 LI-ION BATTERY KIT (NO20N2X, NTR30-50N2 WITH BATTERY, INTEGRATED) - OPTION
024_01-01-24 LI-ION BATTERY KIT (NO20N2XP WITH BATTERY, INTEGRATED) - OPTION
025_01-01-25 MIRROR, RIGHT
026_01-01-26 MIRROR, LEFT
027_01-01-27 MIRROR (NTR30-50N2)
028_01-01-28 PAPER HOLDER (NO20N2XP) - OPTION
029_01-01-29 PICKING TRAY (NO20N2XP)
030_01-01-30 STEERING UNIT, 465Ah (NO20N2X, NTR30-50N2)
031_01-01-31 STEERING UNIT, 620Ah (NO20N2X, NTR30-50N2) - OPTION
032_01-01-32 STEERING (NO20N2XP)
033_01-01-33 STORAGE UNIT (NO20N2X, NTR30-50N2)
034_01-01-34 WORKING LIGHT, REAR (NTR30-50N2)
035_01-01-35 WRAPPING FOIL HOLDER, REAR, LOAD BACKREST (NO20N2X)
036_01-01-36 WRAPPING FOIL HOLDER, FRONT, RAIL (NO20N2X, NTR30-50N2)
037_01-01-37 WRAPPING FOIL HOLDER, FRONT, RAISING PLATFORM (NO20N2XP)
038_01-01-38 DRIVING LIGHT (LIFT PLATFORM)
039_01-01-39 DRIVING LIGHT (FIXED PLATFORM)
040_01-01-40 BLUE SPOT LIGHT (LIFT PLATFORM)
041_01-01-41 BLUE SPOT LIGHT (FIXED PLATFORM)
042_01-01-42 RED SPOT LIGHT (LIFT PLATFORM)
043_01-01-43 RED SPOT LIGHT (FIXED PLATFORM)
044_02-02-01 EL-PANEL (NO20N2X)
045_02-02-02 EL-PANEL (NO20N2X) - OLD
046_02-02-03 EL-PANEL (NO20N2XP)
047_02-02-04 EL-PANEL (NO20N2XP) - OLD
048_02-02-05 EL-PANEL (NTR30-50N2)
049_02-02-06 EL-PANEL (NTR30-50N2) - OLD
050_02-02-07 EL-PANEL, RL629754
051_02-02-08 FAN
052_02-02-09 LED BEACON 6262 W_ CONNECTORS
053_02-02-10 POWER SUPPLY, 12V
054_02-02-11 POWER SUPPLY, 24V
055_02-02-12 POWER SUPPLY, 5V USB
056_02-02-13 WARNING LIGHT, WITHOUT 2ND LEVEL GUARD RAILS
057_02-02-14 WARNING LIGHT, WITH 2ND LEVEL GUARD RAILS (NO20N2X(P))
058_03-03-01 LIFTING DEVICE (NO20N2X)
059_03-03-02 LIFTING DEVICE (NO20N2XP)
060_03-03-03 SCISSOR LIFT (NO20N2X(P))
061_04-04-01 ASSEMBLING SET
062_04-04-02 BATTERY ROLLER
063_04-04-03 BATTERY ROLLER, Ø38
064_04-04-04 CHASSIS (NTR30-50N2)
065_04-04-05 CONNECTOR, 4-PIN TRAILER SOCKET (NTR30-50N2)
066_04-04-06 CONNECTOR, 7-PIN TRAILER SOCKET (NTR30-50N2)
067_04-04-07 COUPLING, MANUAL, Ø25 (NTR30-50N2)
068_05-05-01 CYLINDER, Ø30
069_05-05-02 CYLINDER, Ø50
070_05-05-03 LIFTING CYLINDER (NO20N2X(P))
071_05-05-04 LIFT CYLINDER, 850mm
072_05-05-05 LIFT CYLINDER, 1200mm
073_05-05-06 HYDRAULIC SYSTEM, MAST LIFT WITH PRESSURE SENSOR (NO20N2X)
074_05-05-07 HYDRAULIC AGGREGATE, MINI 3G 2,2kW (NO20N2X)
075_05-05-08 HYDRAULIC SYSTEM, MAST LIFT WITH PRESSURE SENSOR (NO20N2XP)
076_05-05-09 HYDRAULIC AGGREGATE, MINI 3G 2,2kW WITH VALVE BLOCK (NO20N2XP)
077_05-05-11 HYDRAULIC AGGREGATE, MICRO POWER PACK 2G WITH 1,2kW (NTR30-50N2)
078_05-05-12 HYDRAULIC SYSTEM, LOW LIFT WITHOUT PRESSURE SENSOR
079_05-05-13 HYDRAULIC AGGREGATE, LOW LIFT WITHOUT PRESSURE SENSOR
080_05-05-14 HYDRAULIC SYSTEM, LOW LIFT WITH PRESSURE SENSOR (FIXED PLATFORM)
081_05-05-15 HYDRAULIC AGGREGATE, LOW LIFT WITH PRESSURE SENSOR (FIXED PLATFORM)
082_05-05-16 HYDRAULIC SYSTEM, LOW LIFT WITHOUT PRESSURE SENSOR (LIFT PLATFORM)
083_05-05-17 HYDRAULIC SYSTEM, LOW LIFT WITH PRESSURE SENSOR (LIFT PLATFORM)
084_05-05-18 HYDRAULIC SYSTEM, MAST LIFT WITHOUT PRESSURE SENSOR (FIXED PLATFORM)
085_05-05-19 HYDRAULIC SYSTEM, MAST LIFT WITHOUT PRESSURE SENSOR (LIFT PLATFORM)
086_05-05-20 HYDRAULIC AGGREGATE (RL638611)
087_06-06-01 MAIN ASSEMBLY (NO20N2X(P))
088_06-06-02 MAIN ASSEMBLY (NTR30-50N2)
089_06-06-03 TRACTOR UNIT (NO20N2X)
090_06-06-05 TRACTOR UNIT (NTR30-50N2)
091_06-06-06 INSTRUMENT PANEL, KEY + BATTERY DISPLAY (NO20N2X, NTR30-50N2)
092_06-06-07 INSTRUMENT PANEL, KEY + BATTERY DISPLAY (NO20N2XP)
093_06-06-08 INSTRUMENT PANEL, PIN KEY + PIN PAD + BATTERY DISPLAY (NO20N2X, NTR30-50N2)
094_06-06-09 INSTRUMENT PANEL, PIN KEY + PIN PAD + BATTERY DISPLAY (NO20N2XP)
095_06-06-10 INSTRUMENT PANEL, KEY + COLOR DISPLAY (NO20N2X, NTR30-50N2)
096_06-06-11 INSTRUMENT PANEL, KEY + COLOR DISPLAY (NO20N2XP)
097_06-06-12 INSTRUMENT PANEL, PIN KEY + COLOR DISPLAY (NO20N2X, NTR30-50N2)
098_06-06-13 INSTRUMENT PANEL, PIN KEY + COLOR DISPLAY (NO20N2XP)
099_06-06-14 INSTRUMENT PANEL, KEY+DISPLAY, LI-ION (NO20N2X, NTR30-50N2)
100_06-06-15 INSTRUMENT PANEL, KEY+DISPLAY, LI-ION (NO20N2XP)
101_06-06-16 INSTRUMENT PANEL, PIN KEY+PIN PAD+DISPLAY, LI-ION (NO20N2X, NTR30-50N2)
102_06-06-17 INSTRUMENT PANEL, PIN KEY+PIN PAD+DISPLAY, LI-ION (NO20N2XP)
103_06-06-18 INSTRUMENT PANEL, KEY+AURORA, LI-ION (NO20N2X, NTR30-50N2)
104_06-06-19 INSTRUMENT PANEL, KEY+AURORA, LI-ION (NO20N2XP)
105_06-06-20 INSTRUMENT PANEL, PIN KEY+AURORA, LI-ION (NO20N2X, NTR30-50N2)
106_06-06-21 INSTRUMENT PANEL, PIN KEY+AURORA, LI-ION (NO20N2XP)
107_06-06-22 KEYBOARD, PIN CODE UNIT
108_06-06-23 BATTERY COVER, 465Ah (NO20N2X, NTR30-50N2)
109_06-06-24 BATTERY COVER, 620Ah (NO20N2X, NTR30-50N2)
110_06-06-25 BATTERY COVER, 465Ah (NO20N2X(P))
111_06-06-26 BATTERY COVER, 620Ah (NO20N2X(P))
112_06-06-27 BATTERY LOCKING, FIXED
113_06-06-28 BATTERY LOCKING, FIXED, LI-ION - OPTION
114_06-06-29 BATTERY LOCKING, OPEN TO LEFT - OPTION
115_06-06-30 BATTERY LOCKING, OPEN TO RIGHT - OPTION
116_06-06-31 BUMPER (FRONT GUARD)
117_06-06-32 BUMPER (HEAVY BUMPER)
118_06-06-33 COVER PLATE
119_06-06-34 EMERGENCY STOP - OPTION
120_06-06-35 EMERGENCY STOP, LI-ION - OPTION
121_06-06-36 LEVER
122_06-06-37 LIMIT SWITCH
123_06-06-38 LOAD SUPPORT (NO20N2X(P))
124_06-06-39 MACHINERY SHIELD
125_06-06-40 COVER PLATE
126_06-06-41 PLATE WITH FAN
127_06-06-42 OPERATOR COMPARTMENT, WITHOUT FLOOR SWITCH (NO20N2X(P))
128_06-06-43 OPERATING COMPARTMENT, WITH FLOOR SWITCH (NO20N2X(P)) - OPTION
129_06-06-44 PEDAL, FLOOR SWITCH ASSEMBLY
130_06-06-45 SWITCH
131_06-06-46 DECAL
132_07-07-01 LIFT CHAIN, 850mm
133_07-07-02 LIFT CHAIN, 1200mm - OPTION
134_08-08-01 FORK CROSSWIDE HANDLING
135_09-09-01 DRIVE UNIT
136_09-09-02 GEAR
137_09-09-03 STEERING MOTOR
138_10-10-01 CASTER WHEEL
139_10-10-02 LOAD WHEEL, SINGLE
140_10-10-03 LOAD WHEEL, TANDEM
